uus teema   vasta Tarkvara »  Linux & UNIX »  ID Kaardi käima saamine Linux MX märgi kõik teemad loetuks
tiitm
Uus kasutaja
sõnum 07.08.2026 14:00:08 ID Kaardi käima saamine Linux MX vasta tsitaadiga
Tervist!
Otsustasin oma Dell 630 peale panna Linux MX xfce. MX hakkas meeldima. Seni olen 10 aastat Minte pidanud. Nüüd pusin Eesti ID kaardi teemaga. Ei tea, kas nii pidi või tohtis, aga vana panga kaarti sain nii lugema: https://mxlinux.org/wiki/networking/dod-common-access-card-cac-reader/ Midagi loeb: z@mx:~
$ pcsc_scan
PC/SC device scanner
V 1.7.3 (c) 2001-2024, Ludovic Rousseau <ludovic.rousseau@disney.com>
Using reader plug'n play mechanism
Scanning present readers...
0: OMNIKEY CardMan 1021 00 00
Fri Aug 7 13:21:53 2026
Reader 0: OMNIKEY CardMan 1021 00 00
Event number: 0
Card state: Card inserted,
ATR: 3B 6A 00 00 80 66 A1 09 02 01 63 0E 90 00
+ TS = 3B --> Direct Convention
+ T0 = 6A, Y(1): 0110, K: 10 (historical bytes)
TB(1) = 00 --> VPP is not electrically connected
TC(1) = 00 --> Extra guard time: 0
+ Historical bytes: 80 66 A1 09 02 01 63 0E 90 00
Category indicator byte: 80 (compact TLV data object)
Tag: 6, len: 6 (pre-issuing data)
Data: A1 09 02 01 63 0E
Tag: 9, len: 0 (unknown)
Tag: 0, len: 0 (unknown)
Possibly identified card (using /usr/share/pcsc/smartcard_list.txt):
ID kaardi install
z@mx:~
$ cd ~/Allalaadimised
z@mx:~/Allalaadimised
$ sh install-open-eid.sh
### Debian is not officially supported
Press ENTER to continue, CTRL-C to cancel
### Installing possibly missing https support for APT (apt install apt-transport-https)
apt-transport-https is already the newest version (3.0.3).
Summary:
Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 217
### Debian trixie is not officially supported
### Trying to install packages from Ubuntu noble repository
Adding RIA repository to APT sources list (/etc/apt/sources.list.d/ria-repository.list)
deb [signed-by=/usr/share/keyrings/ria-repository.gpg] https://installer.id.ee/media/ubuntu/ noble main
Adding key to trusted key set
0xC6C83D68 'RIA Software Signing Key <signing@ria.ee>'
Installing software (apt update && apt install open-eid)
Hit:1 http://deb.debian.org/debian trixie InRelease
Get:2 http://security.debian.org/debian-security trixie-security InRelease [43,4 kB]
Get:3 https://dl.google.com/linux/chrome-stable/deb stable InRelease [2 548 B]
Get:4 http://deb.debian.org/debian trixie-updates InRelease [47,3 kB]
Get:5 https://dl.google.com/linux/chrome-stable/deb stable/main amd64 Packages [1 411 B]
Hit:6 https://installer.id.ee/media/ubuntu noble InRelease
Get:7 http://security.debian.org/debian-security trixie-security/main amd64 Packages [234 kB]
Get:9 http://security.debian.org/debian-security trixie-security/main i386 Packages [210 kB]
Get:10 http://security.debian.org/debian-security trixie-security/main Translation-en [142 kB]
Get:8 https://mxrepo.com/mx/repo trixie InRelease [25,6 kB]
Get:11 https://mxrepo.com/mx/repo trixie/main i386 Packages [242 kB]
Get:12 https://mxrepo.com/mx/repo trixie/main amd64 Packages [252 kB]
Get:13 https://mxrepo.com/mx/repo trixie/main i386 Contents (deb) [1 071 kB]
Get:14 https://mxrepo.com/mx/repo trixie/main amd64 Contents (deb) [1 435 kB]
Get:15 https://mxrepo.com/mx/repo trixie/ahs amd64 Packages [97,0 kB]
Get:16 https://mxrepo.com/mx/repo trixie/ahs amd64 Contents (deb) [4 218 kB]
Fetched 8 021 kB in 14s (572 kB/s)
225 packages can be upgraded. Run 'apt list --upgradable' to see them.
Solving dependencies... Error!
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
Unsatisfied dependencies:
qdigidoc4 : Depends: libqt6gui6t64 (>= 6.4.0) but it is not installable
Depends: libqt6network6t64 (>= 6.4.0) but it is not installable
Depends: libqt6printsupport6t64 (>= 6.1.2) but it is not installable
Depends: libqt6widgets6t64 (>= 6.2.0) but it is not installable
web-eid-native : Depends: libqt6gui6t64 (>= 6.1.2) but it is not installable
Depends: libqt6network6t64 (>= 6.1.2) but it is not installable
Depends: libqt6widgets6t64 (>= 6.1.2) but it is not installable
Error: Unable to correct problems, you have held broken packages.
Error: The following information from --solver 3.0 may provide additional context:
Unable to satisfy dependencies. Reached two conflicting decisions:
1. qdigidoc4:amd64 is selected for install because:
1. open-eid:amd64=26.4.27.8413-2404 is selected for install
2. open-eid:amd64 Depends qdigidoc4
2. qdigidoc4:amd64 Depends libqt6gui6t64 (>= 6.4.0)
but none of the choices are installable:
[no choices]
Selline õnnetu tulemus, kui lasin EID Linuxile installi käima. Kuidas saan ID kaardi käima Linux MX-is?
