praegune kellaaeg 10.08.2026 15:29:42
tiitm
Uus kasutaja
07.08.2026 14:00:08
ID Kaardi käima saamine Linux MX |
Tervist!
Otsustasin oma Dell 630 peale panna Linux MX xfce. MX hakkas meeldima. Seni olen 10 aastat Minte pidanud. Nüüd pusin Eesti ID kaardi teemaga. Ei tea, kas nii pidi või tohtis, aga vana panga kaarti sain nii lugema: https://mxlinux.org/wiki/networking/dod-common-access-card-cac-reader/ Midagi loeb: z@mx:~
$ pcsc_scan
PC/SC device scanner
V 1.7.3 (c) 2001-2024, Ludovic Rousseau <ludovic.rousseau@disney.com>
Using reader plug'n play mechanism
Scanning present readers...
0: OMNIKEY CardMan 1021 00 00
Fri Aug 7 13:21:53 2026
Reader 0: OMNIKEY CardMan 1021 00 00
Event number: 0
Card state: Card inserted,
ATR: 3B 6A 00 00 80 66 A1 09 02 01 63 0E 90 00
+ TS = 3B --> Direct Convention
+ T0 = 6A, Y(1): 0110, K: 10 (historical bytes)
TB(1) = 00 --> VPP is not electrically connected
TC(1) = 00 --> Extra guard time: 0
+ Historical bytes: 80 66 A1 09 02 01 63 0E 90 00
Category indicator byte: 80 (compact TLV data object)
Tag: 6, len: 6 (pre-issuing data)
Data: A1 09 02 01 63 0E
Tag: 9, len: 0 (unknown)
Tag: 0, len: 0 (unknown)
Possibly identified card (using /usr/share/pcsc/smartcard_list.txt):
ID kaardi install
z@mx:~
$ cd ~/Allalaadimised
z@mx:~/Allalaadimised
$ sh install-open-eid.sh
### Debian is not officially supported
Press ENTER to continue, CTRL-C to cancel
### Installing possibly missing https support for APT (apt install apt-transport-https)
apt-transport-https is already the newest version (3.0.3).
Summary:
Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 217
### Debian trixie is not officially supported
### Trying to install packages from Ubuntu noble repository
Adding RIA repository to APT sources list (/etc/apt/sources.list.d/ria-repository.list)
deb [signed-by=/usr/share/keyrings/ria-repository.gpg] https://installer.id.ee/media/ubuntu/ noble main
Adding key to trusted key set
0xC6C83D68 'RIA Software Signing Key <signing@ria.ee>'
Installing software (apt update && apt install open-eid)
Hit:1 http://deb.debian.org/debian trixie InRelease
Get:2 http://security.debian.org/debian-security trixie-security InRelease [43,4 kB]
Get:3 https://dl.google.com/linux/chrome-stable/deb stable InRelease [2 548 B]
Get:4 http://deb.debian.org/debian trixie-updates InRelease [47,3 kB]
Get:5 https://dl.google.com/linux/chrome-stable/deb stable/main amd64 Packages [1 411 B]
Hit:6 https://installer.id.ee/media/ubuntu noble InRelease
Get:7 http://security.debian.org/debian-security trixie-security/main amd64 Packages [234 kB]
Get:9 http://security.debian.org/debian-security trixie-security/main i386 Packages [210 kB]
Get:10 http://security.debian.org/debian-security trixie-security/main Translation-en [142 kB]
Get:8 https://mxrepo.com/mx/repo trixie InRelease [25,6 kB]
Get:11 https://mxrepo.com/mx/repo trixie/main i386 Packages [242 kB]
Get:12 https://mxrepo.com/mx/repo trixie/main amd64 Packages [252 kB]
Get:13 https://mxrepo.com/mx/repo trixie/main i386 Contents (deb) [1 071 kB]
Get:14 https://mxrepo.com/mx/repo trixie/main amd64 Contents (deb) [1 435 kB]
Get:15 https://mxrepo.com/mx/repo trixie/ahs amd64 Packages [97,0 kB]
Get:16 https://mxrepo.com/mx/repo trixie/ahs amd64 Contents (deb) [4 218 kB]
Fetched 8 021 kB in 14s (572 kB/s)
225 packages can be upgraded. Run 'apt list --upgradable' to see them.
Solving dependencies... Error!
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
Unsatisfied dependencies:
qdigidoc4 : Depends: libqt6gui6t64 (>= 6.4.0) but it is not installable
Depends: libqt6network6t64 (>= 6.4.0) but it is not installable
Depends: libqt6printsupport6t64 (>= 6.1.2) but it is not installable
Depends: libqt6widgets6t64 (>= 6.2.0) but it is not installable
web-eid-native : Depends: libqt6gui6t64 (>= 6.1.2) but it is not installable
Depends: libqt6network6t64 (>= 6.1.2) but it is not installable
Depends: libqt6widgets6t64 (>= 6.1.2) but it is not installable
Error: Unable to correct problems, you have held broken packages.
Error: The following information from --solver 3.0 may provide additional context:
Unable to satisfy dependencies. Reached two conflicting decisions:
1. qdigidoc4:amd64 is selected for install because:
1. open-eid:amd64=26.4.27.8413-2404 is selected for install
2. open-eid:amd64 Depends qdigidoc4
2. qdigidoc4:amd64 Depends libqt6gui6t64 (>= 6.4.0)
but none of the choices are installable:
[no choices]
Selline õnnetu tulemus, kui lasin EID Linuxile installi käima. Kuidas saan ID kaardi käima Linux MX-is?
07.08.2026 19:30:16
Pane see mure oma lemmik LLMi, saad häid ideid mida proovida.
Mis jäi silma - see distro on Debian, RIA skriptid on Ubuntu jaoks. Pole ju teineteisest väga kaugel, aga libqt6gui6t64 asemel on Debianis libqt6gui6. Ja eks sellistes detailides saatan ongi.
EDIT: parandatud.
viimati muutis Dirty Harry 07.08.2026 22:20:02, muudetud 1 kord |
147 |
Supiplex
07.08.2026 22:17:30
| RIA skriptid on Debiani jaoks |
St. RIA pakendab oma tarkvara Ubuntu, mitte Debiani jaoks.
Tüütu jah. Ma ka Debiani kasutaja, mõni aasta lähevad RIA pakid peale, mõni aasta ei lähe. Siis ootan järgmist aastat, kui Ubuntu/Debian QT pakkide hooldajad jälle mõistusele tulevad. Ega RIA ka ei kiirusta, 26.04 on juba 4 kuud väljas, neil pakke ikka pole.
Senikaua kasutan https://www.dokobit.com - hädapärased asjad saab korda aetud.
_________________ The young lady had an unusual list,
Linked in part to a structural weakness.
She set no preconditions.
viimati muutis Supiplex 07.08.2026 22:21:19, muudetud 1 kord |
| Kommentaarid: 38 loe/lisa |
34 |
07.08.2026 22:19:40
| Supiplex kirjutas: |
St. RIA pakendab oma tarkvara Ubuntu, mitte Debiani jaoks. |
Ikka niipidi jah, mul läks vähe valesti. Tänud parandamast.
147 |
kunn888
Uus kasutaja
08.08.2026 17:22:34
Proovi asendada RIA skriptis Trixie repo noble jammyga
Trixie)
make_warn "Debian $codename is not officially supported"
make_warn "Trying to install packages from Ubuntu jammy repository"
add_repository jammy
masmre
| Kommentaarid: 82 loe/lisa |
76 |
tiitm
Uus kasutaja
10.08.2026 14:10:33
Flatpak ongi plaanis. Tegelikult Gemini juba nädalavahetusel eksitas mind pikalt ja Digidoc 4 sai tööle. Aga Chrome ei tahtnud sugugi sellega rääkima asuda. Nüüd
peas oleks asi nii et tuleb teha format c ja vähemalt eraldi Chrome (terminalist käivitusega) töötaks RIA Flatpakis. Ise ma pole mingi Linuxi tark. Milline AI võiks mind paremini aidata kuiGemini?
10.08.2026 14:46:35
tiitm, ooda. Sul on nüüd mitu asja siin koos.
1. Kui Digidoc 4 juba käima said siis on hea. Saad edasi tegeleda brauseriga liidestamisega.
2. Format C - see osa on segane. Ega Sa nüüd ei hakka ju uuesti nullist konfima?
3. Iga AI on natuke erinev. Tasuta asjade puhul peaks Microsofti Copilot ( https://copilot.microsoft.com/ ) olema selles mõttes hea, et on võimalik ka "think deeper" võtta ja limiidid on kaugemalt kui tasuta ChatGPT'l (ning taustal on samad OpenAI mudelid). Aga üldiselt on tasuta asjad ikka piiratud võimekusega, tasuliste puhul hakkab juba rohkem läbimõeldud vastuseid saama. Mina ei riski küll ühtegi teisele eelistada, kasutan Copilotit, Claudet, ChatGPT'd läbisegi, olenevalt olukorrast ja juhtumist.
Pigem mulle tundub, et oleks hea Sul endal aru saada, milles kühvel oli ja mida on vaja teha. Iga mainitud AI sobib.
147 |
