07.08.2026 13:00:08
ID Kaardi käima saamine Linux MX
Tervist!
Otsustasin oma Dell 630 peale panna Linux MX xfce. MX hakkas meeldima. Seni olen 10 aastat Minte pidanud. Nüüd pusin Eesti ID kaardi teemaga. Ei tea, kas nii pidi või tohtis, aga vana panga kaarti sain nii lugema: https://mxlinux.org/wiki/networking/dod-common-access-card-cac-reader/ Midagi loeb: z@mx:~
$ pcsc_scan
PC/SC device scanner
V 1.7.3 (c) 2001-2024, Ludovic Rousseau <ludovic.rousseau@disney.com>
Using reader plug'n play mechanism
Scanning present readers...
0: OMNIKEY CardMan 1021 00 00
ID kaardi install
z@mx:~
$ cd ~/Allalaadimised
z@mx:~/Allalaadimised
$ sh install-open-eid.sh
### Debian is not officially supported
Press ENTER to continue, CTRL-C to cancel
### Installing possibly missing https support for APT (apt install apt-transport-https)
apt-transport-https is already the newest version (3.0.3).
Summary:
Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 217
### Debian trixie is not officially supported
### Trying to install packages from Ubuntu noble repository
Unsatisfied dependencies:
qdigidoc4 : Depends: libqt6gui6t64 (>= 6.4.0) but it is not installable
Depends: libqt6network6t64 (>= 6.4.0) but it is not installable
Depends: libqt6printsupport6t64 (>= 6.1.2) but it is not installable
Depends: libqt6widgets6t64 (>= 6.2.0) but it is not installable
web-eid-native : Depends: libqt6gui6t64 (>= 6.1.2) but it is not installable
Depends: libqt6network6t64 (>= 6.1.2) but it is not installable
Depends: libqt6widgets6t64 (>= 6.1.2) but it is not installable
Error: Unable to correct problems, you have held broken packages.
Error: The following information from --solver 3.0 may provide additional context:
Unable to satisfy dependencies. Reached two conflicting decisions:
1. qdigidoc4:amd64 is selected for install because:
1. open-eid:amd64=26.4.27.8413-2404 is selected for install
2. open-eid:amd64 Depends qdigidoc4
2. qdigidoc4:amd64 Depends libqt6gui6t64 (>= 6.4.0)
but none of the choices are installable:
[no choices]
Selline õnnetu tulemus, kui lasin EID Linuxile installi käima. Kuidas saan ID kaardi käima Linux MX-is?
Pane see mure oma lemmik LLMi, saad häid ideid mida proovida.
Mis jäi silma - see distro on Debian, RIA skriptid on Ubuntu jaoks. Pole ju teineteisest väga kaugel, aga libqt6gui6t64 asemel on Debianis libqt6gui6. Ja eks sellistes detailides saatan ongi.
EDIT: parandatud.
viimati muutis Dirty Harry 07.08.2026 21:20:02, muudetud 1 kord
St. RIA pakendab oma tarkvara Ubuntu, mitte Debiani jaoks.
Tüütu jah. Ma ka Debiani kasutaja, mõni aasta lähevad RIA pakid peale, mõni aasta ei lähe. Siis ootan järgmist aastat, kui Ubuntu/Debian QT pakkide hooldajad jälle mõistusele tulevad. Ega RIA ka ei kiirusta, 26.04 on juba 4 kuud väljas, neil pakke ikka pole.
Senikaua kasutan https://www.dokobit.com - hädapärased asjad saab korda aetud. _________________ The young lady had an unusual list,
Linked in part to a structural weakness.
She set no preconditions.
viimati muutis Supiplex 07.08.2026 21:21:19, muudetud 1 kord
Trixie)
make_warn "Debian $codename is not officially supported"
make_warn "Trying to install packages from Ubuntu jammy repository"
add_repository jammy
Flatpak ongi plaanis. Tegelikult Gemini juba nädalavahetusel eksitas mind pikalt ja Digidoc 4 sai tööle. Aga Chrome ei tahtnud sugugi sellega rääkima asuda. Nüüd
peas oleks asi nii et tuleb teha format c ja vähemalt eraldi Chrome (terminalist käivitusega) töötaks RIA Flatpakis. Ise ma pole mingi Linuxi tark. Milline AI võiks mind paremini aidata kuiGemini?
1. Kui Digidoc 4 juba käima said siis on hea. Saad edasi tegeleda brauseriga liidestamisega.
2. Format C - see osa on segane. Ega Sa nüüd ei hakka ju uuesti nullist konfima?
3. Iga AI on natuke erinev. Tasuta asjade puhul peaks Microsofti Copilot ( https://copilot.microsoft.com/ ) olema selles mõttes hea, et on võimalik ka "think deeper" võtta ja limiidid on kaugemalt kui tasuta ChatGPT'l (ning taustal on samad OpenAI mudelid). Aga üldiselt on tasuta asjad ikka piiratud võimekusega, tasuliste puhul hakkab juba rohkem läbimõeldud vastuseid saama. Mina ei riski küll ühtegi teisele eelistada, kasutan Copilotit, Claudet, ChatGPT'd läbisegi, olenevalt olukorrast ja juhtumist.
Pigem mulle tundub, et oleks hea Sul endal aru saada, milles kühvel oli ja mida on vaja teha. Iga mainitud AI sobib.
0-st peale jah see Gemini hakkas ju qt6 taolisi renamema Debiani jaoks ja mida iganes veel kannapöördeid ta seal tegi. Seal nüüd segapuder. Hiljem tekkis Flatpaki mõte. Kuna Chromega sidet ei saanud, tekkis uus mõte toppida väike chrome RIA flatpakis käima. Vast saab nii. Olles Linuxi võhik, käis töö nii et gemini andis käsu, lasin kohe terminalis käima copysin käskluse ja tulemuse geminile tagasi ja tal olid kohe uued käigud valmis. Vahel avastas, et midagi läks valesti ja vaja tagasi võtta. Kas nii saan käima kõik?
Kui ise teemat ei tunne ja pimesi käske käima lasta, siis on tulemus etteaimamatu ja ennustamatu.
Kas sul chrome brauseris web eid extension on lubatud? Flatpaki installiga peab selle, kui ma 6igesti m2letan ise panema. Otsi lihtsalt web eid extension chrome laienduste hulgast ja installi see.
Id kaardi lehel k6ik kirjas: https://www.id.ee/artikkel/paigalda-id-tarkvara/
See teema on ju Dell D630 ja Linux MX eesti ID kaart. On rohkem hobiprojekt ja EI või JA küsimus. Nüüd paistab töö juures aega olevat ja proovin oma Asuse I3 peal võimelda põhiliselt Chat GPT abiga. Alustan jälle uuest MX Xfce-st
