uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  nVidia Blackwell (GB202/GB203/GB205/GB206/GB207) märgi kõik teemad loetuks
mine lehele 1, 2, 3 ... 37, 38, 39  järgmine
Zonerman
Zonerman
sõnum 20.03.2024 14:12:27 nVidia Blackwell (GB202/GB203/GB205/GB206/GB207) vasta tsitaadiga
Tegin teema, kus saab arutada ja jagada infot ühes kohas, kui lekib juurde. Iga kuu tuleb rohkem ja rohkem infot.
Hetke teada oleva info põhjal arvatavad spekid Blackwell osas on ajas muutuv kuniks täpsemat infot lekib.
31.05.24 kõlakate põhjal hetkel.
Vana info:
Nvidia’s upcoming GB202 GPU could feature a multi-chip package with 192 SMs and a 512-bit memory bus. (Eeldatav TDP on 500w)
It's also rumored to feature a 512-bit memory bus that is 33% wider than the one on Nvidia’s RTX 4090, the memory bandwidth will feature a 77% boost compared to the 4090, and 28Gbps GDDR7 memory modules which would be 33% faster than the 21Gbps memory modules in the RTX 4090.
GB202 will use the same process node as GB100. TSMC 4N(vidia) is based on TSMC 5, not 4nm.
16-pin 12VHPWR connector could be a standard for the 5090 and other 5000-series cards, meaning even third-party board partners would need to use the it.
People is confused about Nvidia Blackwell top die gaming GPU memory bus and VRAM capacity. I can't say too much right now but gen-to-gen performance uplift is the biggest ever. Don't forget that Blackwell was designed to compete with a monster 3nm MCM RDN4
All signs seem to point to late 2024 or early 2025 at the absolute earliest.
https://www.techradar.com/computing/gpu/nvidia-rtx-5090-gpu-rumors-possible-specs-and-everything-we-know
Lisaks tuleb arvestada, et Nvidia võib planeerida Blackwelliga konkureerida oletatavasti ka rDNA5'ga kui AMD plaan high-end rDNA4 ei too ning alles rDNA5'ga kuid varem.
Malemäng laias laastus, et ette arvata konkurendi plaane.
Sõim ja räuskamine läheb SIIA
viimati muutis Zonerman 31.05.2024 13:54:32, muudetud 3 korda
kaspar737
sõnum 20.03.2024 14:19:09 vasta tsitaadiga
Huvitav saab näha olema, kui palju 5090 voolu võtab, kui node ikka 4nm peal põhinev.
Killhoven
OC`er
Killhoven
sõnum 20.03.2024 17:23:53 vasta tsitaadiga
Esimesed kõlakad on juba tõepoolet liikvel. Kõige huvitavam neist ehk see, et järjest rohkem "allikaid" räägivad 5090 võiks tulla selle aasta lõpus juba, võiks kasutada DDR7 ja konfiguratsiooni järgi "vaid" 24GB VRAM, kõva edasiminek RT osas, hind rohkem kui 4090 MRSP. Elame näeme.
Kommentaarid: 410 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 352
heretic666
heretic666
sõnum 20.03.2024 17:38:02 vasta tsitaadiga
Raske uskuda et juba see aasta reliis, konkurenti ei ole.
Dolph
sõnum 20.03.2024 21:03:58 Re: nVidia Blackwell (GB202/GB203/GB205/GB206/GB207) vasta tsitaadiga
Zonerman kirjutas:
At least, there is a 30% increase in density
Lovelace oli TSMC 4N. Kui Blackwell on ka TSMC 4N, siis ei ole ju "30% increase in density"
Kommentaarid: 16 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 14
Kristoferr
Kristoferr
sõnum 20.03.2024 21:24:18 vasta tsitaadiga
Tundub, et korralik monster tuleb sellest 5090'st.
Liitu Z.ai coding plaaniga ja saa 10% soodust!
Liitu Wise'ga!
Kommentaarid: 268 loe/lisa Kasutajad arvavad:  :: 4 :: 0 :: 219
Zonerman
Zonerman
sõnum 21.03.2024 01:18:55 Re: nVidia Blackwell (GB202/GB203/GB205/GB206/GB207) vasta tsitaadiga
Dolph kirjutas:
Zonerman kirjutas:
Seda pole kuskil kinnitatud veel, mis protsessi Blackwell kasutab. TSMC 4N or P on vaid oletus. Ka ei ole teada kiibi suurust. Eemaldasin selle info.
Kristoferr kirjutas:
Jah ja kallis ka. Kui lekke andmed hakkavad settima rohkem, siis tuleb päris kallis kaart.
ahvilõust
ahvilõust
sõnum 21.03.2024 10:20:54 vasta tsitaadiga
5090-ga ei hakka vaid kabla sulama vaid ka mobo?
Kiirem RT renderduses on küll hää. Aga kes see reaalselt RTd mängudes käima paneb? Ma etem panen korralikku fps-i ja reso peale.
Aga jah nVittia peaks enne kuumuse ja voolu õgimise vähendama. 1000W kast mitte iialgi! thumbs_down.gif
Gdesainer
Zonerman
Zonerman
sõnum 21.03.2024 15:26:45 vasta tsitaadiga
Üsna hea kokkuvõte.
Link
One
sõnum 22.03.2024 17:46:14 vasta tsitaadiga
ahvilõust kirjutas:
Toiteplokk sulab ka koos kaablitega ära.
Zonerman
Zonerman
sõnum 24.03.2024 13:32:08 vasta tsitaadiga
Viimased kõlakad Blackwell launch pigem selle aasta teises pooles. https://wccftech.com/nvidia-limit-supply-geforce-rtx-40-ada-gpus-make-room-rtx-50-blackwell-gaming-lineup/
Optimist
Optimist
sõnum 28.03.2024 16:13:33 vasta tsitaadiga
Killhoven kirjutas:
...Kõige huvitavam neist ehk see, et järjest rohkem "allikaid" räägivad 5090 võiks tulla selle aasta lõpus juba, võiks kasutada DDR7 ja konfiguratsiooni järgi "vaid" 24GB VRAM, kõva edasiminek RT osas, hind rohkem kui 4090 MRSP. Elame näeme.
512-bitise mäluga on kas 16 või 32Gb VRAM, 24GB tähendaks 384-bitist mälu ribalaiust. Samas kui AMDilt konkurentsi ei tule, siis võimalik, et see 512-bitine pole äkki enam prioriteet.
Kommentaarid: 10 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 8
KrikU
sõnum 31.03.2024 22:29:22 vasta tsitaadiga
512-bit mälu konfiguratsioon on senini üsna eksootiline nähtus, aga igatahes midagu mis võiks olla teemaks.
Nvidia GPU puhul on see olnud kasutuses üsna ammu ainult ühe generatsiooni GPU peal - GTX 280 ja 285 aastast 2009
AMD on kasutanud seda lahendust pisut enam, ning esimesena üldse 2900 PRO/XT kaartidel nii 2007 paiku ning Radeon 290/290/295X2 390/390X 2015 aastatel ja lisaks oli erilahendus Fury HBM mäludega kus oli üldse 4096 bit variant.
Zonerman
Zonerman
sõnum 01.04.2024 11:52:42 vasta tsitaadiga
Mina isiklikult olen siiski skeptiline, et gaming GPU tuleb 512bit. Kui 512 tõele vastab, siis vb 5090Ti ehk aga sellise configa kaart oleks väga väga kallis. See võiks tulla millalgi hiljem, kui rDNA5 ilmub. Nvidia sisuliselt konkureerib endaga halo kaartide segmendis.
Optimist
Optimist
sõnum 01.04.2024 15:17:02 vasta tsitaadiga
Zonerman kirjutas:
Mina isiklikult olen siiski skeptiline, et gaming GPU tuleb 512bit. Kui 512 tõele vastab, siis vb 5090Ti ehk aga sellise configa kaart oleks väga väga kallis...
Chipletitega on seda way lihtsam kokku lappida, kui monoliitset. nVidia ja kallid kaardid on ju sünonüüm praegu icon_biggrin.gif
sõnum 08.04.2024 01:37:27 vasta tsitaadiga
- londiste
One
sõnum 06.05.2024 18:28:51 vasta tsitaadiga
https://www.techpowerup.com/322139/nvidia-to-only-launch-the-flagship-geforce-rtx-5090-in-2024-rest-of-the-series-in-2025
Tea mis hinnaga tuleb kui tuleb, pakuks, et eu-s 2.5k+ reaalseks hinnaks. MRSP võib muidugi lambi panna, et paremaid ülevaateid saada..
Zonerman
Zonerman
sõnum 06.05.2024 18:43:56 vasta tsitaadiga
Esimene kuu aega mina pakuks Eestis, kui need siia jõuavad ligi 3k eur. Püsiv hind tõenäoliselt sinna jah 2.5k kanti.
sukelduja
sukelduja
sõnum 07.05.2024 15:19:20 vasta tsitaadiga
Winterwind kirjutas:
Teised pakuvad jälle, et 5080 tuleb enne.
https://videocardz.com/newz/nvidia-geforce-rtx-5080-reportedly-launches-before-rtx-5090
Kui TDP veel suuremaks läheb kui praegustel kaartidel, siis tuleb juba eraldi tuba jahutama hakata. Vähemalt suvel.
Scart
Scart
sõnum 07.05.2024 15:24:57 vasta tsitaadiga
sukelduja kirjutas:
1dumbpcuser
sõnum 07.05.2024 15:34:12 vasta tsitaadiga
M: MSI B660M MORTAR
O: AM5 ITX emaplaat
sukelduja
sukelduja
sõnum 07.05.2024 15:41:51 vasta tsitaadiga
Scart kirjutas:
sukelduja kirjutas:
4090 on 450w
Scart
Scart
sõnum 07.05.2024 15:43:54 vasta tsitaadiga
sukelduja kirjutas:
Scart kirjutas:
sukelduja kirjutas:
4090 on 450w
4090 ei kasuta mängides mitte kunagi 450w ja piirdub tavaolukorras ~250-300w vahemikus pendeldamisega. Vähemkoormavate mängude puhul, näiteks EVE Online, tiksub üldse 120-140w kandis.
Zonerman
Zonerman
sõnum 07.05.2024 17:25:56 vasta tsitaadiga
Teeme nii, et jätame 4090 teise teema jaoks ja ei hakka siin diskuteerima.
ot:
defaultis võtab 4090 AIB mängudes keskmiselt 350-370w vahele techpowerup erinevate kaartide review andmed. Igasugu kätsisi modimised on fine tuning ja seda saab teha pea iga kaardiga ning tootjast sõltumata
486
sõnum 07.05.2024 17:28:05 vasta tsitaadiga
Scart kirjutas:
sukelduja kirjutas:
Scart kirjutas:
sukelduja kirjutas:
4090 on 450w
Ja muidugi inimesed ostavad selliseid kaarte, et eve online mängida. Kaart peaks oma max j6udlusega jahe olema mitte kaableid sulatama. Ainuke viis kuidas neid depiilsusi kasutada on k6ik mängud 60fps piirata. Isegi doomi mängides lähevad need 4080d kuumaks.
zero
Scart
Scart
sõnum 07.05.2024 18:06:56 vasta tsitaadiga
486 kirjutas:
4080 ja 4090 ongi jahedad. Ühed kõige jahemad kaardid, mis GPU'de ajastul üldse tehtud, sest jahutus ehitati peale 600w jaoks, aga kaardid ise on up to 450w, ja sealt omakorda läheb veel 150 tavaolukorras maha. EVE'i mängides ei lähe kosmoses olles isegi ventilaatorid tööle, kaart ise samal ajal tõmbab 120w.
486
sõnum 08.05.2024 09:15:47 vasta tsitaadiga
Scart kirjutas:
486 kirjutas:
kopp.gif Scart = Sein!
zero
Scart
Scart
sõnum 08.05.2024 10:44:25 vasta tsitaadiga
486 kirjutas:
Scart kirjutas:
486 kirjutas:
Endast räägid või? Sa pole siia teema kahele lehele tootnud midagi muud peale risu. Rääkimata sellest, et "sellise kaardi ostjad ei mängi EVE'". Eks ma lähen lasen oma 2008 jaanuaris loodud konto maha siis ära, ei tohi mängida ju enam thumbs_up.gif
Renq
Renq
sõnum 10.05.2024 18:40:17 vasta tsitaadiga
https://wccftech.com/nvidia-geforce-rtx-5090-rtx-5080-unveil-same-time-availability-few-weeks-apart/
kraaks
sõnum 22.05.2024 02:22:30 vasta tsitaadiga
Kui praegu on 3090, siis vast tasub oodata 5090.
lillekasvatus.ee
Kommentaarid: 4 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 2
Kristoferr
Kristoferr
sõnum 23.05.2024 08:17:20 vasta tsitaadiga
kraaks, oleneb, kas võtaksid lihtsalt moe pärast selle lipulaeva või reaalselt tunned, et kõik alla 5090 jääks nõrgaks icon_biggrin.gif .
Liitu Wise'ga!
1dumbpcuser
sõnum 23.05.2024 09:40:59 vasta tsitaadiga
Kui juba oodata, siis ikka 5090Ti või misiganes see täis kiviga kaart oleks icon_lol.gif
M: MSI B660M MORTAR
O: AM5 ITX emaplaat
Zonerman
Zonerman
sõnum 23.05.2024 11:43:03 vasta tsitaadiga
Ma arvasin, et ta trollib. 3090 on suht sarnase perfiga kui 4070Ti ilma uute lisavidinateta. Jooksutab MW3 4K ultra sätetel juba sinna 80-100fps kanti ilma RT. Kui sellest on vähe, siis jah peaks juba 6090 ikka ära ootama doh.gif
Tõsiselt rääkides, siis kui raha on osta mida iganes, kui tõesti on vaja kõige paremat mis raha eest saab. Seal ei loe enam millal osta. 4090 kärab ka veel mitu aastat.
1dumbpcuser
sõnum 23.05.2024 12:24:35 vasta tsitaadiga
Zonerman kirjutas:
M: MSI B660M MORTAR
O: AM5 ITX emaplaat
486
sõnum 23.05.2024 12:55:16 vasta tsitaadiga
1dumbpcuser kirjutas:
Zonerman kirjutas:
Ära muretse küll skart varsti sisse tormab ja trollima hakkab et 4090 k6ige jahedam ja k6ige efektiivsem jne blära!
zero
busta
busta
sõnum 23.05.2024 13:45:51 vasta tsitaadiga
Zonerman kirjutas:
mw3 3090, tõsi, kõik tilulilu on just kinni keeratud. Hindan selget pilti ja head latentsust ja ega mälu kiirus on am4 peal silmaga nähtav-tuntav, millest enam alla ei taha tulla. Statsid paranevad jõudsalt, kuigi mul on nendest suva. Ehk uiisutab selle kooslusega veel mõnda aega. Ei viitsi neid arvuteid koguaeg ehitada.
Edit: Minu seades on palju jahedam 40-50C. Lisaks on Nvidia control panelist enamus kinni keeratud tglt, aa jne.
viimati muutis busta 27.05.2024 14:59:25, muudetud 1 kord
heretic666
heretic666
sõnum 23.05.2024 15:40:41 vasta tsitaadiga
486 kirjutas:
Zonerman kirjutas:
Pigem kindel grupp HV kasutajaid kel mingi automated script et kui 4090 kusagil foorumis mainitakse siis ruttavad tuleohtlikkuse tõttu sõnu peale lugema nagu üks õige eeskujulik kodanik peab.
Zonerman
Zonerman
sõnum 23.05.2024 16:59:03 vasta tsitaadiga
busta kirjutas:
Zonerman kirjutas:
Ei peagi ehitama ju aga osadele on see lihtsalt nagu õhu hingamine, et peab uuendama. Ega seda ei saa ka ette heita vb meeldibki ehitada. Mina olen keskmiselt uuendanud kogu kasti koos kastiga iga 4-6a tagant ja mitte varem. Eraldi siis proset kuniks emaplaat toetab.
heretic666,
Eks nalja peab ka olema veidi mõistuse piires. Eile sattusin üht uut videot nägema, kus mingi hiina service tüüp taastas 4090 jällegi. Nagu ikka jootis toite otsa maha pcb'lt ja pani uue asemele ning sealt ümber ka mingid asjad oli veidi viga saanud. Kuna keelt ei mõistnud ja tõlget polnud, siis eeldasin, et keegi vist üritas seal midagi enne teda parandada. Korda ta igatahes sai selle kaardi. Tööd jagub icon_cool.gif
dex
dex
sõnum 23.05.2024 17:19:30 vasta tsitaadiga
icon_smile.gif mõni tahab lihtsalt teema ära märkida, et uued põnevad uudised pildis oleks.
Süümi, juumi, makkami ja kui tüüle nakkami...
Kommentaarid: 98 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 87
SirAskAlot
sõnum 23.05.2024 23:06:35 vasta tsitaadiga
486 kirjutas:
Zonerman kirjutas:
Üldjuhul ei mõelda kaardi jahedusest ja effektiivsusest rääkides kaardi toitepesa konstruktsiooni nõrkust ja sellest tulevenvaid porbleeme.
See, et see sinule mingeid seoseid tekitab.
Ma soovitan sul füüsika õpikud algajatele läbi lugeda. Koolis sa seda ilmselt ei teinud. Võibolla saad sa siis järgmine kord aru millest räägitakse ja millest sa ise räägid. Antud hetkel eksponeerid sa kõigile oma rumalust.
Zonerman
Zonerman
sõnum 24.05.2024 00:26:46 vasta tsitaadiga
PCB layout väidetavalt muutub 5090 founders osas.
https://videocardz.com/newz/nvidia-geforce-rtx-5090-founders-edition-pcb-reportedly-split-into-three-parts
heretic666
heretic666
sõnum 24.05.2024 00:51:36 vasta tsitaadiga
32GB GDDR7 ja 512 bit mäluribalaius kõlab kulukalt
486
sõnum 24.05.2024 10:37:14 vasta tsitaadiga
SirAskAlot kirjutas:
486 kirjutas:
Zonerman kirjutas:
Ja ma räägin kaardist üldiselt. sitaks kuumad ja värd ebaefektiivsed. See saast kaart läheb kuumaks isegi nii sama netis surfates! Äge muidugi et siinset trollid kaitsevad selliseid vigaseid kaarte. HV surnud tänu teile !thumbs_down.gif
zero
SirAskAlot
sõnum 24.05.2024 12:29:31 vasta tsitaadiga
486 kirjutas:
486 kirjutas:
Zonerman kirjutas:
Mul on 4080 arvutis ja ma pole sinu poolt kirjeldatud probleeme märganud. Kui sinu 4080-90 netis surfates ülekuumeneb, siis on probleem su süsteemi seadetes või on tegu vigase kaardiga.
Seda et HV surnud on võid tänada teatud rumalate isikute seltskonda, kes iga neile mittemeeldivale arvamusele sõimu ja lollustega vastavad.
Võtame kas või sinu posti. Kas see teeb must trolli ja nvidia fänni kui ma arvan , et 4080 on kõige jahedam kaart mis mu arvutis on olnud ?
Ei tee.
Kui teatud seltskond sellistest asjadest aru ei saa , siis ongi tagajärjeks, et enamus mõistlike inimesi hoiab HV foorumist eemale. Mul on see teema tutvusringkonnas jutuks tulnud ja üldine arvamus on olnud, et HV foorumi maine on madal ja inimesed pigem väldivad seda.
Ilmselt ei ole ma kõige parem isik sellel teemal vestlemiseks, sest kui keegi mind sovlab või arvab ,et mul pole õigust siin postitada, siis ütlen ma talle ka vastu. Ilmselt pole see ka kõige õigem koht sellel teemal vestlemiseks.
sõnum 24.05.2024 12:35:54 vasta tsitaadiga
486 kirjutas:
milline kaart?
"netis surfates" võib tähendada väga erinevaid asju olenevalt, mida täpselt seal teed ja millised featuurid sisse lülitatud on.
teine külg on muidugi ka see, et mida pead silmas "läheb kuumaks" all? täna lülitab enamik kaarte omal vendid välja ja see kehtib ka lihtsama "netis surfates" kohta.
- londiste
Scart
Scart
sõnum 24.05.2024 12:36:20 vasta tsitaadiga
486 kirjutas:
HV on surnud, sest sinusugused ajavad sellist iba, et seda on võimatu kommenteerida. 4080 idleb normaalsetes tingimustes alla 40C - https://www.guru3d.com/review/geforce-rtx-4080-founder-edition-review/page-7/ ja see on FE, millest aftermarketi mudelid on veel paremad. Mõnel 4080'l on lausa 4090 cooler peal, mis on loodud jahutama 600w kaarti.
sõnum 24.05.2024 13:12:30 vasta tsitaadiga
Scart, see on 5xxx seeria teema, mida sa jaurad siin oma "legacy" kaardist. icon_lol.gif
SirAskAlot
sõnum 25.05.2024 10:21:02 vasta tsitaadiga
Etz kirjutas:
Ükski nendest Nvidia GPU teemadest pole siiani olnud konkreetse xxxx seeria teema. Kõik nad on mingil hetkel laiali valgunud ja nendes on kõikide maailma probleemide üle vaieldud. Ma võin ju mööda foorumi teemasid ringi kolama hakata ja kui keegi teemast välja läheb nende kallal norima hakata. Sõpru ma nii ei leiaks, aga ma saaks kuulutada, et õiglus on kõike tähsam.
Ja ma luban. Erinevalt sinust ma eksija nägu ei vaata. Mul on savi kas inimene on minusse hästi või halvasti suhtunud.
Teiseltpoolt pole see isegi väga teemaväline areng.
Ilmselt tuleb 5xxx seeria tarkvaraline jahutuse kontroll samasugune nagu 4xxx seeria oma. Kui see on 4xxx seerial vigane ja tekitab probleeme, siis on see ilmselt vigane ka 5xxx seerial. Samad probleemid peaks esinema ka 5xxx seerial. Nvidia kaardid(tegelikult enamus PC ventikaid) on juba aastaid ventikaid tarkvaraliselt konrollinud ja tuimalt ei keerle seal enam midagi.
Täiendan veits oma posti, et mu mõte veits selgem oleks. Kerige teemat tagasi ja vaadake kuidas see 4xxx osa üldse alguse sai. Võrdlusest eelmise põlvkonnaga. 5090 võrdluspunkt eelmiste põlvkondadega on 4090. See on alati nii olnud. Uut kaarti võrreldakse tavaliselt eelmise põlvkonna samaväärse kaardiga. Seda on siin foorumis aastakümneid tehtud ja ma ei näe põhjust miks selle kallal norima peaks.
Teine asi on , et Scart ei olnud see kelle emotsioonid keema läksid ja kellele peaks märkuse tegema. Ma ei tea mis probleemid siin varem on olnud, aga oleks kena kui inimesed ei alustaks suhtlemist sealt kus nad 2 aastat tagasi lõpetasid. Kena oleks kui me piirduks ikka konkreetse teemaga ja kena oleks kui me selle teema eelnevad postid enne läbi loeks.
Vael
sõnum 26.05.2024 17:34:30 vasta tsitaadiga
AMD pidi suht kindlalt lipulaevadega enam mitte lagedale tulema..
Lisaks tahab nVidia ka AI pealt koore kraapida, seega vaevalt me seda 512bit kaarti enda arvutites niipea näeme. Vb kui 1a möödas ja superarvutid valmis ehitatud...
kraaks
sõnum 26.05.2024 22:19:08 vasta tsitaadiga
3090 jääb sutsu nõrgaks, 4K resolutsioon, kõik kellad viled. Muidugi mu prose ka vana juba sutsu. tahan vähemalt 120 fps-i cod-is
lillekasvatus.ee
uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  nVidia Blackwell (GB202/GB203/GB205/GB206/GB207) mine lehele 1, 2, 3 ... 37, 38, 39  järgmine
