24.11.2015 01:20:38
DELL-i tarnis uued sülearvutid iseallkirjastatud juursertifikaadiga |
Populaarse Reddit lehe andmeil on DELL kordamas sama fiaskot, mida Lenovo koges möödunud suvel nuhkvaraga Superfish, kui paigaldas kasutaja nõusolekut küsimata koodijupi, mis võimaldas nuhkida kasutajate järgi. DELL XPS 15 sülearvuti ostnud kasutajad avastasid, et sülearvutid tulid eelinstalleeritud iseallkirjastatud eDellRoot nimelise juursertifikaadiga.
Iseallkirjastatud juursertifikaadiga on võimalik sooritada nn vahemehe-rünnakuid (man in the middle attack) ja andmeid manipuleerida ilma kasutaja teadmata.
I had a new Dell Inspiron in the office that shipped last Friday (11/21). I opened it and checked it. It didn't have the update, until I installed Dell Updates, and then it did. Screenshots:
http://imgur.com/a/DA6P5 |
| If you have recently bought a Dell computer and want to see if you are affected by this, go to Start -> type "certmgr.msc" -> (accept on UAC prompt) -> Trusted Root Certification Authorities -> Certificates and check if you have an entry with the name "eDellRoot". If so, congratulations, you've been pwned by Dell, the very company you paid for your computer! |
| This means that a network attacker that could intercept their traffic with a Man-in-the-middle attack would be able to read and modify the Dell customer's data without being easily noticed. Normally when an attacker does this, the user's browser throws alarms and big red flags, but any user with this root certificate installed will probably not notice it unless they happened to look at the website's full SSL certificate chain (which casual users rarely do). |
Loe lähemalt: https://www.reddit.com/r/technology/comments/3twmfv/dell_ships_laptops_with_rogue_root_ca_exactly/
HV valuutakalkulaator
viimati muutis Tanel 24.11.2015 11:05:38, muudetud 3 korda |
Tiim
24.11.2015 07:17:43
oeh
_________________ mida sa vahid mu allkirja, AHV raisk |
ocb
24.11.2015 08:53:42
| Tanel, ära loobi asjatult sõnu kui sa veel ei tea, milles tegelikult asi. Kindlasti on sul kodus lauasahtlis kööginuga, see ei tee veel sinust mõrvarit. Hetkel ilma ametliku teateta, on su jutt laim.
LongHorn
24.11.2015 08:59:06
Peale arvuti ostu esimese asjana tuleks teha format ja puhas OS ise peale installida.
Juba ka seepärast, et üldjuhul ei ole Sul vaja kõike seda mis seal peal on.
HPN
sooty
24.11.2015 09:16:25
Paari tähe trükkimisele kuluva aja kokkuhoidmiseks?
ocb
24.11.2015 09:33:40
Muidugi lugesin ja sain aru milleks seda serti vaja oli. Dell viisakalt vabandab ja tänab neid kliente, kes andsid murest teada, mitte ei vassi ega saada klienti kuu peale. Võrdluseks võib tuua Apple, kes siiani pole oma SSL Heartbleed turvaristki kommenteerinud, kuigi probleemist juba üle aasta möödas.
| LongHorn kirjutas: |
Juba ka seepärast, et üldjuhul ei ole Sul vaja kõike seda mis seal peal on. |
Ja installid sinna Windows 10...
LKits
DVDRW
24.11.2015 11:23:36
Nüüd küsimus kumb on turvalisem kas:
1. puhas W7 install ja kõik updateid kinni
2. w10 jätta peale ja uuendused kõik lubada
attrs
WäntWõll
make.believe
24.11.2015 12:32:59
| DVDRW kirjutas: |
2. w10 jätta peale ja uuendused kõik lubada |
Kui sa teed puhta installi siis sa ei saa saada Dell-I bloatware-I, millega antud jama kaasneb
Lahendatud.
Kahju lihtsalt, et Lenovo hiljutisest jamast midagi ei õpitud
Lihtsalt kurb on lugeda mida "härrad" läbi lasevad oma majast.
mahno
24.11.2015 13:01:45
DVDRW kirjutas:
Nii vildakat küsimust annab küsida. Millisest ohust või riskist sa räägid? Updatemata W7 on 101% ebaturvaline.[/quote]
24.11.2015 14:48:54
| DVDRW kirjutas: |
See kas arvuti on turvaline või mitte ei sõltu OS-st ega sellest kas uuendused on lubatud või mitte. See sõltub eelkõige ikka tihendist kuvari ja tooli vahel ja sellest kust ta oma tarkvara hangib ja milliseid veebilehti külastab ja milliseid linke avab. Ka turvalisim OS maailmas ei suuda kaitsta dumbjuuserist kasutajat kes iga nädal arvab, et ta on võitnud biljon dollarit meili teel
_________________ Win11 25H2 upgrade skriptid neile kelle masin ise ei taha 23H2 või 24H2 pealt ennast uuendada:
https://foorum.hinnavaatlus.ee/viewtopic.php?p=11720738#11720738 |
Renka
24.11.2015 15:20:40
| ocb kirjutas: |
Muidugi lugesin ja sain aru milleks seda serti vaja oli. Dell viisakalt vabandab ja tänab neid kliente, kes andsid murest teada, mitte ei vassi ega saada klienti kuu peale. Võrdluseks võib tuua Apple, kes siiani pole oma SSL Heartbleed turvaristki kommenteerinud, kuigi probleemist juba üle aasta möödas. |
Mis kommentaari sa ootad? Mille kohta üldse? Miks peaks?
Kas Apple peaks kõigi neisse mittepuutuvate turvariskide/aukude kohta kommentaari avaldama?
LKits
24.11.2015 19:15:08
| Tomorrow kirjutas: |
| DVDRW kirjutas: |
See kas arvuti on turvaline või mitte ei sõltu OS-st ega sellest kas uuendused on lubatud või mitte. See sõltub eelkõige ikka tihendist kuvari ja tooli vahel ja sellest kust ta oma tarkvara hangib ja milliseid veebilehti külastab ja milliseid linke avab. Ka turvalisim OS maailmas ei suuda kaitsta dumbjuuserist kasutajat kes iga nädal arvab, et ta on võitnud biljon dollarit meili teel  |
Ei sõltu ainult tihendist.
Mõningased turvaaugud eksisteerivad olenemata tihendi intelligentsusest, sest süsteem ei saa kunagi olla perfektne loomise järgus, vaid peab olema pidevas arengus.
24.11.2015 20:49:37
| Kui asi on riistvarasse kodeeritud, siis ei aita ühegi opsüsteemi reinstall või muu tarkvaraline lahendus.
25.11.2015 11:46:59
| Betamax, Riistvaralised tagauksed on väga tume maa millest keegi suurt midagi ei tea. |
Ideaalne ju? Ega pahad poisid sellega uhkeldama ei tule, mistõttu võib seal olla krt teab, mida.
olka
mahho
25.11.2015 22:21:06
[quote="LKits"]
Kahju, et OS-ita arvuteid nii vähe müüakse... igale poole surutakse seda Windowsi kaasa, mis tõstab seadme maksuvust...
Suurtootjad maksavad ca 10USDi litsentsi eest, midagi see märgatavalt kallimaks nüüd küll ei tee =)
DVDRW
26.11.2015 00:08:14
| ot: |
| Tahvlitele ja pulkadele on üldse tasuta (Windows with bing) |
LKits
