uus teema   vasta Uudised »  Pealtkuulamine ja tsensuur, ACTA, DMCA, GDPR »  DELL-i tarnis uued sülearvutid iseallkirjastatud juursertifikaadiga märgi kõik teemad loetuks
sõnum 24.11.2015 02:20:38 DELL-i tarnis uued sülearvutid iseallkirjastatud juursertifikaadiga vasta tsitaadiga
Populaarse Reddit lehe andmeil on DELL kordamas sama fiaskot, mida Lenovo koges möödunud suvel nuhkvaraga Superfish, kui paigaldas kasutaja nõusolekut küsimata koodijupi, mis võimaldas nuhkida kasutajate järgi. DELL XPS 15 sülearvuti ostnud kasutajad avastasid, et sülearvutid tulid eelinstalleeritud iseallkirjastatud eDellRoot nimelise juursertifikaadiga.
Iseallkirjastatud juursertifikaadiga on võimalik sooritada nn vahemehe-rünnakuid (man in the middle attack) ja andmeid manipuleerida ilma kasutaja teadmata.
I had a new Dell Inspiron in the office that shipped last Friday (11/21). I opened it and checked it. It didn't have the update, until I installed Dell Updates, and then it did. Screenshots:
http://imgur.com/a/DA6P5
If you have recently bought a Dell computer and want to see if you are affected by this, go to Start -> type "certmgr.msc" -> (accept on UAC prompt) -> Trusted Root Certification Authorities -> Certificates and check if you have an entry with the name "eDellRoot". If so, congratulations, you've been pwned by Dell, the very company you paid for your computer!
This means that a network attacker that could intercept their traffic with a Man-in-the-middle attack would be able to read and modify the Dell customer's data without being easily noticed. Normally when an attacker does this, the user's browser throws alarms and big red flags, but any user with this root certificate installed will probably not notice it unless they happened to look at the website's full SSL certificate chain (which casual users rarely do).
Loe lähemalt: https://www.reddit.com/r/technology/comments/3twmfv/dell_ships_laptops_with_rogue_root_ca_exactly/
HV-s ID-kaardiga autentimine
viimati muutis Tanel 24.11.2015 12:05:38, muudetud 3 korda
Tiim
Tiim
sõnum 24.11.2015 08:17:43 vasta tsitaadiga
mida sa vahid mu allkirja, AHV raisk
ocb
ocb
sõnum 24.11.2015 09:53:42 ... vasta tsitaadiga
Tanel, ära loobi asjatult sõnu kui sa veel ei tea, milles tegelikult asi. Kindlasti on sul kodus lauasahtlis kööginuga, see ei tee veel sinust mõrvarit. Hetkel ilma ametliku teateta, on su jutt laim.
LongHorn
LongHorn
sõnum 24.11.2015 09:59:06 vasta tsitaadiga
Peale arvuti ostu esimese asjana tuleks teha format ja puhas OS ise peale installida.
Juba ka seepärast, et üldjuhul ei ole Sul vaja kõike seda mis seal peal on.
HPN
HPN
sõnum 24.11.2015 10:02:35 Re: ... vasta tsitaadiga
ocb kirjutas:
Linki ka üldse lugesid? http://en.community.dell.com/dell-blogs/direct2dell/b/direct2dell/archive/2015/11/23/response-to-concerns-regarding-edellroot-certificate
sooty
sõnum 24.11.2015 10:16:25 vasta tsitaadiga
ocb
ocb
sõnum 24.11.2015 10:33:40 vasta tsitaadiga
parasitego kirjutas:
ocb kirjutas:
Muidugi lugesin ja sain aru milleks seda serti vaja oli. Dell viisakalt vabandab ja tänab neid kliente, kes andsid murest teada, mitte ei vassi ega saada klienti kuu peale. Võrdluseks võib tuua Apple, kes siiani pole oma SSL Heartbleed turvaristki kommenteerinud, kuigi probleemist juba üle aasta möödas.
LongHorn kirjutas:
Ja installid sinna Windows 10...
LKits
LKits
sõnum 24.11.2015 11:36:58 vasta tsitaadiga
LongHorn kirjutas:
Terve elu nii teinud ja jätkan samuti, kuni võimalus ja lisandväärtused puuduvad tehase tarkvara kasutamisel.
Kahju, et OS-ita arvuteid nii vähe müüakse... igale poole surutakse seda Windowsi kaasa, mis tõstab seadme maksuvust...
sõnum 24.11.2015 11:42:44 vasta tsitaadiga
UPDATE 2: Dell has released a statement regarding this matter along with instructions for how to remove it (download).
Allikas: https://www.reddit.com/r/technology/comments/3twmfv/dell_ships_laptops_with_rogue_root_ca_exactly/
DVDRW
DVDRW
sõnum 24.11.2015 12:23:36 vasta tsitaadiga
Nüüd küsimus kumb on turvalisem kas:
1. puhas W7 install ja kõik updateid kinni
2. w10 jätta peale ja uuendused kõik lubada
attrs
attrs
sõnum 24.11.2015 12:44:05 vasta tsitaadiga
http://tehnika.postimees.ee/3410541/dell-palub-vabandust-andsime-valja-hakkeritele-meeleparase-sertifikaadiga-arvuteid
WäntWõll
make.believe
WäntWõll
sõnum 24.11.2015 13:32:59 vasta tsitaadiga
DVDRW kirjutas:
Kui sa teed puhta installi siis sa ei saa saada Dell-I bloatware-I, millega antud jama kaasneb icon_idea.gif
Lahendatud.
Lihtsalt kurb on lugeda mida "härrad" läbi lasevad oma majast.
mahno
sõnum 24.11.2015 14:01:45 vasta tsitaadiga
DVDRW kirjutas:
Nii vildakat küsimust annab küsida. Millisest ohust või riskist sa räägid? Updatemata W7 on 101% ebaturvaline.[/quote]
sõnum 24.11.2015 15:48:54 vasta tsitaadiga
DVDRW kirjutas:
See kas arvuti on turvaline või mitte ei sõltu OS-st ega sellest kas uuendused on lubatud või mitte. See sõltub eelkõige ikka tihendist kuvari ja tooli vahel ja sellest kust ta oma tarkvara hangib ja milliseid veebilehti külastab ja milliseid linke avab. Ka turvalisim OS maailmas ei suuda kaitsta dumbjuuserist kasutajat kes iga nädal arvab, et ta on võitnud biljon dollarit meili teel icon_lol.gif
Renka
Renka
sõnum 24.11.2015 16:20:40 vasta tsitaadiga
ocb kirjutas:
ocb kirjutas:
Mis kommentaari sa ootad? Mille kohta üldse? Miks peaks?
Kas Apple peaks kõigi neisse mittepuutuvate turvariskide/aukude kohta kommentaari avaldama?
LKits
LKits
sõnum 24.11.2015 20:15:08 vasta tsitaadiga
Tomorrow kirjutas:
DVDRW kirjutas:
Ei sõltu ainult tihendist.
Mõningased turvaaugud eksisteerivad olenemata tihendi intelligentsusest, sest süsteem ei saa kunagi olla perfektne loomise järgus, vaid peab olema pidevas arengus.
sõnum 24.11.2015 21:49:37 vasta tsitaadiga
Kui asi on riistvarasse kodeeritud, siis ei aita ühegi opsüsteemi reinstall või muu tarkvaraline lahendus.
sõnum 25.11.2015 10:38:19 vasta tsitaadiga
Betamax, Riistvaralised tagauksed on väga tume maa millest keegi suurt midagi ei tea. Iseasi mingi BIOS-sse sissekirjutatud asi.
sõnum 25.11.2015 12:46:59 vasta tsitaadiga
Tomorrow kirjutas:
Ideaalne ju? Ega pahad poisid sellega uhkeldama ei tule, mistõttu võib seal olla krt teab, mida.
olka
olka
sõnum 25.11.2015 16:28:50 vasta tsitaadiga
http://forte.delfi.ee/news/tarkvara/dell-paikas-oma-arvutites-turvaaugu-ara-aga-keegi-leidis-kohe-uue?id=73042493 icon_biggrin.gif , haha thumbs_down.gif
You, all gonna make me loose my mind, loose my mind
mahho
mahho
sõnum 25.11.2015 23:21:06 vasta tsitaadiga
[quote="LKits"]
LongHorn kirjutas:
Suurtootjad maksavad ca 10USDi litsentsi eest, midagi see märgatavalt kallimaks nüüd küll ei tee =)
DVDRW
DVDRW
sõnum 26.11.2015 01:08:14 vasta tsitaadiga
ot:
Tahvlitele ja pulkadele on üldse tasuta (Windows with bing)
LKits
LKits
sõnum 01.12.2015 11:40:16 vasta tsitaadiga
mahho kirjutas:
LKits kirjutas:
ot:
Omal ajal ostsin Asus 1215B ning kaks varianti - üks Windowsi ja teine OS-ita. Esimene maksis 50€ rohkem.
