-Superman-
24.03.2009 14:33:36
OnLive |
Part 1
http://www.gametrailers.com/player/47079.html
Part 2
http://www.gametrailers.com/player/47081.html
You may never buy a new video card ever again. Actually, the only PC gaming hardware you might ever need will cost you less than a Wii, should OnLive's potential live up to its promise.
OnLive is a new video games on demand service that may just change the way you play PC games. The brainchild of Rearden Studios founder Steve Perlman, formerly of Atari, Apple, WebTV and more, and Mike McGarvey, formerly of Eidos, the technology looks to revolutionize the way computer games are brought home. Instead of spending hundreds or thousands of dollars on the latest video game hardware that will make games like Crysis playable at nearly maxed settings, let OnLive's servers handle the processing. All that's required is a low cost "micro console" or a low end PC and a broadband internet connection.
Yes, even your sub $500 netbook or MacBook can play processor intensive, GPU demanding PC games. In fact, that's the whole point. How does it work?
[img]  [/img]
The concept is simple. Your controller input isn't going from your hand to the controller to the machine in front of you, it's going from your hand to the controller through the internet to OnLive's machines then back again as streamed video. Whether you're using a USB gamepad, Bluetooth wireless controller, or tried and true keyboard and mouse, the processing and output happens on OnLive's side, then is fed back to your terminal, with the game "perceptually" played locally.
In other words, it's cloud computed gaming.
Using patented video compression in tandem with algorithms that compensate for lag, jitter and packet loss, OnLive delivers video at up to 720p resolution at frame rates up to 60 frames per second. Of course, the quality of the video feed relies on your connection.
For standard definition television quality, a broadband connection of at least 1.5 megabits per second is required. For HDTV resolution, a connection of at least 5 mbps is needed.
What about lag, you say? OnLive's technology "incubator" Rearden Studios claims that its servers will deliver video feeds that have a ping of less than one millisecond. Its patented video compression technique is also advertised as blazing fast, with video compression taking about one millisecond to process.
That speedy delivery of video game content means more than just video games on demand, it means no install times. It also means cross-platform compatibility, the ability to try demos instantly, and an opportunity to rent or play games almost instantaneously.
It also means real-time streaming of video feeds from players far and wide playing their own games at home via OnLive which could ultimately mean broadcast style feeds to observers. Up to a million, according to OnLive reps.
The best part? It already has serious buy-in from major publishers, including EA, THQ, Codemasters, Ubisoft, Atari, Warner Bros., Take-Two, and Epic Games. Oh, and 2D Boy.
The appeal on the publisher side is that it essentially means less opportunity for profit-whittling piracy. There's little modification on the developer side to make a game run with OnLive. There's even an SDK available. On the consumer side, the prospect of no cheatingor at least heavily reduced cheatingis also desirable.
OnLive is showing 16 of the games planned for the service this week at GDC, some of them playable on low-spec machines, the kind of Dell your grandmother might buy.
Of course, they'll also be playable on OnLive's micro console, a simple, low-cost device that's about the size of your hand. It's simple techthere's not even a GPU in the device. It simply acts as a video decoding control hub, with two USB inputs and support for four Bluetooth devices, and outputs audio and video via optical and HDMI connections. The micro console is expected to be priced competitively, "significantly less" than any current generation console on the market and potentially "free" with an OnLive service contract.
Plans for a monthly subscription are in the works, said to be priced on par with Xbox Live fees, offering the same community and multiplayer features popularized by Microsoft's gaming service. Perhaps the most interesting aspect of the unified OnLive community is the option to save and upload Brag Clips, a 15 second replay of, well, whatever just happened in-game.
We too were a little suspicious of OnLive's capability to deliver perceptually lag-free on-demand games. But then we played a hasty online game of Crysis Wars on the service today and became a little less suspicious. It seemed to work. Obviously, it was in a controlled environment with only a few hundred internal beta testers populating the system. But it worked.
Will it work in the wild? It might. OnLive is currently beta testing internally, with an external beta planned for Summer and a launch later this year. Expected to be deployed by launch will be five server centers hosting the latest and greatest gamesOnLive isn't aiming to be GameTap, with no immediate plans to host archival PC games. Server clusters will be located in Santa Clara, Texas, Virginia and elsewhere, hoping to offer OnLive subscribers within 1,000 miles a seemingly lag-free experience.
We'll be testing the service later this week, letting you know what we thought.
Arvuti(tavaline) või telekas + Internet = Mängi mänge,ei pea installima ega downloadmima.Osta mäng ja mängi kohe.Crysis läheb vana arvutile peale jne...
BETA TULEB SUVEL
viimati muutis -Superman- 24.03.2009 15:21:25, muudetud 1 kord |
Mafia
24.03.2009 14:38:35
Huvitav asi, aga see eeldab head neti ma usun, aga ma ei usu et see asi väga läbi läheb, nvidia, intel, amd/ati ja teised gaming hardweri tootjad ei laseks seda läbi kui see ka töötaks nii nagu kirjeldatud
_________________ Bawse |
| Kommentaarid: 19 loe/lisa |
17 |
-Superman-
24.03.2009 14:41:42
| Mafia kirjutas: |
Huvitav asi, aga see eeldab head neti ma usun, aga ma ei usu et see asi väga läbi läheb, nvidia, intel, amd/ati ja teised gaming hardweri tootjad ei laseks seda läbi kui see ka töötaks nii nagu kirjeldatud  |
Kui ei lähe väga läbi nvidia,intel,amd/ati jne siis ei ole uusi konsoole ka.
See tähendab ,et see OnLive > Kõik mängu konsoolid jne... + Microsoft windows for live = FAIL
Mafia
24.03.2009 14:46:59
| -Superman- kirjutas: |
| Mafia kirjutas: |
See tähendab ,et see OnLive > Kõik mängu konsoolid jne... + Microsoft windows for live = FAIL |
No konsool konsooliks aga ütle miks ma peaks nt mingi crysise mängimiseks 20k gaming PC ostma kui ma saaks selel lahendusega mingi 4k eest kõiki tulevasi mänge mängida max setingutel, ja ei pea hardwei uuendama ?? Mis mõttega ma peaks siis mingeid i7 ja GFX300, 5870X2 jms asju ostma
Ei tahaks uskuda et see nii lihtne ja hea on nagu tundub, seal on mingid konksud taga kas või mingi kuumaks vms a noh elame näeme.
17 |
O
24.03.2009 14:48:46
720p on arvuti peal mängides kergelt öeldes saast pilt ja isegi selle edastamiseks oleks vaja 5mbps sünkroonühendust, milline Eestis on vast paaril protsendil internetikasutajatest
_________________ PS, kui teemades ei vasta |
| Kommentaarid: 76 loe/lisa |
69 |
Valdars
24.03.2009 14:48:48
| Konks on selles, et praegused võrgud ei ole võimelised sellist asja vedama.
| Kommentaarid: 48 loe/lisa |
45 |
-Superman-
24.03.2009 15:04:02
| Mafia kirjutas: |
| Mafia kirjutas: |
Ei tahaks uskuda et see nii lihtne ja hea on nagu tundub, seal on mingid konksud taga kas või mingi kuumaks vms a noh elame näeme. |
Beta tuleb suvel.
Ainus hea asi mida sul läheb vaja on internet.
OnLives on PC mängud
PC gaming dying?
Ei
Eks ootame ja näeme mis tuleb...
| Valdars kirjutas: |
| Konks on selles, et praegused võrgud ei ole võimelised sellist asja vedama. |
Imelik.Mul on steam.Kui ma downloadin midagi siis kiirus on 7mb/s
On küll võimalik.
| O kirjutas: |
720p on arvuti peal mängides kergelt öeldes saast pilt ja isegi selle edastamiseks oleks vaja 5mbps sünkroonühendust, milline Eestis on vast paaril protsendil internetikasutajatest  |
Ma tean jah aga kui PC-l on 720p sitt pilt aga konsoolil on 600p(Call of Duty 4 ja 5) ja pilt on norm.
Usu mind.See ei jää selliseks...
24.03.2009 15:13:01
nagu seda täna juba varem arutatud sai, siis sellisel kujul tolle OnLive teenuse töötamine suure kahtluse all. suurest lag-ist ei pääse mitte kuidagi mööda.
kes nüüd vastu soovib vaielda, siis enne tehke oma käsurida lahti (Start -> Run... -> cmd) ja kirjutage sinna näiteks "tracert www.google.com" ja tõmmake omad paralleelid.
seega praeguse seisuga ütleks, et tegu rohkem ümmarguse marketingijutu kui mitte vaporwarega.
313 |
lawrey
24.03.2009 15:14:29
| O kirjutas: |
Vaevalt, et sünkroonühendust vaja on. Saadad ju ainult kontrolleri käske. Muidugi jah, neti kiirusest olulisem on latentsus... USA's võib asi enam-vähem töötada, tespool maakera elajatel vast mitte nii väga.
Siit tegelikult hea äriidee, lepi tegijatega kokku ja pane Eestisse teenust pakkuv server üles
_________________ -bash: chpwn: command not found |
| Kommentaarid: 39 loe/lisa |
36 |
-Superman-
24.03.2009 15:19:33
| Skeptik kirjutas: |
seega praeguse seisuga ütleks, et tegu rohkem ümmarguse marketingijutu kui mitte vaporwarega. |
EI PÄÄSE MITTE KUNAGI MÖÖDA LAGIST?
Nad juba ütlesid ,et see töödab ja pole läägi.
See on tulevik !!!
Kunagi inimesed arvasid ,et autosi ei tule kunagi aga näe,nüüd on autod olemas...
Filmid aga näe nüüd on filmid olemas,mängud aga näe nüüd on mängud olemas,internet aga näe nüüd on internet olemas.
See kõik on tulevik.Alati tuleb midagi uut...
Valdars
24.03.2009 15:20:24
Ei, tegemist on ikka serveri pool pildi renderdamisega ja selle tagasisaatmisega ja see on midagi muud, kui tavaline võrgumäng.
EDIT:
Neid sõnu ei ole mõtet niikaua tõsiselt võtta, kuni neil midagi reaalselt eksisteerivat ka näidata on.
viimati muutis Valdars 24.03.2009 15:22:34, muudetud 1 kord |
45 |
24.03.2009 15:20:48
-Superman-, jah ei pääse. füüsika õpik kätte vutvutvutt.
313 |
-Superman-
24.03.2009 15:23:29
| Skeptik kirjutas: |
-Superman-, jah ei pääse. füüsika õpik kätte vutvutvutt.  |
Nad ütlesid ,et saavad ja BETA tuleb suvel.
Kui oleks lääg siis nad ei teeks seda....
FFS
| Valdars kirjutas: |
EDIT:
Neid sõnu ei ole mõtet niikaua tõsiselt võtta, kuni neil midagi reaalselt eksisteerivat ka näidata on. |
BETA tuleb suvel.Eks siis näeme kellel on õigus...
24.03.2009 15:24:33
-Superman-, lag on ja jääb. ega nad siis võrgusõlmedest mööda ei pääse. mõtle nüüd loogiliselt.
edit:
ja mis siis veel juhtub kui kõrvaltoas väikevend torrenti käima tõmbab? fps kukub 10 peale ja reso 2x väiksemaks?
viimati muutis SKG 24.03.2009 15:27:03, muudetud 1 kord |
313 |
wicked
24.03.2009 15:24:59
-Superman-, sa usud kõiki müügimehi? Kes siis enne oma tootest kehvasti rääkinud on. Kohtvõrgus oleks see veel võimalik, demotakse nagunii samas võrgus asuvate serveritega.
_________________ I prepared Explosive Runes this morning |
| Kommentaarid: 68 loe/lisa |
63 |
-Superman-
24.03.2009 15:26:26
| wicked kirjutas: |
| -Superman-, sa usud kõiki müügimehi? Kes siis enne oma tootest kehvasti rääkinud on. Kohtvõrgus oleks see veel võimalik, demotakse nagunii samas võrgus asuvate serveritega. |
No kuule OOTA SEE BETA ÄRA JA SIIS ÜTLE KAS ON HEA VÕI EI OLE.
OOTA JA OOTA JA SIIS NÄEME !!!
24.03.2009 15:28:57
polegi vaja oodata, juba praegu näha, mis sest tuleb kui vähegi võrgundusest midagi jagad.
313 |
Mario.
24.03.2009 15:31:38
| Nunnu.. kuid liiga väike resolutsioon.
6 :: |
217 |
-Superman-
24.03.2009 15:33:01
| MarioA. kirjutas: |
| Nunnu.. kuid liiga väike resolutsioon. |
Call of Duty 4 ja 5 on konsooli peal 600p resolutsioon ja see on 720p.
Ma tean jah ,et PC-l on 1080p aga TV-es on 720p päris hea kuna call of duty 4 on päris hea 600p peal
Mario.
24.03.2009 15:42:39
Ikkagi EI.. - muidugi aja pikku internet ja kiirused arenevad. Minu jaoks on 720p madal... Subjektiivne.
Spectate mode on kena pluss muidugi.
Palju xbox live maksab kuus?
6 :: |
217 |
piimaPAKK
24.03.2009 15:49:03
| Skeptik kirjutas: |
kes nüüd vastu soovib vaielda, siis enne tehke oma käsurida lahti (Start -> Run... -> cmd) ja kirjutage sinna näiteks "tracert www.google.com" ja tõmmake omad paralleelid.  |
No mul neti.ee ping on 5ms siin.
Muidugi sa USA serverist oma mängu ei mängi aga Helsinki oleks tehtav imo.
24.03.2009 15:55:04
| piimaPAKK kirjutas: |
| Skeptik kirjutas: |
Muidugi sa USA serverist oma mängu ei mängi aga Helsinki oleks tehtav imo. |
milline server lagivabalt HD video kokkupakib ja sinuni saadab?
mõtle nüüd. sa mängid mingit racing mängu. kiire kurviline tee. pidurdad, kiirendad, keerad iga suunas. need nupuvajutused peavad jõudma serverisse ja seal hakatakse alles videot kokkupakkima ning saadetakse sulle vastav pilt koju. ja kui seda kõike veel onlines teistega koos... no way, võibolla malet/kabet ehk.
viimati muutis SKG 24.03.2009 16:01:11, muudetud 2 korda |
313 |
lightbluefox
24.03.2009 15:58:18
Paistab et OnLive promojad on ühe meie seast juba suutnud ära võrgutada
Mina arvan, et teretulnud lahendus, kui sa mängid harva, aga tahaks paljusid mänge proovida ja ei oma suurt rahkotti et pidevalt arvutit uuendada, on see hea valik.
Ma ei julgeks küll midagi lubada, et ta konsooli ja/või pc mängurlust tapma hakkab, aga müügile avaldab kindlasti mõju.
Harvale mängijale oleks siis see lahendus super, kutsud sõbrad külla, rendid õhtuks filmi asmele ühe ralli ja maksad mõned dollarid. Ei pea ostma selle mängu pärast konsooli ega võimast arvutit (millele tuleb mäng paigaldada ja seadistada).
| Kommentaarid: 45 loe/lisa |
44 |
Inim
24.03.2009 16:11:45
| Kommentaarid: 4 loe/lisa |
piimaPAKK
24.03.2009 16:12:07
| Skeptik kirjutas: |
milline server lagivabalt HD video kokkupakib ja sinuni saadab?  |
Sellel pakkimis tehnoloogial arvatavasti nende kogu ärimudel baseerubki
Ma ei ole muidugi ise katsetand seda teenust aga kui EA, Take-Two, Ubisoft, Epic, Atari, Codemasters, Warner Bros. ja Eidos
on ennast sinna kirja pannud, siis päris tühi mull see ka ei ole.
24.03.2009 16:20:40
| Skeptik kirjutas: |
on ennast sinna kirja pannud, siis päris tühi mull see ka ei ole. |
midagi nii revolutsioonolist, mida isegi parimate koodekite autorid pole siiani suutnud? sälitada üheaegselt nii HD reso, hea pildikvaliteet ja seda kõike ilma pakkimiseks kulumata ajaga?
313 |
piimaPAKK
24.03.2009 16:29:07
| Skeptik kirjutas: |
midagi nii revolutsioonolist, mida isegi parimate koodekite autorid pole siiani suutnud? sälitada üheaegselt nii HD reso, hea pildikvaliteet ja seda kõike ilma pakkimiseks kulumata ajaga?  |
Üldiselt niimoodi toimubki areng, et tehakse paremini kui siiani parimad on suutnud
Peale selle pakitakse mängu pilti, kus võibolla annab kasutada mingiseid nipple ning
nad saavad kasutada vastavat riistvara selleks.
24.03.2009 16:41:11
| Skeptik kirjutas: |
nad saavad kasutada vastavat riistvara selleks. |
füüsikaseadustest sa ei pääse, aga tundub, et see osasid ei heiduta ja usutakse rohkem hoopis reklaamimulli.
viimati muutis SKG 24.03.2009 16:41:34, muudetud 1 kord |
313 |
wicked
63 |
-Superman-
24.03.2009 16:45:03
| Skeptik kirjutas: |
| Skeptik kirjutas: |
füüsikaseadustest sa ei pääse, aga tundub, et see osasid ei heiduta ja usutakse rohkem hoopis reklaamimulli. |
Ehk anna siis tõestus ,et ei pääse...
Kunagi öeldi ka ,et interneti ei tule kunagi kuna füüsikaseadustest sa ei pääse...
Kas sa tead ,et praegust tehakse loomast kloone?Sa vist ei tea kuna sinu jutt: füüsikaseadustest sa ei pääse
24.03.2009 16:48:22
| Skeptik kirjutas: |
| Skeptik kirjutas: |
Kas sa tead ,et praegust tehakse loomast kloone?Sa vist ei tea kuna sinu jutt: füüsikaseadustest sa ei pääse |
fakt on see, et kõik võrgusõlmed ja ühendused, mis jäävad lõppkasutaja ja nende serveri vahele jäävad ja seal vahel toimuvat liiklust nemad kuidagi kiirendada ei saa. nad võivad ju oma võrgukoodi väga heaks teha, aga see ei muuda asja. selle vahemaa peale lag jääb.
teine asi on see, et taoline asi tahab saada väga stabiilset ühendust, seega igasugune muu võrku koormav tegevus sama ühenduse tagant suurendab võrgu läägi veelgi.
/me kahe jalaga maa peal
313 |
iDemon
24.03.2009 16:49:29
Praegu on see fail. Maybe 2015, kui kiire nett on kõigile taskukohane ja üldse kättesaadav, praegu aga raudne ei.
Engadgeti kommentaatoritest rääkis ka keegi sellest vahemaa värgist.
| Kommentaarid: 122 loe/lisa |
104 |
rere252
24.03.2009 17:07:17
See asi saab tõenäoliselt mingil hetkel M$-lt süüdistuse... hint: Live.
OnLive ise tundub küll revolutsiooniline ja kui see jors seal videotes jama ei ajanud, et läägi vabadus on saavutatud 7 aasta pikkuse tööga, võib asi isegi toimida. Kui toimib siis on OnLive vägagi .
rem4605
24.03.2009 17:42:13
Väärt idee poistel ikkagi
Aga jahhh, praegu tundub võimatu, aga eks näis suvel siis
| Kommentaarid: 21 loe/lisa |
17 |
DeTHiCa.
24.03.2009 18:26:12
see on mingi huumor teema siin. esimene aprill juba nii vara käes see aasta?
selliseid lubadusi loopida... ulme.
140 |
G80
24.03.2009 19:24:58
Idee on huvitav aga jah niipea sellest välja küll midagi ei tule.
210 |
XNDR
24.03.2009 19:36:11
Lag on musthave sellise asja puhul. Lisaks tundub veel, et multiplayer mängud saavad olema suht piiratud võimalustega kui internet on niigi hõivatud pildi edastamisega.
Eks aeg edasi näitab mis sellest üritusest välja kujuneb.
_________________ SteamID
twitch
level1.ee |
19 |
ufo56
24.03.2009 19:48:50
Võrgu kiirus peaks küll 5-6gbit VÄHEMALT olema. Ja pluss suured vahemaad. Ei kujuta ette kuidas küll see toimima hakkaks. Üldiselt suht esimese aprilli uudis
Lae pildid -> pilt.io |
| Kommentaarid: 79 loe/lisa |
67 |
24.03.2009 19:53:20
asi pole niivõrd võrgu kiiruses kui stabiilses ühenduses ja viiteaegades
teine asi on ka see, et pead leppima teenusepakkuja ettemääratud mänguvalikuga
313 |
DeTHiCa.
24.03.2009 20:00:16
lisaks siis sellele et mängud oleks kõik siis vanilla versioonid... vahest ongi just MODid mis mängu heaks teevad. ja mis riistvaratootjatest saaksid? ati ja nvidia hakkavad võrgukaableid ja -kaarte tootma?
süvendaksid sellega ainult töötust ja majanduskriisi.
140 |
rere252
24.03.2009 20:12:30
| DeTHiCa. kirjutas: |
süvendaksid sellega ainult töötust ja majanduskriisi. |
Keegi peab OnLive-i servudele ka graafikakaarte valmistama.
-Superman-
24.03.2009 20:32:06
| Skeptik kirjutas: |
| Skeptik kirjutas: |
| Skeptik kirjutas: |
/me kahe jalaga maa peal  |
Kuule kuule ega see pole 1 server.
Euroopas saab ka olema servusi jne...
Ei tea miks nad siis räägivad ,et see läheb tööle kuigi tgl ei lähe...
See oleks sama hea:
Ütlen ,et see mäng on hea aga kui välja tuleb siis seda mängu pole olemas...
For 720p HD video, OnLive requires a high-speed broadband connection rated at 5Mbps; standard-def video can swing as low as 1.5 Mbps.
http://www.elisa.ee/et/Eraklient/Hinnad/26/Ulikiire-koduinternet-Tallinnas-ja-Parnus
Kodulahendusena pakume interneti püsiühendust allalaadimiskiirustega 5 või 15 megabitti sekundis
| Skeptik kirjutas: |
teine asi on ka see, et pead leppima teenusepakkuja ettemääratud mänguvalikuga |
Seal peaks olema kõik 2006-2009 mängud juba nagu näha oli...
wicked
63 |
24.03.2009 20:46:00
Euroopas serverid? kõik mängud vahemikus 2006-2009? ehk viitad sellele infole?
saa nüüd aru, et olgu see Interneti kiirus sul 5Mbps või 15Mbps - lag jääb - see ei kao kuskile. näiteks mul on kodus 15Mbps ühendus ja tööl kõigest 4Mbps, aga kodus on ping Eesti serveritesse 2-3x suurem kui tööl.
313 |
beastbeats
| Kommentaarid: 369 loe/lisa |
285 |
Ho Ho
24.03.2009 21:01:56
Nad juba ütlesid ,et see töödab ja pole läägi. |
Nad ütlesid "seemingly lag-free experience" ehk siis "pealtnäha lagivaba" ehk siis lag eksisteerib kuid seda on (üritatud) varjata.
OOTA JA OOTA JA SIIS NÄEME !!! |
Oota beta ära ja siis kuku kiitma
Kui kaua aega kulub praegu korraliku kvaliteediga video pakkimiseks? Nemad rääkisid seal 1 ms per frame ehk 1000 kaadrit sekundis. Videot pakitakse parimate prosede-algoritmidega hetkel <50 kaadri sekundis ning nood prosed on täiskoormuse all. Kuidas suudavad nemad ära lahendada probleemi, kus sul on vaja lisaks mängu enda jooksutamisele ka videot pakkida ja kliendile saata?
Ehk näitaksid kus seda keegi väitnud on?
| Kuule kuule ega see pole 1 server. |
Kas iga mängija jaoks on oma masin? Ehk siis kui neil on korraga online 10% tollest 200M kliendist keda nad püüdma tahavad hakata siis on igaühe jaoks oma PC ehk siis kokku ~20M PC'st koosnev farm? Olen enam kui kindel, et nad üritavad ühte kasti kokku suruda >4 paralleelselt jooksutatava mängu, loomulikult siis ka vastavalt madalamale tõmmatud kvaliteedi-kiirusega.
| Ei tea miks nad siis räägivad ,et see läheb tööle kuigi tgl ei lähe... |
Googelda ja uuri välja mida tähendab vaporware.
See oleks sama hea:
Ütlen ,et see mäng on hea aga kui välja tuleb siis seda mängu pole olemas... |
Erm, proovi veidikenegi mõttega kirjutada.
5Mbps tugevalt alla HD kvaliteediga video streamimise kiirust.
Pingist veel rääkida, siis 12M elioni ühenduse taga ilma igasuguse võrguliikluseta on ping neti'sse 35ms.
| Seal peaks olema kõik 2006-2009 mängud juba nagu näha oli... |
Ehk tead öelda millised neist ka reaalselt mängitavad on? Ilusaid pildikesi oskab iga loll joonistada
87 |
prtv
24.03.2009 21:06:21
Mina aga märgin teema ära ning vaatan kuidas te siin kaklete.
Tahes tahtmata tuleb tõdeda, et vägagi hea idee aga, et kindel olla peab ise katsuma asja.
_________________ |
| Kommentaarid: 82 loe/lisa |
73 |
marco
24.03.2009 21:16:45
| Server clusters will be located in Santa Clara, Texas, Virginia and elsewhere, hoping to offer OnLive subscribers within 1,000 miles a seemingly lag-free experience. |
Ehk siis pole meil selle beetaga suvel miskit peale hakata. Kuigi isegi 1fps puhul tahaks seda imeasja näha.
_________________ Does "genuine" mean "with the real bugs"? |
| Kommentaarid: 9 loe/lisa |
9 |
blas
24.03.2009 21:35:50
64k ought to be enough RAM for anybody...ehk kui lähtuks ainult tänastest võimalustest ja oskustest siis homseid lahendusi ei tulekski
_________________ The truth is out there |
| Kommentaarid: 81 loe/lisa |
Mafia
24.03.2009 21:41:22
~6h pärast 7pm kohaliku ajajärgi hakkab pressikas. Gamespot kannab üle
Kellel aega, vaadake
17 |
