uus teema   vasta Tarkvara »  Arvutimängude foorum »  OnLive märgi kõik teemad loetuks
mine lehele 1, 2, 3 ... 13, 14, 15  järgmine
-Superman-
sõnum 24.03.2009 15:33:36 OnLive vasta tsitaadiga
Part 1
http://www.gametrailers.com/player/47079.html
Part 2
http://www.gametrailers.com/player/47081.html
You may never buy a new video card ever again. Actually, the only PC gaming hardware you might ever need will cost you less than a Wii, should OnLive's potential live up to its promise.
OnLive is a new video games on demand service that may just change the way you play PC games. The brainchild of Rearden Studios founder Steve Perlman, formerly of Atari, Apple, WebTV and more, and Mike McGarvey, formerly of Eidos, the technology looks to revolutionize the way computer games are brought home. Instead of spending hundreds or thousands of dollars on the latest video game hardware that will make games like Crysis playable at nearly maxed settings, let OnLive's servers handle the processing. All that's required is a low cost "micro console" or a low end PC and a broadband internet connection.
Yes, even your sub $500 netbook or MacBook can play processor intensive, GPU demanding PC games. In fact, that's the whole point. How does it work?
The concept is simple. Your controller input isn't going from your hand to the controller to the machine in front of you, it's going from your hand to the controller through the internet to OnLive's machines then back again as streamed video. Whether you're using a USB gamepad, Bluetooth wireless controller, or tried and true keyboard and mouse, the processing and output happens on OnLive's side, then is fed back to your terminal, with the game "perceptually" played locally.
In other words, it's cloud computed gaming.
Using patented video compression in tandem with algorithms that compensate for lag, jitter and packet loss, OnLive delivers video at up to 720p resolution at frame rates up to 60 frames per second. Of course, the quality of the video feed relies on your connection.
For standard definition television quality, a broadband connection of at least 1.5 megabits per second is required. For HDTV resolution, a connection of at least 5 mbps is needed.
What about lag, you say? OnLive's technology "incubator" Rearden Studios claims that its servers will deliver video feeds that have a ping of less than one millisecond. Its patented video compression technique is also advertised as blazing fast, with video compression taking about one millisecond to process.
That speedy delivery of video game content means more than just video games on demand, it means no install times. It also means cross-platform compatibility, the ability to try demos instantly, and an opportunity to rent or play games almost instantaneously.
It also means real-time streaming of video feeds from players far and wide playing their own games at home via OnLive which could ultimately mean broadcast style feeds to observers. Up to a million, according to OnLive reps.
The best part? It already has serious buy-in from major publishers, including EA, THQ, Codemasters, Ubisoft, Atari, Warner Bros., Take-Two, and Epic Games. Oh, and 2D Boy.
The appeal on the publisher side is that it essentially means less opportunity for profit-whittling piracy. There's little modification on the developer side to make a game run with OnLive. There's even an SDK available. On the consumer side, the prospect of no cheating—or at least heavily reduced cheating—is also desirable.
OnLive is showing 16 of the games planned for the service this week at GDC, some of them playable on low-spec machines, the kind of Dell your grandmother might buy.
Of course, they'll also be playable on OnLive's micro console, a simple, low-cost device that's about the size of your hand. It's simple tech—there's not even a GPU in the device. It simply acts as a video decoding control hub, with two USB inputs and support for four Bluetooth devices, and outputs audio and video via optical and HDMI connections. The micro console is expected to be priced competitively, "significantly less" than any current generation console on the market and potentially "free" with an OnLive service contract.
Plans for a monthly subscription are in the works, said to be priced on par with Xbox Live fees, offering the same community and multiplayer features popularized by Microsoft's gaming service. Perhaps the most interesting aspect of the unified OnLive community is the option to save and upload Brag Clips, a 15 second replay of, well, whatever just happened in-game.
We too were a little suspicious of OnLive's capability to deliver perceptually lag-free on-demand games. But then we played a hasty online game of Crysis Wars on the service today and became a little less suspicious. It seemed to work. Obviously, it was in a controlled environment with only a few hundred internal beta testers populating the system. But it worked.
Will it work in the wild? It might. OnLive is currently beta testing internally, with an external beta planned for Summer and a launch later this year. Expected to be deployed by launch will be five server centers hosting the latest and greatest games—OnLive isn't aiming to be GameTap, with no immediate plans to host archival PC games. Server clusters will be located in Santa Clara, Texas, Virginia and elsewhere, hoping to offer OnLive subscribers within 1,000 miles a seemingly lag-free experience.
We'll be testing the service later this week, letting you know what we thought.
Arvuti(tavaline) või telekas + Internet = Mängi mänge,ei pea installima ega downloadmima.Osta mäng ja mängi kohe.Crysis läheb vana arvutile peale jne...
BETA TULEB SUVEL
viimati muutis -Superman- 24.03.2009 16:21:25, muudetud 1 kord
Mafia
Mafia
sõnum 24.03.2009 15:38:35 vasta tsitaadiga
Huvitav asi, aga see eeldab head neti ma usun, aga ma ei usu et see asi väga läbi läheb, nvidia, intel, amd/ati ja teised gaming hardweri tootjad ei laseks seda läbi kui see ka töötaks nii nagu kirjeldatud icon_razz1.gif
Bawse
Kommentaarid: 19 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 17
-Superman-
sõnum 24.03.2009 15:41:42 vasta tsitaadiga
Mafia kirjutas:
Kui ei lähe väga läbi nvidia,intel,amd/ati jne siis ei ole uusi konsoole ka.
See tähendab ,et see OnLive > Kõik mängu konsoolid jne... + Microsoft windows for live = FAIL
Mafia
Mafia
sõnum 24.03.2009 15:46:59 vasta tsitaadiga
-Superman- kirjutas:
Mafia kirjutas:
No konsool konsooliks aga ütle miks ma peaks nt mingi crysise mängimiseks 20k gaming PC ostma kui ma saaks selel lahendusega mingi 4k eest kõiki tulevasi mänge mängida max setingutel, ja ei pea hardwei uuendama ?? Mis mõttega ma peaks siis mingeid i7 ja GFX300, 5870X2 jms asju ostma icon_biggrin.gif
Ei tahaks uskuda et see nii lihtne ja hea on nagu tundub, seal on mingid konksud taga kas või mingi kuumaks vms a noh elame näeme.
Bawse
O
O
sõnum 24.03.2009 15:48:46 vasta tsitaadiga
720p on arvuti peal mängides kergelt öeldes saast pilt ja isegi selle edastamiseks oleks vaja 5mbps sünkroonühendust, milline Eestis on vast paaril protsendil internetikasutajatest thumbs_down.gif
PS, kui teemades ei vasta
Kommentaarid: 76 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 69
Valdars
Valdars
sõnum 24.03.2009 15:48:48 vasta tsitaadiga
Konks on selles, et praegused võrgud ei ole võimelised sellist asja vedama.
Kommentaarid: 47 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 44
-Superman-
sõnum 24.03.2009 16:04:02 vasta tsitaadiga
Mafia kirjutas:
Mafia kirjutas:
Beta tuleb suvel.
Ainus hea asi mida sul läheb vaja on internet.
PC gaming dying?
Eks ootame ja näeme mis tuleb...
Valdars kirjutas:
Imelik.Mul on steam.Kui ma downloadin midagi siis kiirus on 7mb/s
On küll võimalik.
O kirjutas:
Ma tean jah aga kui PC-l on 720p sitt pilt aga konsoolil on 600p(Call of Duty 4 ja 5) ja pilt on norm.
Usu mind.See ei jää selliseks...
sõnum 24.03.2009 16:13:01 vasta tsitaadiga
nagu seda täna juba varem arutatud sai, siis sellisel kujul tolle OnLive teenuse töötamine suure kahtluse all. suurest lag-ist ei pääse mitte kuidagi mööda.
kes nüüd vastu soovib vaielda, siis enne tehke oma käsurida lahti (Start -> Run... -> cmd) ja kirjutage sinna näiteks "tracert www.google.com" ja tõmmake omad paralleelid. icon_smile.gif
seega praeguse seisuga ütleks, et tegu rohkem ümmarguse marketingijutu kui mitte vaporwarega.
Müüa: Xbox 360 E 500GB (UUS)
lawrey
lawrey
sõnum 24.03.2009 16:14:29 vasta tsitaadiga
O kirjutas:
Vaevalt, et sünkroonühendust vaja on. Saadad ju ainult kontrolleri käske. Muidugi jah, neti kiirusest olulisem on latentsus... USA's võib asi enam-vähem töötada, tespool maakera elajatel vast mitte nii väga.
Siit tegelikult hea äriidee, lepi tegijatega kokku ja pane Eestisse teenust pakkuv server üles icon_razz.gif
-bash: chpwn: command not found
-Superman-
sõnum 24.03.2009 16:19:33 vasta tsitaadiga
Skeptik kirjutas:
EI PÄÄSE MITTE KUNAGI MÖÖDA LAGIST?
Nad juba ütlesid ,et see töödab ja pole läägi.
See on tulevik !!!
Kunagi inimesed arvasid ,et autosi ei tule kunagi aga näe,nüüd on autod olemas...
Filmid aga näe nüüd on filmid olemas,mängud aga näe nüüd on mängud olemas,internet aga näe nüüd on internet olemas.
See kõik on tulevik.Alati tuleb midagi uut...
Valdars
Valdars
sõnum 24.03.2009 16:20:24 vasta tsitaadiga
Ei, tegemist on ikka serveri pool pildi renderdamisega ja selle tagasisaatmisega ja see on midagi muud, kui tavaline võrgumäng.
EDIT:
Neid sõnu ei ole mõtet niikaua tõsiselt võtta, kuni neil midagi reaalselt eksisteerivat ka näidata on.
viimati muutis Valdars 24.03.2009 16:22:34, muudetud 1 kord
sõnum 24.03.2009 16:20:48 vasta tsitaadiga
-Superman-
sõnum 24.03.2009 16:23:29 vasta tsitaadiga
Skeptik kirjutas:
Nad ütlesid ,et saavad ja BETA tuleb suvel.
Kui oleks lääg siis nad ei teeks seda....
FFS
Valdars kirjutas:
EDIT:
BETA tuleb suvel.Eks siis näeme kellel on õigus...
sõnum 24.03.2009 16:24:33 vasta tsitaadiga
-Superman-, lag on ja jääb. ega nad siis võrgusõlmedest mööda ei pääse. mõtle nüüd loogiliselt. icon_smile.gif
edit:
ja mis siis veel juhtub kui kõrvaltoas väikevend torrenti käima tõmbab? icon_lol.gif fps kukub 10 peale ja reso 2x väiksemaks?
viimati muutis SKG 24.03.2009 16:27:03, muudetud 1 kord
wicked
wicked
sõnum 24.03.2009 16:24:59 vasta tsitaadiga
-Superman-, sa usud kõiki müügimehi? Kes siis enne oma tootest kehvasti rääkinud on. Kohtvõrgus oleks see veel võimalik, demotakse nagunii samas võrgus asuvate serveritega.
Kommentaarid: 68 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 63
-Superman-
sõnum 24.03.2009 16:26:26 vasta tsitaadiga
wicked kirjutas:
No kuule OOTA SEE BETA ÄRA JA SIIS ÜTLE KAS ON HEA VÕI EI OLE.
OOTA JA OOTA JA SIIS NÄEME !!!
sõnum 24.03.2009 16:28:57 vasta tsitaadiga
polegi vaja oodata, juba praegu näha, mis sest tuleb kui vähegi võrgundusest midagi jagad. icon_smile.gif
Mario.
sõnum 24.03.2009 16:31:38 vasta tsitaadiga
Nunnu.. kuid liiga väike resolutsioon.
-Superman-
sõnum 24.03.2009 16:33:01 vasta tsitaadiga
MarioA. kirjutas:
Call of Duty 4 ja 5 on konsooli peal 600p resolutsioon ja see on 720p.
Ma tean jah ,et PC-l on 1080p aga TV-es on 720p päris hea kuna call of duty 4 on päris hea 600p peal
Mario.
sõnum 24.03.2009 16:42:39 vasta tsitaadiga
Ikkagi EI.. - muidugi aja pikku internet ja kiirused arenevad. Minu jaoks on 720p madal... Subjektiivne.
Spectate mode on kena pluss muidugi.
Palju xbox live maksab kuus?
piimaPAKK
piimaPAKK
sõnum 24.03.2009 16:49:03 vasta tsitaadiga
Skeptik kirjutas:
No mul neti.ee ping on 5ms siin.
Muidugi sa USA serverist oma mängu ei mängi aga Helsinki oleks tehtav imo.
sõnum 24.03.2009 16:55:04 vasta tsitaadiga
piimaPAKK kirjutas:
Skeptik kirjutas:
milline server lagivabalt HD video kokkupakib ja sinuni saadab? icon_smile.gif
mõtle nüüd. sa mängid mingit racing mängu. kiire kurviline tee. pidurdad, kiirendad, keerad iga suunas. need nupuvajutused peavad jõudma serverisse ja seal hakatakse alles videot kokkupakkima ning saadetakse sulle vastav pilt koju. ja kui seda kõike veel onlines teistega koos... no way, võibolla malet/kabet ehk. icon_smile.gif
viimati muutis SKG 24.03.2009 17:01:11, muudetud 2 korda
lightbluefox
sõnum 24.03.2009 16:58:18 vasta tsitaadiga
Paistab et OnLive promojad on ühe meie seast juba suutnud ära võrgutada icon_lol.gif
Mina arvan, et teretulnud lahendus, kui sa mängid harva, aga tahaks paljusid mänge proovida ja ei oma suurt rahkotti et pidevalt arvutit uuendada, on see hea valik.
Ma ei julgeks küll midagi lubada, et ta konsooli ja/või pc mängurlust tapma hakkab, aga müügile avaldab kindlasti mõju.
Harvale mängijale oleks siis see lahendus super, kutsud sõbrad külla, rendid õhtuks filmi asmele ühe ralli ja maksad mõned dollarid. Ei pea ostma selle mängu pärast konsooli ega võimast arvutit (millele tuleb mäng paigaldada ja seadistada).
Inim
Inim
sõnum 24.03.2009 17:11:45 vasta tsitaadiga
piimaPAKK
piimaPAKK
sõnum 24.03.2009 17:12:07 vasta tsitaadiga
Skeptik kirjutas:
Sellel pakkimis tehnoloogial arvatavasti nende kogu ärimudel baseerubki icon_rolleyes.gif
Ma ei ole muidugi ise katsetand seda teenust aga kui EA, Take-Two, Ubisoft, Epic, Atari, Codemasters, Warner Bros. ja Eidos
on ennast sinna kirja pannud, siis päris tühi mull see ka ei ole.
uus teema   vasta Tarkvara »  Arvutimängude foorum »  OnLive mine lehele 1, 2, 3 ... 13, 14, 15  järgmine
