uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  nVidia GT200 teema märgi kõik teemad loetuks
mine lehele 1, 2, 3 ... 109, 110, 111  järgmine
G80
G80
sõnum 21.05.2008 08:58:02 nVidia GT200 teema vasta tsitaadiga
GT200 die size measured at 576 mm2
The upcoming GeForce GTX 260/280 GPUs are based on the GT200 (NV60) core and will be built using a 65 nm manufacturing process at TSMC. However, we heard that not many chips will actually fit on a 300 mm wafer, since Nvidia has come up with a huge die measuring 24 x 24 mm, resulting in a die area size of 576 mm2. This area is almost 100 mm2 larger than Nvidia’s previous 90 nm high-end GPU (G80) and a consequence of 16 processing blocks (G80 came with nine blocks, eight were enabled for GTX models, six for GTS versions) and a new 512-bit memory controller, which replaces the old 384-bit model (the GTS260 will integrate a 448-bit version). The current G92 or GeForce 8800GT/8800GTS512/9800GTX/9800GX2 CPUs are built in a 65 nm process and end up at a die size of 330 mm2. With its new GPU generation, Nvidia is going to continue on the safe route and plan with enough spare transistors for 240 shader units (actually, 240FP+240MADD). The same will be the case with the GeForce GTX 280 and 260. The GPU will have 15 processing units (240 shader processors) available on the GTX280, while the GTX260 will come with 12 units for a grand total of 192 shader processors. Our sources state that the manufacturing cost of the GT200 die is somewhere between $100 to $110 per piece.
http://www.tgdaily.com/content/view/37554/135/
No DX10.1 for Nvidia GT200
Sellest on kahju.
http://www.dailytech.com/article.aspx?newsid=11842
Ära siia kliki
Kommentaarid: 256 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 210
heretic666
heretic666
sõnum 21.05.2008 09:01:28 vasta tsitaadiga
St et lähiajal pole ka Assassins Creedil seda patchi oodata, mis tooks 10.1 toe tagasi.
G80
G80
sõnum 21.05.2008 11:27:05 vasta tsitaadiga
GeForce GTX 280 die(IHS) pic leaked
http://en.expreview.com/2008/05/20/nvidia-geforce-gtx-280-spy-picssort-of/
Ära siia kliki
Cb4
Cb4
sõnum 21.05.2008 11:31:24 vasta tsitaadiga
G80 kirjutas:
Ma ei ole agressiivne juht, olen lihtsalt võistlushimuline.
Kommentaarid: 113 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 95
ufo56
ufo56
sõnum 21.05.2008 12:15:18 vasta tsitaadiga
 Lae pildid -> pilt.io
Firefly
Firefly
sõnum 21.05.2008 12:25:39 vasta tsitaadiga
G80, sinu uudis on kadunud, äkki leiad pildi oma arvuti temp kaustast üles ja jagad edasi?
Kommentaarid: 152 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 142
HDTanel
Overclocker
HDTanel
sõnum 21.05.2008 12:45:30 vasta tsitaadiga
G80 kirjutas:
Sellest on kahju.
Tegelt küsiks kas Dx9.0 ja Dx9.0c vahel oli suurt vahe? kottigi polnud. nVidia näeb lihtsalt, et pole mõtet seda lisada kuna parem lisada futures dx11 support ja kõik. Loogiline, sest isegi dx9 ja dx10 vahet pole eriti silmava võimalik eristada
Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel
One
sõnum 21.05.2008 13:57:46 vasta tsitaadiga
loota, et GTX 260 vms uijooba selle odavama nimi tegelikult on, mingi säästukaart tuleb
on puhas lollus..
G80
G80
sõnum 21.05.2008 14:20:03 vasta tsitaadiga
Firefly kirjutas:
Ära siia kliki
wrx123
sõnum 21.05.2008 16:00:55 vasta tsitaadiga
Keegi ligikaudse transistorite arvu viitsiks välja arvutada? 8)
-FoX-
-FoX-
sõnum 21.05.2008 17:05:32 vasta tsitaadiga
9800GX2 on 8pin pistik aga toitekal mul ainul 2 x 6pin. Kas miski üleminekut molexile vms ei ole 8pin to molex vms?
Aita suve, söö lund!
Kommentaarid: 367 loe/lisa Kasutajad arvavad:  :: 6 :: 3 :: 307
Firefly
Firefly
sõnum 21.05.2008 17:12:47 vasta tsitaadiga
jigsaw813 kirjutas:
Kaardiga on vajalikud üleminekud kaasas
sõnum 21.05.2008 17:26:45 vasta tsitaadiga
wrx123 kirjutas:
Pidavat olema 1 Miljardi kanti.
G80
G80
sõnum 21.05.2008 18:52:00 vasta tsitaadiga
jigsaw813 kirjutas:
Nii siin ei jää muud üle, kui kaart mulle anda, kuna mul olemas 8-pin otsaga toide. icon_biggrin.gif
Ma pakun 1,1-1,4miljardit. 8)
EDIT:
Palju ma mööda ei pannudki:
280 GTX ... mmmm sexy 8)
http://forums.vr-zone.com/showthread.php?t=278769
http://www.hardware-infos.com/news.php?news=2078
Ära siia kliki
Worm390
Worm390
sõnum 21.05.2008 19:11:22 vasta tsitaadiga
No kui need andmed tõesed siis see GTX280 on ikka julmemat sorti tulirelv...
Selle peaks endale ka sebima kui välja tuleb hetkese 8800GT asemel...
-FoX-
-FoX-
sõnum 21.05.2008 19:22:53 vasta tsitaadiga
CoiL
CoiL
sõnum 21.05.2008 19:25:32 vasta tsitaadiga
G80, sa pead nüüd vist varsti oma nime ära muutma! icon_lol.gif beer_yum.gif
Kommentaarid: 95 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 83
Cb4
Cb4
sõnum 21.05.2008 19:26:15 vasta tsitaadiga
jigsaw813 kirjutas:
Mul on sama mure icon_neutral.gif , nagu aru saan tuleb suurem kui 8800gtx,
Peltz
Peltz
sõnum 21.05.2008 19:30:48 vasta tsitaadiga
TO Jigsaw: EI, külmutustreiler on must buy.
Kas gameril on vaja kõrgemat resot kui praegused kaardid võimaldavad?
"Do you know what the 'Chain of Command' is? It's the chain i'm going to beat You with untill You understand who is in command!"
"And you have the right to say, No!"
viimati muutis Peltz 21.05.2008 19:31:19, muudetud 1 kord
G80
G80
sõnum 21.05.2008 19:31:39 vasta tsitaadiga
Cb4 kirjutas:
jigsaw813 kirjutas:
CorsairX kirjutas:
Ära siia kliki
ufo56
ufo56
sõnum 21.05.2008 19:32:29 vasta tsitaadiga
-FoX-
-FoX-
sõnum 21.05.2008 19:32:57 vasta tsitaadiga
Oled kindel ,et sama kui 8800GTX? Mina 9900GTX pilte ei leidnud:S Ja samas huvitav kas 9800GTX tuleb kiirem kui 9800GX2?icon_razz.gif
Cb4
Cb4
sõnum 21.05.2008 19:35:57 vasta tsitaadiga
[quote="G80"]
Cb4 kirjutas:
jigsaw813 kirjutas:
Mh, kuskil oli kirjas nagu et tuleb suurem, võibolla lugesin valesti!
G80
G80
sõnum 21.05.2008 19:36:01 vasta tsitaadiga
jigsaw813 kirjutas:
Oled kindel ,et sama kui 8800GTX? Mina 9900GTX pilte ei leidnud:S Ja samas huvitav kas 9800GTX(mõtlesid ikka GTX 280) tuleb kiirem kui 9800GX2?icon_razz.gif
Mina olen kindel, et on kiirem, just eriti suurtel resodel, kuna 9800GX2 sureb suurtel resodel koos AA-ga.
8800GTX is 10.5 inches long.
Ütleb meie hea sõber www.google.com
Ära siia kliki
viimati muutis G80 21.05.2008 19:38:17, muudetud 1 kord
Cb4
Cb4
sõnum 21.05.2008 19:37:53 vasta tsitaadiga
-FoX-
-FoX-
sõnum 21.05.2008 19:38:48 vasta tsitaadiga
Aga see 9800GX2 on tõesti 1GB mälu või on nagu ikka 2x512MB ja kasutab ka 512MB aga reklaamitakse kui 1GB?icon_razz.gif
Pekki ma hakkan raha koguma:P
G80
G80
sõnum 21.05.2008 19:40:03 vasta tsitaadiga
jigsaw813 kirjutas:
Jep reklaamitakse 1GB aga tegelt 512MB, kuna SLI-s ei liideta mälu.
Sellepärast surebki 9800GX2 crysises 1920x1020+ 4xAA jubedalt, isegi 8800GTX on tast kiirem siis, kuna tal 786MB mälu.
gtx280 pidavat ligi 2x suurema jõudlusega kui 9800gx2 olema
Mingi 40-50% healjuhul kiirem imo aga seegi on juba hea. 8)
Ära siia kliki
viimati muutis G80 21.05.2008 19:40:52, muudetud 1 kord
Cb4
Cb4
sõnum 21.05.2008 19:40:17 vasta tsitaadiga
jigsaw813 kirjutas:
Tubli,
mul juba kogutud icon_razz1.gif ,
tuleks kaart ainult kiiremini välja!!!
sõnum 21.05.2008 19:48:40 vasta tsitaadiga
G80 kirjutas:
triple
muide, gx2 ei tohiks mälupuudusesse surra crysisega. ja mida tähendab isegi gtx. palju neid suurema mäluga asju siis on? 1gb 8800gt ei näidanud igatahel mingeid asjalikke perfisuurenemisi reviewdes.
- londiste
viimati muutis londiste 21.05.2008 19:49:55, muudetud 1 kord
-FoX-
-FoX-
sõnum 21.05.2008 19:49:47 vasta tsitaadiga
Mis see kaart maksma võib hakata? 620w chieftecist või 600w fortron epsilonist peaks vist 1 kaarti jooksutamiseks piisav olema?icon_biggrin.gif Hetkel mul 9600GT SLI teeb ka head tööd ei hakka GX2 ostma aga see GTX280 oi pljaaaad thumbs_up.gif
Aah
Aah
sõnum 21.05.2008 19:53:46 vasta tsitaadiga
Kas Nvidia kavatseb millalgi 55nm peale ka üle minna?
sõnum 21.05.2008 19:54:53 vasta tsitaadiga
Ubisoft comments on Assassin's Creed DX10.1 controversy - UPDATED
http://techreport.com/discussions.x/14707
veel tolle dx10.1 kohta. kallutatud artikkel tundub olema aga inf on seal olemas.
- londiste
1dumbpcuser
sõnum 21.05.2008 20:04:42 vasta tsitaadiga
Kas GTX 260 on disabled/neutered 280?
M: MSI B660M MORTAR
O: AM5 ITX emaplaat
sõnum 21.05.2008 20:06:55 vasta tsitaadiga
y
- londiste
ufo56
ufo56
sõnum 21.05.2008 20:11:47 vasta tsitaadiga
Hind GTX 280 siis mingi 7-8k?
sõnum 21.05.2008 20:13:30 vasta tsitaadiga
ufo56 kirjutas:
Arvata on...
G80
G80
sõnum 21.05.2008 20:19:05 vasta tsitaadiga
londiste kirjutas:
G80 kirjutas:
triple
No aga millega sa siis põhjendad seda kole suurt perfi langust?Arvata on,et jääb mälu taha kinni.
Peaks olema jah.
Ära siia kliki
sirius4k
sirius4k
sõnum 21.05.2008 20:20:07 vasta tsitaadiga
On küll jah.. 260 on 280, millel mõned asjad kinni keeratud.
Kommentaarid: 56 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 55
sõnum 21.05.2008 20:24:47 vasta tsitaadiga
G80, mälusiin? takt?
- londiste
G80
G80
sõnum 21.05.2008 20:31:15 vasta tsitaadiga
londiste kirjutas:
No 9800GX2 ja 8800GTX takt on peaegu sama, isegi GX2 kasuks.
See juba ammu tõestatud, et crysis sööb meeletult mälu.
512MB jääb very high ja korraliku AA suurel resol muidugi väheseks. icon_wink.gif
Ära siia kliki
One
sõnum 21.05.2008 20:45:21 vasta tsitaadiga
tomorrow kirjutas:
ufo56 kirjutas:
Arvata on...
kui see tõesti selline killer tuleb nagu fännpoid unes näevad siis võid seda 7k küll unes näha icon_lol.gif
One
sõnum 21.05.2008 20:58:08 vasta tsitaadiga
see GT200 on umbes sama kui 9800GTX:
G80 kirjutas:
GeForce 9800 GTX (G100) Specs revealed
- Codenamed G100
- 65nm process
- 256 shader processors
- 780MHz core clock
- 3200MHz memory clock
- 512-bit memory width
- 2048MB (256X8) GDDR5 chips
- GDDR5 @ 0.25-0.5ns
- Dual DVI-out
- Supports DX 10.1, VP3
- 15-25% lower TDP than 8800GTS
http://forums.vr-zone.com/showthread.php?t=218890
http://bbs.chiphell.com/viewthread.php?tid=14253&extra=page%3D1
http://www.google.com/translate?u=http%3A%2F%2Fbbs.chiphell.com%2Fviewthread.php%3Ftid%3D14253%26extra%3Dpage%253D1&langpair=zh%7Cen&hl=en&ie=UTF8
Mälu läbilase on ikka julm...
Oleks tore,kui see on tõsi. 8) 8) 8)
SP arv ja core klokk ei ole ulmelised aga mälu on küll veits kahtlane.
- Dual DVI-out
omgwtf
omgwtf
sõnum 21.05.2008 21:07:42 vasta tsitaadiga
Vot! Neid spece ma otsisingi thumbs_up.gif Krt mulle kohe tundusid need specid mis hetkel siis sellest GeeTee200 kuidagi tuttavad doh.gif
1dumbpcuser
sõnum 21.05.2008 21:13:50 vasta tsitaadiga
Oot, kas nVidia hakkab tõesti DX10.1 toetama? Nad pidid ju selle IMO vahele jätma ja alles 11 kasutuselle võtma icon_rolleyes.gif
M: MSI B660M MORTAR
O: AM5 ITX emaplaat
Mercury
sõnum 21.05.2008 21:15:16 vasta tsitaadiga
Kommentaarid: 61 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 60
One
sõnum 21.05.2008 21:19:00 vasta tsitaadiga
postituse point oli selles, et igasugused "real specs" laadsed postitused on puhas bs.
ps see ei olnud veel kõige hullem specside post.
paljud arvasid, et 9800GTX tuleb juba 1+ miljardi transiga
-FoX-
-FoX-
sõnum 21.05.2008 21:51:47 vasta tsitaadiga
Palju see asi reaalselt voolu tahtma hakkab?icon_razz.gif Saab veel 620w chiefteciga hakkama?icon_smile.gif
Chidori
Chidori
sõnum 21.05.2008 21:51:49 vasta tsitaadiga
kuulge see teema siin on suht BS - arvestage, et nvidia ise väitis, et 9800GX2 tuleb the best gun in the west ja perf on tunduvalt parem kui teistel. Juba kipun arvama, et suurem lootus jääb ati uue seeria peale.
Kommentaarid: 115 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 99
-FoX-
-FoX-
sõnum 21.05.2008 21:53:20 vasta tsitaadiga
Millal siis ametlikult loota on esimesi tõeseid teste?
G80
G80
sõnum 21.05.2008 22:01:03 vasta tsitaadiga
Winterwind kirjutas:
G80 kirjutas:
- Codenamed G100
- 65nm process
- 780MHz core clock
- Dual DVI-out
- Dual DVI-out
- 256 shader processors - peaegu tõsi
- 780MHz core clock seda me veel näeme aga vaevalt ta nii kõrge tuleb.
- 512-bit memory width no see on sulatõsi.
- Dual DVI-out
tomorrow kirjutas:
ufo56 kirjutas:
Arvata on...
Eks ta sinna 8kilo kanti tule, esimene hind võib olla isegi 9 kilo lähedale.
Nagu juhtus 9800GX2 hinnaga, algul oli 9kilo kandis aga üle kuu aja pärast sai juba 6,7kiloga AK-st. 8)
Sellise püssi nagu GTX 280 7-8 kilo välja käia polegi ulme, kui ikka perfi on siis on õigalne diil.
Ära siia kliki
uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  nVidia GT200 teema mine lehele 1, 2, 3 ... 109, 110, 111  järgmine
