G80
21.05.2008 08:58:02
nVidia GT200 teema |
GT200 die size measured at 576 mm2
| The upcoming GeForce GTX 260/280 GPUs are based on the GT200 (NV60) core and will be built using a 65 nm manufacturing process at TSMC. However, we heard that not many chips will actually fit on a 300 mm wafer, since Nvidia has come up with a huge die measuring 24 x 24 mm, resulting in a die area size of 576 mm2. This area is almost 100 mm2 larger than Nvidias previous 90 nm high-end GPU (G80) and a consequence of 16 processing blocks (G80 came with nine blocks, eight were enabled for GTX models, six for GTS versions) and a new 512-bit memory controller, which replaces the old 384-bit model (the GTS260 will integrate a 448-bit version). The current G92 or GeForce 8800GT/8800GTS512/9800GTX/9800GX2 CPUs are built in a 65 nm process and end up at a die size of 330 mm2. With its new GPU generation, Nvidia is going to continue on the safe route and plan with enough spare transistors for 240 shader units (actually, 240FP+240MADD). The same will be the case with the GeForce GTX 280 and 260. The GPU will have 15 processing units (240 shader processors) available on the GTX280, while the GTX260 will come with 12 units for a grand total of 192 shader processors. Our sources state that the manufacturing cost of the GT200 die is somewhere between $100 to $110 per piece. |
http://www.tgdaily.com/content/view/37554/135/
No DX10.1 for Nvidia GT200
Sellest on kahju.
http://www.dailytech.com/article.aspx?newsid=11842
210 |
heretic666
21.05.2008 09:01:28
St et lähiajal pole ka Assassins Creedil seda patchi oodata, mis tooks 10.1 toe tagasi.
| Kommentaarid: 73 loe/lisa |
G80
210 |
Cb4
21.05.2008 11:31:24
| G80 kirjutas: |
GeForce GTX 280 die(IHS) pic leaked
Võimas.  |
Täpselt
_________________ Ma ei ole agressiivne juht, olen lihtsalt võistlushimuline.
Did i ever tell you the definition of "Insanity"? |
| Kommentaarid: 113 loe/lisa |
95 |
ufo56
| Kommentaarid: 79 loe/lisa |
67 |
Firefly
21.05.2008 12:25:39
| G80, sinu uudis on kadunud, äkki leiad pildi oma arvuti temp kaustast üles ja jagad edasi?
142 |
HDTanel
Overclocker
21.05.2008 12:45:30
| G80 kirjutas: |
Sellest on kahju.
http://www.dailytech.com/article.aspx?newsid=11842 |
Tegelt küsiks kas Dx9.0 ja Dx9.0c vahel oli suurt vahe? kottigi polnud. nVidia näeb lihtsalt, et pole mõtet seda lisada kuna parem lisada futures dx11 support ja kõik. Loogiline, sest isegi dx9 ja dx10 vahet pole eriti silmava võimalik eristada
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
496 |
One
21.05.2008 13:57:46
576mm2 on ikka räme lahmakas küll
loota, et GTX 260 vms uijooba selle odavama nimi tegelikult on, mingi säästukaart tuleb
on puhas lollus..
728 |
G80
210 |
wrx123
21.05.2008 16:00:55
| Keegi ligikaudse transistorite arvu viitsiks välja arvutada? 8)
| Kommentaarid: 17 loe/lisa |
16 |
-FoX-
21.05.2008 17:05:32
9800GX2 on 8pin pistik aga toitekal mul ainul 2 x 6pin. Kas miski üleminekut molexile vms ei ole 8pin to molex vms?
_________________ Aita suve, söö lund! |
| Kommentaarid: 367 loe/lisa |
6 :: |
307 |
Firefly
21.05.2008 17:12:47
| jigsaw813 kirjutas: |
| 9800GX2 on 8pin pistik aga toitekal mul ainul 2 x 6pin. Kas miski üleminekut molexile vms ei ole 8pin to molex vms? |
Kaardiga on vajalikud üleminekud kaasas
142 |
| Kommentaarid: 92 loe/lisa |
G80
210 |
Worm390
21.05.2008 19:11:22
No kui need andmed tõesed siis see GTX280 on ikka julmemat sorti tulirelv...
Selle peaks endale ka sebima kui välja tuleb hetkese 8800GT asemel...
| Kommentaarid: 20 loe/lisa |
20 |
-FoX-
21.05.2008 19:22:53
Kas see relv veel tavalisse korpusesse ka mahub?
6 :: |
307 |
CoiL
21.05.2008 19:25:32
G80, sa pead nüüd vist varsti oma nime ära muutma!
| Kommentaarid: 95 loe/lisa |
83 |
Cb4
21.05.2008 19:26:15
Kas see relv veel tavalisse korpusesse ka mahub?  |
Mul on sama mure , nagu aru saan tuleb suurem kui 8800gtx,
st, et lähen rellakaga kastile kallale vist
95 |
Peltz
21.05.2008 19:30:48
TO Jigsaw: EI, külmutustreiler on must buy.
Kas gameril on vaja kõrgemat resot kui praegused kaardid võimaldavad?
_________________ "Do you know what the 'Chain of Command' is? It's the chain i'm going to beat You with untill You understand who is in command!"
"And you have the right to say, No!"
viimati muutis Peltz 21.05.2008 19:31:19, muudetud 1 kord |
| Kommentaarid: 23 loe/lisa |
22 |
G80
21.05.2008 19:31:39
| Cb4 kirjutas: |
st, et lähen rellakaga kastile kallale vist  |
Sama pikk, kui 8800GTX ju.
| CorsairX kirjutas: |
G80, sa pead nüüd vist varsti oma nime ära muutma!  |
On see võimalik?
210 |
ufo56
67 |
-FoX-
21.05.2008 19:32:57
Oled kindel ,et sama kui 8800GTX? Mina 9900GTX pilte ei leidnud:S Ja samas huvitav kas 9800GTX tuleb kiirem kui 9800GX2?
6 :: |
307 |
Cb4
21.05.2008 19:35:57
[quote="G80"]
| Cb4 kirjutas: |
Mh, kuskil oli kirjas nagu et tuleb suurem, võibolla lugesin valesti!
jigsaw813 Sul nimedega veits pahasti
95 |
G80
21.05.2008 19:36:01
Oled kindel ,et sama kui 8800GTX? Mina 9900GTX pilte ei leidnud:S Ja samas huvitav kas 9800GTX(mõtlesid ikka GTX 280) tuleb kiirem kui 9800GX2? |
Mina olen kindel, et on kiirem, just eriti suurtel resodel, kuna 9800GX2 sureb suurtel resodel koos AA-ga.
GTX 280 sisuliselt ju ongi 9800GX2 ainult single tuum jne.
| 8800GTX is 10.5 inches long. |
Ütleb meie hea sõber www.google.com
Sama pikk tuleb ka GTX 280.
viimati muutis G80 21.05.2008 19:38:17, muudetud 1 kord |
210 |
Cb4
21.05.2008 19:37:53
gtx280 pidavat ligi 2x suurema jõudlusega kui 9800gx2 olema
See oleks vast pauk
95 |
