uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  nVidia GT200 teema märgi kõik teemad loetuks
mine lehele 1, 2, 3 ... 220, 221, 222  järgmine
G80
G80
sõnum 21.05.2008 07:58:02 nVidia GT200 teema vasta tsitaadiga
GT200 die size measured at 576 mm2
The upcoming GeForce GTX 260/280 GPUs are based on the GT200 (NV60) core and will be built using a 65 nm manufacturing process at TSMC. However, we heard that not many chips will actually fit on a 300 mm wafer, since Nvidia has come up with a huge die measuring 24 x 24 mm, resulting in a die area size of 576 mm2. This area is almost 100 mm2 larger than Nvidia’s previous 90 nm high-end GPU (G80) and a consequence of 16 processing blocks (G80 came with nine blocks, eight were enabled for GTX models, six for GTS versions) and a new 512-bit memory controller, which replaces the old 384-bit model (the GTS260 will integrate a 448-bit version). The current G92 or GeForce 8800GT/8800GTS512/9800GTX/9800GX2 CPUs are built in a 65 nm process and end up at a die size of 330 mm2. With its new GPU generation, Nvidia is going to continue on the safe route and plan with enough spare transistors for 240 shader units (actually, 240FP+240MADD). The same will be the case with the GeForce GTX 280 and 260. The GPU will have 15 processing units (240 shader processors) available on the GTX280, while the GTX260 will come with 12 units for a grand total of 192 shader processors. Our sources state that the manufacturing cost of the GT200 die is somewhere between $100 to $110 per piece.
http://www.tgdaily.com/content/view/37554/135/
No DX10.1 for Nvidia GT200
Sellest on kahju.
http://www.dailytech.com/article.aspx?newsid=11842
Ära siia kliki
Kommentaarid: 256 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 210
heretic666
heretic666
sõnum 21.05.2008 08:01:28 vasta tsitaadiga
St et lähiajal pole ka Assassins Creedil seda patchi oodata, mis tooks 10.1 toe tagasi.
G80
G80
sõnum 21.05.2008 10:27:05 vasta tsitaadiga
GeForce GTX 280 die(IHS) pic leaked
http://en.expreview.com/2008/05/20/nvidia-geforce-gtx-280-spy-picssort-of/
Ära siia kliki
Cb4
Cb4
sõnum 21.05.2008 10:31:24 vasta tsitaadiga
G80 kirjutas:
Ma ei ole agressiivne juht, olen lihtsalt võistlushimuline.
Kommentaarid: 113 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 95
ufo56
ufo56
sõnum 21.05.2008 11:15:18 vasta tsitaadiga
 Lae pildid -> pilt.io
Firefly
Firefly
sõnum 21.05.2008 11:25:39 vasta tsitaadiga
G80, sinu uudis on kadunud, äkki leiad pildi oma arvuti temp kaustast üles ja jagad edasi?
Kommentaarid: 151 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 141
HDTanel
Overclocker
HDTanel
sõnum 21.05.2008 11:45:30 vasta tsitaadiga
G80 kirjutas:
Sellest on kahju.
Tegelt küsiks kas Dx9.0 ja Dx9.0c vahel oli suurt vahe? kottigi polnud. nVidia näeb lihtsalt, et pole mõtet seda lisada kuna parem lisada futures dx11 support ja kõik. Loogiline, sest isegi dx9 ja dx10 vahet pole eriti silmava võimalik eristada
Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel
One
sõnum 21.05.2008 12:57:46 vasta tsitaadiga
loota, et GTX 260 vms uijooba selle odavama nimi tegelikult on, mingi säästukaart tuleb
on puhas lollus..
G80
G80
sõnum 21.05.2008 13:20:03 vasta tsitaadiga
Firefly kirjutas:
Ära siia kliki
wrx123
sõnum 21.05.2008 15:00:55 vasta tsitaadiga
Keegi ligikaudse transistorite arvu viitsiks välja arvutada? 8)
-FoX-
-FoX-
sõnum 21.05.2008 16:05:32 vasta tsitaadiga
9800GX2 on 8pin pistik aga toitekal mul ainul 2 x 6pin. Kas miski üleminekut molexile vms ei ole 8pin to molex vms?
Aita suve, söö lund!
Kommentaarid: 365 loe/lisa Kasutajad arvavad:  :: 6 :: 3 :: 306
Firefly
Firefly
sõnum 21.05.2008 16:12:47 vasta tsitaadiga
jigsaw813 kirjutas:
Kaardiga on vajalikud üleminekud kaasas
sõnum 21.05.2008 16:26:45 vasta tsitaadiga
wrx123 kirjutas:
Pidavat olema 1 Miljardi kanti.
G80
G80
sõnum 21.05.2008 17:52:00 vasta tsitaadiga
jigsaw813 kirjutas:
Nii siin ei jää muud üle, kui kaart mulle anda, kuna mul olemas 8-pin otsaga toide. icon_biggrin.gif
Ma pakun 1,1-1,4miljardit. 8)
EDIT:
Palju ma mööda ei pannudki:
280 GTX ... mmmm sexy 8)
http://forums.vr-zone.com/showthread.php?t=278769
http://www.hardware-infos.com/news.php?news=2078
Ära siia kliki
Worm390
Worm390
sõnum 21.05.2008 18:11:22 vasta tsitaadiga
No kui need andmed tõesed siis see GTX280 on ikka julmemat sorti tulirelv...
Selle peaks endale ka sebima kui välja tuleb hetkese 8800GT asemel...
-FoX-
-FoX-
sõnum 21.05.2008 18:22:53 vasta tsitaadiga
CoiL
CoiL
sõnum 21.05.2008 18:25:32 vasta tsitaadiga
G80, sa pead nüüd vist varsti oma nime ära muutma! icon_lol.gif beer_yum.gif
Kommentaarid: 95 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 83
Cb4
Cb4
sõnum 21.05.2008 18:26:15 vasta tsitaadiga
jigsaw813 kirjutas:
Mul on sama mure icon_neutral.gif , nagu aru saan tuleb suurem kui 8800gtx,
Peltz
Peltz
sõnum 21.05.2008 18:30:48 vasta tsitaadiga
TO Jigsaw: EI, külmutustreiler on must buy.
Kas gameril on vaja kõrgemat resot kui praegused kaardid võimaldavad?
"Do you know what the 'Chain of Command' is? It's the chain i'm going to beat You with untill You understand who is in command!"
"And you have the right to say, No!"
viimati muutis Peltz 21.05.2008 18:31:19, muudetud 1 kord
G80
G80
sõnum 21.05.2008 18:31:39 vasta tsitaadiga
Cb4 kirjutas:
jigsaw813 kirjutas:
CorsairX kirjutas:
Ära siia kliki
ufo56
ufo56
sõnum 21.05.2008 18:32:29 vasta tsitaadiga
-FoX-
-FoX-
sõnum 21.05.2008 18:32:57 vasta tsitaadiga
Oled kindel ,et sama kui 8800GTX? Mina 9900GTX pilte ei leidnud:S Ja samas huvitav kas 9800GTX tuleb kiirem kui 9800GX2?icon_razz.gif
Cb4
Cb4
sõnum 21.05.2008 18:35:57 vasta tsitaadiga
[quote="G80"]
Cb4 kirjutas:
jigsaw813 kirjutas:
Mh, kuskil oli kirjas nagu et tuleb suurem, võibolla lugesin valesti!
G80
G80
sõnum 21.05.2008 18:36:01 vasta tsitaadiga
jigsaw813 kirjutas:
Oled kindel ,et sama kui 8800GTX? Mina 9900GTX pilte ei leidnud:S Ja samas huvitav kas 9800GTX(mõtlesid ikka GTX 280) tuleb kiirem kui 9800GX2?icon_razz.gif
Mina olen kindel, et on kiirem, just eriti suurtel resodel, kuna 9800GX2 sureb suurtel resodel koos AA-ga.
8800GTX is 10.5 inches long.
Ütleb meie hea sõber www.google.com
Ära siia kliki
viimati muutis G80 21.05.2008 18:38:17, muudetud 1 kord
Cb4
Cb4
sõnum 21.05.2008 18:37:53 vasta tsitaadiga
uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  nVidia GT200 teema mine lehele 1, 2, 3 ... 220, 221, 222  järgmine
