uus teema   vasta Raud »  Protsessorid »  AMD K10 arutelu märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 9, 10, 11 ... 93, 94, 95  järgmine
erick
erick
sõnum 14.03.2008 11:47:20 vasta tsitaadiga
maatriks kirjutas:
Kuidas sellest "vahvlist" protsessorid saadakse? Ammu huvitanud, kuid otsida ei oska...
The circuitry of every chip on the wafter is tested before the chips are even cut apart. Once defective chips have been established, the wafter is cut apart. The defective chips are trashed and those that passed the first test are packaged into the CPU packaging we see every day. These chips are then tested one final time to assure that the packaging process went smoothly, and then they are shipped off to wholesalers, who sell to businesses, who sell to you. The voyage that silicon makes from the beaches of california into your computer is long, tedious, and expensive. Going from two purification stages to creating $3,000 wafers to extensive pathway etching boggles the mind. However, this article has given you a basic idea of how long of a process this is, and hopefully has finally answered the question everyone has asked; “Why are CPUs so expensive?”
Täielik protsess algsuest lõpuni on ära toodud siin.
One
sõnum 19.03.2008 19:41:50 vasta tsitaadiga
GNT-s Asus M3A78-EMH HDMI olemas.
heretic666
heretic666
sõnum 19.03.2008 19:47:05 vasta tsitaadiga
See mingi tillukesem variant ?
Siine kuidagi vähe ja sata pesad kuhugile nurka kokku surutud.
Denkeš
Denkeš
sõnum 19.03.2008 21:44:54 vasta tsitaadiga
nood 780G seeria plaadid vist kõik mATX-d?! Kahjuks pole asusesl ega gigabytel eraldi videomälu, mingitel tootjatel oli plaadile integreeritud 64mb videomälu.
a.k.a Ummikummi
Kommentaarid: 5 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 4
1dumbpcuser
sõnum 20.03.2008 12:55:05 vasta tsitaadiga
Denkeš kirjutas:
Tuleb ka ATX-mõõdus plaate:
Asus M3A78-EH HDMI ja M3A-H Prime HDMI, ECS A780GM-A, Jetway SY-AM78S, DFI LP DK780G-M2R, Sapphire PI-AM2RS780G
Integreeritud videomäluga on nii, et AMD poolt on asi toetatud, kuid tootjad pole sellistest variantidest teada andnud.
Ise kah muidu ootaks mõne täismõõdulise ATX mobo ära icon_wink.gif thumbs_up.gif
M: MSI B660M MORTAR
O: AM5 ITX emaplaat
sakinaga
sõnum 20.03.2008 13:16:38 vasta tsitaadiga
meedikakeskust just hea mATX-st teha ja sellele turule see 90% suunatud ju on.
Kommentaarid: 164 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 155
Jänes
sõnum 21.03.2008 00:37:29 vasta tsitaadiga
1dumbpcuser kirjutas:
Denkeš kirjutas:
Sideport memory-ga plaadid on olemas, ainult siiapoole neid ei tooda. Tuntud tootjatel see puudub.
http://www.ocworkbench.com/2008/J&W/J&W%20RS780UVD-AM2+/g3.htm
ASUS-el ja ESC-l on ATX plated olemas.
http://products.amd.com/en-us/MotherboardResult.aspx?f1=AMD+780G&f2=ATI+Radeon+Graphics&f3=&f4=&f5=&f6=True&f7=False&f8=&
1dumbpcuser
sõnum 21.03.2008 15:32:10 vasta tsitaadiga
Kas see Hybrid-Crossfire töötab ainult int. GPU+HD3450? Kas nt kahe HD3450 kaardi panemisel lakkab töötamast?
M: MSI B660M MORTAR
O: AM5 ITX emaplaat
WäntWõll
make.believe
WäntWõll
sõnum 21.03.2008 16:04:56 vasta tsitaadiga
Hübriid on mõeldud ainult integ. ja PCI-E graafika vahel valimiseks thumbs_up.gif
One
sõnum 21.03.2008 17:53:12 vasta tsitaadiga
wanawoll kirjutas:
ei, HD3450 töötab koos int videoga CrossFires ja saab sellest tulenevalt paremaid fps-e
WäntWõll
make.believe
WäntWõll
sõnum 21.03.2008 17:55:33 vasta tsitaadiga
Näetsa jälle targem
Draco
Draco
sõnum 24.03.2008 12:26:42 vasta tsitaadiga
On teada ka millal Phenom B3 turule jõuab ? (9550 näiteks)
Purgatory Judgement
Denkeš
Denkeš
sõnum 26.03.2008 19:14:52 vasta tsitaadiga
Draco kirjutas:
Eks ta siia arvatavasti aprill-mai jõua aga ega tal erilist vahet B2-ga pole.
Euroopas tänasest juba hinnakirjas: http://geizhals.at/eu/?fs=Phenom&x=53&y=13&in=
a.k.a Ummikummi
Aah
Aah
sõnum 26.03.2008 23:16:57 vasta tsitaadiga
Kas mingi mõte on seda Phenomit üldse osta?
Kristoferr
Kristoferr
sõnum 27.03.2008 01:58:08 vasta tsitaadiga
Aah kirjutas:
no saad suht odavalt endale neljatuumalise, mis enamasti hätta ei jää.
Kellamise võid ära unustada, aga muidu pole tal ju nii väga häda midagi.
Liitu Z.ai coding plaaniga ja saa 10% soodust!
Liitu Wise'ga!
Kommentaarid: 269 loe/lisa Kasutajad arvavad:  :: 4 :: 0 :: 220
its2cold
sõnum 27.03.2008 11:13:04 vasta tsitaadiga
AMD on nüüd terve plejaadi protsessoreid välja toonud thumbs_up.gif .
Üks test:
http://techreport.com/articles.x/14424
Kommentaarid: 198 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 175
G80
G80
sõnum 27.03.2008 15:08:45 vasta tsitaadiga
its2cold kirjutas:
Üks test:
Tuleks veel pingutada ja kui juba 3,6GHz kätte saaks siis oleks loom.
Aga see juhtub 45nm peal alles vist.
http://techreport.com/articles.x/14424/16
Ära siia kliki
Kommentaarid: 256 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 210
Kristoferr
Kristoferr
sõnum 27.03.2008 15:43:35 vasta tsitaadiga
Selle testi järgi tundub Phenom @ 2,6G olema suht võrdne Q6600´ga. Polegi nii halb. icon_smile.gif Kahju, et korralikult klokkuma ei saada.
PS. eelnevas postituses 3GHz OC saavutati mitte 1,3V pealt nagu CPUZ väidab vaid 1,48V ebastabiilselt ja 1,51V peal stabiilselt. icon_biggrin.gif
Testis oleks tahtnud näha Phenom X4 @ 3Ghz 3DM06 CPU skoori. Kahjuks ei näidatud. icon_neutral.gif Ilmselt kuhugi 4K kanti oleks see pidanud tulema. icon_rolleyes.gif
Iseenesest pole phenomil enam väga häda midagi. Veidike suurem voolutarve võrreldes uute QuadCore´ga pole eriliseks takistuseks Phenomi ostmisel. Peaasi, et Phenomi hind oleks mõnevõrra soodsam.
Protsessori suurema voolutarbe peaks korvama Phenomit toetavate emaplaatide väiksem voolutarve võrreldes s775 emaplaatidega icon_smile.gif
Kellel uue arvuti ost plaanis, soovitan mina küll tõsiselt AMD platformi peale mõelda ja anda omapoolne panus AMD finantsaugust väljaaitamiseks icon_biggrin.gif thumbs_up.gif beer_yum.gif
Liitu Wise'ga!
AJ
AJ
sõnum 28.03.2008 23:12:05 vasta tsitaadiga
its2cold kirjutas:
Üks test:
Veel paar testi
http://www.hothardware.com/Articles/AMD_Phenom_X4_9850_B3_Revision/
http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=3272
E: Veel ülevaateid
http://www.legitreviews.com/article/682/1/
http://www.sharkyextreme.com/hardware/cpu/article.php/3737046
http://www.xbitlabs.com/articles/cpu/display/phenom-x4-9850.html
http://www.firingsquad.com/hardware/amd_phenom_9850_black_edition_review/
mikk150
sõnum 29.03.2008 00:23:20 vasta tsitaadiga
mismoodi nad tahavad 140W TDP d maha jahutada?
varsti teevad vesijahutusega in-box prose XD
sakinaga
sõnum 29.03.2008 00:40:24 vasta tsitaadiga
mikk150 kirjutas:
Turbiiniga ofc, minilennukipropeller.
andrez3d
andrez3d
sõnum 29.03.2008 11:52:39 vasta tsitaadiga
Ei ole see 140W midagi nii hull. Endal on Athlon64 @2700 mhz ja full loadil peaks see 125W+ olema. Idles on temp ca 27 ja full loadil pole ma veel üle 50 kraadi kunagi näinud. Jahutiks AC 64 pro.
Kommentaarid: 97 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 91
sõnum 29.03.2008 18:05:06 vasta tsitaadiga
140w?
- londiste
heretic666
heretic666
sõnum 29.03.2008 20:05:31 vasta tsitaadiga
londiste, mis küsimust sa esitad ?
Denkeš
Denkeš
sõnum 29.03.2008 20:12:00 vasta tsitaadiga
tõenäoliselt 140 W TDP kohta, ma tahaks ka teada kus siin 140 w TDP-st juttu on, siiani peaks ikka 125 w TDP olema.
a.k.a Ummikummi
sõnum 29.03.2008 21:56:01 vasta tsitaadiga
täpselt, et kust see 140w järsku tuleb. kõiki reviewsid läbi lugeda ei viitsinud, tabelid hakkasid põhimõttelt korduma ja uutel prosedel on tp 125w.
tuletame meelde, et iirc on amd tdp siiani miski teise skaalaga kui inteli oma. ja näitab maksimaalset. ja 125w on nii amd fx prosede kui inteli extreme ja p4 prosede juures juba korduvalt läbikäinud etapp.
- londiste
Draco
Draco
sõnum 30.03.2008 20:28:04 vasta tsitaadiga
Oskab keegi targem rääkida millal neid neid B3 variante eesti lettidel saada on ?
Purgatory Judgement
mikk150
sõnum 31.03.2008 21:46:51 vasta tsitaadiga
Phenom X4 9950 2.6 GHz 2.0 GHz 140W TBA
Ivoshiee
sõnum 31.03.2008 21:52:58 vasta tsitaadiga
mikk150 kirjutas:
Mõistlisem leht oleks:
http://www.sharkyextreme.com/hardware/cpu/article.php/3261_3737046__10
Folding@home
FAH foorum
Kristoferr
Kristoferr
sõnum 02.04.2008 14:10:41 vasta tsitaadiga
Nõmedalt palju voolu võtab Idles, idle-loadi vahe on väike võrreldes Inteli isenditega. icon_mad.gif
Liitu Wise'ga!
Draco
Draco
sõnum 02.04.2008 16:28:29 vasta tsitaadiga
Kristoferr kirjutas:
http://www.fudzilla.com/index.php?option=com_content&task=view&id=6554&Itemid=40
Xenomorph
sõnum 06.04.2008 19:56:59 vasta tsitaadiga
Pmst oleks veidike infot vaja :=) mõtlesin oma am2 platele mingi phenom protsessori osta aga kas mõttekam pole suvel hoopis raha säästa ja siis talvel se uus am3 plate ja ddr3 mälud osta ? Olen lugenud , et need phenom 9500 ja 9600 prosed on "fail".
Kommentaarid: 30 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 29
Laurman
Laurman
sõnum 06.04.2008 20:03:43 vasta tsitaadiga
StaticX kirjutas:
Talvel tuleb AM3 välja? Aga jah Phenom kukkus suure hiilgusega läbi.
Präega vist kõige kasulikum võtta mõni Inteli platform.
Kommentaarid: 110 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 104
Aah
Aah
sõnum 06.04.2008 20:52:52 vasta tsitaadiga
Millal se Phenom 45nm välja tuleb? Kui sinna lisada 790 kiibiga mobo ja DDR3 , mis selleks ajaks on taskukohaseks muutunud, võib üritusest asja saada.
Ho Ho
Ho Ho
sõnum 06.04.2008 21:13:54 vasta tsitaadiga
Kui kannatad phenom 45nm ära oodata siis kannatad ka Nehalemi ära oodata. Suure tõenäosusega on vähemalt tippmudelid enam-vähem korraga selle aasta lõpu poole turul. Kui tõesti plaanid Intelit osta siis oleks hea ka sellega oodata kuna suure tõenäosusega Nehalem ühegi praeguse mobo peale ei istu. Selle koha pealt peaks vähemalt teoorias olema AM2+ suts tulevikukindlam valik.
Denkeš
Denkeš
sõnum 07.04.2008 22:48:46 vasta tsitaadiga
Kasulik ennem läbi lugeda kui tahate phenomit 780G plaadil kasutada: http://www.anandtech.com/mb/showdoc.aspx?i=3279&p=2
a.k.a Ummikummi
Xenomorph
sõnum 08.04.2008 12:27:43 vasta tsitaadiga
Põhimõtteliselt phenom x4 on praegune AMD tippmudel ? Kuna need lettidele jõuavad
Ho Ho
Ho Ho
sõnum 08.04.2008 12:45:38 vasta tsitaadiga
https://www.hinnavaatlus.ee/products/Arvutiriistvara/Protsessorid/?TypeID=3397
Iseasi kas neid B2 prosesid osta tasub
heretic666
heretic666
sõnum 08.04.2008 17:33:47 vasta tsitaadiga
2300 eegi eest quad masinasse pole sugugi paha, kuigi quad core support on teadagi tavainimesele, selle raha eest mingi püssim E8*** seeria võtta.
Jänes
sõnum 10.04.2008 23:13:48 vasta tsitaadiga
Keegi teab ka millal neid 4850E prosesid ka müügile on oodata? Ülevaadetes olid ju ammu, aga müügil veel ei ole.
WäntWõll
make.believe
WäntWõll
sõnum 11.04.2008 00:09:24 vasta tsitaadiga
link :: AMD Phenom X4 9850 Black Edition review
B3 hakkab vaikselt ilmet võtma,pole veel päris OC kunna aga noh arvestatdeds hinda siis päris kobe thumbs_up.gif
Draco
Draco
sõnum 11.04.2008 08:03:40 vasta tsitaadiga
wanawoll kirjutas:
Jääb arusaamatuks siiski kui kaugele see prose läheb olles 110% stabiilne icon_confused.gif
Sponge
Sponge
sõnum 11.04.2008 10:51:00 vasta tsitaadiga
XS-i lugedes tundub et need b3 black editionid töötavad enamus vaevata üle 3 GHz stabiilselt. isegi 3500 mhz juba kätte saadud icon_lol.gif beer_yum.gif aga asi seegi icon_idea.gif korralik areng vähemalt võrreldes eelmise reviga.
Kommentaarid: 398 loe/lisa Kasutajad arvavad:  :: 4 :: 4 :: 323
G80
G80
sõnum 12.04.2008 17:08:38 vasta tsitaadiga
AMD-l Shanghai 45nm Opteron ES väljas:
We don’t have the frequencies, we don’t have anything better than that it comes in second half of 2008 and that it needs 1.150V to run. It will be able to go over 3GHz, but we don’t know the exact speed.
http://www.fudzilla.com/index.php?option=com_content&task=view&id=6117&Itemid=1
Ära siia kliki
Ivoshiee
sõnum 12.04.2008 20:37:45 vasta tsitaadiga
Vaatan siin üht kataloogi ning nüüd on ka Eestis saada järgmised tükid:
HD9550WCGHBOX
HD9750XAGHBOX
Folding@home
FAH foorum
One
sõnum 23.04.2008 19:10:54 vasta tsitaadiga
Ivoshiee kirjutas:
HD9550WCGHBOX
HD9750XAGHBOX
quadide kohta on hinnad ikka päris head..
saaks nüüd selle voolutarbe ka normaalseks siis võiks juba täitsa mõelda
edit:
AMD 780G vs Intel G35
AMD has released marketing material comparing their integrated graphics chip with Intel.
The material shows the 780G operating in IGP only mode as well as Hybrid Crossfire mode with
real-time in-game videos.
Link
http://www.techpowerup.com/58135/AMD_780G_vs_Intel_G35.html
Irw, Inteli onboard on ikka ERITI masendav junn. Sellist saasta ostetakse icon_lol.gif
kuigi analoogne, maybe isegi sama video on siin vist juba liikunud..
edit:
Veel triplecore Phenomeid:
AMD Launches Three More Triple-core Phenom X3 Processors
http://forums.techpowerup.com/showthread.php?t=58519
Availability
AMD Phenom X3 processors are expected to be available from AMD’s leading channel providers.
AMD Phenom X3 8750 triple-core processor - (2.4GHz) - $195
AMD Phenom X3 8650 triple-core processor - (2.3GHz) - $165
AMD Phenom X3 8450 triple-core processor - (2.1GHz) - $145
For processor pricing details, please visit http://www.amd.com/pricing
Taavi©
Taavi©
sõnum 27.04.2008 10:21:05 vasta tsitaadiga
Inflatsioon on maksustamine ilma seadusandluseta
Kommentaarid: 377 loe/lisa Kasutajad arvavad:  :: 6 :: 1 :: 328
G80
G80
sõnum 27.04.2008 10:43:41 vasta tsitaadiga
Ära siia kliki
Ivoshiee
sõnum 28.04.2008 07:59:12 vasta tsitaadiga
X3 Phenom on ilmunud GNT nimekirja.
Folding@home
FAH foorum
Xenomorph
sõnum 28.04.2008 23:09:52 vasta tsitaadiga
Vaatasin netist , et minu emaplaat toetab ka x4 phenomeid aga netist leian ma x3 phenomid :/ Ja kas x2 pealt x4 peale tähendab seda , et arvuti muutub reaalselt ka kiiremaks või need lisa tuumad ei leia kasutust veel .
uus teema   vasta Raud »  Protsessorid »  AMD K10 arutelu mine lehele eelmine  1, 2, 3 ... 9, 10, 11 ... 93, 94, 95  järgmine
