uus teema   vasta Raud »  Protsessorid »  AMD K10 arutelu märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 19, 20, 21 ... 187, 188, 189  järgmine
erick
erick
sõnum 14.03.2008 10:47:20 vasta tsitaadiga
maatriks kirjutas:
Kuidas sellest "vahvlist" protsessorid saadakse? Ammu huvitanud, kuid otsida ei oska...
The circuitry of every chip on the wafter is tested before the chips are even cut apart. Once defective chips have been established, the wafter is cut apart. The defective chips are trashed and those that passed the first test are packaged into the CPU packaging we see every day. These chips are then tested one final time to assure that the packaging process went smoothly, and then they are shipped off to wholesalers, who sell to businesses, who sell to you. The voyage that silicon makes from the beaches of california into your computer is long, tedious, and expensive. Going from two purification stages to creating $3,000 wafers to extensive pathway etching boggles the mind. However, this article has given you a basic idea of how long of a process this is, and hopefully has finally answered the question everyone has asked; “Why are CPUs so expensive?”
Täielik protsess algsuest lõpuni on ära toodud siin.
One
sõnum 19.03.2008 18:41:50 vasta tsitaadiga
GNT-s Asus M3A78-EMH HDMI olemas.
heretic666
heretic666
sõnum 19.03.2008 18:47:05 vasta tsitaadiga
See mingi tillukesem variant ?
Siine kuidagi vähe ja sata pesad kuhugile nurka kokku surutud.
Denkeš
Denkeš
sõnum 19.03.2008 20:44:54 vasta tsitaadiga
nood 780G seeria plaadid vist kõik mATX-d?! Kahjuks pole asusesl ega gigabytel eraldi videomälu, mingitel tootjatel oli plaadile integreeritud 64mb videomälu.
a.k.a Ummikummi
Kommentaarid: 5 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 4
1dumbpcuser
sõnum 20.03.2008 11:55:05 vasta tsitaadiga
Denkeš kirjutas:
Tuleb ka ATX-mõõdus plaate:
Asus M3A78-EH HDMI ja M3A-H Prime HDMI, ECS A780GM-A, Jetway SY-AM78S, DFI LP DK780G-M2R, Sapphire PI-AM2RS780G
Integreeritud videomäluga on nii, et AMD poolt on asi toetatud, kuid tootjad pole sellistest variantidest teada andnud.
Ise kah muidu ootaks mõne täismõõdulise ATX mobo ära icon_wink.gif thumbs_up.gif
M:
Kommentaarid: 100 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 95
sakinaga
sõnum 20.03.2008 12:16:38 vasta tsitaadiga
meedikakeskust just hea mATX-st teha ja sellele turule see 90% suunatud ju on.
Kommentaarid: 159 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 151
Jänes
sõnum 20.03.2008 23:37:29 vasta tsitaadiga
1dumbpcuser kirjutas:
Denkeš kirjutas:
Sideport memory-ga plaadid on olemas, ainult siiapoole neid ei tooda. Tuntud tootjatel see puudub.
http://www.ocworkbench.com/2008/J&W/J&W%20RS780UVD-AM2+/g3.htm
ASUS-el ja ESC-l on ATX plated olemas.
http://products.amd.com/en-us/MotherboardResult.aspx?f1=AMD+780G&f2=ATI+Radeon+Graphics&f3=&f4=&f5=&f6=True&f7=False&f8=&
1dumbpcuser
sõnum 21.03.2008 14:32:10 vasta tsitaadiga
Kas see Hybrid-Crossfire töötab ainult int. GPU+HD3450? Kas nt kahe HD3450 kaardi panemisel lakkab töötamast?
M:
WäntWõll
make.believe
WäntWõll
sõnum 21.03.2008 15:04:56 vasta tsitaadiga
Hübriid on mõeldud ainult integ. ja PCI-E graafika vahel valimiseks thumbs_up.gif
One
sõnum 21.03.2008 16:53:12 vasta tsitaadiga
wanawoll kirjutas:
ei, HD3450 töötab koos int videoga CrossFires ja saab sellest tulenevalt paremaid fps-e
WäntWõll
make.believe
WäntWõll
sõnum 21.03.2008 16:55:33 vasta tsitaadiga
Näetsa jälle targem
Draco
Draco
sõnum 24.03.2008 11:26:42 vasta tsitaadiga
On teada ka millal Phenom B3 turule jõuab ? (9550 näiteks)
Purgatory Judgement
Denkeš
Denkeš
sõnum 26.03.2008 18:14:52 vasta tsitaadiga
Draco kirjutas:
Eks ta siia arvatavasti aprill-mai jõua aga ega tal erilist vahet B2-ga pole.
Euroopas tänasest juba hinnakirjas: http://geizhals.at/eu/?fs=Phenom&x=53&y=13&in=
a.k.a Ummikummi
Aah
Aah
sõnum 26.03.2008 22:16:57 vasta tsitaadiga
Kas mingi mõte on seda Phenomit üldse osta?
Kristoferr
Kristoferr
sõnum 27.03.2008 00:58:08 vasta tsitaadiga
Aah kirjutas:
no saad suht odavalt endale neljatuumalise, mis enamasti hätta ei jää.
Kellamise võid ära unustada, aga muidu pole tal ju nii väga häda midagi.
Liitu Binance'ga
Liitu Honey'ga
Kommentaarid: 264 loe/lisa Kasutajad arvavad:  :: 4 :: 0 :: 215
its2cold
sõnum 27.03.2008 10:13:04 vasta tsitaadiga
AMD on nüüd terve plejaadi protsessoreid välja toonud thumbs_up.gif .
Üks test:
http://techreport.com/articles.x/14424
Kommentaarid: 196 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 173
G80
G80
sõnum 27.03.2008 14:08:45 vasta tsitaadiga
its2cold kirjutas:
Üks test:
Tuleks veel pingutada ja kui juba 3,6GHz kätte saaks siis oleks loom.
Aga see juhtub 45nm peal alles vist.
http://techreport.com/articles.x/14424/16
Ära siia kliki
Kommentaarid: 256 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 210
Kristoferr
Kristoferr
sõnum 27.03.2008 14:43:35 vasta tsitaadiga
Selle testi järgi tundub Phenom @ 2,6G olema suht võrdne Q6600´ga. Polegi nii halb. icon_smile.gif Kahju, et korralikult klokkuma ei saada.
PS. eelnevas postituses 3GHz OC saavutati mitte 1,3V pealt nagu CPUZ väidab vaid 1,48V ebastabiilselt ja 1,51V peal stabiilselt. icon_biggrin.gif
Testis oleks tahtnud näha Phenom X4 @ 3Ghz 3DM06 CPU skoori. Kahjuks ei näidatud. icon_neutral.gif Ilmselt kuhugi 4K kanti oleks see pidanud tulema. icon_rolleyes.gif
Iseenesest pole phenomil enam väga häda midagi. Veidike suurem voolutarve võrreldes uute QuadCore´ga pole eriliseks takistuseks Phenomi ostmisel. Peaasi, et Phenomi hind oleks mõnevõrra soodsam.
Protsessori suurema voolutarbe peaks korvama Phenomit toetavate emaplaatide väiksem voolutarve võrreldes s775 emaplaatidega icon_smile.gif
Kellel uue arvuti ost plaanis, soovitan mina küll tõsiselt AMD platformi peale mõelda ja anda omapoolne panus AMD finantsaugust väljaaitamiseks icon_biggrin.gif thumbs_up.gif beer_yum.gif
Liitu Binance'ga
Liitu Honey'ga
AJ
AJ
sõnum 28.03.2008 22:12:05 vasta tsitaadiga
its2cold kirjutas:
Üks test:
Veel paar testi
http://www.hothardware.com/Articles/AMD_Phenom_X4_9850_B3_Revision/
http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=3272
E: Veel ülevaateid
http://www.legitreviews.com/article/682/1/
http://www.sharkyextreme.com/hardware/cpu/article.php/3737046
http://www.xbitlabs.com/articles/cpu/display/phenom-x4-9850.html
http://www.firingsquad.com/hardware/amd_phenom_9850_black_edition_review/
mikk150
sõnum 28.03.2008 23:23:20 vasta tsitaadiga
mismoodi nad tahavad 140W TDP d maha jahutada?
varsti teevad vesijahutusega in-box prose XD
sakinaga
sõnum 28.03.2008 23:40:24 vasta tsitaadiga
mikk150 kirjutas:
Turbiiniga ofc, minilennukipropeller.
andrez3d
andrez3d
sõnum 29.03.2008 10:52:39 vasta tsitaadiga
Ei ole see 140W midagi nii hull. Endal on Athlon64 @2700 mhz ja full loadil peaks see 125W+ olema. Idles on temp ca 27 ja full loadil pole ma veel üle 50 kraadi kunagi näinud. Jahutiks AC 64 pro.
Kommentaarid: 97 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 91
sõnum 29.03.2008 17:05:06 vasta tsitaadiga
140w?
- londiste
heretic666
heretic666
sõnum 29.03.2008 19:05:31 vasta tsitaadiga
londiste, mis küsimust sa esitad ?
Denkeš
Denkeš
sõnum 29.03.2008 19:12:00 vasta tsitaadiga
tõenäoliselt 140 W TDP kohta, ma tahaks ka teada kus siin 140 w TDP-st juttu on, siiani peaks ikka 125 w TDP olema.
a.k.a Ummikummi
uus teema   vasta Raud »  Protsessorid »  AMD K10 arutelu mine lehele eelmine  1, 2, 3 ... 19, 20, 21 ... 187, 188, 189  järgmine
