erick
14.03.2008 11:47:20
maatriks kirjutas: |
Kuidas sellest "vahvlist" protsessorid saadakse? Ammu huvitanud, kuid otsida ei oska... |
Naljakas et keegi pole sulle siiani vastust pakkunud
tsitaat: |
The circuitry of every chip on the wafter is tested before the chips are even cut apart. Once defective chips have been established, the wafter is cut apart. The defective chips are trashed and those that passed the first test are packaged into the CPU packaging we see every day. These chips are then tested one final time to assure that the packaging process went smoothly, and then they are shipped off to wholesalers, who sell to businesses, who sell to you. The voyage that silicon makes from the beaches of california into your computer is long, tedious, and expensive. Going from two purification stages to creating $3,000 wafers to extensive pathway etching boggles the mind. However, this article has given you a basic idea of how long of a process this is, and hopefully has finally answered the question everyone has asked; Why are CPUs so expensive? |
Täielik protsess algsuest lõpuni on ära toodud siin.
Kommentaarid: 105 loe/lisa |
95 |
One
19.03.2008 19:41:50
GNT-s Asus M3A78-EMH HDMI olemas.
Kommentaarid: 1009 loe/lisa |
728 |
heretic666
19.03.2008 19:47:05
See mingi tillukesem variant ?
Siine kuidagi vähe ja sata pesad kuhugile nurka kokku surutud.
Kommentaarid: 72 loe/lisa |
Denke
19.03.2008 21:44:54
nood 780G seeria plaadid vist kõik mATX-d?! Kahjuks pole asusesl ega gigabytel eraldi videomälu, mingitel tootjatel oli plaadile integreeritud 64mb videomälu.
Kommentaarid: 5 loe/lisa |
1dumbpcuser
20.03.2008 12:55:05
Denkeš kirjutas: |
nood 780G seeria plaadid vist kõik mATX-d?! Kahjuks pole asusesl ega gigabytel eraldi videomälu, mingitel tootjatel oli plaadile integreeritud 64mb videomälu. |
Tuleb ka ATX-mõõdus plaate:
Asus M3A78-EH HDMI ja M3A-H Prime HDMI, ECS A780GM-A, Jetway SY-AM78S, DFI LP DK780G-M2R, Sapphire PI-AM2RS780G
Integreeritud videomäluga on nii, et AMD poolt on asi toetatud, kuid tootjad pole sellistest variantidest teada andnud.
Ise kah muidu ootaks mõne täismõõdulise ATX mobo ära
_________________ O: Low-profile pci bracket |
Kommentaarid: 100 loe/lisa |
95 |
sakinaga
20.03.2008 13:16:38
meedikakeskust just hea mATX-st teha ja sellele turule see 90% suunatud ju on.
Kommentaarid: 159 loe/lisa |
151 |
Jänes
Kommentaarid: 6 loe/lisa |
1dumbpcuser
21.03.2008 15:32:10
Kas see Hybrid-Crossfire töötab ainult int. GPU+HD3450? Kas nt kahe HD3450 kaardi panemisel lakkab töötamast?
95 |
WäntWõll
make.believe
21.03.2008 16:04:56
1dumbpcuser kirjutas: |
Kas see Hybrid-Crossfire töötab ainult int. GPU+HD3450? Kas nt kahe HD3450 kaardi panemisel lakkab töötamast? |
Hübriid on mõeldud ainult integ. ja PCI-E graafika vahel valimiseks
Kommentaarid: 374 loe/lisa |
300 |
One
21.03.2008 17:53:12
wanawoll kirjutas: |
Hübriid on mõeldud ainult integ. ja PCI-E graafika vahel valimiseks  |
ei, HD3450 töötab koos int videoga CrossFires ja saab sellest tulenevalt paremaid fps-e
728 |
WäntWõll
make.believe
21.03.2008 17:55:33
AAAAAAAAa OK
Näetsa jälle targem
300 |
Draco
24.03.2008 12:26:42
On teada ka millal Phenom B3 turule jõuab ? (9550 näiteks)
_________________ Purgatory Judgement |
Kommentaarid: 12 loe/lisa |
12 |
Denke
26.03.2008 19:14:52
Draco kirjutas: |
On teada ka millal Phenom B3 turule jõuab ? (9550 näiteks) |
Eks ta siia arvatavasti aprill-mai jõua aga ega tal erilist vahet B2-ga pole.
Euroopas tänasest juba hinnakirjas: http://geizhals.at/eu/?fs=Phenom&x=53&y=13&in=
Aah
26.03.2008 23:16:57
Kas mingi mõte on seda Phenomit üldse osta?
Kommentaarid: 21 loe/lisa |
21 |
Kristoferr
27.03.2008 01:58:08
Aah kirjutas: |
Kas mingi mõte on seda Phenomit üldse osta? |
no saad suht odavalt endale neljatuumalise, mis enamasti hätta ei jää.
Kellamise võid ära unustada, aga muidu pole tal ju nii väga häda midagi.
_________________ Liitu Binance'ga
Liitu Honey'ga |
Kommentaarid: 257 loe/lisa |
209 |
its2cold
Kommentaarid: 196 loe/lisa |
173 |
G80
Kommentaarid: 256 loe/lisa |
210 |
Kristoferr
27.03.2008 15:43:35
Selle testi järgi tundub Phenom @ 2,6G olema suht võrdne Q6600´ga. Polegi nii halb. Kahju, et korralikult klokkuma ei saada.
PS. eelnevas postituses 3GHz OC saavutati mitte 1,3V pealt nagu CPUZ väidab vaid 1,48V ebastabiilselt ja 1,51V peal stabiilselt.
Testis oleks tahtnud näha Phenom X4 @ 3Ghz 3DM06 CPU skoori. Kahjuks ei näidatud. Ilmselt kuhugi 4K kanti oleks see pidanud tulema.
Iseenesest pole phenomil enam väga häda midagi. Veidike suurem voolutarve võrreldes uute QuadCore´ga pole eriliseks takistuseks Phenomi ostmisel. Peaasi, et Phenomi hind oleks mõnevõrra soodsam.
Protsessori suurema voolutarbe peaks korvama Phenomit toetavate emaplaatide väiksem voolutarve võrreldes s775 emaplaatidega
Kellel uue arvuti ost plaanis, soovitan mina küll tõsiselt AMD platformi peale mõelda ja anda omapoolne panus AMD finantsaugust väljaaitamiseks
Liitu Honey'ga |
209 |
AJ
Kommentaarid: 37 loe/lisa |
36 |
mikk150
29.03.2008 00:23:20
mismoodi nad tahavad 140W TDP d maha jahutada?
varsti teevad vesijahutusega in-box prose XD
Kommentaarid: 3 loe/lisa |
sakinaga
29.03.2008 00:40:24
mikk150 kirjutas: |
varsti teevad vesijahutusega in-box prose XD |
Turbiiniga ofc, minilennukipropeller.
151 |
andrez3d
29.03.2008 11:52:39
Ei ole see 140W midagi nii hull. Endal on Athlon64 @2700 mhz ja full loadil peaks see 125W+ olema. Idles on temp ca 27 ja full loadil pole ma veel üle 50 kraadi kunagi näinud. Jahutiks AC 64 pro.
Kommentaarid: 97 loe/lisa |
91 |
29.03.2008 18:05:06
140w?
_________________ - londiste
Kommentaarid: 241 loe/lisa |
215 |
heretic666
29.03.2008 20:05:31
londiste, mis küsimust sa esitad ?
Denke
29.03.2008 20:12:00
tõenäoliselt 140 W TDP kohta, ma tahaks ka teada kus siin 140 w TDP-st juttu on, siiani peaks ikka 125 w TDP olema.
