anubis
25.08.2017 07:28:28
| Pole väga vahet. Vaata vastavalt eelarvele kas kõige odavam või selline mis pikas plaanis mõistlik investeering.
283 |
jt234
25.08.2017 12:57:41
Tundub, et läheneb aeg emaplaadi vahetuseks. Hankisin nvme ketta ja SATA pesadest kohe puudus
_________________ Dima oli siin |
123 |
| Kommentaarid: 92 loe/lisa |
A-Circus.
25.08.2017 14:34:26
| Üks m.2 pesa peaks ju igal plaadil otse prosega PCI 3.0 X4 kaudu ühendatud olema, seega ühe m.2 NVMe ketta olemasolul ei tohiks ühtegi SATA porti kaotada.
| Kommentaarid: 50 loe/lisa |
48 |
jt234
25.08.2017 15:03:26
Tomorrow, Jah. 4 SATA + 2 SATA/nvme, aga on 4 ketast + nvme + cdrom
123 |
anubis
25.08.2017 15:27:09
| Siis X370 peale vaja liikuda - või siis asenda väiksemad HDDd ühe suuremaga.
283 |
jt234
25.08.2017 15:40:00
Ilmselt ASROCK X370 Gaming K4. Saab p-state oc ka ühes ära proovida.
123 |
anubis
26.08.2017 18:10:10
http://techreport.com/news/32459/amd-ships-revised-ryzen-cpus-with-a-compile-bug-fix
A little while ago, the Linux-headed sleuths over at Phoronix came across an obscure bug in Ryzen CPUs that triggered segmentation faults ("segfaults," which cause application crashes) in a compiler-specific workload. The bug was confirmed by AMD's engineers, who described it as a "performance marginality problem" and indicated that owners of affected CPUs could reach out to AMD Customer Care. The engineers also noted that Ryzen Threadripper and Epyc processors are unaffected. Phoronix's Michael Larabel took AMD up on its replacement offer and recently received a revised CPU that's apparently clear of the bug. |
| Ryzen CPUs manufactured before week 25 (mid-June) of 2017 appear to be the ones affected by the problem. The bug is reasonably difficult to trigger, but users that want to rest easy can reach out to AMD Customer Care and get a replacement part. |
Tea, kas peaks küsima, saaks vbolla märgatavalt parema kivi.
283 |
white
| Kommentaarid: 13 loe/lisa |
12 |
pots4t4j4
26.08.2017 18:28:25
Mis plastiknagad ? Need mustad plastikust junnid pead emaplaadi küljest ära võtma enne jahuti paigaldamist, need seal vist lihtsalt backplate kinni hoidmiseks?
E: paistab, et mingi porrlahenduste puhul on need mustad junnid just need, kuhu külge jahutuse pead kinnitama ?
viimati muutis pots4t4j4 26.08.2017 18:31:46, muudetud 2 korda |
401 |
white
26.08.2017 18:43:20
| See ei ole AM4 socket . Täpselt nii üritasingi panna aga see surve on meeletu kui peaksin latchi kinni suruma. St emaplaadi samgad liiga madalal.
12 |
pots4t4j4
26.08.2017 18:51:05
| Tee pilti sellest kui jahutus on prose peal aga mitte kinni pandud.
401 |
26.08.2017 18:56:22
Lol mäletan kunagi Socket 939 peal pidi samuti üsna suure survega heatsinki peale suruma kahe plastik osa peale. Ühe poole pidi enne kinnitama ja siis teise poole jõuga suruma clipi peale. Tegu oli ümmarguse Zalmani "flower" aftermarket jahutiga. Mäletan kah, et olin üsna mures emaplaadi kahjustamise pärast.
Samas kuldreegel on, et asjad peavad lihtsalt käima. Kui sa pead märgatavat jõudu kasutama, siis on midagi valesti ja asi ei pea nii käima või on tegu äärmiselt kehva kehva disainiga. Jahutiga tuleb kaasa ka juhis. Mida see ütleb?
_________________ Win11 25H2 upgrade skriptid neile kelle masin ise ei taha 23H2 või 24H2 pealt ennast uuendada:
https://foorum.hinnavaatlus.ee/viewtopic.php?p=11720738#11720738 |
anubis
26.08.2017 19:33:15
| Ega sul clip lukustusasendis pole? Kõlab nagu oleks..
283 |
mikk55
26.08.2017 22:59:38
mis värk nende 1150 (ja 1151) intel i5 ja i7 protsessoritega on, et need kasutatuna isegi vaat et rohkem kui uued RYZEN protsessorid maksavad?
_________________ Tegelen autovõtmete lisamisega (peamiselt BMW ja Mercedes) ja osade autode puhul ka plokkide kodeerimisega jne. |
| Kommentaarid: 53 loe/lisa |
51 |
anubis
26.08.2017 23:01:21
| Upgradejad ja frankensteinide ehitajad. Mängumasinatesse ju täiesti hea valik.
283 |
27.08.2017 08:33:52
| mikk55 kirjutas: |
| mis värk nende 1150 (ja 1151) intel i5 ja i7 protsessoritega on, et need kasutatuna isegi vaat et rohkem kui uued RYZEN protsessorid maksavad? |
Ilmselt single thread jõudlus loeb. Isegi teise põlvkonna Core i5 on kohati rohkem single thread jõudlust, kui Ryzenil. Samas eks see on ka see asi, et keegi ei taha neid poolmuidu ära anda. Kuigi hetkel i5 eest küll suurt mõtet enam maksta pole - ükskõik kas kasutatuna või uuena. i7 on iseasi.
anubis
283 |
28.08.2017 11:40:59
anubis, stabiilne mille osas? undervolt?
_________________ - londiste
216 |
siven
28.08.2017 11:44:26
| mikk55 kirjutas: |
niipalju kui ise uurisin ja tahtsin ka ryzeni peale kolida siis selgus kurb tõsiasi ,et i7 4790k on endiselt king mängudes....
lisaks saab seda nii räigelt ülekellata ,et tõmbab ka kõige uuemale ryzenile pika puuga...
samas ei jää i7 ka aeglaseks mingis videotöötluses või mis iganes nii ,et ei näe ryzeni vahetuse pointi absoluutselt:/
kahju muidugi lootsin ,et ryzen paneb pika puuga intelile ja saab lõpuks prose vahetada
149 |
anubis
28.08.2017 11:52:47
| londiste kirjutas: |
| anubis, stabiilne mille osas? undervolt? |
Jep, lisaks 4 pulka mälu 2133->2666
-0.1v vCore.
283 |
pots4t4j4
28.08.2017 11:53:25
| siven kirjutas: |
| mikk55 kirjutas: |
kahju muidugi lootsin ,et ryzen paneb pika puuga intelile ja saab lõpuks prose vahetada |
Kus see pika puuga on ? 4ghz peal jooksev ryzen 3200 mäluga on tihti suht samasse auku kui 7700K @ 5
401 |
siven
28.08.2017 11:57:40
| pots4t4j4 kirjutas: |
| siven kirjutas: |
| mikk55 kirjutas: |
Kus see pika puuga on ? 4ghz peal jooksev ryzen 3200 mäluga on tihti suht samasse auku kui 7700K @ 5 |
vb tõesti mingeid teste vaatasin ei tea ma mis mälude või asjadega jooksis... vaatasin just gaming benche ja stock peal sai kotti ryzen enamus mängudes juba.
mõnes mängus oli 5fps rohkem... aga kui i7 ära oc-da siis on kõikides mängudes üle...
vb nüüd siis midagi muutund ei viitsi uurida ja ei usu ka...
et mobo + prose välja vahetada eeldan vähemalt 10-15 fps boosti keskmiselt ,et üldse selle mõelda.
149 |
anubis
28.08.2017 12:30:06
Selleks pead videokaardi välja vahetama.
Paljutuumne protsessor võib aidata alumise otsa (st miinimum või nn. 0,1%/1% low fps) tõstmisel, seda on ka Ryzeniga märgata. Üldiselt on see eelis igapäevakasutuses paremini tuntav kui numbrites välja paistab.
(mängumootorid on jätkuvalt optimeeritud maksimaalselt 4c/8t jaoks, seega mingit hõbekuuli ei saa Ryzenist oodata, eriti kuna Inteli isendid on sama/parema IPC juures võimelised ~1Ghz kõrgemal sagedusel käima)
283 |
