uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  nVidia Volta (GV100) märgi kõik teemad loetuks
mine lehele 1, 2, 3 ... 9, 10, 11  järgmine
anubis
anubis
sõnum 11.05.2017 08:31:55 nVidia Volta (GV100) vasta tsitaadiga
link :: Nvidia
Võib vast Volta kohta oma teema teha nüüd?
https://www.techpowerup.com/gpudb/2957/tesla-v100
https://www.techpowerup.com/233187/nvidia-announces-its-volta-based-tesla-v100
V100 jätkab sealt kus P100 alustas, tegemist ei ole mängukaardiga. Selleks tuleb oodata GV102/GV104/GV106/GV108 isendeid.
This chip is a beast of a processor: it packs 21 billion transistors (up from 15,3 billion found on the P100); it's built on TSMC's 12 nm FF process (evolving from Pascal's 16 nm FF); and measures a staggering 815 mm² (from the P100's 610 mm².) This is such a considerable leap in die-area that we can only speculate on how yields will be for this monstrous chip, especially considering the novelty of the 12 nm process that it's going to leverage. But now, the most interesting details from a gaming perspective are the 5,120 CUDA cores powering the V100 out of a total possible 5,376 in the whole chip design, which NVIDIA will likely leave for their Titan Xv. These are divided in 84 Volta Streaming Multiprocessor Units with each carrying 64 CUDA cores (84 x 64 = 5,376, from which NVIDIA is cutting 4 Volta Streaming Multiprocessor Units for yields, most likely, which accounts for the announced 5,120.) Even in this cut-down configuration, we're looking at a staggering 42% higher pure CUDA core-count than the P100's. The new V100 will offer up to 15 FP 32 TFLOPS, and will still leverage a 16 GB HBM2 implementation delivering up to 900 GB/s bandwidth (up from the P100's 721 GB/s).
viimati muutis anubis 26.05.2017 13:51:05, muudetud 1 kord
Killhoven
OC`er
Killhoven
sõnum 11.05.2017 08:37:53 vasta tsitaadiga
Võiks teha jah. Kui ma õigesti kuulsin, siis eilsel Nvidia GPU Tehnoloogia konverentsil mainis Huang, et Volta baasil mängimiseks sobivad videokaardid pidid müüki jõudma juba Q4 2017.
Kommentaarid: 409 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 351
hempadonok
hempadonok
sõnum 11.05.2017 08:50:50 vasta tsitaadiga
Killhoven kirjutas:
Võiks teha jah. Kui ma õigesti kuulsin, siis eilsel Nvidia GPU Tehnoloogia konverentsil mainis Huang, et Volta baasil mängimiseks sobivad videokaardid pidid müüki jõudma juba see aasta Q4 2017.
Mälutootja jällegi väitis, et GDDR6 saabub kasutusse 2018 alguses
SK Hynix’s GDDR6 will power Nvidia’s Volta GPU, coming out next year.
Mis V100 puhul imestama paneb, et tuumade läbilase pole suurenenud P100-ga võrreldes
P100- 10.6 TF FP32 / 3584 cores = 2.957 GF per core.
V100- 15 TF FP32 / 5120 cores = 2.929 GF per core.
Hommik on õhtust kainem ...Aegopodium!
sõnum 11.05.2017 09:27:19 vasta tsitaadiga
Korralik beast ikka. 5K CUDA tuumasid ja 815mm² kiip icon_eek.gif . Huvitav kas see on arvestatud koos mälude ja interposeriga? Ma eeldan et on. Muidu need juurde panna siis on mingi 1000mm² icon_biggrin.gif
Iseasi millised siis consumer kaardid tulevad ja eelkõige millised saavad olema 12nm yieldid. 16nm-ga oli küll alguses suuri probleeme. GP102 kiipe suudeti piisavas koguses laiatarbe entusiast turu jaoks tootma hakata alles see aasta. Jah Pacal XP tuli küll 2016 August aga see polnuid esiteks full fat GP102 ja teiseks oli ülikallis. Ega GP100 yieldidki alguses midagi head polnud aga kuna nende müüdav kogus oli imeväike ja hind kolossaalne, siis see toimis. Samas vaadates nüüd Vega probleeme ei teagi palju sellest oli 16nm tootmisprotseei ja palju HBM2 süü GP100 puhul. Oli see ju esimene kaart üldse selle mäluga ja palju varem kui Vega.
Väheke spekulatsiooni kah:
GV100: 5,376 Cores, 815mm², 16/32GB 4096-bit HBM2 @ 500Mhz, 900GB/s, 15 Tflops+
GV102: 4,480 Cores, ~500mm², 16/24GB 384-bit GDDR6 @ 16Gbps, 768GB/s, 15 Tflops+
GV104: 3,584 Cores, ~375mm², 8/16GB 256-bit GDDR6 @ 14Gbps, 512GB/s, 12 Tflops+
GV106: 2,688 Cores, ~250mm², 4/8GB 256-bit GDDR6 @ 14Gbps, 512GB/s, 10 Tflops+
GV108: 1,792 Cores, ~150mm², 2/4GB 128-bit GDDR6 @ 12Gbps, 256GB/s, 7 Tflops+
See eeldab, et iga madalama klassi kaardil keeratakse üks SM klaster (896 tuuma) kinni. GV100-l on 6xSM klastrit ehk 6x896=5376
GV108-l oleks siis kaks aktiivset aga võib vabalt ka üks olla ainult sisse lülitatud. GDDR6 kiirused eeldan vahemikus 12-16Gbps ja mälumahud kõigil mudelitel kaks varianti. GV102 puhul siis Titan saab suurema 24GB mahu ja Ti väiksema 16GB mahu, kuna ajalooliselt on VRAM maht olnud nende eraldajaks.
Lõppu võtke paar teelusikatäit soola kah sisse aga mingi aimu peaks andma. Kellade ja voolutarbe osas ei tea nii täpselt, aga arvata võib, et need tulevad head, kui Tesla V100 jookseb @ 1455Mhz @ 150W koos 5120 tuumaga. potentsiaalselt näeme siis 100W GV104 @ 2,5Ghz ja 150W GV102 @ 2Ghz.
anubis
anubis
sõnum 11.05.2017 09:40:34 vasta tsitaadiga
GV100 tõenäoliselt ei tule müügile. Pole väga pointi.
"G" märge "GV" koodis tähendaks "Graphics" ehk Graphics Volta - videokaardina nVidia oma "100" kiipe ei müü. Nad optimeeritud teistsuguste rakenduste jaoks.
sõnum 11.05.2017 13:30:53 vasta tsitaadiga
anubis, See oli võrdluseks ilmselgelt.
EDIT: Minu eelmise aasta augustis tehtud post. Vaatame kas ja kui täppi läheb:
Tomorrow kirjutas:
kui vaadata tavalist jõudlusekasvu mis iga uue põlvkonnaga tuleb, siis võiks midagi sellist spekuleerida:
GTX 1160 = GTX 1080 jõudlus
GTX 1170 = GTX Titan X jõudlus
GTX 1180 = GTX 1080 SLI jõudlus
NATAS999
sõnum 15.05.2017 13:17:27 vasta tsitaadiga
nvidia on mu teada varemgi suure mõõtmelisi kive disainind. kas mitte fermi esialgne disain polnd mitte üle tehase max mõõtmete ja läks n.ö. back to the drawing board? icon_biggrin.gif
HDTanel
Overclocker
HDTanel
sõnum 17.05.2017 04:23:34 vasta tsitaadiga
Hämmingus täiesti kuidas nVidia lihtsalt treib ja treib uut tehnoloogiat välja ja AMD magab icon_neutral.gif Volta juba selle aasta keskel kusagil... September pakun... ulme.
Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel
Goon
Goon
sõnum 17.05.2017 06:49:36 vasta tsitaadiga
HDTanel kirjutas:
Oot sa ütled HV foorumis, et AMD polegi maailma parim ettevõte ve ja su posti polegi veel kustutatud? icon_eek.gif
Nvidial ja AMDl väga erinev firma poliitika. Nvidial on mitu kaarti arendust korraga arendamises, samas kui AMDl on 1 (vega) ja kui see lõpuks välja tuleb siis Nvidial on 2 kaarti millel on parem perfomance. Ja kui AMD hind tundub ostjatele parem, siis Nvidia laseb lihtsalt kaartide hindasid alla, millega see konkreetselt võistleb. Ma ei näe et AMD hakkaks enda asju teistmoodi tegema, et nad vist jäävadki tagaajaja rolli, mis on konkurentsi poolest halb. thumbs_down.gif
sõnum 17.05.2017 07:53:10 vasta tsitaadiga
Nvdia teeb juba softi poolega ära. Teine fakt on see, et nvidia on ikka nii suureks kasvanud nii et enam pole kohatu AMD vs Intel stiilis võrdlus st. lihtsalt nime pealt müüb juba.
Näiteks R9 290 oli kordades stabiilsem (0 softikala) kui RX480. Mõlemad realease hetkel ostetud custom kaardid.
sõnum 17.05.2017 11:25:15 vasta tsitaadiga
Goon kirjutas:
ei ole ju. poliitika on täpselt sama - mõlemal on järgmine arhitektuur tegemises (volta ja vega). tegelikult olid mõlemad ka sarnase probleemi ees kui järgmine arhitektuur hilines ja lahendusedki sarnased kuigi praktikas veidi erinevalt välja kukkunud - polaris ja pascal olid hilisemad lisandid roadmapile vaheastmeks enne järgmise tulekut.
- londiste
sõnum 18.05.2017 09:27:21 vasta tsitaadiga
Võimalik, et nvidial nüüd rohkem tuli takus, sest Google arendab enda AI kiipi. Ökom kui nvidia.
NATAS999
sõnum 18.05.2017 10:06:42 vasta tsitaadiga
Magic kirjutas:
sõnum 18.05.2017 10:12:35 vasta tsitaadiga
No eilsele börsi odavmüügile tundus see kena põhjendus olevat. Ise nii süvenenud pole, aga taust on see, et konkurents ilmselt kasvab.
hempadonok
hempadonok
sõnum 18.05.2017 10:19:31 vasta tsitaadiga
Magic kirjutas:
Google AI käib ikka läbi kvantarvuti(mida arendab D-Wave), see on hoopis erinev maailm
sõnum 18.05.2017 10:25:27 vasta tsitaadiga
Aga seni google kasutanud nvidia asju, seega ikka konkurents.
Goon
Goon
sõnum 18.05.2017 10:59:07 vasta tsitaadiga
veits offtopic aga kõik börsiturud olid öösel punases Trumpi skandaalide tõttu ja see tekitab ebakindlust. Kõige parem maasikas on muidugi see
Killhoven
OC`er
Killhoven
sõnum 18.05.2017 11:27:40 vasta tsitaadiga
ot:
hempadonok kirjutas:
Magic kirjutas:
Täpsuse huvides - kvantarvutit ei eksisteeri (veel) praegu peamiselt mittekoherentsuse probleemi tõttu.
sõnum 23.05.2017 09:03:40 vasta tsitaadiga
Väga vara kui see tõsi peaks olema icon_eek.gif . Huvitav on see, et see kasutab SLI connectorite asemel NVLINK connectoreid. Kas ka GV100 GPU ei tea. Igatahes 1x8pin + 1x6pin power.
anubis
anubis
sõnum 23.05.2017 09:17:34 vasta tsitaadiga
http://www.tweaktown.com/news/57672/nvidias-purported-volta-based-titan-xv-spotted/index.html
Link ka
Gap
Gap
sõnum 24.05.2017 19:21:08 vasta tsitaadiga
Huvitav oleks praegu näiteks teada kui palju kiirem on Volta näiteks maxwellist ? palju edasiminek on võrreldes pascali seeria kaartidega icon_rolleyes.gif arvan et esimesi mängimiseks mõeldud volta kaarte ei tule see aasta kindlasti .... sest et 1080Ti on vist praegu suht võimas kaart ja ei jää üheski mängus lahjaks...iseasi kas 4k-l veab kõik põhjas ? Volta võiks siis juba nii võimas olla et veaks ära 4k mänge ... Muidugi tahaks ka 4k monitori,aga need on nii kuradi kallid ikka veel minuarvates ... 1200-1400€ on ikka üle mõistuse thumbs_down.gif
WäntWõll
make.believe
WäntWõll
sõnum 24.05.2017 19:23:53 vasta tsitaadiga
icon_eek.gif mis monitor
Gap
Gap
sõnum 24.05.2017 19:26:55 vasta tsitaadiga
mismõttes mis ? no sa pole vaadanud mis hinnad on 4k monitoridel ?
sõnum 24.05.2017 20:08:51 vasta tsitaadiga
Gap kirjutas:
See 4K on suht overhyped imo. Tegu on lihtsalt kõrgema resoga. Sama efekti saab tekitada mängudes ka 1080p või 1440p peal kasutades DSR valikut. Rääkimata sellest, et 27" 4K on suht kirbukiri. Kasutatav 4K diagonaal algab seal 35" peal ja ülesse aga siis läheb monitor jälle liiga suureks.
Mina pigem soovitan 1080p 144Hz või 1440p 144Hz. Esiteks odavam (sõltuvalt paneelitüübist kuni 700 max) ja teiseks seal on 1080Ti või Volta (kindlasti) palju parem suutes 100fps+ kõik põhjas teha. 4K peal peab koguaeg muretsema, et alla 60 ei kukuks. Vb Volta muudab seda, aga see pole kerge 4K kõik põhjas üle 60 hoida (eriti nõudlikes mängudes).
Samas kui plaan uus monitor võtta, siis ehk veidi oodata ja vaadata mis HDR-st saab. Hetkel asi veel areneb aga on mitu standardit mis pole kunagi hea tulevikukindlus ja ühilduvuse mõttes.
Mis puutub Volta vs Pascal, siis kindlasti 1180 vms on jälle 20-25% kiirem, kui 1080Ti. 1180Ti sellest omakorda jälle 25% kiirem jne.
Kui Maxwelli pealt Volta peale lähed on kiirusetõus muidugi palju suurem olles seal 75-100% kandis sõltuvalt sellest mis kaart sul praegu on ja mis kaardi võtad.
WäntWõll
make.believe
WäntWõll
sõnum 25.05.2017 11:37:54 vasta tsitaadiga
Gap kirjutas:
Olen ikka, https://www.hinnavaatlus.ee/products/Arvutikomponendid/Monitorid/?search=a6a9b3e0c6a7e6b83f9d9b1851f2c8eb&Order=MinPrice&Sort=0
hinnad seal 400-700 vahemikus, kust see 500-700 lampi otsa tuleb ei tea.
sõnum 25.05.2017 13:06:47 vasta tsitaadiga
24" või 27" peal uhd on parasjagu mõttetu. 30+" tähendab 600st ülespoole.
sinna otsa siis va/ips ja kõrge sagedus ning freesync/gsync.
- londiste
WäntWõll
make.believe
WäntWõll
sõnum 25.05.2017 15:35:28 vasta tsitaadiga
Sõltub mängust FPS MP ja 27"+ on nagunii ise juba täis mõttetu tegevus.
sõnum 25.05.2017 15:44:03 vasta tsitaadiga
27" on täitsa hea, eeldusel, et tegu on mõistliku resoga. 30-32" ka.
43" ja 55" telekate peal olen ka proovinud, need on tõesti juba liiga suured - peab hakkama reaalselt pead pöörama.
muu kui twitch shooteri puhul on suuremad ekraanid kohutavalt efektsed ja ka mängimiseks täiesti head.
aga see läks offtopicuks. 1080ti on uhd@60hz, volta peab sealt kiirem tulema, siis on uhd@120/144hz monitoridel ja hea mõte sees.
- londiste
Auron
Auron
sõnum 25.05.2017 16:11:15 vasta tsitaadiga
Kõigepealt vaja niipaljugi perfi, et @1440p saaks selle 144 kaadri ligi konstantselt.
sõnum 25.05.2017 21:30:55 vasta tsitaadiga
Auron kirjutas:
Hakkas ennast huvitama see, kuna olen 1440p (küll 165Hz) ja GTX 1080 peal. Eeldan, et 1180 on 25% kiirem, kui 1080Ti ja 1180TI/Titan V sellest omakorda 25% kiirem. Lõppu panin ka hüpoteetilise nexgen kaardi (125% kiirem, kui 1080Ti icon_eek.gif . Pildil on ekslikult 100%)
1440p 1080Ti numbrid on võetud siit: https://www.techpowerup.com/reviews/Zotac/GeForce_GTX_1080_Ti_Amp_Extreme/
Dolph
sõnum 25.05.2017 23:34:14 vasta tsitaadiga
WäntWõll kirjutas:
ei ole. 32 tolli on väga ok
Kommentaarid: 16 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 14
HDTanel
Overclocker
HDTanel
sõnum 26.05.2017 03:15:46 vasta tsitaadiga
Ma saan varsti siin 43" Philipsi 4k monitori testimiseks.. 40" praegu siin kõrval ja see on 4k jaoks nagu suht ideaalne. Teleritel jah 65" 4k on selline ideaalne aga krdima teleritel ikka häirib räigelt vahest see 30ms reageerimis aeg, mis on ikka üsna kohutav.. peab krt ära rääkima mõne teleri tootjaga, et low response time teleri teeks icon_biggrin.gif
Keegi teab üldse, mis keelab teleritel madala response time?
Krüpto
Soundwave
Soundwave
sõnum 26.05.2017 17:44:19 vasta tsitaadiga
Uuri siit http://www.rtings.com
sõnum 29.05.2017 11:24:38 vasta tsitaadiga
http://wccftech.com/nvidia-rumored-debut-new-volta-graphics-card-computex-tomorrow-watch-live-keynote/
Ei tundu nagu väga usutav, aga igasugustele Vega lootustele paneks see küll põntsu, kui nvidia suudaks juba pool aastat enne main Volta lauchi Titani väljastada icon_eek.gif
Tegelikult see oleks ka loogiline, et early adopteritele seda pakutaks. Arvatavasti ainult läbi Nvidia enda poe ja default FE jahutusega. Nagu Titan X eelmise aasta augustis.
Hind? Noh arvestades ilmselt 16GB HBM2, siis pakun poolteist neeru näiteks icon_biggrin.gif
Nali naljaks. Arvatavasti 2000$ kanti kui nvidia päris hulluks ei lähe.
anubis
anubis
sõnum 29.05.2017 11:54:02 vasta tsitaadiga
Nvidia launchib pigem ikka GV102'e.
815mm2 + 16GB HBM2 kivi ei maksaks kohe kindlasti mitte $2000, pigem topelt seda.
Lisaks suunitlus teine GV/V100'l.
sõnum 29.05.2017 12:23:30 vasta tsitaadiga
Ma oleks väga üllatunud, kui GV102 juba tootmisküps on. Lisaks peab see tulema kas GDDR5X mäludega või HBM2-ga, kuna GDDR6 pole veel tootmisküps. Samas teades nvidiat võib see keynote ka mingi deep learning jms asi olla jälle icon_biggrin.gif
Dolph
sõnum 30.05.2017 22:43:25 vasta tsitaadiga
No nii, Nvidia on Comptexil ära esinenud ja Volta mängukiipidest pole haisugi.
Gap
Gap
sõnum 16.06.2017 18:32:50 vasta tsitaadiga
http://www.guru3d.com/news-story/upcoming-geforce-gtx-cards-use-gddr5x-not-hbm2.html
As it stands now, opcoming consumer GeForce cards based on Volta will not use HBM2.
Auron
Auron
sõnum 16.06.2017 19:05:45 vasta tsitaadiga
Gap kirjutas:
Tundub nagu nVidia üritab GDDRX mälu kasutades oma uut generatsiooni liigutada kiiremini ja suuremas mahus turule.
sooty
sõnum 16.06.2017 22:30:04 vasta tsitaadiga
Kas volta performansit ka juba lekitatud on? Panin 1070 kasti ja päris nobe teine.
Dj-E
Aeg Maha 2a
sõnum 17.06.2017 01:35:21 vasta tsitaadiga
Tomorrow kirjutas:
Ah mine kuupeale oma DSR-ga. See on võlts värk ja ei ole võrreldav sellega kui sul on ekraanil rohkem päris piksleid. DSR-ga sa ei saa elusees sarnast kvaliteeti nagu 4K monitor/tv suudab pakkuda. Ilmselgelt sa pole ühtegi mängu päris 4K-s mänginud, et siin sellist soga ajad. icon_confused.gif
HDTanel
Overclocker
HDTanel
sõnum 17.06.2017 10:17:59 vasta tsitaadiga
Gap kirjutas:
Keda see HBM2 kotib ausalt... mida ta nüüd mängudes niiväga juurde annaks anyway?
Veidi üle hypetud. Tore on, et tuleb aga see pole põhiline, mis kaardi kiireks teeks. GDDR5X tundub ülimalt norm olema senimaani.
Krüpto
sõnum 17.06.2017 11:39:26 vasta tsitaadiga
Dj-E kirjutas:
Tomorrow kirjutas:
Üsna võrreldav. Screenshot teha, siis see on 3840x2160 nagu olema peab. Mäng on ka silmnähtavamalt teravam, kui 1080p. Seega kuigi ekraan suudab ikka kuvada samaaegselt 1080 pikslit näeb mäng ikkagi tunduvalt teravam välja.
Nüüd tule mulle rääkima kuidas DSR-ga 4K desktop pole see sama desktop mis native 4K icon_lol.gif
Ma saaks aru, et jutt käib checkerboardingust või upscalingust siis ma oleks nõus, et pole 4K. DSR on downscaling mis on vähe teine asi.
Iseasi on smoothing filter mida DSR kasutab (vaikimisi 33%) aga selle saab välja lülida.
Dj-E
Aeg Maha 2a
sõnum 17.06.2017 11:56:29 vasta tsitaadiga
Tomorrow kirjutas:
Dj-E kirjutas:
Tomorrow kirjutas:
Teiseks. Kui sul on FHD monitor ütleme näiteks 32" siis sellel on piksleid 2 073 600. Ja kui võtta 32" UHD monitor millel on piksleid 8 294 400 siis kasuta oma aju ja mõtle ise kumma pilt on teravam? Ei näita see DSR-i esmane upscale ja pärastine downscale kah sellele FHD monitoril samaväärset pilti kuna FHD monitoril on juba pikslid 4 korda suuremad kui UHD monitoril. Juba füüsiliselt ei saa FH monitoril olla sama ilus pilt. Olen nõus sellega, et DSR parandab veidi pildi kvaliteeti aga seda ei saa iialgi võrrelda native UHD/4K resoga.
sõnum 17.06.2017 12:07:02 vasta tsitaadiga
Dj-E, UHD vs 4K icon_rolleyes.gif . Pmst keegi ei kasutagi true 4K (4096x2160). Kõik nimetavad 3840x2160 4K mitte UHD.
Ok tunnistan, et pole sama hea pilt DSR-ga. Let's leave it at that. Teema on ikkagi Volta.
Mis puutub sellese uudisesse, siis see on BS. Mitte GDDR5X-ga ei tule vaid GDDR6-ga. Vähemalt enamus Volta kaarte. Vb low end variandid tulevad ka G5X-ga.
anubis
anubis
sõnum 20.06.2017 18:37:44 vasta tsitaadiga
http://www.anandtech.com/show/11559/nvidia-formally-announces-pcie-tesla-v100-available-later-this-year
[..]“expected to be available later this year from NVIDIA reseller partner and manufacturers”[..]
Vastasseis saab siis olema:
Vega FE - FP16@26TF / FP32@13TF
V100 - FP16@28TF / FP32@14TF
FP64 pole mingit vastasseisu, kuna VegaFE on 1/16 ehk 750GF vs v100 7TF.
dohc-48v12
Aeg maha 1p
dohc-48v12
sõnum 21.06.2017 16:32:50 vasta tsitaadiga
HDTanel kirjutas:
Gap kirjutas:
Noo on ika vahe küll. kas sa sõidad skoda fabia-ga või nissan gtr-ga ! Jah tavaolukorras tänaval seal vahet pole tõesti, kuna kiirusepiirangud igal pool, aga ringrajal sa tead ise mis olukord on.
Ei tea, palju tõele vastab aga:
The first graphics cards to use SK Hynix's GDDR6 RAM are expected to use 12 GB of RAM with a 384-bit memory bus, yielding a bandwidth of 768GB/s
Miks ADMIN Anti112 ambusib mind? andis 1p cooldowni aga ma ei saa peale selle enam mitteühtegi postitust teha! üks päev ei kuid!
Kommentaarid: 112 loe/lisa Kasutajad arvavad:  :: 6 :: 0 :: 85
sõnum 21.06.2017 16:40:42 vasta tsitaadiga
hbm2 kui selline ei ole väärtus iseeneses. tuleb vaadata, millist kasu kasutatud lahendusest saab, ja millised varjuküljed sel on.
- londiste
NATAS999
sõnum 22.06.2017 09:17:32 vasta tsitaadiga
dohc-48v12, on ikka vahe kas gtr või fabia tavaolukorras linnatänaval. linnatänaval tavaolukorras näitab fabia gtr'le tagutulesid ja gtr jääb meie tänavatel kõhu peale kinni.
Scart
Scart
sõnum 22.06.2017 10:07:22 vasta tsitaadiga
See vaidlus ei vii kuhugi. GDDR5x ja GDDR6 on reaalses elus sama efektiivsusega nagu HBM2.
uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  nVidia Volta (GV100) mine lehele 1, 2, 3 ... 9, 10, 11  järgmine
