anubis
11.05.2017 08:31:55
nVidia Volta (GV100) |
link :: Nvidia
Võib vast Volta kohta oma teema teha nüüd?
https://www.techpowerup.com/gpudb/2957/tesla-v100
https://www.techpowerup.com/233187/nvidia-announces-its-volta-based-tesla-v100
V100 jätkab sealt kus P100 alustas, tegemist ei ole mängukaardiga. Selleks tuleb oodata GV102/GV104/GV106/GV108 isendeid.
tsitaat: |
This chip is a beast of a processor: it packs 21 billion transistors (up from 15,3 billion found on the P100); it's built on TSMC's 12 nm FF process (evolving from Pascal's 16 nm FF); and measures a staggering 815 mm² (from the P100's 610 mm².) This is such a considerable leap in die-area that we can only speculate on how yields will be for this monstrous chip, especially considering the novelty of the 12 nm process that it's going to leverage. But now, the most interesting details from a gaming perspective are the 5,120 CUDA cores powering the V100 out of a total possible 5,376 in the whole chip design, which NVIDIA will likely leave for their Titan Xv. These are divided in 84 Volta Streaming Multiprocessor Units with each carrying 64 CUDA cores (84 x 64 = 5,376, from which NVIDIA is cutting 4 Volta Streaming Multiprocessor Units for yields, most likely, which accounts for the announced 5,120.) Even in this cut-down configuration, we're looking at a staggering 42% higher pure CUDA core-count than the P100's. The new V100 will offer up to 15 FP 32 TFLOPS, and will still leverage a 16 GB HBM2 implementation delivering up to 900 GB/s bandwidth (up from the P100's 721 GB/s). |
viimati muutis anubis 26.05.2017 13:51:05, muudetud 1 kord |
Kommentaarid: 326 loe/lisa |
277 |
Killhoven
OC`er
11.05.2017 08:37:53
Võiks teha jah. Kui ma õigesti kuulsin, siis eilsel Nvidia GPU Tehnoloogia konverentsil mainis Huang, et Volta baasil mängimiseks sobivad videokaardid pidid müüki jõudma juba Q4 2017.
_________________ Foorumis on ühe lolli kohta kümme tarka, nii et jõud on enam-vähem võrdsed.™ |
Kommentaarid: 400 loe/lisa |
346 |
hempadonok
11.05.2017 08:50:50
Killhoven kirjutas: |
Võiks teha jah. Kui ma õigesti kuulsin, siis eilsel Nvidia GPU Tehnoloogia konverentsil mainis Huang, et Volta baasil mängimiseks sobivad videokaardid pidid müüki jõudma juba see aasta Q4 2017. |
Mälutootja jällegi väitis, et GDDR6 saabub kasutusse 2018 alguses
tsitaat: |
SK Hynix’s GDDR6 will power Nvidia’s Volta GPU, coming out next year. |
Mis V100 puhul imestama paneb, et tuumade läbilase pole suurenenud P100-ga võrreldes
tsitaat: |
P100- 10.6 TF FP32 / 3584 cores = 2.957 GF per core.
V100- 15 TF FP32 / 5120 cores = 2.929 GF per core. |
_________________ ★Hommik on õhtust kainem ...Aegopodium! |
Kommentaarid: 11 loe/lisa |
11.05.2017 09:27:19
Korralik beast ikka. 5K CUDA tuumasid ja 815mm² kiip . Huvitav kas see on arvestatud koos mälude ja interposeriga? Ma eeldan et on. Muidu need juurde panna siis on mingi 1000mm²
Iseasi millised siis consumer kaardid tulevad ja eelkõige millised saavad olema 12nm yieldid. 16nm-ga oli küll alguses suuri probleeme. GP102 kiipe suudeti piisavas koguses laiatarbe entusiast turu jaoks tootma hakata alles see aasta. Jah Pacal XP tuli küll 2016 August aga see polnuid esiteks full fat GP102 ja teiseks oli ülikallis. Ega GP100 yieldidki alguses midagi head polnud aga kuna nende müüdav kogus oli imeväike ja hind kolossaalne, siis see toimis. Samas vaadates nüüd Vega probleeme ei teagi palju sellest oli 16nm tootmisprotseei ja palju HBM2 süü GP100 puhul. Oli see ju esimene kaart üldse selle mäluga ja palju varem kui Vega.
Väheke spekulatsiooni kah:
GV100: 5,376 Cores, 815mm², 16/32GB 4096-bit HBM2 @ 500Mhz, 900GB/s, 15 Tflops+
GV102: 4,480 Cores, ~500mm², 16/24GB 384-bit GDDR6 @ 16Gbps, 768GB/s, 15 Tflops+
GV104: 3,584 Cores, ~375mm², 8/16GB 256-bit GDDR6 @ 14Gbps, 512GB/s, 12 Tflops+
GV106: 2,688 Cores, ~250mm², 4/8GB 256-bit GDDR6 @ 14Gbps, 512GB/s, 10 Tflops+
GV108: 1,792 Cores, ~150mm², 2/4GB 128-bit GDDR6 @ 12Gbps, 256GB/s, 7 Tflops+
See eeldab, et iga madalama klassi kaardil keeratakse üks SM klaster (896 tuuma) kinni. GV100-l on 6xSM klastrit ehk 6x896=5376
GV108-l oleks siis kaks aktiivset aga võib vabalt ka üks olla ainult sisse lülitatud. GDDR6 kiirused eeldan vahemikus 12-16Gbps ja mälumahud kõigil mudelitel kaks varianti. GV102 puhul siis Titan saab suurema 24GB mahu ja Ti väiksema 16GB mahu, kuna ajalooliselt on VRAM maht olnud nende eraldajaks.
Lõppu võtke paar teelusikatäit soola kah sisse aga mingi aimu peaks andma. Kellade ja voolutarbe osas ei tea nii täpselt, aga arvata võib, et need tulevad head, kui Tesla V100 jookseb @ 1455Mhz @ 150W koos 5120 tuumaga. potentsiaalselt näeme siis 100W GV104 @ 2,5Ghz ja 150W GV102 @ 2Ghz.
Kommentaarid: 92 loe/lisa |
anubis
11.05.2017 09:40:34
GV100 tõenäoliselt ei tule müügile. Pole väga pointi.
"G" märge "GV" koodis tähendaks "Graphics" ehk Graphics Volta - videokaardina nVidia oma "100" kiipe ei müü. Nad optimeeritud teistsuguste rakenduste jaoks.
277 |
11.05.2017 13:30:53
anubis, See oli võrdluseks ilmselgelt.
EDIT: Minu eelmise aasta augustis tehtud post. Vaatame kas ja kui täppi läheb:
tsitaat: |
Tomorrow kirjutas: |
kui vaadata tavalist jõudlusekasvu mis iga uue põlvkonnaga tuleb, siis võiks midagi sellist spekuleerida:
GTX 1160 = GTX 1080 jõudlus
GTX 1170 = GTX Titan X jõudlus
GTX 1180 = GTX 1080 SLI jõudlus
GTX Titan V = Vastutustundetu  |
NATAS999
15.05.2017 13:17:27
nvidia on mu teada varemgi suure mõõtmelisi kive disainind. kas mitte fermi esialgne disain polnd mitte üle tehase max mõõtmete ja läks n.ö. back to the drawing board?
Kommentaarid: 41 loe/lisa |
39 |
HDTanel
Overclocker
17.05.2017 04:23:34
Hämmingus täiesti kuidas nVidia lihtsalt treib ja treib uut tehnoloogiat välja ja AMD magab Volta juba selle aasta keskel kusagil... September pakun... ulme.
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
Kommentaarid: 635 loe/lisa |
496 |
Goon
17.05.2017 06:49:36
HDTanel kirjutas: |
Hämmingus täiesti kuidas nVidia lihtsalt treib ja treib uut tehnoloogiat välja ja AMD magab Volta juba selle aasta keskel kusagil... September pakun... ulme. |
Oot sa ütled HV foorumis, et AMD polegi maailma parim ettevõte ve ja su posti polegi veel kustutatud?
Nvidial ja AMDl väga erinev firma poliitika. Nvidial on mitu kaarti arendust korraga arendamises, samas kui AMDl on 1 (vega) ja kui see lõpuks välja tuleb siis Nvidial on 2 kaarti millel on parem perfomance. Ja kui AMD hind tundub ostjatele parem, siis Nvidia laseb lihtsalt kaartide hindasid alla, millega see konkreetselt võistleb. Ma ei näe et AMD hakkaks enda asju teistmoodi tegema, et nad vist jäävadki tagaajaja rolli, mis on konkurentsi poolest halb.
Kommentaarid: 2 loe/lisa |
17.05.2017 07:53:10
Nvdia teeb juba softi poolega ära. Teine fakt on see, et nvidia on ikka nii suureks kasvanud nii et enam pole kohatu AMD vs Intel stiilis võrdlus st. lihtsalt nime pealt müüb juba.
Näiteks R9 290 oli kordades stabiilsem (0 softikala) kui RX480. Mõlemad realease hetkel ostetud custom kaardid.
Kommentaarid: 234 loe/lisa |
200 |
17.05.2017 11:25:15
Goon kirjutas: |
Nvidial ja AMDl väga erinev firma poliitika. Nvidial on mitu kaarti arendust korraga arendamises, samas kui AMDl on 1 (vega) ja kui see lõpuks välja tuleb siis Nvidial on 2 kaarti millel on parem perfomance. |
ei ole ju. poliitika on täpselt sama - mõlemal on järgmine arhitektuur tegemises (volta ja vega). tegelikult olid mõlemad ka sarnase probleemi ees kui järgmine arhitektuur hilines ja lahendusedki sarnased kuigi praktikas veidi erinevalt välja kukkunud - polaris ja pascal olid hilisemad lisandid roadmapile vaheastmeks enne järgmise tulekut.
_________________ - londiste
Kommentaarid: 241 loe/lisa |
215 |
18.05.2017 09:27:21
Võimalik, et nvidial nüüd rohkem tuli takus, sest Google arendab enda AI kiipi. Ökom kui nvidia.
200 |
NATAS999
18.05.2017 10:06:42
Magic kirjutas: |
Võimalik, et nvidial nüüd rohkem tuli takus, sest Google arendab enda AI kiipi. Ökom kui nvidia. |
39 |
18.05.2017 10:12:35
No eilsele börsi odavmüügile tundus see kena põhjendus olevat. Ise nii süvenenud pole, aga taust on see, et konkurents ilmselt kasvab.
200 |
hempadonok
18.05.2017 10:19:31
Magic kirjutas: |
No eilsele börsi odavmüügile tundus see kena põhjendus olevat. Ise nii süvenenud pole, aga taust on see, et konkurents ilmselt kasvab. |
Google AI käib ikka läbi kvantarvuti(mida arendab D-Wave), see on hoopis erinev maailm
18.05.2017 10:25:27
Aga seni google kasutanud nvidia asju, seega ikka konkurents.
200 |
Goon
18.05.2017 10:59:07
Eks google peab softi ka arendama sellele - muidu hea uudis
veits offtopic aga kõik börsiturud olid öösel punases Trumpi skandaalide tõttu ja see tekitab ebakindlust. Kõige parem maasikas on muidugi see
Killhoven
OC`er
18.05.2017 11:27:40
ot: |
hempadonok kirjutas: |
Magic kirjutas: |
Google AI käib ikka läbi kvantarvuti(mida arendab D-Wave), see on hoopis erinev maailm |
Täpsuse huvides - kvantarvutit ei eksisteeri (veel) praegu peamiselt mittekoherentsuse probleemi tõttu. |
346 |
23.05.2017 09:03:40
Titan Volta pildile saadud?
Väga vara kui see tõsi peaks olema . Huvitav on see, et see kasutab SLI connectorite asemel NVLINK connectoreid. Kas ka GV100 GPU ei tea. Igatahes 1x8pin + 1x6pin power.
anubis
277 |
Gap
24.05.2017 19:21:08
Huvitav oleks praegu näiteks teada kui palju kiirem on Volta näiteks maxwellist ? palju edasiminek on võrreldes pascali seeria kaartidega arvan et esimesi mängimiseks mõeldud volta kaarte ei tule see aasta kindlasti .... sest et 1080Ti on vist praegu suht võimas kaart ja ei jää üheski mängus lahjaks...iseasi kas 4k-l veab kõik põhjas ? Volta võiks siis juba nii võimas olla et veaks ära 4k mänge ... Muidugi tahaks ka 4k monitori,aga need on nii kuradi kallid ikka veel minuarvates ... 1200-1400€ on ikka üle mõistuse
Kommentaarid: 21 loe/lisa |
17 |
WäntWõll
make.believe
24.05.2017 19:23:53
tsitaat: |
mis monitor
Kommentaarid: 374 loe/lisa |
300 |
Gap
24.05.2017 19:26:55
mismõttes mis ? no sa pole vaadanud mis hinnad on 4k monitoridel ?
17 |
24.05.2017 20:08:51
Gap kirjutas: |
Huvitav oleks praegu näiteks teada kui palju kiirem on Volta näiteks maxwellist ? palju edasiminek on võrreldes pascali seeria kaartidega arvan et esimesi mängimiseks mõeldud volta kaarte ei tule see aasta kindlasti .... sest et 1080Ti on vist praegu suht võimas kaart ja ei jää üheski mängus lahjaks...iseasi kas 4k-l veab kõik põhjas ? Volta võiks siis juba nii võimas olla et veaks ära 4k mänge ... Muidugi tahaks ka 4k monitori,aga need on nii kuradi kallid ikka veel minuarvates ... 1200-1400€ on ikka üle mõistuse  |
See 4K on suht overhyped imo. Tegu on lihtsalt kõrgema resoga. Sama efekti saab tekitada mängudes ka 1080p või 1440p peal kasutades DSR valikut. Rääkimata sellest, et 27" 4K on suht kirbukiri. Kasutatav 4K diagonaal algab seal 35" peal ja ülesse aga siis läheb monitor jälle liiga suureks.
Mina pigem soovitan 1080p 144Hz või 1440p 144Hz. Esiteks odavam (sõltuvalt paneelitüübist kuni 700 max) ja teiseks seal on 1080Ti või Volta (kindlasti) palju parem suutes 100fps+ kõik põhjas teha. 4K peal peab koguaeg muretsema, et alla 60 ei kukuks. Vb Volta muudab seda, aga see pole kerge 4K kõik põhjas üle 60 hoida (eriti nõudlikes mängudes).
Samas kui plaan uus monitor võtta, siis ehk veidi oodata ja vaadata mis HDR-st saab. Hetkel asi veel areneb aga on mitu standardit mis pole kunagi hea tulevikukindlus ja ühilduvuse mõttes.
Mis puutub Volta vs Pascal, siis kindlasti 1180 vms on jälle 20-25% kiirem, kui 1080Ti. 1180Ti sellest omakorda jälle 25% kiirem jne.
Kui Maxwelli pealt Volta peale lähed on kiirusetõus muidugi palju suurem olles seal 75-100% kandis sõltuvalt sellest mis kaart sul praegu on ja mis kaardi võtad.
WäntWõll
make.believe
300 |
