18.01.2017 12:10:43
Vot see on see formaatide sõda. Igaks juhuks tasub kõik sisse toppida
So far, Life's Good!
LG OLED TV will support all major HDR formats.
Universal HDR-compliant displays
Apparently, all 2017 LG OLED TV will be compatible with all existing operational HDR formats (HEVC HDR10, HEVC Dolby Vision, HEVC HLG HDR, VP9-HLG YouTube HDR, VP9-PQ YouTube HDR) and upcoming Technicolor HDR ( apparently aka Technicolor/Philips HDR or SMPTE ST 2094-20/30 dynamic metadata-based Dynamic HDR or ETSI SL-HDR1).
http://forum.blu-ray.com/showpost.ph...0&postcount=27
For various reasons, the industry has created different HDR formats which can provide a big picture quality jump from SDR.
For the consumer, at the end of the day, it is HDR content that matters most, not HDR content format.
A consumer-driven HDR TV shall be able to play any operational HDR content.
And different HDR formats are just different (HDR) software running on capable (i.e. powerful enough) TV System-on-Chip with 10-bit HEVC/VP9 hardware accelerated decoding, like the Sigma Designs STV7804 TV SoC or the MediaTek MT5597 TV SoC (CompuTV, Welcome to the Moore law’s world!).
As the industry is unable to reach a consensus on HDR, a consumer-driven HDR TV shall support all operational HDR formats in the same way AVRs have universal support for audio formats.
18.01.2017 12:24:42
See pole mitte formaatide sõda, vaid kohanemine iga võimaliku tegija tõlgendusega asjast, millele pole siiani standardit loodud. Ma olen seda kusagil foorumis ka öelnud selle vaidluse peale, et HDR ei tähenda, et te näete mingi teise või kolmanda osapoole tõlgendust HDR pildist, kui teleris olev järgib ainult LG HDR tõlgendust.
Hüvasti Netflix HDR; hüvasti BBC HDR; hüvasti Amazon HDR; hüvasti iga järgmine XXX HDR. Teie teler ei toeta mitte ühtegi järgnevate tegijate tõlgendust asjast.
128 |
18.01.2017 12:31:32
No lg paneb igaks juhuks kõik formaadid masinasse
MaxPower
18.01.2017 17:42:53
| Jänes kirjutas: |
| raxz kirjutas: |
| Killhoven kirjutas: |
| OLEDil on ka omad probleemid millega soovitan tutvuda. esimesed mis pähe hüppavad: image retention või võiks öelda isegi isegi burn-in, kiire värvide tuhmumine. Olin hiljuti sarnase küsimuse ees ja leidsin, et kvaliteetne LCD on mõttekam. Las see OLED tehnoloogia veel areneb kui hinda ja kvaliteeti võrrelda. |
Kas sul on isiklikud kogemused või NSR?
Kas keegi siit on neid probleeme oma OLEDil kohanud? |
Paljudel üldse OLED on ? Et saaks mingit adekvaatset vastust.  |
andke jah teada kellel OLED-id...täitsa huvitaks ennastki, et kuidas igapäeva elus tunduvad? Ma muidu veendunud OLED-i fän aga endal veel ple
| Kommentaarid: 12 loe/lisa |
12 |
18.01.2017 17:44:26
keegi foorumis ostis ju suisa paar tk neid, ei viitsi ajalugu lapata täna
Six
18.01.2017 17:51:15
Mul on 55" ja 65" EF950V.
Seni rahul... kuigi 55" läheb vist kohe varsti HV-sse müüki.
Suuremat vaja.
EDIT: Müügil https://foorum.hinnavaatlus.ee/viewtopic.php?t=696857
| jeesus188 kirjutas: |
| keegi foorumis ostis ju suisa paar tk neid, ei viitsi ajalugu lapata täna |
viimati muutis Six 19.01.2017 09:24:03, muudetud 1 kord |
| Kommentaarid: 40 loe/lisa |
39 |
MaxPower
18.01.2017 17:54:19
| lähed B6 või mõne vingema mudeli peale või proovid üldse teist tootjat?
12 |
Six
18.01.2017 18:02:21
Pole veel otsustanud, kas võtan B6 või ootan ära B7.
Samas oleks huvitav ka teada, mis hinnaga Sony ja Pana välja tulevad.
Aga nendega läheb vist liiga kaua aega... kuskilt jäi meelde, et 2017 lõpu poole alles. Või ma eksin...
Seega peab vist ikka algatuseks B6 võtma.
| MaxPower kirjutas: |
| lähed B6 või mõne vingema mudeli peale või proovid üldse teist tootjat? |
39 |
MaxPower
18.01.2017 18:06:25
see sony mudel mis esitleti, ma olen 99% kindel et tuleb kallim kui B7, sama ka panasonicu kohta...ma arvan et hinnad sinna kanti kus LG-l E seeria või isegi sellestki rohkem. Aga eks aeg näitab
12 |
Six
18.01.2017 18:11:45
Pole leidnud infot, mis erinevus hakkab olema B7 ja C7.
Kuna raud pidi kõigil sama olema ja soundbari pole tänu ressiiverile vaja, siis need mudelid jäävad valikusse.
39 |
MaxPower
12 |
Six
18.01.2017 18:40:33
Tänan.
The difference between B7 and C7 is mostly design. C7 has LG’s “Alpine” stand.
39 |
18.01.2017 19:03:36
| Six kirjutas: |
Kuna raud pidi kõigil sama olema ja soundbari pole tänu ressiiverile vaja, siis need mudelid jäävad valikusse. |
Pm LG kõik OLEDid on sama rauaga jah, aga hakkad teistsuguse raami, soundbari jne asjade eest kõvasti rohkem maksma. Kokkuvõttes mõttetu ja ise peale B7 muud ei piilugi
MaxPower
18.01.2017 19:48:14
väga huvitav on nüüd teada, mis hinnaga B7 müüki tuleb ehk siis küsimus on, et kui palju kallim kui praegune B6 (kas õigustab hinnavahet või mitte) Kui nüüd automaailmast paralleeli tõmmata siis B7 tundub nagu facelift mudel olevat, et alles 2018 võib midagi päris uut oodata...
12 |
mikk351
135 |
MaxPower
19.01.2017 08:50:11
| LG mudel peaks olema vähemalt 7-ndast (UH7707) seeriast...samsungi kohta ei ole nii pädev, et soovitada.
12 |
Freedom
19.01.2017 09:22:10
| Jänes kirjutas: |
| raxz kirjutas: |
andke jah teada kellel OLED-id...täitsa huvitaks ennastki, et kuidas igapäeva elus tunduvad? Ma muidu veendunud OLED-i fän aga endal veel ple  |
4 kuud vana 55EG910V ostetud. Kõik on super ja telekaga väga rahul.
| Kommentaarid: 4 loe/lisa |
scarface
19.01.2017 23:41:10
Tere,
Oleks huvi 55"+ 1080p TV vastu millel oleks reaalne 120Hz. Peaks nagu olemas olema mõni variant?? Jõle raske on leida reaalset TV hertzi.
Tahaks mängimiseks kaadreid juurde, 60 on veits jama.
Oskab keegi suunata?
Tänude ette!
Mehh, lugesin veits veel ja tundub, et ei tehtagi üle 60Hz, miks nii? : D Mõni haruldus aint töötab vist kui manuaalselt panna 120 peale. TV gaming pole moes või kuidas.
| Kommentaarid: 43 loe/lisa |
41 |
MummikAl
| Kommentaarid: 42 loe/lisa |
39 |
20.01.2017 00:06:39
telekas võib küll 120hz osata aga sisendist 120hz signaali sisse võtvat telekat ei tohiks ühtegi olla.
_________________ - londiste
215 |
MummikAl
39 |
20.01.2017 00:30:53
hmm, meeldiv lugeda, et eksisin
krt, miks sellised asjad specis korralikult kirjas ei võiks olla :/
215 |
scarface
20.01.2017 00:33:14
Jah, aga need on kõik UHD telerid ja 1080p peal on asi kole ju.
Keegi kirutab aastal 2014: The Good King Snugglewumps says:
December 8, 2014 at 9:08 am
E601i-A3 running at 120Hz at 1920 x 1080 with Nvidia’s custom resolution settings.
https://www.vizio.com/e601ia3.html Selline Teler oleks siis ideaalne mulle. Aga pole saada ju : p
41 |
sukelduja
| Kommentaarid: 25 loe/lisa |
25 |
20.01.2017 10:35:37
scarface, selle taga on paar erinevat põhjust:
- hdmi 2.0 piir on uhd@60hz
- ka telekate sisene raud ei ole sealt kõrgemale võimeline. kuna töötlemisvõimekus on sisuliselt bitrate pealt arvestatav, siis 1080p@120hz < uhd@60hz
ka nende 1080p@120hz võimeliste 4k telekate juures peaks input lag päris korralik mure olema.
215 |
