uus teema   vasta Hinnavaatlus »  Mobiiltelefonid/ GPS seadmed / Muu tehnika »  Sony Xperia Z3 Compact märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 95, 96, 97 ... 110, 111, 112  järgmine
sooty
sõnum 24.08.2016 09:23:34 vasta tsitaadiga
Kuna kasutan väikest telefoni (ptüi ptüi, et tulevikus ka <5" toodaksid), siis mitmes aknas ei tööta niikuinii.
icon_question.gif Mure kah - viimasel ajal ei taha väljuvad kõned kutsuda, teine pool hakkab lihtsalt rääkima. Juhtub ainult Telia võrguga (laud ja mobiil)
Draqula
sõnum 24.08.2016 09:27:02 vasta tsitaadiga
sooty kirjutas:
Ametlik android N Sony Z3 seeriale v.a. Z3+ ei tule.
Loodetavasti turvauuendusi ikka annavad, hetkel vist ikka märts.
http://blogs.sonymobile.com/2016/08/23/sony-xperia-and-android-7-0-nougat/
Üks huvitav kommentaar selle blogipostituse juures:
Comment by Myself5 from XDA- Developers:
If someone here would be able to read the Android Sourcecode, they would know why the Z3 and other msm8974 devices are no longer officially supported.
With 7.0.0, all msm8974 code was removed from AOSP. After all, what you expect is that Sony is supporting a no longer AOSP supported chipset. At what point is that a fair assumption?
Of cause its sad to hear that the Z3 got the N Previews and now is no longer supported, but guess why there was no Preview 4 or 5 either? Probably that was around the time when Google gave the 8974 chipset the boot.
After all, the article is not really well researched in my eyes, and written like its Sony’s fault that the 8974 platform is no longer supported. Of cause up to some point it is. But there is also a greater matter, which is not in the hands of Sony at all.
BTW, Sony’s Open Devices program will probably find a way sooner or later, its just not something the company can do officially IMO.
Ehk siis tundub olevat Google poolt tehtud chipseti toe muudatus põhjuseks, miks me 7 ei näe.
prtv
sõnum 24.08.2016 10:02:19 vasta tsitaadiga
Arvatavasti põhjus selles et sd801 gpu ei toeta vulcan APId mida on vaja 7.0s ey saada sertifikaati googlelt.
sõnum 24.08.2016 11:21:26 vasta tsitaadiga
sooty kirjutas:
Olen ise sama asja kohanud, rohkem pole uurinud. Tegelikult peaks Teliale sellest teada andma aga pole viitsinud.
Kommentaarid: 184 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 147
DigeBeni
DigeBeni
sõnum 24.08.2016 12:15:27 vasta tsitaadiga
Mark0 kirjutas:
sooty kirjutas:
+1 olen teada andnud aga 0 tagasisidet icon_neutral.gif esimesed tähelepanekud juba suve algusest ...
arm2004
arm2004
sõnum 25.08.2016 17:20:01 vasta tsitaadiga
http://www.gsmarena.com/sony_xperia_x_compact_image_points_to_rebirth_of_the_famous_line-news-20137.php icon_eek.gif
nooope!
sooty
sõnum 25.08.2016 18:33:26 vasta tsitaadiga
Igati positiivne uudis.
sõnum 25.08.2016 18:45:58 vasta tsitaadiga
Win11 25H2 upgrade skriptid neile kelle masin ise ei taha 23H2 või 24H2 pealt ennast uuendada:
arm2004
arm2004
sõnum 26.08.2016 05:45:51 vasta tsitaadiga
http://www.gsmarena.com/sony_xperia_x_compact_and_xperia_xr_specs_leak_ahead_of_sonys_ifa_announcement-news-20145.php
loodetavasti tuleb ikka 4GB RAM. aga vähem kui nädala pärast selge icon_smile.gif
nooope!
arm2004
arm2004
sõnum 26.08.2016 15:13:47 vasta tsitaadiga
http://www.gsmarena.com/xdadevs_member_boots_android_70_nougat_on_sony_xperia_sp-blog-20158.php
et jah, sellise moega ma oma garantiiaja lõpuni (1a3k veel) ei kannata ja loomkatsed algavad varem, pakuks, et järgmine kevad või nii icon_razz1.gif
edit: aina paremaks läheb icon_lol.gif
http://www.gsmarena.com/android_nougat_ported_to_the_lg_nexus_4-blog-20165.php
nooope!
viimati muutis arm2004 27.08.2016 12:56:25, muudetud 2 korda
arm2004
arm2004
sõnum 26.08.2016 18:13:18 vasta tsitaadiga
hope just keeps on coming in!
http://www.gsmarena.com/the_xperia_xr_and_xperia_x_compact_may_launch_in_late_september-news-20156.php
nooope!
-KRANTS-
vitamiinidiiler
-KRANTS-
sõnum 28.08.2016 17:01:08 vasta tsitaadiga
arm2004 kirjutas:
Huvitav kas need ongi need mudelid millega sony septembris toimuval suurel laadal välja tulevad? Või on neil midagi muud varuks?
Kommentaarid: 364 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 243
maadleja
sõnum 31.08.2016 19:22:11 vasta tsitaadiga
Oskab keegi öelda, kust z3 compactile musta laadimisava klappi saab?
sooty
sõnum 31.08.2016 21:40:49 vasta tsitaadiga
Homme pärastlõunal saab selgust X compact / XR(Z) osas. 13:00 CEST Sony pressikas
maadleja kirjutas:
http://www.ebay.com/itm/Original-Waterproof-Memory-SIM-Card-Charger-Port-Cover-Sony-Xperia-Z3-Compact-/390994878710
Google on suht viisakas abimees kui kenasti küsida. Ebay's pakkumist lademetes, link ei pruugi kõige odavam variant olla.
maadleja
sõnum 01.09.2016 06:40:21 vasta tsitaadiga
Aga Eestis?
arm2004
arm2004
sõnum 01.09.2016 08:05:05 vasta tsitaadiga
mul mingi uus anomaalia tekkinud. sel nädalal 2 korda: kolmapäeval ja just nüüd. nimelt SIM kaob justkui ära, restardiga on tagasi icon_confused.gif
nooope!
sõnum 01.09.2016 08:47:25 vasta tsitaadiga
arm2004, Loksub pesas?
arm2004
arm2004
sõnum 01.09.2016 09:00:46 vasta tsitaadiga
Tomorrow kirjutas:
eip. ei näe ka põhjust miks peaks loksuma. ainult detsembris kaks korda sisse-välja võetud tutikas SIM tutikas telefonis icon_rolleyes.gif
nooope!
sooty
sõnum 01.09.2016 10:38:02 vasta tsitaadiga
Osta kõnekaart ja proovi sellega. Pigem pakuks, et SIM viga. Ei kujuta ette, kuidas kaart pesas loksuda saaks.
Kui operaator sõbralik, siis ehk vahetavad välja. Sain kuu tagasi SIM vahetamisel esimese hoobiga vigase kaardi, mis üldse tööle ei hakanud. Proovisin terve päeva restarte ja sisse-välja manöövreid. Tagasi minnes oli juba terve partii maha kriipsutatud ja anti kohe uus.
maadleja kirjutas:
Aga Eestis?
+1 tund, e. kell 14:00
arm2004
arm2004
sõnum 01.09.2016 10:59:37 vasta tsitaadiga
kõnekaart küll mingit efekti ei annaks. päris nii ikka ei saa, et jumalteab mitu päeva pole kättesaadav icon_rolleyes.gif
ja kuidas/miks peaks SIM hapuks minema kui see vaid alla aasta vana, veekindlas telefonis ja 2 korda sisse-välja kistud? don't make sense to me...
pakuks, et ikka miski softipuuk, nagu mastivahetus vmt jooksutaks miskit kokku. juhtunud on nii, et töölt minema hakates oli ok, koju jõudes "kadunud". ja täna kodunt tulema hakates oli ok, tööle jõudes "kadunud".
nooope!
Draqula
sõnum 01.09.2016 11:05:15 vasta tsitaadiga
arm2004 kirjutas:
SIM kaardi vahetus tundub asi, mida ma esimesena prooviks, kuna operaator peaks uue kaardi defekti korral tasuta andma ja investeeringuks olekski vaid esinduses käimise ajakulu. Lihtsalt üks riskifaktor nimekirjast maas.
maadleja
sõnum 01.09.2016 11:08:23 vasta tsitaadiga
sooty kirjutas:
maadleja kirjutas:
Aga Eestis?
Mõtlesin, et kas Eestis kuskilt laadimisava klappi ka leida on võimalik?
sooty
sõnum 01.09.2016 13:21:17 vasta tsitaadiga
Kes vaadata saab/tahab, siis LIVE
https://www.youtube.com/watch?v=2aXBMVYt9NM
http://www.gsmarena.com/sony_unveils_xperia_xz_flagship_and_xperia_x_compact-news-20274.php
The Xperia X Compact may share some DNA with the XZ, but it is not a smaller version of the latest flagship. It's exactly what the name suggests - a Compact flavor of the Xperia X. This means we will be getting a mini edition of the Xperia X with the same Snapdragon 650 chipset, same attention to detail in design, but also the same imission in the specs (ahem, water-proofing, ahem!). icon_sad.gif icon_confused.gif
See on väga kummaline otsus
Igast remondiputkast peaks tellida saama. Iseasi, kas saab sama soodsalt.
arm2004, arvan, et mõtled asja üle. SIM võib vabalt hingusele minna, alusta ikka kergematest asjadest. Samuti võib arvutis software recovery teha, et see välistada. Xperia compacnion tõmbab puhta image ja paneb peale. Samuti on olemas teenus nimega 'vahetu suunamine'
Draqula
sõnum 01.09.2016 13:46:36 vasta tsitaadiga
Nojah, pettumus indeed.
Aga tahaks näha akupidamise teste uue compacti osas.
Z5c oli aku pidamise osas tugev tagasiminek võrreldes Z3c, tahaks näha kas vigadest on õpitud.
sõnum 01.09.2016 13:56:26 vasta tsitaadiga
hetkel tundub, et x compacti asemel sihiks mõnda eelmist mudelit... kuidas z1c, z3c ja z5c omavahel võrdluses pädevad? plussid ja miinused?
x compacti on tagasiminek, sest pole veekindlust..
uus teema   vasta Hinnavaatlus »  Mobiiltelefonid/ GPS seadmed / Muu tehnika »  Sony Xperia Z3 Compact mine lehele eelmine  1, 2, 3 ... 95, 96, 97 ... 110, 111, 112  järgmine
