sooty
24.08.2016 10:23:34
Kuna kasutan väikest telefoni (ptüi ptüi, et tulevikus ka <5" toodaksid), siis mitmes aknas ei tööta niikuinii.
Mure kah - viimasel ajal ei taha väljuvad kõned kutsuda, teine pool hakkab lihtsalt rääkima. Juhtub ainult Telia võrguga (laud ja mobiil)
| Kommentaarid: 12 loe/lisa |
12 |
Draqula
24.08.2016 10:27:02
Üks huvitav kommentaar selle blogipostituse juures:
Comment by Myself5 from XDA- Developers:
If someone here would be able to read the Android Sourcecode, they would know why the Z3 and other msm8974 devices are no longer officially supported.
With 7.0.0, all msm8974 code was removed from AOSP. After all, what you expect is that Sony is supporting a no longer AOSP supported chipset. At what point is that a fair assumption?
Of cause its sad to hear that the Z3 got the N Previews and now is no longer supported, but guess why there was no Preview 4 or 5 either? Probably that was around the time when Google gave the 8974 chipset the boot.
After all, the article is not really well researched in my eyes, and written like its Sony’s fault that the 8974 platform is no longer supported. Of cause up to some point it is. But there is also a greater matter, which is not in the hands of Sony at all.
BTW, Sony’s Open Devices program will probably find a way sooner or later, its just not something the company can do officially IMO. |
Ehk siis tundub olevat Google poolt tehtud chipseti toe muudatus põhjuseks, miks me 7 ei näe.
| Kommentaarid: 42 loe/lisa |
34 |
prtv
24.08.2016 11:02:19
Arvatavasti põhjus selles et sd801 gpu ei toeta vulcan APId mida on vaja 7.0s ey saada sertifikaati googlelt.
_________________ |
| Kommentaarid: 82 loe/lisa |
73 |
24.08.2016 12:21:26
| sooty kirjutas: |
| Mure kah - viimasel ajal ei taha väljuvad kõned kutsuda, teine pool hakkab lihtsalt rääkima. Juhtub ainult Telia võrguga (laud ja mobiil) |
Olen ise sama asja kohanud, rohkem pole uurinud. Tegelikult peaks Teliale sellest teada andma aga pole viitsinud.
147 |
DigeBeni
24.08.2016 13:15:27
| Mark0 kirjutas: |
| sooty kirjutas: |
Olen ise sama asja kohanud, rohkem pole uurinud. Tegelikult peaks Teliale sellest teada andma aga pole viitsinud. |
+1 olen teada andnud aga 0 tagasisidet esimesed tähelepanekud juba suve algusest ...
163 |
arm2004
97 |
sooty
25.08.2016 19:33:26
| Igati positiivne uudis.
12 |
| Kommentaarid: 92 loe/lisa |
arm2004
97 |
arm2004
97 |
arm2004
97 |
-KRANTS-
vitamiinidiiler
28.08.2016 18:01:08
Huvitav kas need ongi need mudelid millega sony septembris toimuval suurel laadal välja tulevad? Või on neil midagi muud varuks?
| Kommentaarid: 364 loe/lisa |
243 |
maadleja
31.08.2016 20:22:11
| Oskab keegi öelda, kust z3 compactile musta laadimisava klappi saab?
sooty
12 |
maadleja
01.09.2016 07:40:21
| Aga Eestis?
arm2004
01.09.2016 09:05:05
mul mingi uus anomaalia tekkinud. sel nädalal 2 korda: kolmapäeval ja just nüüd. nimelt SIM kaob justkui ära, restardiga on tagasi
_________________ nooope! |
97 |
arm2004
01.09.2016 10:00:46
| Tomorrow kirjutas: |
| arm2004, Loksub pesas? |
eip. ei näe ka põhjust miks peaks loksuma. ainult detsembris kaks korda sisse-välja võetud tutikas SIM tutikas telefonis
97 |
sooty
01.09.2016 11:38:02
Osta kõnekaart ja proovi sellega. Pigem pakuks, et SIM viga. Ei kujuta ette, kuidas kaart pesas loksuda saaks.
Kui operaator sõbralik, siis ehk vahetavad välja. Sain kuu tagasi SIM vahetamisel esimese hoobiga vigase kaardi, mis üldse tööle ei hakanud. Proovisin terve päeva restarte ja sisse-välja manöövreid. Tagasi minnes oli juba terve partii maha kriipsutatud ja anti kohe uus.
| maadleja kirjutas: |
| Aga Eestis? |
+1 tund, e. kell 14:00
12 |
arm2004
01.09.2016 11:59:37
kõnekaart küll mingit efekti ei annaks. päris nii ikka ei saa, et jumalteab mitu päeva pole kättesaadav
ja kuidas/miks peaks SIM hapuks minema kui see vaid alla aasta vana, veekindlas telefonis ja 2 korda sisse-välja kistud? don't make sense to me...
pakuks, et ikka miski softipuuk, nagu mastivahetus vmt jooksutaks miskit kokku. juhtunud on nii, et töölt minema hakates oli ok, koju jõudes "kadunud". ja täna kodunt tulema hakates oli ok, tööle jõudes "kadunud".
97 |
Draqula
01.09.2016 12:05:15
| arm2004 kirjutas: |
pakuks, et ikka miski softipuuk, nagu mastivahetus vmt jooksutaks miskit kokku. juhtunud on nii, et töölt minema hakates oli ok, koju jõudes "kadunud". ja täna kodunt tulema hakates oli ok, tööle jõudes "kadunud". |
SIM kaardi vahetus tundub asi, mida ma esimesena prooviks, kuna operaator peaks uue kaardi defekti korral tasuta andma ja investeeringuks olekski vaid esinduses käimise ajakulu. Lihtsalt üks riskifaktor nimekirjast maas.
34 |
maadleja
01.09.2016 12:08:23
| sooty kirjutas: |
| Aga Eestis? |
+1 tund, e. kell 14:00 |
Mõtlesin, et kas Eestis kuskilt laadimisava klappi ka leida on võimalik?
sooty
01.09.2016 14:21:17
Kes vaadata saab/tahab, siis LIVE
https://www.youtube.com/watch?v=2aXBMVYt9NM
http://www.gsmarena.com/sony_unveils_xperia_xz_flagship_and_xperia_x_compact-news-20274.php
The Xperia X Compact may share some DNA with the XZ, but it is not a smaller version of the latest flagship. It's exactly what the name suggests - a Compact flavor of the Xperia X. This means we will be getting a mini edition of the Xperia X with the same Snapdragon 650 chipset, same attention to detail in design, but also the same imission in the specs (ahem, water-proofing, ahem!).
See on väga kummaline otsus
Igast remondiputkast peaks tellida saama. Iseasi, kas saab sama soodsalt.
arm2004, arvan, et mõtled asja üle. SIM võib vabalt hingusele minna, alusta ikka kergematest asjadest. Samuti võib arvutis software recovery teha, et see välistada. Xperia compacnion tõmbab puhta image ja paneb peale. Samuti on olemas teenus nimega 'vahetu suunamine'
12 |
Draqula
01.09.2016 14:46:36
Nojah, pettumus indeed.
Aga tahaks näha akupidamise teste uue compacti osas.
Z5c oli aku pidamise osas tugev tagasiminek võrreldes Z3c, tahaks näha kas vigadest on õpitud.
34 |
01.09.2016 14:56:26
hetkel tundub, et x compacti asemel sihiks mõnda eelmist mudelit... kuidas z1c, z3c ja z5c omavahel võrdluses pädevad? plussid ja miinused?
x compacti on tagasiminek, sest pole veekindlust..
182 |
