uus teema   vasta Tarkvara »  Arvutimängude foorum »  Elite: Dangerous märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3, 4, 5, 6, 7, 8, 9  järgmine
Scart
Scart
sõnum 24.12.2014 16:30:15 vasta tsitaadiga
Ma ei viitsi oma posti tõlkima hakata, seega kopeerin niisama siia ka.
Tip for quick and early money boost. As far as I know, new commander always starts in Federation space around star system LHS-3447. This should also be the system where your preorder Eagle is stored.
Go the station storing the Eagle, sell that sucker for 40K and outfit your Sidewinder with gattling gimballed lazors and jump next door to LTT-18486. In that system are two gas giants, both orbited by stations and Resource Extraction Points. The station you want is Boswell. It has a full complement of services available.
Now, this is the fun part. Jump to the REP and start blasting away at the ships with Wanted status, but make sure to always check their allegiance before opening fire. To to that, press 1 after targeting, select Contacts and find the target on the list. You will see the bounty, the allegiance of the Wanted commander and the bounty amount. Do not fire if the enemy commander is allied to the guys who control the Boswell Station.
ELITE uses some sort of ass backwards rep system which causes you to lose rep for any allied party if you shoot their guy who has a Wanted status, thus if you fire upon and kill a guy from the controlling party of the Boswell station, you will lose your docking rights and thus, you will lose control of the entire system as Boswell is their only station in the universe.
You can of course say "screw it" and shoot everything, but keep in mind that you need to dock to a Federation allied station to claim your bounties and the next Fed station is 5-6 minute drive away from the REP, making it a 15 minute trip to claim the money. With Boswell, you are back in action in 2 minutes.
Arvestage sellega, et bountyhuntides tuleb tõsiselt jälgida bountyga komandöri kuuluvust. Kui tegu on Föderatsiooni/regional poweri alla kuuluva laevaga, siis selle pilpaks lastes tuleb vastu võtta rep penalty, mis lõppkokkuvõttes lukustab teid selle poweri jaamadest välja ning lõpuks mõjutab see ka Föderatsiooni reppi ja võib teid reaalselt lukustada tervest Fed-spacest lõplikult välja.
Afaik on tegu reputation bugiga, aga kurat teab millal see ära parandatakse ning kas üldse.
Kris1
sõnum 24.12.2014 16:45:23 vasta tsitaadiga
Scart kirjutas:
Vastukaaluks bountyde rahaks tegemine tõstab reputatsiooni. Ei tea kuidas see balanseerub, kuna ise olen kasutanud sellist taktikat, et olen bountyhuntinud nende süsteemide kõrval kus olen reputatsiooni tõsta püüdnud (ja rahaks teinud selles süsteemis mida püüdsin tõsta).
Scart
Scart
sõnum 24.12.2014 18:03:24 vasta tsitaadiga
Kris1 kirjutas:
Scart kirjutas:
Seda küll, aga Redditi andmetel on tegu negatiivse taastootmisega ehk bountyde väljamakse annab vähem reppi tagasi, kui eelnevalt nende teenimine ära võtab elik see ongi see mainitud reputation bug. Ma ise hetkel lasen ainult kindlalt piraatide alla kuuluvaid selle, sest nende repp ei mõjuta miskit.
raitl
sõnum 25.12.2014 06:22:53 vasta tsitaadiga
Minupoolne väike lisasoovitus bounty hunteritele - investeerige "Kill Warrant Scanner"isse. Tihtipeale on ühele ja samale piloodile pandud mitu bounty't erinevate fraktsioonide poolt. Ilma scannerita läheb kirja ainult see bounty, mis on välja antud fraktsiooni poolt, kes kontrollib seda kosmoseruumi, kus hetkel asud.
Kommentaarid: 166 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 147
aap14
aap14
sõnum 25.12.2014 23:53:26 vasta tsitaadiga
Ootan natuke veel enne kui ostan. Las lisavad korralikud tutorialid ja rohkem sisu ja tegevust ja võimalusi.
Üldiselt on asjal võimalik muutuda selleks, mida Eve Online oleks algusest peale pidanud olema. Eks vaatab, kuidas asjad arenevad icon_smile.gif
Slow is smooth and smooth is fast
Redikate
Redikate
sõnum 26.12.2014 15:46:37 vasta tsitaadiga
aap14 kirjutas:
EvE's saad ka oma laeva nüüd WASD'ga liigutada muidu, kuigi see pole sama mis E: D, siis EvE on minu jaoks E: D'st nii umbes 5a ees. Eks ole näha kas nad suudavad seda vahet kuidagi vähendada.
http://nodejs.org/
"I'm also a person. Programming is just one thing I do."
Kris1
sõnum 26.12.2014 19:04:58 vasta tsitaadiga
Ma olen EvE ainult mõned tunnid mänginud, kuid minu arust nad ikka täiesti erinevad mängud. Erinevad rõhud. Juba see, et EvE on pigem selline PvP, ja kogu sealne craftimine jne. Ei usu, et Elite selliseks areneb.
Ise võtsin täna Elites kaevandamise ehk miningu ette. Kuna seiklesin niikuinii ääresüsteemides, siis polnud pristine olekus ringide (ja tavaliste astroidide) leidmisega suurt vaeva. Teadsin ka et kui "Metallic", siis kõige suurem tõenäosus leida hinnalisi metallimaake (kuld, plaatina ehk platinium, hõbe jen). Esimene cluster kuhu sisse hüppasin oli natuke ebaõnnestunud - kuna polnud ühtegi kohaliku võimuesindaja laeva, siis olin (npc) piraatide märklauaks - kaevandamisest ei tulnud midagi eriti välja, kuid bountysid teenisin lühikese ajaga väga korralikult (olin päris hästi relvastatud).
Järgmised katsed olid palju paremad, pole kunagi õnnelikum olnud authority laevade kohaloleku üle icon_smile.gif. Liikusin ka edasi hiidplaneetide ringidesse (suvalises kohas, mitte RES), jällegi pristine metallic. Mulle kaevandamine päris meeldib siin mängus. Ainult sellele keskendumine viskaks ehk üle, aga vahetevahel huvitav teha (tänasega isu täis ei saanud). Kui sellega tahtmine teenida, siis keskenduda neile maakidele mis hinnalised on. Katse-eksituse meetodil liikuda järjest edasi (odavad ignoreerida), seal kus midagi hinnalist on, kaevandada. Maagitükke scoopides soovitan keskenduda oma kiirusele ja maagitüki kaugusele (suurele asteroidile minimaalselt tähelepanu, ainult segab sind, las ta seal tiirleb, ja mõni kokkupõrge pole ka midagi hullu).
Visuaalselt on kaevandamine ka päris hästi õnnestunud (kõik need tähevalguse peegeldused, varjud, planeedid jne). Tegin paar screenshoti (spoiler tagi sees).
sukelduja
sukelduja
sõnum 05.01.2015 12:32:26 vasta tsitaadiga
Kaubandusega tegelejatele on abiks selline väike programm https://forums.frontier.co.uk/showthread.php?t=74171 . Täitmine on küll natuke tüütu alguses, aga hiljem on palju abi. (Marketi aken lahti, F10 abil screenshot(id), alt+tab Commander logi ja täidad screenshoti järgi ära.)
Neile, kes T-Flight HOTASt kasutavad on kindasti abiks https://forums.frontier.co.uk/showthread.php?t=16140&page=11 Smackeri konfiguratsioon. Minumeelest täiesti geniaalne idee kasutada Throttle nuppe nagu SHIFTe, et kahe nupu kombinatsioonidega mitmekordistada kasutatavaid funktsioone.
aap14
aap14
sõnum 05.01.2015 17:20:22 vasta tsitaadiga
Oskate soovitada mõnda hetkel Eestis kättesaadavat max 60 eurost joysticki sellisteks flight simudeks?
Installisin hiljuti Freespace 2-he koos modidega ja tahaks selleks korraliku lennuriistvara. Hiljem kasutaks seda ka ED jaoks kui devvid mängu rohkem arendanud on.
sukelduja
sukelduja
sõnum 06.01.2015 11:58:27 vasta tsitaadiga
aap14 kirjutas:
Tundub, et joystickidega on raske seis praegu. Ainuke mida saada tundub olevat selles hinnaklassis on Saitek Joystick MAD CATZ-CYBORG V1 Flight Stick. Ise seda kasutanud pole. Aasta tagasi oleks selle raha eest saanud throttle ja joysticki. Mina kasutan Thrustmasteri T-Flight Hotas X komplekti ja olen väga rahul. Ainul saada pole enam kuskilt.
Kusjuures tühjaks on ostetud ka ebay ja amazon, ühtegi odava hinnaga Saiteki ja Thrustmasteri komplekti pole enam saada.
Ühte müüb keegi kuldses börsis.
http://www.kuldnebors.ee/search/search.mec?pob_post_id=43013661&pob_action=show_post&pob_cat_id=10682&srid=kbso
jt234
jt234
sõnum 06.01.2015 12:06:05 vasta tsitaadiga
aap14 kirjutas:
Kui leiad kuskilt, siis Mad Catz Cyborg F.L.Y 5 on (vähemalt minu jaoks) täiesti sobilik variant.
nt: http://arvutitark.ee/est/TOOTEKATALOOG/SULEARVUTID-17-ekraaniga-sulearvutid120/Joystick-MAD-CATZ-CYBORG-FLY-5-PC-12-action-buttons-Rotating-85480
Dima oli siin
Kommentaarid: 132 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 124
r3s3t
r3s3t
sõnum 08.01.2015 04:59:57 vasta tsitaadiga
Ostsin sellise http://arvutitark.ee/est/TOOTEKATALOOG/cyborg+v1/Joystick-MAD-CATZ-CYBORG-V1-Flight-Stick-Flight-simulation-Throttle-85481
Jalad või asjad on masendavad, laua peal kõigub kahtlaselt kui aktiivsem dogfight käigus on.
Rudder kontroll on kahtlane(ma ei tea mis axis see täpselt oli) ühele poole peab ikka väänama, teisele poole liigub juba väikse jõuga.
Aga noh sitast saia ei saa, oleks pidanud ikka selle thrustmasteri hotase võtma.
komafriik ,,
cubedude
cubedude
sõnum 08.01.2015 20:10:18 vasta tsitaadiga
Kas asi on täiesti saast või tegelikult ikka mängitav ja nauditav? Mõtlen ise ka just et 50€ ei raatsi päris lihtsalt selle peale veel kulutada, mida odavam seda parem aga samas sooviks nautida mängu ka.
Kommentaarid: 90 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 87
Kris1
sõnum 09.01.2015 01:27:47 vasta tsitaadiga
cubedude kirjutas:
Soovitan mänguvideosid ja striime vaadata. Kui meeldib teha asju mida näed, siis võib meeldida; kui ei meeldi need asjad (mis hetkel küllaltki limiteeritud), siis suurem võimalus et mäng pole maitsele. Mulle igatahes meeldib (mis peaks ka sellest teemast selge olema icon_smile.gif )
Väga hea tsiteering on Scott Manley kirjeldus (pole minu kirja pandud): "What they've delivered is a wide experience, a very immersive experience, but a lot of people think that it is a mile wide and an inch deep. And that's a valid criticism, I think it's easily the most immersive space sim you have, but it is very much what you make it."
https://www.youtube.com/watch?v=qaDdVBTwJ9w&feature=youtu.be&t=5m54s
(alates 5:54 nagu link näitab, natuke pikemalt kui lühike tsitaat)
Olen ennem ka kirjutanud, et Elite on mäng kus tuleb ise seiklusi otsida, mitte jääda ootama et neid sulle jutustatakse (ja see on asi mis usun ei muutu ka tulevikus, see on Elite - nagu tagline ka ütleb - blaze your own trail). Mängu kõige suurem miinus ehk see, et ta hetkel veel küllaltki limiteeriv. Loodan minagi, et aegapidi luuakse uusi tegevusi/võimalusi (ja laiendatakse olemasolevaid). Nii neil ka plaanis (alles täna õhtu postitas üks mängu peaprodutsente et suurendavad inimeste arvu kes mängu loomisega tegelevad, ise näen selles ainult positiivset märki. Mitte et Frontier väikefirma oleks, Elite loomisega oli ametis 80-100 inimest).
r3s3t
r3s3t
sõnum 09.01.2015 12:11:17 vasta tsitaadiga
cubedude kirjutas:
Ma ei tea, võibolla asi on minus aga läksin hiire ja klaveri peale tagasi. Üpris jäik ja nõme oli tolle cyberiga lennata. Kui osta mingi gear siis ikka natuke maad kuulata jne, ei tasu kohe ehku peale minna ja mingit saasta koju tellida.
Thrustmasteri asjad pidid väga korralikud olema ja kui arvestada et 2015 on space simu aasta siis võib juba CH productsi geari osta, siis läheb juba 100-150€(throttle, fighterstick)
Siis võib kindel olla et asjad korralikud ja mäng nauditav.
komafriik ,,
lazynator
lazynator
sõnum 09.01.2015 18:09:42 vasta tsitaadiga
võtsin ka ligi , esimene selline "space sim" mida mänginud olen , esimene mängusessioon venis kella 6eni hommiku icon_smile.gif siiamaani rahul
mängin controlleriga proovisin joysticki ka aga ei istunud.
soovitan VoiceAttacki ka kasutada teeb elu mugavamaks , fullout nerd mode tahad siis võid mõne Voice Packi ka ligi võtta.
http://www.elitetradingtool.co.uk/ kah abiks.
huvi pärast küsin mis süsteemis keegi asub ise hetkel LHS 3479
el Bambito
Scart
Scart
sõnum 09.01.2015 18:13:35 vasta tsitaadiga
Ma pole alates 19 detsember ühtegi teist mängu käima saanud pannagi. Häirivalt hea mäng on icon_lol.gif
raitl
sõnum 09.01.2015 18:28:46 vasta tsitaadiga
Scart, tore näha et esmased emotsioonid ei suutnud sind heast asjast eemale peletada icon_cool.gif
Scart
Scart
sõnum 11.01.2015 14:34:07 vasta tsitaadiga
raitl kirjutas:
Eks parandamist on veel küllaga, kuid baas on all aus. Frontier teatas ka just, et nad on müünud 300k koopiat, seega tulevik on helge.
Kuna siin threadis on tõsine meedia-ikaldus, siis minu poolt üks graafika, flighti ja combati showcase video.
Link
Mõned väikesed pointerid:
1)Kui olete veel Föderatsioonis ning algusaladel, siis Eravate on esimene suur hub mida kohtate. Peamised rahategemise jaamad on Maine ja Ackermann. Näiteks ostke teed Ackermannis, viige see Potritisse ja müüge maha, ostke vastavalt rahaseisule oret ning viige tagasi Eravates Maine'i kosmosejaama, millelt ostke Marine Equipmenti ja viige Ackermanni. Hea paadiga on miljon+ krediiti tunnis selle ringiga garanteeritud.
2) Kasutage Slopey's Market Tooli ning Throddi Trading Tooli - http://www.elitetradingtool.co.uk/ ning http://www.slopey.com/ED/BPC.exe
3) Lugege Reddit, siis lugege natuke veel ja siis veel - http://www.reddit.com/r/EliteDangerous Redditis on ka alamjaotused erinevate tegevuste jaoks ning abi on alati ainult paari kliki kaugusel.
4) Õppige selgeks Galaxy Map ja sellel orienteerumine. Trading Routed näitavad ära mis produkti mingi süsteem toodab ja seega ekspordib ning mida ta tarbib ja mis süsteemist seda sisse tuuakse.
5) Galaxy Map näitab lisaks ka süsteemide majandusbaasi tüüpi ehk Agriculture toodab ilmselgelt söögikraami ning Extraction pakub müügiks erinevaid maake ning maagid on hetkel vaieldamatult suurima kasum-per-tonn produktid, mida lihtsurelik saab vedada. Maksimaalne kasum on rare itemid, aga neid just Sidewinderiga ei vea.
6) Tehke missioone ja andke sisse bountysid, et saada reppi. Repp on kahetasandiline - on valitseva jõu repp ehk Föderatsioonis on Födede repp ning lisaks on süsteemides ka selle süsteemi kohapealsete elanike kuid ka intergalaktiliste korporatsioonide repp. Mida kõrgem on teie repp, seda paremaid (loe: "rohkem kasumit andvaid") missioone kosmosejaamades antakse ja see skaleruumine on üsna metsik. Kui esimesed missioonid annavad 3-4k kasumit, siis ma lõpetasin täna kahe hüppega cargo haul missiooni, mille kasum oli 145k puhtalt.
7) Ostke ja uuendage laevu High Tech (High Tech on majandusbaas nagu ülal mainitud ning on Galaxy Mapil kirjas) süsteemides. High Tech süsteemide jaamad on varustatud kõige parema varustuse ning kõigi saada olevate laevadega. Eravatele lähim süsteem on GD219, mis on viie hüppe kaugusel. Võin tuua näite - Eravates Cobrale cargo holdid peale ostes on kõige suuremad kaheksatonnised aga GD219 süsteemis on saadaval kuueteistkümnesed. Hinnavahe on ainult 20k!
8) Isegi Sidewinderiga saab teenida jahil käies korralikult pappi. Otsige üles süsteem gaasihiiglastega, mille rõngastes asuvad Resource Extraction Sited ning hüpake sisse ja blast away. Mu ülal lingitud videos on see protsess üsna mõistlikult näha ning ka Sidewinder teeb seal korralikult tööd. Mul pole hetkel detailselt meeles, aga lähim süsteem Eravatale oli kaks hüpet otse "alla". Kõigepealt eesliide-3447 ja siis sellest otse alla süsteem, oli vist eesliide-18446. Teenitud bountyd saab kätte alles jaamas, seega korralikult rapsida saanuna on arukas taganeda ning minna võtta raha välja. Kui teie laev hävineb, kaotate kõik pending maksed ehk jääte ilma bountydest ja maha müümata exploration datast.
Kris1
sõnum 11.01.2015 19:30:17 vasta tsitaadiga
Lisaks paar tükki ka omaltpoolt.
* samamoodi Nav pointid (kohe seal tähe kõrval kus tuleb hyperspace´ist välja) on hea koht bountysid küttida. Alternatiiv Resource Extraction Site´idele.
* radaril teha vahet kas mängija või NPC - kui on seest tühi ruut/kolmnurk siis mängija, kui seest täis siis NPC (ruut on relvad sees, kolmnurk on relvad väljas st valmis laskma).
* Outpostides (need jaamad kus dockimine on tähistaeva all) on võibolla raske aru saada kus pidi peab "maanduma". Hea on kohe meelde jätta, et number on alati tagumisel pool. Vähemalt mina teen selle järgi vahet (et poleks viimasel hetkel ringikeeramist).
* Erinevate laevade statsid - ise vaatan siit https://forums.frontier.co.uk/showthread.php?t=73571
Ise olen väliseid vidinaid kasutanud ainult rare asjade liigutamiseks (ja laevade specide vaatamiseks); tavalist kaubandust olen teinud kasutades loogikat ja mängu sees olevaid abivahendeid. Nii on minu jaoks palju huvitavam. icon_smile.gif
r3s3t
r3s3t
sõnum 11.01.2015 22:43:18 vasta tsitaadiga
Enda poolt veel.
Kui jõuad selle kaheksanurk kujulise stationi juurde ja ei suuda sissepääsu leida siis siruta oma käsi ekraani ette. Siruta pöial endast kaugemale ja vaata mis suunas jaam pöörleb. See pool kuhu pöial näitab, sinna suunas lenda ja leiad ka sissepääsu üles.
Kui hypercruises lendad kuhugi targeti juurde, siis pane alati 100% kiirusega. Siis kui ~7 sekundit(mitte vähem kui 7) on ETA's järele jäänud võta kiirus 75% peale, nii ei pane mitte kunagi mööda.(nende kiiruste kohta on ka bindid optionsites)
Soovitan lennata süsteemi kus on mitu Resource Extraction Pointi, lenda ühte ja lenda 3-4 minutit ringi, paaniliselt G spämmides. Kui wanted anacondad välja ei ilmu tõmba sealt uttu ja mine uude pointi.(ise tegin nii 400k 15 minuti jooksul)
komafriik ,,
sukelduja
sukelduja
sõnum 12.01.2015 10:37:57 vasta tsitaadiga
r3s3t kirjutas:
Enda poolt veel.
Mis laev ja mis relvastusega sul on?
r3s3t
r3s3t
sõnum 12.01.2015 21:42:54 vasta tsitaadiga
sukelduja kirjutas:
r3s3t kirjutas:
-snip-
Cobra, enamus juppe maxed out.
4 gimballed minigunnerit.
Kindlasti shield cell(kõige kallim mis lubada saad) vajalik kui sul ei õnnestu mente anacondasid tankima panna.
Ise tavaliselt hakkam kõmmutama alles siis kui
1. Olen julge ja mendid on anaconda shieldi kutuks teinud(neil on jõhker shield ikka, suht kaua peab vastu).
2. Olen vähem julge ja anaconda on 30% elude peal.(bounty sellest eriliselt ei muutu)
siis kui anaconda on oma shieldi regenninud, lähen kaugemale ja ootan kuni mendid selle jälle maha lasevad.
Siuke taktika meenutab siukest WoW main tank/off tank süsteemi icon_biggrin.gif
komafriik ,,
raitl
sõnum 13.01.2015 07:03:21 vasta tsitaadiga
r3s3t, ise lendan Viperiga, 2x class 1 gimballed multi-cannons + 2x class 2 gimballed multi-cannons. Avastasin "win" taktika anacondade vastu - lendad täpselt head on keskmisel kiirusel ning plasma acceleratori range jõudes rakendad evasive maneuvers icon_smile.gif
See tähendab - kiirus sinisne ala miinimumi ja full downward thrust on lateral thrusters. Samal ajal anaconda kõhtu sihikul hoides. Tulemuseks on loop of death kus anaconda sisuliselt tiirutab ümber sinu, kõht kogu aeg sinu torude ees, samal ajal on temal lahendus vaid väga minimaalsel osal torudest. Tavaliselt võtan anaconda maha enne kui seadusesilmad kohale jõuavad. Kasutades selleks maksimaalselt 1-2 shield cell laengut.
r3s3t
r3s3t
sõnum 13.01.2015 15:08:36 vasta tsitaadiga
raitl kirjutas:
Ise nägin kuidas kurjamite anaconda ühe laksuga mendi anaconda loojakarja saatis. Teised mendid läksid närvi ja jihaadisid anacondale sisse, järjest õhku lennates mina lasin lõpus salvest paarkümmend kuuli ja sain 140k, not bad icon_smile.gif
komafriik ,,
Yorick
Yorick
sõnum 15.01.2015 19:36:24 vasta tsitaadiga
http://www.escapistmagazine.com/videos/view/zero-punctuation/9991-Elite-Dangerous-Review
Kris1
sõnum 15.01.2015 23:21:13 vasta tsitaadiga
Kui juba sellistest miniülevaadetest jutt, siis lisaks omaltpoolt ka lingi TotalBiscuiti arvamusele (nagu ta nimetab et ülevaateks seda nimetada just ei saa). Esimesed 5min allolevast videost. Väga head sõnad tema poolt - ma natuke laiendaks selle ka supercruise´le ja muule kosmosevahelisele reisimisele. See on asi mis minu arvates väga hästi õnnestunud (tean ka et mõnede arvates maailma igavaim tegevus icon_lol.gif ).
Link
Ja kui veel ülevaadetest rääkida, siis täna oli "Puhata ja mängida" saadet kuulates (püüan iga nädal ikka kas youtubest otse või mingi päev järgi vaadata) huvitav kuulda nende saatejuhi Raineri arvamust. Küll alles esimene mulje, ja osadest asjadest ta (päris) valesti aru saanud, aga ehk järgmine saade juba selgem pilt (või siis juba Digi ajakirjas mingi kirjatükk).
Mängust ka. Täna tehti teatavaks järgmiste kuude plaanid. Et mitte üksipulki ümber kirjutada kopeerin lihtsalt teksti spoiler tagi sisse. Kommenteerin ainult seda, et silma on hakanud mõne mängija imestus selle üle et beta testimise eest küsitakse mingit lisasummat. Minu arvates on see just selline "kosmeetika" mille pealt loodan nad teenivad. Igal juhul minu arvates väga head uudised, ja ka tempo üle pole midagi nuriseda - veebruar pole kaugel, ja samad sõnad ka märtsi kohta. Lisamärkus ka see, et sellised 1.1 ja 1.2 jne on mängu ostjatele tasuta (ainult suurte Expansionite, mida praegu veel ühtegi ametlikult teatatud pole, eest küsitakse lisasummasid).
Ertai
Ertai
sõnum 15.01.2015 23:28:08 vasta tsitaadiga
Ma ise vaatan ka P&M saadet,aga veidi tundub, et Rainer ei ole see inimene (no offence), kes Elite'i mängiks. Liiga hardcore mäng tundub talle olevat, pigem Martini v siis isegi Reinu teema.
Kommentaarid: 52 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 47
Kris1
sõnum 16.01.2015 00:34:35 vasta tsitaadiga
Ertai kirjutas:
Ma ootaks järgmise nädala ära - võibolla tuleb sealt sellist kriitikat et taotakse maa alla. icon_lol.gif
Aga heameel et keegi neist võttis mängu ette. P&M on väga mõnus saade, jutt jookseb neil hästi ja nende arvamust erinevate mängude ja uudiste kohta on väga huvitav kuulata.
NeroEST
NeroEST
sõnum 16.01.2015 14:22:29 vasta tsitaadiga
See on vist harv kui zeroP kiidab mängu.
Nii, et polegi siis flop?
X- rebirthile teeb silmad ette?
Winter is coming...
Kommentaarid: 38 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 37
Scart
Scart
sõnum 16.01.2015 15:50:34 vasta tsitaadiga
NeroEST kirjutas:
Täiesti erinevad žanrid ning võrrelda neid ei saa. Elite on noh, Elite ja ma ei teagi ühtegi teist samasugust mängu.
r3s3t
r3s3t
sõnum 16.01.2015 16:03:47 vasta tsitaadiga
Scart kirjutas:
NeroEST kirjutas:
X rebirth oli siuke feil, et pole just raske maaslamajat togida.
komafriik ,,
Ertai
Ertai
sõnum 16.01.2015 19:46:57 vasta tsitaadiga
Kuna ma ise olen suur X seeria fänn olnud, siis peaksin Elite'i ligi võtma (sadu tunde Xide all)
Rebirthi ei mänginud, õnneks ei teinud ja preorderi.
Xid olid ikka väga head asjad, X:Terran Conflict näiteks.
Probleem selles, et kuidagi tühjaks lõpuks jäi jne.
Elite täidab selle augu vähemalt vast ära ja edasiminek on tohutu.
Kris1
sõnum 16.01.2015 21:08:40 vasta tsitaadiga
Neile kes Frontieri foorumit ei külasta, ega mänguarendajate postitusi jälgi, siis paar väikest uuendust mis kõige eelduste kohaselt peaks 1.1 sisse tulema.
AI programmerija Sarah Jane Avory kirjutas, et muutis ümber süsteemi kus iga kogemata tulev lask vastase pihta kuulutab tagaotsitavaks (wanted). Kopeerin olulisemad tsitaadid ja detailid:
Mängu peadisainer Sandro Sammarco kirjutas väiksest muutusest shield cell bank´iga:
Serio
Serio
sõnum 16.01.2015 21:19:07 vasta tsitaadiga
Mul veel seda mängu ei ole aga jälgin suure huviga arengut. Hea viis arendajate postitusi näha on kasutada RSS Feed-i. Firefoxis kasutan Bamboo Feed Reader laiendit.
Selles teemas on seletatud kuidas seda teha: https://forums.frontier.co.uk/showthread.php?t=52253
Laiakas
Laiakas
sõnum 17.01.2015 11:48:11 vasta tsitaadiga
Asi on sama kaiff kui esimene Elite icon_smile.gif Tellisin omale riiuli-iluks selle karbiversiooni ka ära: praegu on see veel küll pre-order aga küll nad valmis pressivad need plaadid kah icon_smile.gif Eriti mõnus tunne on, et esimest Elitet sai aastaid näpitud ja kuna klahvid on suht samad esimese Elitega siis laeva juhtimine on käemällu jäänud icon_smile.gif Mõtlemist on siin muidugi rohkem. Natuke häirib see, et esimeses Elites võisid laeva täiustada palju vaid pappi on: siin aga määrab jubinate külgeinstallimise laeva kandevõime ja kinnituspunktide arv. Vähemalt mulle tundub nii esimestel muljetel: kaupmees, kaevur, õnnekütt, avastaja jne: igal juhul pead valikud tegema, et mida sul just vaja on. Praegu on mul algne sidewinderi kast ja olin valiku ees, et kas fuel scoops või cargo rack. Mingist docking computerist ei saa unistadagi: osta jõuaks aga siis peaks millestki olulisemast loobuma. ... nu üli-pro-superasi ja ei kahetse ühtegi eurikut. Laev ootab ja lendama, ei saa kaua jututada midagi icon_biggrin.gif
Elite on Elite
viimati muutis Laiakas 17.01.2015 16:54:37, muudetud 2 korda
raitl
sõnum 17.01.2015 12:33:55 vasta tsitaadiga
Laiakas, vaheta olemasolevad komponendid kallimate ja kvaliteetsemate vastu. Enamasti on nad kergemad ja sealt need väärtuslikud tonnid tulevad.
Laiakas
Laiakas
sõnum 17.01.2015 16:10:43 vasta tsitaadiga
Mhhh... on ikka nii? Internal moduleid on sidewinderil näiteks 11 ja nii paljusid pudinaid saadki külge kruttida või kuidas see 12. koht tekiks? Näiteks tahaks fuel scoopikest veel lisada aga kõik moodulpesad juba kasutusel. Tonninduse vähendamine teeb lihtsalt laeva kiiremaks ja manööverdusvõimelisemaks.
Elites olen ka laiakas nimega, kui seal näete siis ärge omasid pekske icon_razz.gif
Veel muljeid proovimistest:
Piraatlus: natsa paremad laserid peale ja võib hädisemaid bot-e toksida küll: suht ruttu jätavad kauba maha aga ise jõuavad udu tõmmata. Ühesõnaga kosun enne siis vaatan seda teemat.
Tellimused jaamades: õnneasi, mis trehvab. Võib ka mingi konteineri toimetamise eest algaja jaoks hea nutsu saada arvele.
Kaevandus: jube tüütu asi nagu esimeseski Elites icon_biggrin.gif Käi ja toksi asteroide nigu totakas, sest neid scannida ei saa ning enamus sisaldab odavat rämpsu. Plaatina, kuld, beryllium ja nu hõbe kah on norm hinnaga. Ja kui tüki küljest lased siis on väärt kraami sisaldus tavaliselt vaid mingi 10-18 protsenti. üle 30 prosese maagi pudenemine on pidu-pidu icon_razz.gif Laeval peab ka raffineerimisseade olema, mis üleliigsest rämpsust eraldab maksva väärtusliku osa. Mingit tonnikest hõbedat siksisin ühe asteroidi juures tund aega ja siis viskasin jaamas kaevanduslaserid minema. See on lihtsalt igav. Mulle vähemalt.
Kaupmees: selleks peab suur laev olema kui tavakaupu liigutades hästi teenida tahad. Tulevikus ostan ja proovin.
Uurimine: korralikud scannerid (mu arust saab algse basicuga vaid tähti lahata ja planeediga ei oska see midagi peale hakata: Täiendus: saab planeete ka, just proovisin.) ja laev peaks siis vast Eagle olema: kiire ja nobe.
Ühesõnaga: kõik algajad puutuvad kokku hunniku dilemmadega, et mida teha ja kust pappi arenemiseks saada icon_biggrin.gif Mina ka icon_razz.gif
Aga VÄÄGA-VÄÄGA haigelt hea asi ja ilge tundideneelaja, niiet tähelegi ei pane icon_smile.gif Ja see reaalne Universum milles lendad: juba nende vaatepiltide pärast tasub Elites lennata: kõik on erinev, kordumatu ja ülikaunis!
... jätk
Reaalmaailmas tagasi icon_biggrin.gif Nagu ütlesin siis Elite kaotab ajataju icon_razz.gif
Tähelepanekuid:
*tagaotsitava (wanted) kleepsu saab omale lihtsalt: lased kedagi keda ei tohiks, tühistad tellimuse, numisiganes aga seda staatust ei pea põdema. Mu pearaha on praegu Föderatsiooni poolt mingi 29 tuhhi. Neid saan ise föderatsiooni baasis ära tasuda ja kõik oki. Praegu lihtsalt sebin anarhhiates icon_razz.gif Kui pollar või piraat üritab sind hüperruumis maha tõmmata siis hakkab ta sind reaalkosmosesse sikutama. Sellest saad pääseda: su ette tekib siis selline rescue tunnelile suunav sinine target ja kui suudad end sellel suunal hoida (laev on natsa alajuhitav siis ja see asi rillerdab ekraanil) siis pääsed. Enamjagu ma olen pääsenud. Kui siiski sikutatakse sind kosmosesse ja pahad hakkavad ahnelt sind kõmmutama, kuid algajana tunnetad, et laev on lahinguks lahja siis hoia kiirust spidoka peal sinise skaala tipus: see on mingi 70 proset mootori võimsusest. Siis säilib hea manööverdusvõime. Paned hüperi uuesti laadima, pahalast hoiad radari järgi endast taga ja vasakul-paremal (laseb enamuse sust mööda siis) ning kannatad ta võimlemised ära ning tõmbad hüperruumi uuesti udu icon_razz.gif Kõik Sidewinderiga ilusti sooritatav. Mul on algusest peale sama laev ja ei midagi hullu. Kui väga rahakesed ja eesmärgid käest ära kaovad siis saad Optionide alt oma saved nullida, kuid arvesta, et siis kaotad ka kogu eelmise läbikäidu. Tähesüsteemid, kogemuse, raha.. Proovi seda vältida: lahe ju hiljem tunda, et raskemas olukorras oled ise välja rabelenud icon_razz.gif Selliseid olukordi tekib algul sageli: võtad ülejõu käiva tellimuse: lendad mingisse pärapõrgu seda täitma ja siis avastad, et süsteem on tundmatu (ei tea kus baas), ei jätku kütust, pahasid liiga palju, baasis pole kraami mida lootsid... nu miljon asja, mis ootusi ei pruugi täita icon_biggrin.gif : ära loobu siis!, tühista ebamugav tellimus ja maksad hiljem trahvi ära ja kõik on jälle oki icon_biggrin.gif .. Elites ongi see siseehitus pettumuste ja õnnestumiste puhul rõõmustamisteks jube realistlikult üles ehitatud icon_smile.gif Miski ei tule lihtsalt aga kui tuleb siis naudid icon_razz.gif ..hiljem rikkaks ja tuunitud käruga cruisima hakkad, siis läheb muidugi igavamaks icon_biggrin.gif icon_biggrin.gif icon_razz.gif
Elite on Elite
viimati muutis Laiakas 17.01.2015 17:10:15, muudetud 1 kord
Kris1
sõnum 17.01.2015 16:46:00 vasta tsitaadiga
Laiakas,
Sisemiste moodulite limiteeritus on väga vajalik asi, see on üks tähtis komponent sellest mis teeb konktreetsest laevast konkreetse laeva. Eagle ja Viper puhul näiteks on neid küllaltki vähe sest tegu puhtalt lahingulaevadega; Cobra jällegi on universaal (head mooduli kohad + piisavalt relvakohti); Asp ja Type6 jällegi rohkete moodulitega sest esimene neist on peamiselt mõeldud kaardistamiseks (fuel scoop, detailed discovery scanner ja üldine scanner on tõsisemaks ettevõtmiseks miinimum) ja teine on esimene kesktasemel kaubalaev. Need on asjad mis panevad kombineerima, ja mõtlema mis laeva on tarvis mis ülesanneteks.
Kui keegi on sind tirinud planeetidevaheliselt liikumiselt (supercruise) välja (interdiction), siis esimene asi kogu energia mootoritesse (ENG) panna, ja boostida et jääd niipalju ellu et jõuad uuesti välja hüpata. Muidugi valik ka võidelda. Kui ma Cobraga kauplesin ja kaardistasin, siis ma isegi lootsin et mind mõne tagaotsitava poolt maha tõmmakse - väike lisateenistus kulus ära. Olen siis ennem ka kirjutanud, et väga fun on ka ise teisi niiviisi maha võtta - oled kuskil madala turvalisusega süsteemis, näed ära et mingi wanted laev liigub planeetide vahel, võtad ta sappa ja paned interdiction mooduli tööle. Tavaliselt tagaotsitavad arvutilaevad annavad ise järgi.
Soovitan ka igasugu missioone ja muid tegevusi kombineerida. Kui lähed tagaotsitavaid jahtima, vaata ennem kas bulletin boardil mingit ülesannet sellekohta pole. Või kui kaupled, äkki keegi vajab midagi, või tahab midagi kuhugi viia. Kui liigud erinevate süsteemide vahel, siis alati soovitav ka kaardistada (kui just polnud vajadust olnud see moodul ära vahetada), hea lisateenistus.
Laiakas
Laiakas
sõnum 17.01.2015 17:14:06 vasta tsitaadiga
No et siis ika kehtibki see moodulite limiteeritus icon_smile.gif Ma õrnalt lootsin, et järsku annab kohti tulevikus juurde osta. Märkisin lihtsalt, et esimeses Elites sellist piirangut polnud. Seal oli vaid relvastuse hulk piiratud. Ütleme et kui 4 laserit siis 5-t peale ei kruvinud. See on muidugi uues Elites ka. Muid porisemiskohti mul polegi icon_biggrin.gif Kusjuures see moodulite piiratus on natsa ajuvaba siiski. Sama kui sa isiklikku autosse ei saaks tahaistmele lastetooli paigaldada sest tehase manuaalis on kirjas, et navi lisamisega said kõik lisade kohad täis icon_biggrin.gif Kui mul on hi-tech praktiliselt kaalutu ja väikese energianõudlikusega lisa jaoks raha ning eeloleva põhjal laev suudaks selle pudina ära majandada siis miks ma seda saada ei tohiks? Millest ma loobuma peaks kui tahaks luksust docking computer´i näol? protsess muutub ju näiteks ruttu igavaks.. : keeruta jaama ümber platsi otsides: ma muide ei usu, et Sa ka enam seda naudiks icon_razz.gif Dokkamine on päris algajale vaatemänguline. Hiljemalt teisel päeval muutub see tüütuks icon_smile.gif
Elite on Elite
Scart
Scart
sõnum 17.01.2015 17:17:27 vasta tsitaadiga
Kris1
sõnum 17.01.2015 17:27:59 vasta tsitaadiga
Limiteeritus on kõigepealt gameplay element. Ja ka in-fiction on see päris loogiline - kui ikka laev on väike, siis sinna palju ei pane. Mõnel väiksel vidinal võib jah öelda, et mis see üks lisaskänner oleks, aga siin tuleb lihtsalt tõdeda et tegu mänguga. Kui Eagle mahutaks ära 4 või 5 sisemist moodulit, siis ma mingi teise laevaga ei mängikski. Kui aga tahan kas kaubandust või tähesüsteemide kaardistust teha, siis tuleb mul vaadata suuremate laevade poole.
Ma automaatset dockingut pole kasutanud, ja arvan et ei kasutagi. icon_lol.gif Lõbusam on ise manuaalselt (ja ka palju kiirem), ja vähemalt minul pole see veel ära tüüdanud, sama fun kui alguses. Väga hästi õnnestunud element.
Laiakas
Laiakas
sõnum 17.01.2015 17:36:59 vasta tsitaadiga
Scartile
Lase ajal natsa joosta, Su arvamus muutub sest ekraanil visuaalne pilt ju ei muutu ning kogu protsess muutub Su jaoks tavaliseks AEGASÖÖVAKS rutiiniks icon_razz.gif Umbes nagu hommikul hambaidpestes teed samu liigutusi icon_razz.gif Mul esimesest Elitest sellest siiber icon_biggrin.gif icon_biggrin.gif Et asi edaspidi põnevust dokkamisel säilitaks peaks arendajad sinna siis mingi tiheda trafficu juurde tinistama või jaamasid põnevamaks tegema visuaalselt. Usu mind, see muutub ajas samaigavaks kui bussijuht oma igapäevast marssuuti läbib...
Krisile
Mäng on Elite reikarnatsioon ehk olemuselt ju tema taaselustamine: nagu ise ütlesid, see on mäng. miks siis esimese reaalsusega rohkem klappivast osast loobuma pidi??? (isegi X-Tensionis polnud moodulite piirangut ju, mis on Elitega võrreldes lahja kõiges muus).. Simulatsioon peaks ikka püüdma loogikasse jääda mu jaoks ka nii ajuvabas punktis kasvõi, et menüüst oleks võikamalik ka lastetooli paigaldada icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif
Elite on Elite
viimati muutis Laiakas 21.01.2015 11:54:57, muudetud 3 korda
Scart
Scart
sõnum 17.01.2015 17:40:02 vasta tsitaadiga
Laiakas kirjutas:
Scartile
Ma pole mänginud midagi muud alates launchipäevast, seega ei muutu siin rutiiniks midagi. Kui sul on miljoni eest träni trümmis, värisevad käed päris korralikult iga kord.
Laiakas
Laiakas
sõnum 17.01.2015 19:26:45 vasta tsitaadiga
eeem.. icon_smile.gif Ma sain vanas Elites Elite taseme ja kuna see asi on tõsiselt võluv siis see jama naelutab Su aastateks icon_razz.gif Käte värin kuulub asja juurde miljoniga icon_biggrin.gif .. Tõsisema mängimise puhul on sellised piiramised pikema aja jooksul nagu tõrv meepütis. Ohh , muidugi on see dokkamine kama ja üleelatav ... lihtsalt ma ei taba loogilist pointi, et milleks see olema peab. Fuel scoop näiteks pole enam luksus aga tähesüsteemide tõsisemal avastamisel juba hädavajalik asi, et ennast tähe juures tankida.. nu krt. pole kuhugi installida seda oma sidewinderile: kõik olemasolevad moodulid on hädavajalikud.. Arendajad võiks siis vähemalt 2-3 lisakohta juurde panna. Ma muide ei usu et nad oma arendustegemistes ennast ise nii piiraks testides icon_razz.gif Cheativad nagunii icon_razz.gif
Hahaaa icon_biggrin.gif ma üldse ei tahtnud nii palju vinguda icon_biggrin.gif icon_razz.gif
Ok, midagi lahedat ka siis: ma ostsin Voiceattaci ja häälkäskluste paketi Elite Dangerousile. Häälkäsklused on omamoodi kirss tordile icon_smile.gif Illustreerimiseks üks ja teil suu vesiseks ajamiseks muarust täitsa lahe venku video Astrast:
https://www.youtube.com/watch?v=s4QkltClArw
Täitsa äge tunne on kui ütled: gear up või jump ning Elites kõik nii juhtubki pluss kõrva hellitavalt ka ju kuulatav vastureaktsioon, sest tädi hääl on.. nu lahe icon_biggrin.gif Paketis mis ma ostsin on Astra vastuseid .. väääga palju icon_smile.gif ja seal videos olev Rimas jagas ka oma VoiceAttaci häälestusprofiili (Täiendus: tsekkasin just, ta on youtuubikus selle lingi maha võtnud aga mul on olemas. Kes tahab siis mailigu mulle laiakas@mail.com ja saadan. mul on see olemas) ning temal oli seal viide mingile hullule kogusele käskudele, kus Astra räägib lisaks käskude teostamisele küsimise peale tähespektritest, müüdavate kaupade kirjeldusi ja igast värki: mingi selline wikipedia moodi.., aga niipalju ju nagunii ei kasuta.
Täiendus... ei saa ju nii laisk olla - peksa mulle icon_biggrin.gif, et kribad foorumisse ja viiteid ei anna. Nii, kes asjade vastu huvi tunneb siis:
*Elite Dangerosi jaoks Astra (nu see laheda häälega tädi vastused icon_razz.gif) saab osta siit: http://www.elitedangerousvoicepack.com/ ja lisaks proge VoiceAttack siit: http://www.voiceattack.com/ . Esimene maksis mingi vist 7 eurikut ja teine oli vist 5 kopikatega. Natsa otsisin piravariante ka aga.. las see mäng jääb täitsa puhtaks: inimesed on kõvasti vaeva näinud icon_smile.gif Asja mänguga kokkusidumiseks annan sellise video: https://www.youtube.com/watch?v=6aQwq01L8kc ingliskeelseid on ka, mul vene keel lihtsalt rohkem suus, see venekeelne õpetus.
Elite on Elite
Scart
Scart
sõnum 17.01.2015 19:31:08 vasta tsitaadiga
Müü Sidewinder maha ja liigu edasi, mis sa selle nuubilaevaga ikka rabeled.
Laiakas
Laiakas
sõnum 17.01.2015 21:38:53 vasta tsitaadiga
Küll jõuab icon_smile.gif Pealegi pole sellel winderil ka midagi väga häda kui tuunida: hiljem uut laeva ostes saad sinna investeeritud enamus raha hinnas tagasi ju. Uues Elites on piraatide agressiivsus võrreldes esimese Elitega ikka hämmastavalt lahja: selle SideWinderiga võid rahulikult tükk aega ringi loperdada. Siin kui seisu tahad pead rohkem ise torkima minema icon_smile.gif
Loodan, et mingi updatega tuleb veel üks komponent 84 aasta Elitest siia. UFO-d. Neid kohtas üliharva. Tulid ei tea kust: jube kiired, kannul püsida ei õnnestunud, et jälitada. Neid oli ka pagana raske hävitada: ülikiired, manööverdasid järsult. Piisavalt osav olid ja võimas relvastus siis sai jagu küll. Enamjaolt hävinesid täielikult, vahel harva jätsid mingi erimagusa nänniga konteineri maha icon_smile.gif .. neil seal Frontieris on vanu üllatusi lisada küll ja küll veel..
Elite on Elite
sukelduja
sukelduja
sõnum 17.01.2015 23:49:59 vasta tsitaadiga
Elu nagu seiklusfilmis, kuidas minnakse jälitama piraati, kelle eest 800 000+ pearaha välja pandud.
https://www.youtube.com/watch?v=czqGrxujscg&feature=youtu.be
Ertai
Ertai
sõnum 18.01.2015 00:03:25 vasta tsitaadiga
sukelduja kirjutas:
vaatasin ka selle eile ära.
Üks kahest youtube'i tegelasest, kelle gameplay'd vaatan. (teine mäng pole Elite)
Väga lahedalt edasi antud Elite'i. Kutt on üle keskmise osav ja tark ka.
P.S. Kas on tõsi, et Braben ja Co liidab mingi hetk jaamades ringi liikumise jms asja ka ? Ehk mingisugune FPS tugi, kus jalutad ringi.
Hetkel üks suuremaid puudusi on vist korralik co-op süsteem,kus bountyd ja asjad jagatud ja üksteisele creditsi ülekandmine jne.
RPSi artikkel oli päris hea Elite'i kohta.
Tundub nagu oleks ikka veel 0.9 Elite, aga kindlasti liigub legendaarse staatuse suunas.
Kris1
sõnum 18.01.2015 02:33:09 vasta tsitaadiga
Isinona videod on jah juba legendaarsed. Juba tema FAOFF dockimised panevad imestama. Tal igas videos on ka oma narrative, ja kuigi mõni tema otsus pole olnud kõige targem, siis tema oskustes ei kahtle keegi.
Lisan siia ühe teise mängija video, midagi sarnast nagu siin lingitud viimane Isinona oma. Tsiteerides tema videot - putting the "hunting" back into bounty hunting. Väikse lisamärkusena oli mullegi siin videos paar asja mida ei teadnud.
https://www.youtube.com/watch?v=m3Q7c0dkI3c
Rääkides expansionitest, siis praegu veel ei tea mis tuleb ja millal tuleb. Suure tõenäosusega esimene on jah kas planeetidele maandumine/liikumine või siis laevasisene/jaamasisene liikumine. Arvan et need tulevad eraldi, ja mingi hetk tagasi vähemalt öeldi et plaan on neid etappidena välja lasta (a´la planeetidele maandumine on kõigepealt atmosfäärita kuud, ja sealt liigutakse edasi keerulisemate asjade juurde). Viimastest uudistest teame vaid niipalju et arendustiimi laiendatakse. Eks sellised asjad võtavad aega, ma lähiajal küll midagi ei ootaks, võimalik et isegi mitte käesoleval aastal. See on kindlasti suur töö - samas kui suutsid Elite alla 2 aastaga valmis teha (kickstarteri viimane päev oli 5.jaanuar 2013), siis ei üllata mind midagi.
Eks Elitel jah mõneti sellist 0.9 maiku, kuid see ka arusaadav miks tehti otsus aasta lõpus välja lasta. Kuhugile tuli joon tõmmata, ja kui mõelda et poleks detsembris välja tulnud siis vaevalt oleksime palju võitnud kui väljalase olnuks näiteks olnud sellel nädalal. Nüüd oli neil joon 16.detsembri peal, siht silme ees, ja usun anti endast maksimum. Nüüd kui jõulupuhkus läbi, asuti uuesti tööle - sealhulgas keerulisemate bugide likvideerimine ja vanade asjade lihvimine. Siiski arvan et 1.0 (mis nüüd jõudnud 1.05 peale) on olnud väga stabiiline, ja raskemaid bugisid pole ka meeletult olnud (ise pole millegi sellise otsa komistanud - et maandumistuled mõnikord vilguvad ja kustuvad elan üle). Nagu ka eelmine nädal öeldi, et paljud parandused jäävad 1.1 peale (nagu Frontieril tavaks olnud et x.0x uuendused on ainult kriitilisemad asjad). Kuna müüginumbrid on olnud head (viimased numbrid mida teatati oli 6.jaanuari seisuga £14.1 miljonit), ja et arendustiim laieneb, siis see on tuleviku suhtes kõige tähtsam. Üks ütlus (mitte konkreetse mängu kohta vaid üldiselt) mida olen lugenud sobib siin hästi - "mänguarendaja kõige suurem vaenlane on aeg" (st. alati seda liiga vähe et kõik asjad oleks nii nagu vaja) - ja see paneb natuke ka teiste mängude puhul teisiti mõtlema (kirume küll GTA ja Witcheri edasilükkamist, aga neil on selline võimalus mängu paremaks teha). icon_smile.gif
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Elite: Dangerous mine lehele eelmine  1, 2, 3, 4, 5, 6, 7, 8, 9  järgmine
