08.11.2014 12:08:04
| trip kirjutas: |
Platz 1: Der Testsieger
MSI GeForce GTX 970 Gaming 4G
The editorial says the MSI GeForce GTX 970 Gaming 4G for this reason a full purchase recommendation.
ja kogulugu  |
järgmine on zotac, muid selgusetuks jääb, miks?
selle pärast?
| The three fan switch in the 2D mode, unfortunately not turned away, but operate with a relatively low volume |
lugesin siis guugli tõlge
keegi seletaks selle lõigu lahti?
Those who place great emphasis on overclocking, should resort to a graphics card that is different preferences for the reference-Power Target and its far exceeded by Nvidia. Use the following table is used to classify the eleven graphics cards tested. The reached in Anno 2070 Power target at the standard frequency is read using the tools GPU-Z.
Model Achievements Power Target Maximum Power Target
Asus GeForce GTX 970 Strix 95-98% 120%
Gainward GeForce GTX 970 106% 106%
Gainward GeForce GTX 970 Phantom 106% 106%
Galax GeForce GTX 970 OC EX 100% 125%
Gigabyte GeForce GTX 970 G1 Gaming 78-79% 112%
Inno3D GTX 970 King Mod watercooled 100% 106%
MSI GeForce GTX 970 Gaming 4G 99% 110%
Palit GeForce GTX 970 JetStream 95-96% 111%
Zotac GeForce GTX 970 105-106% 106%
Zotac GeForce GTX 970 Omega Edition 53-55% 106%
Zotac GeForce GTX 970 Extreme Edition 54-55% 106%
Endless reserves of power with respect to targets have the Zotac GeForce GTX 970 and the GeForce GTX 970 Omega Extreme. The Gigabyte GeForce GTX 970 G1 gaming will remain free from all problems especially after the possible increase. The Asus GeForce GTX 970 Strix, the Galax GeForce GTX 970 OC EX, the MSI GeForce GTX 970 Gaming 4G as well as the Palit GeForce GTX 970 JetStream do not have reserves, but this can be achieved at the maximum clock quickly.
All other models have however already at the standard clock Power Target or even exceed it. This is, interestingly, throughout the reference PCB of the case - only the water-cooled GTX 970 King Mod Inno3D watercooled adheres to the guidelines. |
trip
08.11.2014 12:12:09
zotac maksab 50€ rohkem kui msi .
303 |
kazemaky
08.11.2014 12:28:31
Ma saan DVI-ga biosesse küll, aga seda ainult juhul, kui monitor on enen arvuti sisse lülitamist juba sees. kui monitori pärast alles sisse lülitada, on pilt must kuni windoosani. Veits tüütu
08.11.2014 12:31:49
miks sa monitori eraldi sisse pead lülitama?
kazemaky
08.11.2014 13:20:22
ma olen harjunud seda välja lülitama koos arvutiga, aga ju pean siis hakkama sees hoidma
08.11.2014 13:26:31
| kazemaky kirjutas: |
ma olen harjunud seda välja lülitama koos arvutiga, aga ju pean siis hakkama sees hoidma  |
palju ta elektrit võtab, kui arvuti väljas, 1w?
NATAS999
08.11.2014 13:43:59
| odavam on siis juba lülitiga vargapesa külge arvuti asjad panna. iseasi kui hästi selline klõpsimine toitekatele mõjub.
| Kommentaarid: 41 loe/lisa |
39 |
liiv
08.11.2014 16:03:57
| Tomorrow kirjutas: |
| Scart kirjutas: |
Nvidia võiks küll toorelt <b>piix</b> käia. Tegelt ka noh. Nüüd siis tullakse välja bundlega, mis annab selle sügise AAA mängu ning eelnevalt ostetud kaardid ei ole eligible.
http://www.geforce.com/PickYourPath |
Nvidia...lastes ostjaid üle alates 1999  |
lapsed, pole väga põhjust solvunud olla, eesti ei nagunii kuulu riikide nimekirja kus bundlesid jagatkse. seesamunegi...mida tahtsingi öelda. loo moraal on selles, et kaarte tuleb osta minu käest sest saksamaa on listis
oli täna kopikas rohkem aega ja tegin ühe testi GTX 970 SLI kaartidega. kogu krempel on stockis (ka vesijahutiga prose) http://www.3dmark.com/3dm/4644866, mitte extreme variant http://www.3dmark.com/3dm/4645498?
kohe installin masinasse GTX 980 SLI ja teen veel mõne testi (kui kedagi mõni spets test huvitab siis võin proovida)
| Kommentaarid: 627 loe/lisa |
9 :: |
6 :: |
517 |
08.11.2014 16:17:17
liiv, AMD ei tee ka Eestiga koostööd, a kaartidega tulid kupongid kaasa ikkagi.. välismaa ladudest tulevad meile eniveis ju.
Tee mängude benche ka.
182 |
liiv
08.11.2014 20:55:02
| rmc kirjutas: |
Tee mängude benche ka. |
mhm, eks sõltub jah algallikast. Mõnel tootjal on baltikumis esindus, näiteks Asust võetakse vist on Leedust, need ei saaks mänge sest meie regioonile pole ette nähtud
Tegelikult ma oleks tõesti nõus tegema benche, ma testin paljusid kaarte (praktiliselt kõiki mudeleid). Nett on erinevaid reviewsid täis aga nende usaldusväärsus kõigub tavaliselt 30% (osad on ju tootjate või müüjate poolt tellitud ja nei ole niiväga erapooletud). Jagaks tulemusi hea meelega teistega aga ma vajaks veidi abi selle juures. Näiteks keegi võiks veebilehe teha, kuhu testide tulemused üles panna. Mõnede testprogrammide juures vajaks abi, ma ei tea täpselt millega täpselt testida ja mis setingute juures jne. Uued mängud on reeglina endal olemas
9 :: |
6 :: |
517 |
dohc-48v12
Aeg maha 1p
08.11.2014 21:09:27
| liiv kirjutas: |
| rmc kirjutas: |
Tegelikult ma oleks tõesti nõus tegema benche, ma testin paljusid kaarte (praktiliselt kõiki mudeleid). Nett on erinevaid reviewsid täis aga nende usaldusväärsus kõigub tavaliselt 30% (osad on ju tootjate või müüjate poolt tellitud ja nei ole niiväga erapooletud). Jagaks tulemusi hea meelega teistega aga ma vajaks veidi abi selle juures. Näiteks keegi võiks veebilehe teha, kuhu testide tulemused üles panna. Mõnede testprogrammide juures vajaks abi, ma ei tea täpselt millega täpselt testida ja mis setingute juures jne. Uued mängud on reeglina endal olemas |
_________________ Ime tala, Nagu ime kepike.
Miks ADMIN Anti112 ambusib mind? andis 1p cooldowni aga ma ei saa peale selle enam mitteühtegi postitust teha! üks päev ei kuid! |
6 :: |
85 |
08.11.2014 21:23:38
liiv, hea üleskutse, loodan, et keegi, kes pädevam veebi alal märkab. ei oleks ulmet vaja, vaid minmaalset ja funktsionaalset..
sätete suhtes.. nii palju kui kuvar, riistvara suudab ja siis levinumad resolutsioonid.. ja olenevalt perfist siis nii, et 60 fpsi ära toodaks, ehk mängitav tase, kuhu kruttima peaks :p
182 |
liiv
08.11.2014 22:49:19
| rmc kirjutas: |
sätete suhtes.. nii palju kui kuvar, riistvara suudab ja siis levinumad resolutsioonid.. ja olenevalt perfist siis nii, et 60 fpsi ära toodaks, ehk mängitav tase, kuhu kruttima peaks :p |
Kuvareid on 2. Testida saaks saaks 1920x1200 ja 2560x1440 resol. Ühes arvutis SLI (suurema resoga arvutis). Kuna hetkel on populaarne uus COD Modern Warfare siis praegu mängisin tunnikese. Resol 2560x1440, GTX 970 SLI ja fps oli 91 (+- 10%). Kui ma peaks testima suuremal monitoril väiksemat reso, kas tuleks monitor sättida 1900x1080 ja mängu optionsitest tõmban samuti sellele resole, või piisab kui muuta ainult ühte neist setingutest?
Tegelikult oleks mulle vaja nagunii mingit veebilehte. Saaks kodanikud näha ka neid tooteid mida on võimalik tellida (ma ju ei suuda kogu oma kataloogi siia müüki trükkida). Ei tahagi mingit erilist veebidisani, tavalist praktilise suunitlusega kus ei ole keeruline tooteid lisada. Kellad-viled ei ole ju olulised.
9 :: |
6 :: |
517 |
Gap
09.11.2014 01:30:21
Sain ka Asus gtx970 Strix arvutisse ja kui sai arvuti tööle pandud siis ehmatasin ära et miks kaardi vendid ei tööta ja idle temp on 44C... Otsisin siis netist et kas midagi on valesti ja tuli välja et see peabki nii olema Täitsa lõpp ikka minu jaoks.... sai siis prooviks mingi 3D mark tõmmatud, kuna momendil mul siin mänge veel pole,siis hakkasid lõpuks ikka vendid tööle päris vägev ikka,tahaks juba mängida ja vaadata kui võimas kaart siis on
| Kommentaarid: 21 loe/lisa |
17 |
09.11.2014 01:51:45
| Gap kirjutas: |
Sain ka Asus gtx970 Strix arvutisse ja kui sai arvuti tööle pandud siis ehmatasin ära et miks kaardi vendid ei tööta ja idle temp on 44C... Otsisin siis netist et kas midagi on valesti ja tuli välja et see peabki nii olema Täitsa lõpp ikka minu jaoks.... sai siis prooviks mingi 3D mark tõmmatud, kuna momendil mul siin mänge veel pole,siis hakkasid lõpuks ikka vendid tööle päris vägev ikka,tahaks juba mängida ja vaadata kui võimas kaart siis on  |
idles ma vente ei kuule ja temp ca 31c, see passiivne variant...ma ei tea. 13markis tempid yle 60 ei läinudki.
lase üks test prooviks
Gap
09.11.2014 02:10:46
| jeesus188 kirjutas: |
| Gap kirjutas: |
lase üks test prooviks  |
mis programmiga ma saaks vaadata mingi testi ajal temperatuure ? ja kui mängud saan peale siis mängudes ka ? lasin mingit 3D mark DirectX11 testi enne ... täna enam ei viitsi,homme proovin uuesti
http://www.guru3d.com/articles_pages/asus_geforce_gtx_970_strix_review,1.html
| The new DirectCU II based cooler is so good that it won't even run with GPU temperatures up-to 67 Degrees C. |
17 |
09.11.2014 02:16:31
gpu-z
sensorite all pane linnuke log failile. pärast saad järelvaadata
edit: mul kaart auto peal, siiani pole suutnud vente nagu pöördesse ajada testiga. mänginud samas pole, esimene mäng farcry4 saabub varsti
heretic666
09.11.2014 10:17:33
MSI afterburner näiteks
| Kommentaarid: 73 loe/lisa |
09.11.2014 12:50:57
mu kaardiga on mingi pull - furmark käima lastes on pmst tulemuseks crash.
muidu korraliku loadiga mängides (näiteks: mordor, cod:aw) on loadi peale tulles mõne aja pärast crash.
payday2 mängides, kus gpu load on mingi 50%, paistab mõnda aega töötavat aga pikas perspektiivis on tulemuseks crash.
vahel recoverdatakse, enamasti käib masin resetti.
peale crashi, isegi kui recovery üle käib, lastakse edaspidi takt 540mhz peale ja kõrgemaks ei lähe.
kõiki 970 jaoks sobivaid draivereid olen proovinud, ei ole mingit olulist vahet.
eile peale 3-4h paydayd proovisin furmarki, lasi 5 min nagu vana mees. kaart oli soe, temp 50-60c juures.
hommikul, kaart idleb, 29c. furmark käima, 2 sekundiga crash.
kas see kurat tõesti sõltub temperatuurist?
mis temperatuuridel teil 970/980 kaardid jooksevad?
_________________ - londiste
217 |
Gap
09.11.2014 13:12:07
| heretic666 kirjutas: |
MSI afterburner näiteks |
tänud.tõmbasin selle afterburneri ära seal jooksevad mingid voldid mälu klokid ja muud asjad fan speed on seal 0% ja näitab et max 1% ... ma midagi klokkima ei hakka,kuna ei jaga seda asja ja ei saa midagi aru aga seal on see properties kus ma seal täpselt saan panna et ta mul siin näiteks 3D marki ajal näiteks temperatuure ?
sul on lausa 2 strix arvutis heretic666 kas sul on ka siis nii et idles vendid ei käigi ringi ? ja see temp 40-50 kraadi vahel ei tee kaardile midagi ?
17 |
heretic666
09.11.2014 13:44:57
Detachi see mõõdikute värk, ta recordib sulle graafiku anyway tempidest jne. Peale 3D marki sulgemist saad vaadata mis tempid olid. Idles alumine kaart mul 30 kraadi ja ülemine 60 kraadi, mõlemad passiivis. See temp kukub oluliselt kui 750D korpuse eesmine kaas ja tolmufilter vahelt võtta (2 fani pullivas õhku eest sisse), kuid vajadus selle järele puudub
Gap
09.11.2014 14:11:28
| seal all on mingi fan speed user define ja sinna klikkides kus on 0 näit ,lööb ta näidu 40% peale.seega hakkavad vendid tööle ja lööb temperatuuri 34 kraadi peale ? kas ma saan selle kuidagi nii panna et ta jääkski nii või võib nii ka olla et vendid ei tööta idles nagu muidu on ? kas sul siis nendel kaartidel ilma mingeid programme kasutamata vendid töötasid ?
17 |
heretic666
09.11.2014 14:28:48
Gap, miks sa neid fane tööle tahad hirmsasti panna ? Tegemist on tootja poolt määratud feature'ga, mitte bugiga. Kui temp üle thresholdi tõuseb siis hakkab alles fan ringi käima, madalamal koormusel pole selleks tarvidustki.
Gap
09.11.2014 14:31:51
aa ok. thnx las ta siis olla mõtlesin et äkki peavad ikkagi töötama
17 |
NATAS999
09.11.2014 14:40:23
| heretic666, see ventide seiskus hoidmine alla thresholdi on lihtsalt gimmick, ei midagi muud. näidatakse ju ainult core tempi, mida teeb vrm ja mälud, seda ei tea ju mitte keegi. kusjuures vendid tõmmatakse nullist käima mingi ülimadala rezhiimiga, ehk siis koormus käivitusel on sitaks suur, mis omakorda mõjub mootorile ja toitele laastavalt. ise hoian gpu vente 80% peal ja kuskilt 60 pealt või nii lükkab pöörded põhja. müra mind ei häiri, kuna kõik ülejäänd vendid on nagunii 100% peal (2xCPU + 6 korpuse venti ja toide) ja 80% peal video vendid müra juurde ei tekita.
39 |
