Vares
08.09.2011 16:23:26
Üritan siin ka ajaga kaasas käia ja plaan oli 1.5x pealt 1.7-le üle minna aga selgus, et otse ei saagi, enne vaja veel 1.6-le üleminek teha. Olen nüüd 1.5x pealt 1.6 üleminekuga pool päeva jamanud aga tulemus on ikka selline, et Jupgrade ei jõua peale lahtipakkimist kuhugi edasi. Debug näitab kirjeid:
Checking DONE
[decompress]
[install_config]
Warning: require_once(/home/np51160/domains/xxx.xx/public_html/jupgrade/libraries/joomla/methods.php) [function.require-once]: failed to open stream: No such file or directory in /home/np51160/domains/xxx.xx/public_html/administrator/components/com_jupgrade/includes/install_config.php on line 24
Fatal error: require_once() [function.require]: Failed opening required '/home/np51160/domains/xxx.xx/public_html/jupgrade/libraries/joomla/methods.php' (include_path='.:/usr/local/lib/php') in /home/np51160/domains/xxx.xx/public_html/administrator/components/com_jupgrade/includes/install_config.php on line 24
[cleanup]
[install_db]
Warning: require_once(/home/np51160/domains/xxx.xx/public_html/jupgrade/libraries/joomla/methods.php) [function.require-once]: failed to open stream: No such file or directory in /home/np51160/domains/xxx.xx/public_html/administrator/components/com_jupgrade/includes/install_db.php on line 30
Fatal error: require_once() [function.require]: Failed opening required '/home/np51160/domains/xxx.xx/public_html/jupgrade/libraries/joomla/methods.php' (include_path='.:/usr/local/lib/php') in /home/np51160/domains/xxx.xx/public_html/administrator/components/com_jupgrade/includes/install_db.php on line 30
[undefined] [undefined]
Warning: require_once(/home/np51160/domains/xxx.xx/public_html/jupgrade/libraries/joomla/methods.php) [function.require-once]: failed to open stream: No such file or directory in /home/np51160/domains/xxx.xx/public_html/administrator/components/com_jupgrade/includes/jupgrade.class.php on line 78
Fatal error: require_once() [function.require]: Failed opening required '/home/np51160/domains/xxx.xx/public_html/jupgrade/libraries/joomla/methods.php' (include_path='.:/usr/local/lib/php') in /home/np51160/domains/xxx.xx/public_html/administrator/components/com_jupgrade/includes/jupgrade.class.php on line 78
Ja siis jääb seda viimast osa kordama ja kordama.
Üks kahtlusalune on Netpoint oma kaustade õigusega, sest enne pidin juba tunde erinevaid kaustu ja faile otsima ja nende õigusi muutma, et näiteks saaks 1.522 pealt 1.523 peale üle minna ja et Jupgrade üldse tööle hakkaks.
Aidake hädalist! Äkki on variante, kuidas uuendus muude vahenditega ära teha? Puhta Joomla install ja siis sinna andmete üleviimine on kui töömahukas?
_________________ ValiHeli - Eesti suurima kodukino- ja stereokõlarite ning kõrvaklappide valikuga helitehnika salong! |
66 |
Vahur
20.10.2011 10:33:00
| Oleks vaja Joomla 1.7.2'le lisa, mis lubaks lehti teisse keelde tõlkida. Lisaks oleks veel vaja külastajale automaatselt IP järgi vastavat keelt näidata. Varem kasutasin tõlkimiseks Joom!Fish'i, aga seda pole 1.7'le tehtud.
388 |
Eraser
20.10.2011 10:37:23
| [VaHuR] kirjutas: |
| Oleks vaja Joomla 1.7.2'le lisa, mis lubaks lehti teisse keelde tõlkida. Lisaks oleks veel vaja külastajale automaatselt IP järgi vastavat keelt näidata. Varem kasutasin tõlkimiseks Joom!Fish'i, aga seda pole 1.7'le tehtud. |
Kui pole mingi väga keerulise ülesehitusega leht, siis võid kasutada ka Joomlasse endasse sisseehitatud võimalust mitmekeelsete saitide loomiseks.
Ja kui oled julge poiss, siis võid kasutada ka JoomFishil põhinevat komponenti FaLang. Praegu on see veel beetastaatuses, aga lootust on, et see võib sul ikkagi toimida.
Komponendi eestikeelne tõlge on kah juba valmis, aga jagamiseni pole veel jõudnud.
30 |
eltso
20.10.2011 10:37:41
| [VaHuR] kirjutas: |
Kas sa seda sisemist mootorit ei proovinud mis 1.7-l on?
Ise ootan ka millal joomfish 1.7-le tehakse, nii kaua peab sisseehitatud varianti kasutama.
| Kommentaarid: 14 loe/lisa |
14 |
Laurman
02.11.2011 10:52:47
Joomlaga on oskused pisut rooste läinud. Nimelt rakendan uue template ja tema jääb püsima ainult avalehele.. Teistel lehtedel on kõik vorminduseta.
Mille ma tegemata unustasin?
E: ise küsin - ise vastan. Search engine friendly url rikkus asja ära, selle disablemine kaotas probleemi.
102 |
24.11.2011 00:14:41
Esilehele vaja uudised panna. Ok niisama sain hakkama kuid sooviks panna 2 eraldi kategooriat, et ei jookseks järajest segamini need kategooriad.
Mis vahendiga annaks teha sedasi et vasakule tulpa jääb kategooria 1 uudised ja paremale tulpa kategooria 2 uudised. Või siis ülesse nr1 ja alla nr2 kategooria uudised.
Leidsin küll terve suure hunniku erinevaid abivahendeid kuid neid kõiki läbi testida
Ehk kellelgi soovitusi (algaja joomlaga, mis teha)
| Kommentaarid: 39 loe/lisa |
sakinaga
24.11.2011 01:35:47
üles kat 1 ja alla kat2 uudised saad siis, kui teed ühe ülemkategooria, millele teed kaks alamkategooriat ning siis teed lingi tüübiks articles blog layout vms ja valid artiklite sortimiseks "by category".
Loomulikult pead siis ka valima, et alamkategooriad kaasataks.
| Kommentaarid: 164 loe/lisa |
155 |
fenton
25.11.2011 11:58:38
Muult lehelt lingitud (pidevalt uueneva) pildi lisamine (Joomla 1.5)
Tahaks Joomlas kodulehele lisada üht graafikut nii, et see tõmmatakse iga korda ühelt teiselt lehelt. Et oleks niiöelda pidevalt uuenev pilt. Olen tavakasutaja, kellele tehti Joomlas koduleht ja kes suudab ise menüüsid, artikleid teha, tavalisi pilte lisada. Mingit sisseehitatud valmispluginat selleks Joomlas ilmselt ei ole?
djdanx
25.11.2011 16:33:42
| fenton kirjutas: |
Tahaks Joomlas kodulehele lisada üht graafikut nii, et see tõmmatakse iga korda ühelt teiselt lehelt. Et oleks niiöelda pidevalt uuenev pilt. Olen tavakasutaja, kellele tehti Joomlas koduleht ja kes suudab ise menüüsid, artikleid teha, tavalisi pilte lisada. Mingit sisseehitatud valmispluginat selleks Joomlas ilmselt ei ole? |
nii palju kui aru sain siis saad teha wrapperiga seda ( iframe ), topid selle graafiku urli ja korras.
| Kommentaarid: 51 loe/lisa |
46 |
sakinaga
25.11.2011 16:35:11
Eeldades, et graafik on eraldi lehel, kui ta asub mingi lehe keskel, siis on hapud lood.
155 |
27.11.2011 19:35:23
Veel üks küsimus.
Kuidas saaks sedasi et kui RSS (uudis pärineb teiselt saidilt) uudise pealkiri vaid esilehel on siis lingiks tekiks kohe uudise aadres teisel lehel mitte saidisisene.
Hetkel: uudise pealkiri (uudis ise teisel saidil) -> klikkan peale suunab minu lehel uudisele kus mingi 1 lause uudisest ja all Read More link, kuhu vajutades suunab alles uudisele reaalselt.
Kasutan Feed Gator-t http://extensions.joomla.org/extensions/news-production/automatic-articles/13573
Vist kõik menüüd läbi lapanud aga ei leidnud. Võib ka muud RSSi vidinat soovitada kui sellega ei saa.
sakunne
23.02.2012 20:13:53
Kuupäevaformaatidest erinevates tõlgetes
Kas on võimalik panna erinevate keelte kuupäevaformaadid erinevad, lätlase kommentaar:
läti keeles kuupäevad ja aastaarvud "varustatakse"
punktidega, ja aasta tavaliselt kirjutatakse kuupäeva
ette. Seega õigem oleks "2012. gada 13. februaris".
_________________ Kuna ei pruugi õigel ajal foorumisse sattuda:
SMS: 5051598 [võõraid tel. ei vasta]
Email sakunne@seenior.ee |
| Kommentaarid: 77 loe/lisa |
69 |
Amdfan
13.04.2012 11:22:19
| Palun abi, kuidas muuta Joomla 2.5 puhul brauseri tiitelribal kuvatav info nii, et mingi artikli avamisel ei kuvataks selle artikli nime. Oleks huvitatud, et sõltumata lehest mis avatud on, ei muutuks veebibrausri tiitelribal kuvatav info. Seal võikski olla ainult veebilehe enda nimi.
| Kommentaarid: 367 loe/lisa |
334 |
Eraser
13.04.2012 13:26:57
| Amdfan kirjutas: |
| Palun abi, kuidas muuta Joomla 2.5 puhul brauseri tiitelribal kuvatav info nii, et mingi artikli avamisel ei kuvataks selle artikli nime. Oleks huvitatud, et sõltumata lehest mis avatud on, ei muutuks veebibrausri tiitelribal kuvatav info. Seal võikski olla ainult veebilehe enda nimi. |
Milleks see peaks hea olema? Ma ise olen küll niimoodi asjast aru saanud, et SEO osas oleks pigem soovitatav, et lisaks saidi nimele oleks pealkirjas ka andud lehekülje/artikli pealkiri.
30 |
eltso
13.04.2012 14:25:15
| Amdfan kirjutas: |
Igal menüülingil saad valikute alt "Lehekülje näitamise valikud" panna pealkirja mida näidatakse üleval. Kui see on tühjaks jäetud, siis näidatakse artikli pealkirja.
14 |
Patsaan
29.05.2012 22:11:02
Keegi teab, kuidas saada link image "Avaleht" kõrvale?
Alustasin 24x24 link imagest, siis 16x16 ja praegu on 12x12 link image, aga siiski ei mahu kõrvale.
| Kommentaarid: 34 loe/lisa |
31 |
Eraser
29.05.2012 22:19:17
Seda saad muuta kujunduse CSS-failist.
Eks ta veidi üldine vastus ole (aga seda on ka küsimus)
30 |
Patsaan
29.05.2012 22:29:48
Selline lahter template settingute all, templateks muidu joomlage see free template.
Pean sinna lahtrisse kirjutama midagi?
31 |
sakinaga
29.05.2012 22:37:50
Kas keegi on kursis, kui palju võiks maksta joomla template tegemine? Kujundusidee on enamvähem olemas, seda ei pea välja mõtlema (olemas kujundus teise süsteemi peal, seda tuleks lihtsalt kloonida), oleks tarvis see joomlale söödavaks teha.
155 |
eltso
30.05.2012 09:16:45
Ise kasutanud siiani Gantry frameworkil põhinevaid templatesid ja nendel on, võrreldes jooma vaikimisi kujundusega, ülimalt lihtne ise teha endale sobiv kujundus, seega tuleb ise asi käsile võtta
14 |
Uhuu
20.06.2012 23:25:07
Oskab keegi aidata, kuidas oleks võimalik saata teatud e-mailile teade, kui mõni uus kasuaja juurde registreeritakse.
_________________ Windows ei ole viirus, viirus teeb midagi... |
| Kommentaarid: 15 loe/lisa |
15 |
Laurman
26.06.2012 13:11:47
| Miks mul component (hwdphotoshare) väidab, et tema kataloogid pole writable, kuigi ma andsin neile 777 õigused?
102 |
hesse
28.06.2012 21:44:20
| Sul vist on Netpointi server, mul oli midagi analoogset seal, kaustadel-failidel tegelikult pole neid õiguseid. Pöördu helpdeski, nad panevad õigeks.
| Kommentaarid: 24 loe/lisa |
23 |
J2ru
30.01.2013 17:01:32
| Keegi oskab soovitada tasuta joomla pluginat mis suudaks teha pildi kaleriisse folderieid.
| Kommentaarid: 27 loe/lisa |
19 |
Eraser
30 |
TeddyBbeer
22.02.2013 21:14:34
Olen natukene nikerdanud selle asjandusega ning on tekkinud paar küsimust.
Nimelt kuidas kategooria nimekirjale nö tutvustav tekst külge pookida? Olen proovinud igasuguseid trikke aga kohe kuidagi ei õnnestu... googel ka miskit mõistetavat vastust ei paku... mainiks veel, et webiehitamisest on üldiselt väga üldised teadmised (loe: sittagi ei oska).
ja kas web.zone.ee/koduleht lehele on üldse võimalik joomlaga tehtud kodulehte üles panna? Kuskilt jäi nagu silma, et teed amppsi vms asjaga koduka valmis ja siis transpordid selle mysgli ja phpd mittetoetavasse serverisse..
indu
| Kommentaarid: 63 loe/lisa |
58 |
woox2k
23.02.2013 00:14:02
Keegi oskab soovitada mõnd head kohta kust saaks tirida tasuta joomla pluginaid jms? Tore oleks kui valik oleks ikka suurem kui paarkümmend pluginat.
extensions.joomla.com on suht kasutuks muutunud sest enamus pluginaid nõuavad raha ja Google abiga on raske üldse midagi "free" sõnaga otsida.
_________________ Mess with the best, die like the rest! |
| Kommentaarid: 20 loe/lisa |
18 |
sakinaga
23.02.2013 00:47:56
Otsi extensions.joomla.com-st non-commercial pluginaid.
155 |
woox2k
23.02.2013 02:00:47
Kuule jah, täitsa toimib. Miks ma pole seda enne märganud... Tänud igatahes!
18 |
indu
25.02.2013 15:56:54
Tervist,
Selline küsimus on joomla kohta: Pildil 1 on näha teksti.
Category: User Modules
Published on Saturday, 01 January 2011 00:00
Written by Joomla!
Hits: 10
Tahaks sellest lahti saada mingit moodi. Category manager all sellist lollitust ei ole. Mis pagana plugin see selline olla võib ...
_________________ http://www.lossirestoran.eu/ |
58 |
sakinaga
25.02.2013 16:08:09
Mine Category Manager,
siis valid Options (http://i.imgur.com/iRyYMn0.png)
sealt saad siis valida mida näidatakse ja mida mitte. Antud juhul tuleks muuta väärtusi "Show category", "Show Publish Date", "Show Author" ja "Show Hits". See muudab globaalseid seadeid.
Kui tahad ainult ühel artiklil seda muuta, siis tuleb seda teha artikli muutmise ajal parempoolsetest menüüdest.
155 |
indu
58 |
ufo56
09.05.2014 14:06:31
Oleks vaja joomlale teha selline leht kus saab küsida hinnapakkumist.
Üks võimalus peab olema kindlasti teha nagu toodete menüü kust valides toote nime näidatakse ka pilti. Siis lisaks mõned sellised tavalised vormid kus klient saab panna kirja soovitud mõõdud jne.
Lae pildid -> pilt.io |
| Kommentaarid: 79 loe/lisa |
67 |
djdanx
09.05.2014 14:17:29
| ufo56 kirjutas: |
Üks võimalus peab olema kindlasti teha nagu toodete menüü kust valides toote nime näidatakse ka pilti. Siis lisaks mõned sellised tavalised vormid kus klient saab panna kirja soovitud mõõdud jne. |
Rsform, sellega peaks saama ilusti tehtud.
_________________ teostan töid : magento |
46 |
ufo56
09.05.2014 14:37:38
Hetkel on tehtud mingi kahtlane asi fabrikuga aga seal ei anna kuidagi seda teha kui toode valida menüüst siis vahetuks ka toote pilt. Kui keegi teab kuidas seda teha siis oleks eriti
67 |
eltso
10.05.2014 11:24:46
| ufo56, Sa erinevaid e-poe komponente pole selleks proovinud?
14 |
ufo56
67 |
kk
23.09.2014 08:56:17
| Mul on veebileht Joomla ja Virtuemart2 põhine. E-kauplusest tellimine on aga piinarikas sest klient peab 2x sisestama oma kontaktandmeid ning 2-3x kinnitama oma tellimust enne kui jõuab pangalinkideni. Kas keegi oskab soovitada kuidas seda lihtsamaks saaks teha või siis mõistliku tasu eest see optimiseerimine ära teha? Tänud!
7 :: |
94 |
Eraser
23.09.2014 13:02:05
| kk kirjutas: |
| Mul on veebileht Joomla ja Virtuemart2 põhine. E-kauplusest tellimine on aga piinarikas sest klient peab 2x sisestama oma kontaktandmeid ning 2-3x kinnitama oma tellimust enne kui jõuab pangalinkideni. Kas keegi oskab soovitada kuidas seda lihtsamaks saaks teha või siis mõistliku tasu eest see optimiseerimine ära teha? Tänud! |
Ise kasutan seda lisaprogrammi. Töötab kenasti.
Sarnaseid lahendusi muidu teisigi:
Nende kohta ei oska oma kogemuse põhjal midagi öelda, aga see Ruposteli vidin töötab mul kahel saidil ning täitsa toimib. Seadistamisvõimalusi on tal meeletult. Ühel on mul kusjuures veel alfaversioon, millel olid oma oksakohad, aga põhimõtteliselt toimib. Ühel saidil oli ka mõningaid tõrkeid smartposti pluginatega, aga neistki sai lõpuks mööda. Lisaprogramm on ka osaliselt eesti keelde tõlgitud.
30 |
sakinaga
05.11.2014 18:59:57
Nii, probleem "category blog" vaates ei ole millegipärast näidatud alamkategooriate artiklid. Ehk siis on näha ainult põhikategooria artiklid ja ei midagi muud.
Category options ja Blog Layout options
Article manager options ja kategooriate puu
Siin saab vastus olla kas väga lihtne või väga keeruline. Olen ma midagi tähelepanuta jätnud? Proovisin ka täiesti nullist uut category blog layouti teha, tulemus identne.
Minu mõistus sai igatahes otsa.
-e- Lisainfoks, et tegemist on Joomla 2.5-ga.
Lahendus, kui keegi teine otsinguga siia satub: muuta sätet "Category Order" ja väärtustada "none" vms. Artiklid olid olemas, lihtsalt alamkategooriad olid lõpus.
155 |
Laurman
102 |
djdanx
46 |
Laurman
18.01.2015 14:58:44
| EJS ei täida eesmärki. Ei peida teksti all olevat ala ära vaid muudab selle mingit teist värvi. Mina tahaksin midagi sellist nagu on tehtud sinu poolt pakutud EJS lehel Features, Installation jms..
102 |
woox2k
09.11.2015 09:42:23
Kas keegi oskab soovitada kohta, kust saaks "traditsioonilisi" aga responsive Joomla templatesi. Kuskilt lehtedelt nagu joomla24 jne. otsides ei ole üldiselt templated responsive ja Google abiga otsides tulevad alati mingisugused umbe suure kujundusega responsive lehed.
Ma just otsiks sellist lihtsat, minimalistlikku aga samas vähemalt ühe horisontaalse ja ühe vertikaalse (vasaku) menüü võimalusega. Üks hea näide oleks: https://crosstec.org/templatedemos14/index.php Sisseehitatud slaidishow oleks ka boonuseks aga mitte just nõutud. Loomulikult võiks ju näidislingil olevaga rahule jääda ja lihtsalt seda kasutada aga ma ei tahaks uskuda, et see on ainuke ja valikuvõimalus oleks ka hea.
18 |
merz
09.11.2015 12:44:42
| Pole ammu vaadanud aga www.portaliz.com lehel oli igasugu joomla asju.
| Kommentaarid: 31 loe/lisa |
31 |
Karlapoiss
09.11.2015 12:45:43
| woox2k kirjutas: |
Ma just otsiks sellist lihtsat, minimalistlikku aga samas vähemalt ühe horisontaalse ja ühe vertikaalse (vasaku) menüü võimalusega. Üks hea näide oleks: https://crosstec.org/templatedemos14/index.php Sisseehitatud slaidishow oleks ka boonuseks aga mitte just nõutud. Loomulikult võiks ju näidislingil olevaga rahule jääda ja lihtsalt seda kasutada aga ma ei tahaks uskuda, et see on ainuke ja valikuvõimalus oleks ka hea. |
Ise olen muidu joomlandist võtnud.
ehk midagi sellist? http://www.joomland.org/index.php/joomla3-x/421-master-bootstrap-joomla-3-template
| Kommentaarid: 28 loe/lisa |
28 |
aks
12.06.2016 09:47:10
Sõber on hädas oma Joomla 2.5 kodulehega.
Palju maksaks Joomla 2.5 upgrade 3.x peale?
120 |
djdanx
17.06.2016 16:01:03
| aks kirjutas: |
Palju maksaks Joomla 2.5 upgrade 3.x peale? |
oleneb palju asju peale pandud on (moodulid,pluginad,kujundused jne) ning kas nendele on uuendused saadaval või mitte ...
46 |
ahto42
30.11.2016 10:03:02
Loll on loll olla.
Küsimus. et kas on võimalik kopeerida vana leht jjoomlasse?
Leht kunagi tehtud prsSitemanageriga zones(ftp-ga ligipääs olemas), ei tahaks päris nullist alustada enam. On mingi võimalus?
| Kommentaarid: 6 loe/lisa |
