uus teema   vasta Tarkvara »  WWW »  JOOMLA ja sellega seonduv märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  järgmine
Vares
Vares
sõnum 08.09.2011 15:23:26 vasta tsitaadiga
Üritan siin ka ajaga kaasas käia ja plaan oli 1.5x pealt 1.7-le üle minna aga selgus, et otse ei saagi, enne vaja veel 1.6-le üleminek teha. Olen nüüd 1.5x pealt 1.6 üleminekuga pool päeva jamanud aga tulemus on ikka selline, et Jupgrade ei jõua peale lahtipakkimist kuhugi edasi. Debug näitab kirjeid:
Checking DONE
[decompress]
[install_config]
Warning: require_once(/home/np51160/domains/xxx.xx/public_html/jupgrade/libraries/joomla/methods.php) [function.require-once]: failed to open stream: No such file or directory in /home/np51160/domains/xxx.xx/public_html/administrator/components/com_jupgrade/includes/install_config.php on line 24
Fatal error: require_once() [function.require]: Failed opening required '/home/np51160/domains/xxx.xx/public_html/jupgrade/libraries/joomla/methods.php' (include_path='.:/usr/local/lib/php') in /home/np51160/domains/xxx.xx/public_html/administrator/components/com_jupgrade/includes/install_config.php on line 24
[cleanup]
[install_db]
Warning: require_once(/home/np51160/domains/xxx.xx/public_html/jupgrade/libraries/joomla/methods.php) [function.require-once]: failed to open stream: No such file or directory in /home/np51160/domains/xxx.xx/public_html/administrator/components/com_jupgrade/includes/install_db.php on line 30
Fatal error: require_once() [function.require]: Failed opening required '/home/np51160/domains/xxx.xx/public_html/jupgrade/libraries/joomla/methods.php' (include_path='.:/usr/local/lib/php') in /home/np51160/domains/xxx.xx/public_html/administrator/components/com_jupgrade/includes/install_db.php on line 30
[undefined] [undefined]
Warning: require_once(/home/np51160/domains/xxx.xx/public_html/jupgrade/libraries/joomla/methods.php) [function.require-once]: failed to open stream: No such file or directory in /home/np51160/domains/xxx.xx/public_html/administrator/components/com_jupgrade/includes/jupgrade.class.php on line 78
Fatal error: require_once() [function.require]: Failed opening required '/home/np51160/domains/xxx.xx/public_html/jupgrade/libraries/joomla/methods.php' (include_path='.:/usr/local/lib/php') in /home/np51160/domains/xxx.xx/public_html/administrator/components/com_jupgrade/includes/jupgrade.class.php on line 78
Ja siis jääb seda viimast osa kordama ja kordama.
Üks kahtlusalune on Netpoint oma kaustade õigusega, sest enne pidin juba tunde erinevaid kaustu ja faile otsima ja nende õigusi muutma, et näiteks saaks 1.522 pealt 1.523 peale üle minna ja et Jupgrade üldse tööle hakkaks.
Aidake hädalist! Äkki on variante, kuidas uuendus muude vahenditega ära teha? Puhta Joomla install ja siis sinna andmete üleviimine on kui töömahukas?
ValiHeli - Eesti suurima kodukino- ja stereokõlarite ning kõrvaklappide valikuga helitehnika salong!
Kommentaarid: 71 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 66
Vahur
Vahur
sõnum 20.10.2011 09:33:00 vasta tsitaadiga
Oleks vaja Joomla 1.7.2'le lisa, mis lubaks lehti teisse keelde tõlkida. Lisaks oleks veel vaja külastajale automaatselt IP järgi vastavat keelt näidata. Varem kasutasin tõlkimiseks Joom!Fish'i, aga seda pole 1.7'le tehtud.
Eraser
Eraser
sõnum 20.10.2011 09:37:23 vasta tsitaadiga
[VaHuR] kirjutas:
Kui pole mingi väga keerulise ülesehitusega leht, siis võid kasutada ka Joomlasse endasse sisseehitatud võimalust mitmekeelsete saitide loomiseks.
Ja kui oled julge poiss, siis võid kasutada ka JoomFishil põhinevat komponenti FaLang. Praegu on see veel beetastaatuses, aga lootust on, et see võib sul ikkagi toimida. icon_wink.gif
Komponendi eestikeelne tõlge on kah juba valmis, aga jagamiseni pole veel jõudnud. icon_razz1.gif
Kommentaarid: 33 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 30
eltso
eltso
sõnum 20.10.2011 09:37:41 vasta tsitaadiga
[VaHuR] kirjutas:
Kas sa seda sisemist mootorit ei proovinud mis 1.7-l on?
Ise ootan ka millal joomfish 1.7-le tehakse, nii kaua peab sisseehitatud varianti kasutama.
Laurman
Laurman
sõnum 02.11.2011 09:52:47 vasta tsitaadiga
Joomlaga on oskused pisut rooste läinud. Nimelt rakendan uue template ja tema jääb püsima ainult avalehele.. Teistel lehtedel on kõik vorminduseta.
Mille ma tegemata unustasin?
E: ise küsin - ise vastan. Search engine friendly url rikkus asja ära, selle disablemine kaotas probleemi.
Kommentaarid: 110 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 104
sõnum 23.11.2011 23:14:41 vasta tsitaadiga
Esilehele vaja uudised panna. Ok niisama sain hakkama kuid sooviks panna 2 eraldi kategooriat, et ei jookseks järajest segamini need kategooriad.
Mis vahendiga annaks teha sedasi et vasakule tulpa jääb kategooria 1 uudised ja paremale tulpa kategooria 2 uudised. Või siis ülesse nr1 ja alla nr2 kategooria uudised.
Leidsin küll terve suure hunniku erinevaid abivahendeid kuid neid kõiki läbi testida icon_neutral.gif
Ehk kellelgi soovitusi (algaja joomlaga, mis teha)
sakinaga
sõnum 24.11.2011 00:35:47 vasta tsitaadiga
üles kat 1 ja alla kat2 uudised saad siis, kui teed ühe ülemkategooria, millele teed kaks alamkategooriat ning siis teed lingi tüübiks articles blog layout vms ja valid artiklite sortimiseks "by category".
Loomulikult pead siis ka valima, et alamkategooriad kaasataks.
Kommentaarid: 164 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 155
fenton
sõnum 25.11.2011 10:58:38 vasta tsitaadiga
Muult lehelt lingitud (pidevalt uueneva) pildi lisamine (Joomla 1.5)
Tahaks Joomlas kodulehele lisada üht graafikut nii, et see tõmmatakse iga korda ühelt teiselt lehelt. Et oleks niiöelda pidevalt uuenev pilt. Olen tavakasutaja, kellele tehti Joomlas koduleht ja kes suudab ise menüüsid, artikleid teha, tavalisi pilte lisada. Mingit sisseehitatud valmispluginat selleks Joomlas ilmselt ei ole?
djdanx
djdanx
sõnum 25.11.2011 15:33:42 vasta tsitaadiga
fenton kirjutas:
nii palju kui aru sain siis saad teha wrapperiga seda ( iframe ), topid selle graafiku urli ja korras.
Kommentaarid: 51 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 46
sakinaga
sõnum 25.11.2011 15:35:11 vasta tsitaadiga
Eeldades, et graafik on eraldi lehel, kui ta asub mingi lehe keskel, siis on hapud lood.
sõnum 27.11.2011 18:35:23 vasta tsitaadiga
Veel üks küsimus.
Kuidas saaks sedasi et kui RSS (uudis pärineb teiselt saidilt) uudise pealkiri vaid esilehel on siis lingiks tekiks kohe uudise aadres teisel lehel mitte saidisisene.
Hetkel: uudise pealkiri (uudis ise teisel saidil) -> klikkan peale suunab minu lehel uudisele kus mingi 1 lause uudisest ja all Read More link, kuhu vajutades suunab alles uudisele reaalselt.
Kasutan Feed Gator-t http://extensions.joomla.org/extensions/news-production/automatic-articles/13573
Vist kõik menüüd läbi lapanud aga ei leidnud. Võib ka muud RSSi vidinat soovitada kui sellega ei saa.
sakunne
sakunne
sõnum 23.02.2012 19:13:53 vasta tsitaadiga
Kuupäevaformaatidest erinevates tõlgetes
Kas on võimalik panna erinevate keelte kuupäevaformaadid erinevad, lätlase kommentaar:
läti keeles kuupäevad ja aastaarvud "varustatakse"
punktidega, ja aasta tavaliselt kirjutatakse kuupäeva
ette. Seega õigem oleks "2012. gada 13. februaris".
Kuna ei pruugi õigel ajal foorumisse sattuda:
SMS: 5051598 [võõraid tel. ei vasta]
Email sakunne@seenior.ee
Kommentaarid: 77 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 69
Amdfan
sõnum 13.04.2012 10:22:19 vasta tsitaadiga
Palun abi, kuidas muuta Joomla 2.5 puhul brauseri tiitelribal kuvatav info nii, et mingi artikli avamisel ei kuvataks selle artikli nime. Oleks huvitatud, et sõltumata lehest mis avatud on, ei muutuks veebibrausri tiitelribal kuvatav info. Seal võikski olla ainult veebilehe enda nimi.
Kommentaarid: 375 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 340
Eraser
Eraser
sõnum 13.04.2012 12:26:57 vasta tsitaadiga
Amdfan kirjutas:
Milleks see peaks hea olema? Ma ise olen küll niimoodi asjast aru saanud, et SEO osas oleks pigem soovitatav, et lisaks saidi nimele oleks pealkirjas ka andud lehekülje/artikli pealkiri.
eltso
eltso
sõnum 13.04.2012 13:25:15 vasta tsitaadiga
Amdfan kirjutas:
Igal menüülingil saad valikute alt "Lehekülje näitamise valikud" panna pealkirja mida näidatakse üleval. Kui see on tühjaks jäetud, siis näidatakse artikli pealkirja.
Patsaan
sõnum 29.05.2012 21:11:02 vasta tsitaadiga
Keegi teab, kuidas saada link image "Avaleht" kõrvale?
Alustasin 24x24 link imagest, siis 16x16 ja praegu on 12x12 link image, aga siiski ei mahu kõrvale.
Kommentaarid: 34 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 31
Eraser
Eraser
sõnum 29.05.2012 21:19:17 vasta tsitaadiga
Seda saad muuta kujunduse CSS-failist.
Patsaan
sõnum 29.05.2012 21:29:48 vasta tsitaadiga
Selline lahter template settingute all, templateks muidu joomlage see free template.
Pean sinna lahtrisse kirjutama midagi?
sakinaga
sõnum 29.05.2012 21:37:50 vasta tsitaadiga
Kas keegi on kursis, kui palju võiks maksta joomla template tegemine? Kujundusidee on enamvähem olemas, seda ei pea välja mõtlema (olemas kujundus teise süsteemi peal, seda tuleks lihtsalt kloonida), oleks tarvis see joomlale söödavaks teha.
eltso
eltso
sõnum 30.05.2012 08:16:45 vasta tsitaadiga
Ise kasutanud siiani Gantry frameworkil põhinevaid templatesid ja nendel on, võrreldes jooma vaikimisi kujundusega, ülimalt lihtne ise teha endale sobiv kujundus, seega tuleb ise asi käsile võtta icon_smile.gif
Uhuu
Uhuu
sõnum 20.06.2012 22:25:07 vasta tsitaadiga
Oskab keegi aidata, kuidas oleks võimalik saata teatud e-mailile teade, kui mõni uus kasuaja juurde registreeritakse.
Windows ei ole viirus, viirus teeb midagi...
Laurman
Laurman
sõnum 26.06.2012 12:11:47 vasta tsitaadiga
Miks mul component (hwdphotoshare) väidab, et tema kataloogid pole writable, kuigi ma andsin neile 777 õigused?
hesse
sõnum 28.06.2012 20:44:20 vasta tsitaadiga
Sul vist on Netpointi server, mul oli midagi analoogset seal, kaustadel-failidel tegelikult pole neid õiguseid. Pöördu helpdeski, nad panevad õigeks.
J2ru
J2ru
sõnum 30.01.2013 16:01:32 vasta tsitaadiga
Keegi oskab soovitada tasuta joomla pluginat mis suudaks teha pildi kaleriisse folderieid.
Kommentaarid: 27 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 19
Eraser
Eraser
sõnum 30.01.2013 16:07:48 vasta tsitaadiga
Aga miks plugin? Miks siis mitte juba komponent? Näiteks JoomGallery või Phoca Gallery.
TeddyBbeer
sõnum 22.02.2013 20:14:34 vasta tsitaadiga
Olen natukene nikerdanud selle asjandusega ning on tekkinud paar küsimust.
Nimelt kuidas kategooria nimekirjale nö tutvustav tekst külge pookida? Olen proovinud igasuguseid trikke aga kohe kuidagi ei õnnestu... googel ka miskit mõistetavat vastust ei paku... mainiks veel, et webiehitamisest on üldiselt väga üldised teadmised (loe: sittagi ei oska).
ja kas web.zone.ee/koduleht lehele on üldse võimalik joomlaga tehtud kodulehte üles panna? Kuskilt jäi nagu silma, et teed amppsi vms asjaga koduka valmis ja siis transpordid selle mysgli ja phpd mittetoetavasse serverisse..
indu
indu
sõnum 22.02.2013 22:39:09 vasta tsitaadiga
Võtad vastava kategooria ja kirjutad/kleebid tekstiredaktorisse.
zone.ee sa joomlat küll installida ei saa kuid planet.ee on väga soodne kohake.
https://www.youtube.com/watch?v=9mFxWmJHXLU
Hakka kuulama ja joomla algtõed peaks siit küll selgeks saama.
http://www.lossirestoran.eu/
Kommentaarid: 63 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 58
woox2k
woox2k
sõnum 22.02.2013 23:14:02 vasta tsitaadiga
Keegi oskab soovitada mõnd head kohta kust saaks tirida tasuta joomla pluginaid jms? Tore oleks kui valik oleks ikka suurem kui paarkümmend pluginat.
extensions.joomla.com on suht kasutuks muutunud sest enamus pluginaid nõuavad raha ja Google abiga on raske üldse midagi "free" sõnaga otsida.
Mess with the best, die like the rest!
Kommentaarid: 20 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 18
sakinaga
sõnum 22.02.2013 23:47:56 vasta tsitaadiga
Otsi extensions.joomla.com-st non-commercial pluginaid.
woox2k
woox2k
sõnum 23.02.2013 01:00:47 vasta tsitaadiga
Kuule jah, täitsa toimib. Miks ma pole seda enne märganud... Tänud igatahes!
indu
indu
sõnum 25.02.2013 14:56:54 vasta tsitaadiga
Tervist,
Selline küsimus on joomla kohta: Pildil 1 on näha teksti.
Category: User Modules
Published on Saturday, 01 January 2011 00:00
Written by Joomla!
Hits: 10
Tahaks sellest lahti saada mingit moodi. Category manager all sellist lollitust ei ole. Mis pagana plugin see selline olla võib ...
sakinaga
sõnum 25.02.2013 15:08:09 vasta tsitaadiga
Mine Category Manager,
siis valid Options (http://i.imgur.com/iRyYMn0.png)
sealt saad siis valida mida näidatakse ja mida mitte. Antud juhul tuleks muuta väärtusi "Show category", "Show Publish Date", "Show Author" ja "Show Hits". See muudab globaalseid seadeid.
Kui tahad ainult ühel artiklil seda muuta, siis tuleb seda teha artikli muutmise ajal parempoolsetest menüüdest.
indu
indu
sõnum 08.03.2013 17:03:32 vasta tsitaadiga
Keegi teab mõnd head kodukat veel kus tasuta template. Siiani olen otsinud http://www.joomla24.com/
ufo56
ufo56
sõnum 09.05.2014 13:06:31 vasta tsitaadiga
Oleks vaja joomlale teha selline leht kus saab küsida hinnapakkumist.
Üks võimalus peab olema kindlasti teha nagu toodete menüü kust valides toote nime näidatakse ka pilti. Siis lisaks mõned sellised tavalised vormid kus klient saab panna kirja soovitud mõõdud jne.
 Lae pildid -> pilt.io
djdanx
djdanx
sõnum 09.05.2014 13:17:29 vasta tsitaadiga
ufo56 kirjutas:
Rsform, sellega peaks saama ilusti tehtud.
teostan töid : magento
ufo56
ufo56
sõnum 09.05.2014 13:37:38 vasta tsitaadiga
Hetkel on tehtud mingi kahtlane asi fabrikuga aga seal ei anna kuidagi seda teha kui toode valida menüüst siis vahetuks ka toote pilt. Kui keegi teab kuidas seda teha siis oleks eriti thumbs_up.gif
eltso
eltso
sõnum 10.05.2014 10:24:46 vasta tsitaadiga
ufo56, Sa erinevaid e-poe komponente pole selleks proovinud?
ufo56
ufo56
sõnum 10.05.2014 11:28:16 vasta tsitaadiga
Ei
kk
kk
sõnum 23.09.2014 07:56:17 vasta tsitaadiga
Mul on veebileht Joomla ja Virtuemart2 põhine. E-kauplusest tellimine on aga piinarikas sest klient peab 2x sisestama oma kontaktandmeid ning 2-3x kinnitama oma tellimust enne kui jõuab pangalinkideni. Kas keegi oskab soovitada kuidas seda lihtsamaks saaks teha või siis mõistliku tasu eest see optimiseerimine ära teha? Tänud!
Kommentaarid: 120 loe/lisa Kasutajad arvavad:  :: 7 :: 3 :: 94
Eraser
Eraser
sõnum 23.09.2014 12:02:05 vasta tsitaadiga
kk kirjutas:
Ise kasutan seda lisaprogrammi. Töötab kenasti.
Sarnaseid lahendusi muidu teisigi:
Nende kohta ei oska oma kogemuse põhjal midagi öelda, aga see Ruposteli vidin töötab mul kahel saidil ning täitsa toimib. Seadistamisvõimalusi on tal meeletult. Ühel on mul kusjuures veel alfaversioon, millel olid oma oksakohad, aga põhimõtteliselt toimib. Ühel saidil oli ka mõningaid tõrkeid smartposti pluginatega, aga neistki sai lõpuks mööda. Lisaprogramm on ka osaliselt eesti keelde tõlgitud.
sakinaga
sõnum 05.11.2014 17:59:57 vasta tsitaadiga
Nii, probleem "category blog" vaates ei ole millegipärast näidatud alamkategooriate artiklid. Ehk siis on näha ainult põhikategooria artiklid ja ei midagi muud.
Category options ja Blog Layout options
Article manager options ja kategooriate puu
Siin saab vastus olla kas väga lihtne või väga keeruline. Olen ma midagi tähelepanuta jätnud? Proovisin ka täiesti nullist uut category blog layouti teha, tulemus identne.
Minu mõistus sai igatahes otsa.
-e- Lisainfoks, et tegemist on Joomla 2.5-ga.
Lahendus, kui keegi teine otsinguga siia satub: muuta sätet "Category Order" ja väärtustada "none" vms. Artiklid olid olemas, lihtsalt alamkategooriad olid lõpus.
Laurman
Laurman
sõnum 17.01.2015 23:00:31 vasta tsitaadiga
Keegi oskab soovitada joomla 3.x-le mõnda moodulit/pluginat, mis teeks midagi sarnast HV foorumi funktsioonile? Need mis googlest spoileri peale üles kargasid ei sobinud, ehk on mõne teise nimega vms..
djdanx
djdanx
sõnum 18.01.2015 12:28:22 vasta tsitaadiga
Laurman kirjutas:
http://joomla-extensions.kubik-rubik.de/ejs-easy-joomla-spoiler#download
Laurman
Laurman
sõnum 18.01.2015 13:58:44 vasta tsitaadiga
EJS ei täida eesmärki. Ei peida teksti all olevat ala ära vaid muudab selle mingit teist värvi. Mina tahaksin midagi sellist nagu on tehtud sinu poolt pakutud EJS lehel Features, Installation jms..
woox2k
woox2k
sõnum 09.11.2015 08:42:23 vasta tsitaadiga
Kas keegi oskab soovitada kohta, kust saaks "traditsioonilisi" aga responsive Joomla templatesi. Kuskilt lehtedelt nagu joomla24 jne. otsides ei ole üldiselt templated responsive ja Google abiga otsides tulevad alati mingisugused umbe suure kujundusega responsive lehed.
Ma just otsiks sellist lihtsat, minimalistlikku aga samas vähemalt ühe horisontaalse ja ühe vertikaalse (vasaku) menüü võimalusega. Üks hea näide oleks: https://crosstec.org/templatedemos14/index.php Sisseehitatud slaidishow oleks ka boonuseks aga mitte just nõutud. Loomulikult võiks ju näidislingil olevaga rahule jääda ja lihtsalt seda kasutada aga ma ei tahaks uskuda, et see on ainuke ja valikuvõimalus oleks ka hea.
merz
sõnum 09.11.2015 11:44:42 vasta tsitaadiga
Pole ammu vaadanud aga www.portaliz.com lehel oli igasugu joomla asju.
Kommentaarid: 31 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 31
Karlapoiss
Karlapoiss
sõnum 09.11.2015 11:45:43 vasta tsitaadiga
woox2k kirjutas:
Ise olen muidu joomlandist võtnud.
ehk midagi sellist? http://www.joomland.org/index.php/joomla3-x/421-master-bootstrap-joomla-3-template
aks
aks
sõnum 12.06.2016 08:47:10 vasta tsitaadiga
Sõber on hädas oma Joomla 2.5 kodulehega.
Palju maksaks Joomla 2.5 upgrade 3.x peale?
Kommentaarid: 131 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 121
djdanx
djdanx
sõnum 17.06.2016 15:01:03 vasta tsitaadiga
aks kirjutas:
oleneb palju asju peale pandud on (moodulid,pluginad,kujundused jne) ning kas nendele on uuendused saadaval või mitte ...
ahto42
sõnum 30.11.2016 09:03:02 vasta tsitaadiga
Loll on loll olla.
Küsimus. et kas on võimalik kopeerida vana leht jjoomlasse?
Leht kunagi tehtud prsSitemanageriga zones(ftp-ga ligipääs olemas), ei tahaks päris nullist alustada enam. On mingi võimalus?
uus teema   vasta Tarkvara »  WWW »  JOOMLA ja sellega seonduv mine lehele eelmine  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  järgmine
