Vares
08.09.2011 15:23:26
Üritan siin ka ajaga kaasas käia ja plaan oli 1.5x pealt 1.7-le üle minna aga selgus, et otse ei saagi, enne vaja veel 1.6-le üleminek teha. Olen nüüd 1.5x pealt 1.6 üleminekuga pool päeva jamanud aga tulemus on ikka selline, et Jupgrade ei jõua peale lahtipakkimist kuhugi edasi. Debug näitab kirjeid:
Checking DONE
[decompress]
[install_config]
Warning: require_once(/home/np51160/domains/xxx.xx/public_html/jupgrade/libraries/joomla/methods.php) [function.require-once]: failed to open stream: No such file or directory in /home/np51160/domains/xxx.xx/public_html/administrator/components/com_jupgrade/includes/install_config.php on line 24
Fatal error: require_once() [function.require]: Failed opening required '/home/np51160/domains/xxx.xx/public_html/jupgrade/libraries/joomla/methods.php' (include_path='.:/usr/local/lib/php') in /home/np51160/domains/xxx.xx/public_html/administrator/components/com_jupgrade/includes/install_config.php on line 24
[cleanup]
[install_db]
Warning: require_once(/home/np51160/domains/xxx.xx/public_html/jupgrade/libraries/joomla/methods.php) [function.require-once]: failed to open stream: No such file or directory in /home/np51160/domains/xxx.xx/public_html/administrator/components/com_jupgrade/includes/install_db.php on line 30
Fatal error: require_once() [function.require]: Failed opening required '/home/np51160/domains/xxx.xx/public_html/jupgrade/libraries/joomla/methods.php' (include_path='.:/usr/local/lib/php') in /home/np51160/domains/xxx.xx/public_html/administrator/components/com_jupgrade/includes/install_db.php on line 30
[undefined] [undefined]
Warning: require_once(/home/np51160/domains/xxx.xx/public_html/jupgrade/libraries/joomla/methods.php) [function.require-once]: failed to open stream: No such file or directory in /home/np51160/domains/xxx.xx/public_html/administrator/components/com_jupgrade/includes/jupgrade.class.php on line 78
Fatal error: require_once() [function.require]: Failed opening required '/home/np51160/domains/xxx.xx/public_html/jupgrade/libraries/joomla/methods.php' (include_path='.:/usr/local/lib/php') in /home/np51160/domains/xxx.xx/public_html/administrator/components/com_jupgrade/includes/jupgrade.class.php on line 78
Ja siis jääb seda viimast osa kordama ja kordama.
Üks kahtlusalune on Netpoint oma kaustade õigusega, sest enne pidin juba tunde erinevaid kaustu ja faile otsima ja nende õigusi muutma, et näiteks saaks 1.522 pealt 1.523 peale üle minna ja et Jupgrade üldse tööle hakkaks.
Aidake hädalist! Äkki on variante, kuidas uuendus muude vahenditega ära teha? Puhta Joomla install ja siis sinna andmete üleviimine on kui töömahukas?
_________________ ValiHeli - Eesti suurima kodukino- ja stereokõlarite ning kõrvaklappide valikuga helitehnika salong! |
66 |
Vahur
20.10.2011 09:33:00
| Oleks vaja Joomla 1.7.2'le lisa, mis lubaks lehti teisse keelde tõlkida. Lisaks oleks veel vaja külastajale automaatselt IP järgi vastavat keelt näidata. Varem kasutasin tõlkimiseks Joom!Fish'i, aga seda pole 1.7'le tehtud.
388 |
Eraser
20.10.2011 09:37:23
| [VaHuR] kirjutas: |
| Oleks vaja Joomla 1.7.2'le lisa, mis lubaks lehti teisse keelde tõlkida. Lisaks oleks veel vaja külastajale automaatselt IP järgi vastavat keelt näidata. Varem kasutasin tõlkimiseks Joom!Fish'i, aga seda pole 1.7'le tehtud. |
Kui pole mingi väga keerulise ülesehitusega leht, siis võid kasutada ka Joomlasse endasse sisseehitatud võimalust mitmekeelsete saitide loomiseks.
Ja kui oled julge poiss, siis võid kasutada ka JoomFishil põhinevat komponenti FaLang. Praegu on see veel beetastaatuses, aga lootust on, et see võib sul ikkagi toimida.
Komponendi eestikeelne tõlge on kah juba valmis, aga jagamiseni pole veel jõudnud.
30 |
eltso
20.10.2011 09:37:41
| [VaHuR] kirjutas: |
Kas sa seda sisemist mootorit ei proovinud mis 1.7-l on?
Ise ootan ka millal joomfish 1.7-le tehakse, nii kaua peab sisseehitatud varianti kasutama.
| Kommentaarid: 14 loe/lisa |
14 |
Laurman
02.11.2011 09:52:47
Joomlaga on oskused pisut rooste läinud. Nimelt rakendan uue template ja tema jääb püsima ainult avalehele.. Teistel lehtedel on kõik vorminduseta.
Mille ma tegemata unustasin?
E: ise küsin - ise vastan. Search engine friendly url rikkus asja ära, selle disablemine kaotas probleemi.
97 |
23.11.2011 23:14:41
Esilehele vaja uudised panna. Ok niisama sain hakkama kuid sooviks panna 2 eraldi kategooriat, et ei jookseks järajest segamini need kategooriad.
Mis vahendiga annaks teha sedasi et vasakule tulpa jääb kategooria 1 uudised ja paremale tulpa kategooria 2 uudised. Või siis ülesse nr1 ja alla nr2 kategooria uudised.
Leidsin küll terve suure hunniku erinevaid abivahendeid kuid neid kõiki läbi testida
Ehk kellelgi soovitusi (algaja joomlaga, mis teha)
| Kommentaarid: 39 loe/lisa |
sakinaga
24.11.2011 00:35:47
üles kat 1 ja alla kat2 uudised saad siis, kui teed ühe ülemkategooria, millele teed kaks alamkategooriat ning siis teed lingi tüübiks articles blog layout vms ja valid artiklite sortimiseks "by category".
Loomulikult pead siis ka valima, et alamkategooriad kaasataks.
| Kommentaarid: 159 loe/lisa |
151 |
fenton
25.11.2011 10:58:38
Muult lehelt lingitud (pidevalt uueneva) pildi lisamine (Joomla 1.5)
Tahaks Joomlas kodulehele lisada üht graafikut nii, et see tõmmatakse iga korda ühelt teiselt lehelt. Et oleks niiöelda pidevalt uuenev pilt. Olen tavakasutaja, kellele tehti Joomlas koduleht ja kes suudab ise menüüsid, artikleid teha, tavalisi pilte lisada. Mingit sisseehitatud valmispluginat selleks Joomlas ilmselt ei ole?
djdanx
25.11.2011 15:33:42
| fenton kirjutas: |
Tahaks Joomlas kodulehele lisada üht graafikut nii, et see tõmmatakse iga korda ühelt teiselt lehelt. Et oleks niiöelda pidevalt uuenev pilt. Olen tavakasutaja, kellele tehti Joomlas koduleht ja kes suudab ise menüüsid, artikleid teha, tavalisi pilte lisada. Mingit sisseehitatud valmispluginat selleks Joomlas ilmselt ei ole? |
nii palju kui aru sain siis saad teha wrapperiga seda ( iframe ), topid selle graafiku urli ja korras.
| Kommentaarid: 51 loe/lisa |
46 |
sakinaga
25.11.2011 15:35:11
Eeldades, et graafik on eraldi lehel, kui ta asub mingi lehe keskel, siis on hapud lood.
151 |
27.11.2011 18:35:23
Veel üks küsimus.
Kuidas saaks sedasi et kui RSS (uudis pärineb teiselt saidilt) uudise pealkiri vaid esilehel on siis lingiks tekiks kohe uudise aadres teisel lehel mitte saidisisene.
Hetkel: uudise pealkiri (uudis ise teisel saidil) -> klikkan peale suunab minu lehel uudisele kus mingi 1 lause uudisest ja all Read More link, kuhu vajutades suunab alles uudisele reaalselt.
Kasutan Feed Gator-t http://extensions.joomla.org/extensions/news-production/automatic-articles/13573
Vist kõik menüüd läbi lapanud aga ei leidnud. Võib ka muud RSSi vidinat soovitada kui sellega ei saa.
sakunne
23.02.2012 19:13:53
Kuupäevaformaatidest erinevates tõlgetes
Kas on võimalik panna erinevate keelte kuupäevaformaadid erinevad, lätlase kommentaar:
läti keeles kuupäevad ja aastaarvud "varustatakse"
punktidega, ja aasta tavaliselt kirjutatakse kuupäeva
ette. Seega õigem oleks "2012. gada 13. februaris".
_________________ Kuna ei pruugi õigel ajal foorumisse sattuda:
SMS: 5051598 [võõraid tel. ei vasta]
Email sakunne@seenior.ee |
| Kommentaarid: 77 loe/lisa |
69 |
Amdfan
13.04.2012 10:22:19
| Palun abi, kuidas muuta Joomla 2.5 puhul brauseri tiitelribal kuvatav info nii, et mingi artikli avamisel ei kuvataks selle artikli nime. Oleks huvitatud, et sõltumata lehest mis avatud on, ei muutuks veebibrausri tiitelribal kuvatav info. Seal võikski olla ainult veebilehe enda nimi.
| Kommentaarid: 346 loe/lisa |
317 |
Eraser
13.04.2012 12:26:57
| Amdfan kirjutas: |
| Palun abi, kuidas muuta Joomla 2.5 puhul brauseri tiitelribal kuvatav info nii, et mingi artikli avamisel ei kuvataks selle artikli nime. Oleks huvitatud, et sõltumata lehest mis avatud on, ei muutuks veebibrausri tiitelribal kuvatav info. Seal võikski olla ainult veebilehe enda nimi. |
Milleks see peaks hea olema? Ma ise olen küll niimoodi asjast aru saanud, et SEO osas oleks pigem soovitatav, et lisaks saidi nimele oleks pealkirjas ka andud lehekülje/artikli pealkiri.
30 |
eltso
13.04.2012 13:25:15
| Amdfan kirjutas: |
Igal menüülingil saad valikute alt "Lehekülje näitamise valikud" panna pealkirja mida näidatakse üleval. Kui see on tühjaks jäetud, siis näidatakse artikli pealkirja.
14 |
Patsaan
29.05.2012 21:11:02
Keegi teab, kuidas saada link image "Avaleht" kõrvale?
Alustasin 24x24 link imagest, siis 16x16 ja praegu on 12x12 link image, aga siiski ei mahu kõrvale.
| Kommentaarid: 34 loe/lisa |
31 |
Eraser
29.05.2012 21:19:17
Seda saad muuta kujunduse CSS-failist.
Eks ta veidi üldine vastus ole (aga seda on ka küsimus)
30 |
Patsaan
29.05.2012 21:29:48
Selline lahter template settingute all, templateks muidu joomlage see free template.
Pean sinna lahtrisse kirjutama midagi?
31 |
sakinaga
29.05.2012 21:37:50
Kas keegi on kursis, kui palju võiks maksta joomla template tegemine? Kujundusidee on enamvähem olemas, seda ei pea välja mõtlema (olemas kujundus teise süsteemi peal, seda tuleks lihtsalt kloonida), oleks tarvis see joomlale söödavaks teha.
151 |
eltso
30.05.2012 08:16:45
Ise kasutanud siiani Gantry frameworkil põhinevaid templatesid ja nendel on, võrreldes jooma vaikimisi kujundusega, ülimalt lihtne ise teha endale sobiv kujundus, seega tuleb ise asi käsile võtta
14 |
Uhuu
20.06.2012 22:25:07
Oskab keegi aidata, kuidas oleks võimalik saata teatud e-mailile teade, kui mõni uus kasuaja juurde registreeritakse.
_________________ Windows ei ole viirus, viirus teeb midagi... |
14 |
Laurman
26.06.2012 12:11:47
| Miks mul component (hwdphotoshare) väidab, et tema kataloogid pole writable, kuigi ma andsin neile 777 õigused?
97 |
hesse
28.06.2012 20:44:20
| Sul vist on Netpointi server, mul oli midagi analoogset seal, kaustadel-failidel tegelikult pole neid õiguseid. Pöördu helpdeski, nad panevad õigeks.
| Kommentaarid: 24 loe/lisa |
23 |
J2ru
30.01.2013 16:01:32
| Keegi oskab soovitada tasuta joomla pluginat mis suudaks teha pildi kaleriisse folderieid.
| Kommentaarid: 27 loe/lisa |
19 |
Eraser
30 |
