uus teema   vasta Tarkvara »  Arvutimängude foorum »  The Forest märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3, 4, 5  järgmine
Timberg
ööKARU
Timberg
sõnum 03.04.2014 21:01:40 vasta tsitaadiga
mõned copyppasted faqst
Will there be a peaceful mode?
Yes. You will be able to play the game as a more traditional survival/exploration simulator, with the horror elements effectively disabled.
Where can I buy the game?
The game will be available on Steam, as well as from our store on the games website: http://survivetheforest.com/ . We are also looking into other different options for selling the game and will update this question when things are confirmed.
How much will the game cost?
The initial Alpha release will cost $14.99.
Will you be able to climb trees or mountains?
Currently you cannot climb trees, although enemies in the game will make use of them. Access to mountain areas will be blocked off in the first alpha release.
Can you build defensive structure or bases in the caves and underground?
Not at this time.
Will there be different areas like different cave (sedimentary, igneous or/and metamorphic caves) and will there be different surface environment with like different animals to hunt or kill (is there hunting?) and different plant areas like marsh, jungle, plains?
There will be different small animals you can hunt. There will also be different environments based on North American forest. The environment will include caves, swamps, lakes and mountains.
Can you play as a female character?
Not for the initial alpha release.
486
sõnum 03.04.2014 21:35:46 vasta tsitaadiga
Need vaenlased niigi liiga inimeste moodi.
zero
pohmakas,
käed värisevad
pohmakas,
sõnum 26.05.2014 03:49:40 vasta tsitaadiga
http://store.steampowered.com/app/242760/
Kommentaarid: 164 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 136
siven
siven
sõnum 26.05.2014 15:11:28 vasta tsitaadiga
kahjuks pole MP loodan ,et tuleb üsna varsti...
Kommentaarid: 163 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 149
Syncmahv
Syncmahv
sõnum 26.05.2014 15:58:09 vasta tsitaadiga
Ei tea kui väga sellisele mängule sobiks üldse MP. Loodetavasti enamvähem hind.
siven
siven
sõnum 26.05.2014 15:59:55 vasta tsitaadiga
Syncmahv kirjutas:
ilma COOP võimaluseta on see mäng küll suht fail.
ja hind oli 14 dollarit.
pohmakas,
käed värisevad
pohmakas,
sõnum 26.05.2014 16:03:27 vasta tsitaadiga
co-op pidavat tulema küll, kuid mitte alphas
xxlmaster
xxlmaster
sõnum 26.05.2014 20:29:32 vasta tsitaadiga
on siin keegi siis proovinud ka asja juba?
E: krt asi tuleb välja alles 30 mai icon_redface.gif
dohc-48v12
Aeg maha 1p
dohc-48v12
sõnum 29.05.2014 21:06:39 vasta tsitaadiga
märk maha,
Tuleb ainult steamile ?
Miks ADMIN Anti112 ambusib mind? andis 1p cooldowni aga ma ei saa peale selle enam mitteühtegi postitust teha! üks päev ei kuid!
Kommentaarid: 112 loe/lisa Kasutajad arvavad:  :: 6 :: 0 :: 85
Syncmahv
Syncmahv
sõnum 29.05.2014 21:29:29 vasta tsitaadiga
Kuhu veel?
dohc-48v12
Aeg maha 1p
dohc-48v12
sõnum 29.05.2014 21:58:07 vasta tsitaadiga
igale poole, aga mitte steamile ! sooviks !
Kahjuks vist pole alternatiivi steamile :S
Syncmahv
Syncmahv
sõnum 29.05.2014 22:58:06 vasta tsitaadiga
Eesti aja järgi launch 30.05 19:00. icon_razz.gif
Dave20
sõnum 30.05.2014 17:48:05 vasta tsitaadiga
Mis stiilis see mäng on, kas nagu outlast?
pohmakas,
käed värisevad
pohmakas,
sõnum 30.05.2014 17:52:15 vasta tsitaadiga
Dave20 kirjutas:
Videoid küllaga välja lastud ju. Horror-survival stiilis, ehk siis õudus/ellujäämine.
Chardin
sõnum 30.05.2014 18:11:30 vasta tsitaadiga
Kas keegi aitaks mul seda mängu osta, millegi pärast ei lase steam mul enam paypal balnce'iga maksta kui ei ole krediit kaardiga seotud.
Edit: Sain nüüd eks hiljem annan oma arvamuse.
viimati muutis Chardin 30.05.2014 18:42:20, muudetud 1 kord
Dave20
sõnum 30.05.2014 18:12:46 vasta tsitaadiga
pohmakas, kirjutas:
Dave20 kirjutas:
Vabandust ma polnud veel väga süvenenud selle mängu teemasse icon_redface.gif
Flasky
Flasky
sõnum 30.05.2014 19:06:36 vasta tsitaadiga
siven kirjutas:
Syncmahv kirjutas:
Co-op elimineeriks ju horror elemendi, või mis?
Kes proovinud on, kuidas mäng jookseb?
pohmakas,
käed värisevad
pohmakas,
sõnum 30.05.2014 19:17:25 vasta tsitaadiga
Flasky kirjutas:
siven kirjutas:
Syncmahv kirjutas:
Chardin
sõnum 30.05.2014 20:48:44 vasta tsitaadiga
Mäng näeb minu arust ilus välja, R280X on max seaded 1080p fps 60 kandis mul. Võiks see option kohe olla kust saab horrori välja lülitada aga muidu päris hea. Täheldasin bug'ina et kui itemeid vahetada siis tekib maha ka sama objekt. Lisaks ei õnnestu mul save'ida aga see võib minu viga olla.
siven
siven
sõnum 30.05.2014 21:26:50 vasta tsitaadiga
Chardin kirjutas:
sandbox mode tuleb ka. see lubatud feature.
pohmakas,
käed värisevad
pohmakas,
sõnum 31.05.2014 00:20:17 vasta tsitaadiga
Link
Matisxx
Matisxx
sõnum 31.05.2014 14:07:56 vasta tsitaadiga
Päris hea mäng on, aga päris hirmus on kui rahulikult ehitad ja 10 venda keset ööd sulle seljataha tulevad icon_smile.gif
Velociraptor
Velociraptor
sõnum 31.05.2014 14:18:11 vasta tsitaadiga
Pole viga, varajase alpha kohta. potentsiaali on küll
🕊 Kuruppo ぽ 🕊
https://www.last.fm/user/Ingvaarr
Kommentaarid: 32 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 30
mtv0308
sõnum 31.05.2014 15:20:50 vasta tsitaadiga
xxlmaster kirjutas:
Mina olen proovinud ja praegu soovita küll kellelegi osta.
*Graafika on võrreldes treileriga paar kraadi (kui mitte rohkem) halvem. Väidetavalt keerati esimese release jaoks maha.
*Ehitamine on üpris vaevarikas ning mitte ressursside pärast vaid on probleeme juba käes olevaid asju kasutada. Lihtsalt ei teki seda E tähte, et palki paika panna. Ehitasin maja, mis nõuab 82 palki, mul õnnestus viis paika panna ja siis rohkem ei tekkinud E tähte kuhugi, et järgmist paigutada.
*Sööki ei saa lõkkest kätte ja marjade peal elamine on suht nutune ning nagu arvata võib ei täida väga midagi.
*Puudub salvestamise võimalus ehk iga kord kui mängu tööle lükkad alustad nullist.
*Kui oma esimesed 3-4 põrgulist maha lõin siis rohkem pole neid ka mängus näinud.
http://www.youtube.com/z4nn1n
486
sõnum 31.05.2014 17:41:56 vasta tsitaadiga
Kuigi fps 50-60 vahel on väga imelik see hiirega vaatamine. Väga häiriv. Vana unity probleem. Praktiliselt iga suurem mäng sellel mootoril on selline ja ei ütleks, et arvuti on n6rk.
zero
uus teema   vasta Tarkvara »  Arvutimängude foorum »  The Forest mine lehele eelmine  1, 2, 3, 4, 5  järgmine
