uus teema   vasta Tarkvara »  Arvutimängude foorum »  The Forest märgi kõik teemad loetuks
mine lehele 1, 2, 3  järgmine
Syncmahv
Syncmahv
sõnum 17.01.2014 22:45:27 The Forest vasta tsitaadiga
http://survivetheforest.com/
Tulemas äärmiselt karm mäng mis peaks toetama ka Oculus Rifti.
Ausaltöeldes video järgi vaadates ei julgeks ma seda mängidagi, rääkimata oculuse kasutamisest.
Link
The Forest is an open world survival horror game currently in development for PC.
Build, explore, survive in this terrifying first person survival horror simulator.
The world
Enter a living, breathing forest with changing weather patterns, plants that grow and die. Tides that roll in and out with the day/night cycle. Below ground explore a vast network of caves and underground lakes.
Complete player freedom
Chop down trees to build a camp, or start a fire to keep warm. Scavenge food to keep yourself from starving. Find and plant seeds to grow food.
Build a small shelter or a large ocean side fortress. decorate your home with found items. Lay traps and defenses to keep a safe perimeter.
Gameplay
Explore and build during the day. Defend your base at night. Craft weapons and tools.Bunker down during the evening or bring the fight directly to the enemy.
Fight or Hide
Use stealth to evade enemies, or engage them directly with crude weapons built from sticks and stones.
A new type of open world, survival horror experience
Defend yourself against a clan of genetic mutant enemies that have beliefs, families and morals and that appear almost human.
For PC and Oculus Rift - Alpha Version Coming Early 2014
486
sõnum 17.01.2014 23:14:09 vasta tsitaadiga
Graafika näeb küll kõva välja. See nagu rust kloon. Loodetavasti vaid SP. Mis mootorile see tehakse, Unity?
zero
siven
siven
sõnum 18.01.2014 14:50:18 vasta tsitaadiga
486 kirjutas:
tahad ainult SP???
mp on sellistes mängudes peamine asi;)
Kommentaarid: 163 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 149
Matisxx
Matisxx
sõnum 18.01.2014 14:57:48 vasta tsitaadiga
Co-Op oleks põhiline selle jaoks minu arust.
Syncmahv
Syncmahv
sõnum 19.01.2014 17:47:21 vasta tsitaadiga
Päris korralik skin system.
Link
kusti85
Tavaline kasutaja
sõnum 19.01.2014 18:22:25 vasta tsitaadiga
siven kirjutas:
486 kirjutas:
tahad ainult SP???
Üks näide heast multiplayer survival horrorist palun?
Rockmuusikateemaline viktoriin Tallinnas - https://www.facebook.com/groups/rocktoriintallinn/
Ketas, ketta, ketast, kettasse, kettas, kettast, kettale, kettal, kettalt, kettaks, kettani, kettana, kettata, kettaga. <--SPIKKER
Kommentaarid: 221 loe/lisa Kasutajad arvavad:  :: 3 :: 0 :: 185
mtv0308
sõnum 20.01.2014 04:33:49 vasta tsitaadiga
kusti85 kirjutas:
siven kirjutas:
486 kirjutas:
tahad ainult SP???
Kui ei ole olnud siis ka ei tohi tulla? Miks see ei võiks näiteks esimene olla?
http://www.youtube.com/z4nn1n
Leinö
Leinö
sõnum 20.01.2014 09:18:30 vasta tsitaadiga
co-op võiks ikka olla, muidu läheb veits minecraftiks kätte..
kusti85
Tavaline kasutaja
sõnum 20.01.2014 16:08:26 vasta tsitaadiga
mtv0308 kirjutas:
Selleks, et igasuguse horror elemendi tapab see, et sinu kõrval viibib keegi, kellega sa hetkes sees oled. Eriti kui tuleb online multipleier osa kus suvaline troll sulle selja tagant labidaga pähe saab lajatada vabalt valitud ajahetkel.
Täpselt bnagu kinos seltskonnaga käies õudusfilmi vaadates ei ole film eriti miskit väärt kui sa seda vaatamise ajal omavahel kommenteerida saad mingi kambaga. Või kuidas seal filmis alati punt tegelasi laiali aetakse, et mingi tegelane üksinda panna mingi unknown või known jõuga kokkupuutesse viia.
Leinö kirjutas:
Jep, päevane co-op võiks olla, see oleks sellise ehitamise ja *craft tüüpi asjal suht kohustuslik, muidu oleks tõenäoliselt grind element liiga suur, ja mataks horror poole ära.
Redikate
Redikate
sõnum 20.01.2014 17:23:43 vasta tsitaadiga
kusti85 kirjutas:
DayZ on sinust mööda läinud vist jah?
Otseslt pole küll horror genre, aga käe värinast sealt puudust ei ole tavaliselt.
Ja krt, mul ei ole unityisse eriti usku. Tore asi prototüüpimiseks jms, kuid päris mängu tegemiseks peaks ikka mingit päris enginit kasutama.
Rust on hea näide sellest, kuidas unity pole mingi maailma parim lahendus.
Aga eks ta ole mingil määral toimiv ja odav asi.
http://nodejs.org/
"I'm also a person. Programming is just one thing I do."
xonix
sõnum 20.01.2014 18:57:13 vasta tsitaadiga
Redikate kirjutas:
kusti85 kirjutas:
DayZ SA on modist ikka väga kaugel ning see ei paraneb alles aasta pärast. Ning mootorist rääkides, siis arcade mängule buggine simulaatori mootor panna ei ole ka maailma parim lahendus.
The Forestist rääkides, siis animatsioonid näevad välja päris head ning mõte on ka olemas. Graafiliselt ei peagi olema Crysis 3 niikaua kui ta teeb hästi seda, mida ta teha tahab.
Kommentaarid: 74 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 68
Syncmahv
Syncmahv
sõnum 16.03.2014 13:50:47 vasta tsitaadiga
Sai natuke infot välja kaevatud interneti avarustest.
Most Recent Updates: 3/9/2014
* Multiplayer mode may appear after Alpha release.
* We're coming soon to Steam's "coming soon" list.
* A new trailer will be coming out soon[i.imgur.com] with an Alpha Release date.
* SLI and Crossfire setups will not be supported at Alpha release. The game will however work well with single card setups; SLI/Crossfire is expected to be implemented later into development.
* The second part of the Q&A series with EndNight games is here!
* There will be some unknown performance with AMD cards. So far only Nvidia cards have been tested, with the GTX 660m confirmed to run the game. If you're curious about your cards expected performance try using GPUBoss[gpuboss.com] and see the differences between your current card and the 660m. Odds are if your card can run better or close too the same level you will be able to run The Forest.
* First part of the Q&A series with EndNight games.
- Animals will add ambiance to the world.
- Confirmed 3-D inventory system.
- Details on Mutant A.I. and interaction (i.e. Combat, Traps, Stealth)
- Poisonous plants confirmed.
- Stealth and Camouflage.
* Confirmed[www.neogaf.com] that players can build pre-selected structures; or they can build individual walls, roofs, flooring, and fences to create any kind of home base they want.
-------List of the Confirmed Features In The Forest -------
General Game and Story:
* The games initial price point is estimated at $15.00
* 'The Forest' is labeled as an "Open World Survival-Horror" game.
* The game's setting is stated as a “North American Forest”; with areas like swamps, lakes, caves, and mountains.
* There will be "Mutant, Cannibalistic, Tribesmen" that will hunt you at night.
* The game draws inspiration from: 70's and 80's exploitation films, Italian Cannibal Films, "The Hills Have Eyes", "I Spit On Your Grave", "I Am Legend", and many other films alike.
* There will be no written or verbal dialogue within the game to aid in story telling.
* There is a deep story line though that will slowly be uncovered by the player through visiting locations, finding items, and generally by the experiences within the game.
* The story line will be completely optional. You are free to explore The Forest and play it as you see fit.
* Ben wants this game to scare you more than any game before has. It will have its calm and serene moments inbetween though.
* "There is some question as to who is actually the enemy: them, or you. You're the one who is invading their forest." - Ben Falcone
Graphics:
* The game will utilize the Unity 4 Engine.
* It will support VR Oculus Rift (As of now only the Oculus Rift will be supported)
- Interest in the STEM VR System was expressed by Ben.
* The player’s character will have a full body model, which can interact with the environment in different ways.
* The game world will use an advanced light scattering system with volumetric fog
* The game will use physical shading that allows light to respond naturally for realistic shadow effects.
* Enemy skins will use “Screen-Space Sub Surface Scattering[dmg3d.blogspot.com.es]” for a more realistic feel.
* Certain objects and the rocks in the caves are 3-D scanned from the real world to add more realism.
* Enemies will have feature film quality animations.
(From the trailers it seems that your character will have their own range of high quality animations as well)
* Blood splatter will occur when fighting.
(During the trailer you can visually see blood flying during strikes, and covering the arms of the player)
The Game World:
* A "Huge" Open World.
* Day and Night Cycle; with appropriate tides appearing throughout the day along the coast.
* Weather systems with rain and lightning (only ones confirmed so far).
* Extensive and intricate cave systems with underground lakes.
* Every tree in the game world can be cut down, changing the world dramatically and deforestation can occur. (The ranging effects that this will have not been accurately stated)
* Food sources can also be depleted, and animals over-hunted.
* Plants re-grow overtime, and die as well.
* Several nearby islands can be visited by boat, or on a raft.
* A few of the structures you can craft or take shelter in are: Caves, Tents, Cabins, Sea Side Fortresses, and House Boats.
Gameplay Elements:
* Minimal UI will be utilized during crafting in order to maintain constant immersion in the game.
* Crafting will be done using tools and the surrounding environment. Such as crafting a spear on a rock; or creating a torch by bringing a stick to a fire. And for more advanced Crafting options the player will be able to combine small items together in their backpack.
* There is a stealth system that will be highly encouraged for players to use.
* The player can craft camouflage from foliage, to aid in hiding from the mutants. They can also cover themselves in mud for decreased visibility (Predator[vcrvcr.files.wordpress.com])
* The player can craft multiple weapons such as Spears, and Axes. For more advanced weapons, players will be able to combine items such as their lighter with a can of hairspray to create a crude flamethrower.
* The player can create a large amount of traps, and use camouflage to conceal them.
* The combat will be primarily melee based. There is an idea to add bows, later on.
* The player can block and dodge enemy attacks. And each attack appears to have an appropriate physical reaction when striking an enemy.
Survival in The Forest:
* Food and water are necessary for survival in The Forest.
* You will need to craft a shelter, or a fire to keep your character warm at night or during a storm. If not you can get cold, and sick.
(Negative stat effects will occur)
* You need to sleep.
(Safe to assume that not sleeping will also have negative effects)
* Stamina is a confirmed stat mechanic; carry too much and it will deplete faster than normal.
* You can trap or hunt animals for food.
* You can also plant and grow your own garden.
* You will probably want to boil the water you find. There is a risk that comes with drinking water straight from the source.
* Cooking meat will be required to avoid illness. And leaving dead animal carcasses out for too long will attract flies.
The Cannibalistic Mutants:
* The mutants live within the world’s cave systems.
* Mutants have "Families, Fears, Morals, and Beliefs". The mutants are part of a tribe that have their own customs. Don't think of them only as feral beings.
* They have their own routines, will sleep during the day, hunt and make weird cannibal art at night
* Mutants are more than just AI enemies that fight you. They will interact with one another dynamically, as well as to your actions.
* Several different situations have been described where the mutants will react to your actions:
- Mutants may run away in fear after you have killed one of their tribesmen.
- They will carry their injured friends back to the caves for safety.
- They will mourn[survivetheforest.com] the loss of their kin.
* If you kill the mutants in their caves, or generally do things to make them angry. They will attack you even during the day time.
* Enemy Mutants are finite, so they will not re-spawn indefinitely. Each mutant you kill makes a difference, in more ways than one too it seems.
* Mutants are not weak foot soldiers. Each poses a direct threat and challenge,
* Mutants will generally hunt you at night.
* Mutants can also hunt for you in packs.
* The mutants can climb the forest's trees. The trailer shows instances where they leap from the trees to cut off the player's escape, and to ambush you.
* Mutants will stalk you sometimes before directly attacking. It appears that they will use nearby trees and foliage to sneak up on you.
* From gameplay footage it seems that mutants can jump a good distance, and will use this to their advantage to close the distance on you and to strike.
* Mutants can use weapons to attack you.
(You can see the weapons in question in the 2nd trailer)
Other Features:
* Co-Op Mode: This feature has been confirmed for the game. There is a likely version that will be implemented during Alpha.
* Player Mods: They have expressed an interest to allow the community to mod the game; they are currently working on getting the correct tools to allow for this.
* Online Leaderboards: So far they have confirmed a "Longest Time Survived" leaderboard.
(I suspect several other categories will be added in as well later)
* Different game modes:
- There is a confirmed Peaceful[i.imgur.com] mode with no mutants.
- A hardcore mode where you will have only one life.
- A mode that will procedurally generate a new Forest each time.
* Finisher moves: This is based solely from the scene in the second trailer, where the player bashes the enemy mutant’s skull in with a rock. With the number of high quality animations already in-game, it can be expected that certain finishing moves will be implemented.
* Predatory animals will pose a threat to you within the forest.
(Sharks are the only confirmed predatory animal as of yet)
* Different variations of mutants will exist within The Forest.
- Ben mentioned there was a difference between mutants in the caves and that there will be “smarter hunting cannibals”.
- Certain mutants also have noticeable differences such as: Wearing C-D pendants, Masks on their faces, and body tattoos.
(None of this is confirms that they are indeed different, it is only speculation based on the fact that Mutant's have their own tribal culture. Different versions of outfits, or other distinct features may indicate different status positions)
* Trailer footage as well as interview discussions hint towards something far more deadly than just the mutants though.
* Gamepad (controller) support has been confirmed in The Forest.
* Mid-range to High End PC’s should be able to run the game fairly well.
(This is based on a few replies to the public, in which multiple system specs were posted and they replied saying that they should run the game fairly well. Keep in mind there is still no official announcement from the developers yet on any minimum or recommended specs)
* Sony PlayStation 4 and Microsoft release have been mentioned[www.eurogamer.net], but there is no real information on an expected release. Once the PC release has been completed (no longer Alpha or Beta) there is a good chance for multiple platform support.
siven
siven
sõnum 16.03.2014 15:56:09 vasta tsitaadiga
deem ikka pole early acess väljas cant wait....
Dave20
sõnum 26.03.2014 01:37:28 vasta tsitaadiga
Ei saanud täpselt aru mis selle mängu point on, käid ringi ja tapad zombisid? Kahjuks Eesti keeles mängule tutvustust ei leidnud.
486
sõnum 26.03.2014 05:37:53 vasta tsitaadiga
Dave20 kirjutas:
survival nagu mainkraft, aint natuke parema graafikaga ja realistlikum!
zero
äss
äss
sõnum 26.03.2014 07:31:41 vasta tsitaadiga
Pigem nagu Rust parema graafikaga.
Kommentaarid: 29 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 23
486
sõnum 26.03.2014 13:45:14 vasta tsitaadiga
minuarust rust mingi mp only, kus pole ühtegi npcd
zero
Chardin
sõnum 26.03.2014 14:52:04 vasta tsitaadiga
See oleks väga lahe Co-op ka just.
DayZ probleem on just see et rohkem peab kartma teisi inimesi ning vähemalt minu jaoks on raske eluspüsida kuna ei suuda ennustada nende käitumist. AI puhul on see lihtsam.
Samas kui DayZ puhul oleks zombied ja muu elu väga ohtlik siis võibolla paneks see mängijaid rohkem kokku hoidma mitte kill on sight.
nolifer
sõnum 26.03.2014 15:15:08 vasta tsitaadiga
tundub huvitav
viimati muutis nolifer 07.04.2014 16:29:50, muudetud 4 korda
Syncmahv
Syncmahv
sõnum 03.04.2014 19:29:37 vasta tsitaadiga
Trailer 3.
Nüüd siis avaldatud ka et 22Mai early access.
Link
siven
siven
sõnum 03.04.2014 20:39:26 vasta tsitaadiga
see insta buy for me:D
pohmakas,
käed värisevad
pohmakas,
sõnum 03.04.2014 21:52:14 vasta tsitaadiga
Kommentaarid: 167 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 138
siven
siven
sõnum 03.04.2014 21:53:23 vasta tsitaadiga
pohmakas, kirjutas:
wow kuidagi väga odav:O
näeb välja väga kena. loodame et gameplay ja multiplayer ka decent on:) ootangi rustile vaheldust!
Timberg
ööKARU
Timberg
sõnum 03.04.2014 21:53:51 vasta tsitaadiga
Mootor ja mis tehtud... tundub väga lahe. Mul on sellest lihtsalt kahju, et maailm on täidetud nende mutantide ja muude värdjatega. Raske on uskuda, et olen vähemus, kui soovin mängus vaenlasteks metsloomi, inimesi ja mitte peajalgseid. Samas... raske või mitte, tuleb leppida tõsiasjaga, et juba mõnda aega vorbitakse nii suures koguses just selliseid mänge, kus vastased on peajalgsed või zombid icon_razz.gif Mis seal ikka icon_smile.gif
Õnneks on olemas üksikus mängud nagu mount and blade, kus zombisid ja peajalgseid pole.
seeeeee mäng näeb niii hea välja!
viimati muutis Timberg 03.04.2014 21:58:44, muudetud 1 kord
siven
siven
sõnum 03.04.2014 21:55:27 vasta tsitaadiga
Timberg kirjutas:
no loodame ,et tuleb mingi mod support:D? paned inimese skinnid kolladele.
kuigi jah mingi kurjad indaanlased junglis võiks näiteks olla kollade asemel.
Timberg
ööKARU
Timberg
sõnum 03.04.2014 22:01:40 vasta tsitaadiga
mõned copyppasted faqst
Will there be a peaceful mode?
Yes. You will be able to play the game as a more traditional survival/exploration simulator, with the horror elements effectively disabled.
Where can I buy the game?
The game will be available on Steam, as well as from our store on the games website: http://survivetheforest.com/ . We are also looking into other different options for selling the game and will update this question when things are confirmed.
How much will the game cost?
The initial Alpha release will cost $14.99.
Will you be able to climb trees or mountains?
Currently you cannot climb trees, although enemies in the game will make use of them. Access to mountain areas will be blocked off in the first alpha release.
Can you build defensive structure or bases in the caves and underground?
Not at this time.
Will there be different areas like different cave (sedimentary, igneous or/and metamorphic caves) and will there be different surface environment with like different animals to hunt or kill (is there hunting?) and different plant areas like marsh, jungle, plains?
There will be different small animals you can hunt. There will also be different environments based on North American forest. The environment will include caves, swamps, lakes and mountains.
Can you play as a female character?
Not for the initial alpha release.
486
sõnum 03.04.2014 22:35:46 vasta tsitaadiga
Need vaenlased niigi liiga inimeste moodi.
zero
pohmakas,
käed värisevad
pohmakas,
sõnum 26.05.2014 04:49:40 vasta tsitaadiga
http://store.steampowered.com/app/242760/
siven
siven
sõnum 26.05.2014 16:11:28 vasta tsitaadiga
kahjuks pole MP loodan ,et tuleb üsna varsti...
Syncmahv
Syncmahv
sõnum 26.05.2014 16:58:09 vasta tsitaadiga
Ei tea kui väga sellisele mängule sobiks üldse MP. Loodetavasti enamvähem hind.
siven
siven
sõnum 26.05.2014 16:59:55 vasta tsitaadiga
Syncmahv kirjutas:
ilma COOP võimaluseta on see mäng küll suht fail.
ja hind oli 14 dollarit.
pohmakas,
käed värisevad
pohmakas,
sõnum 26.05.2014 17:03:27 vasta tsitaadiga
co-op pidavat tulema küll, kuid mitte alphas
xxlmaster
xxlmaster
sõnum 26.05.2014 21:29:32 vasta tsitaadiga
on siin keegi siis proovinud ka asja juba?
E: krt asi tuleb välja alles 30 mai icon_redface.gif
dohc-48v12
Aeg maha 1p
dohc-48v12
sõnum 29.05.2014 22:06:39 vasta tsitaadiga
märk maha,
Tuleb ainult steamile ?
Miks ADMIN Anti112 ambusib mind? andis 1p cooldowni aga ma ei saa peale selle enam mitteühtegi postitust teha! üks päev ei kuid!
Kommentaarid: 112 loe/lisa Kasutajad arvavad:  :: 6 :: 0 :: 85
Syncmahv
Syncmahv
sõnum 29.05.2014 22:29:29 vasta tsitaadiga
Kuhu veel?
dohc-48v12
Aeg maha 1p
dohc-48v12
sõnum 29.05.2014 22:58:07 vasta tsitaadiga
igale poole, aga mitte steamile ! sooviks !
Kahjuks vist pole alternatiivi steamile :S
Syncmahv
Syncmahv
sõnum 29.05.2014 23:58:06 vasta tsitaadiga
Eesti aja järgi launch 30.05 19:00. icon_razz.gif
Dave20
sõnum 30.05.2014 18:48:05 vasta tsitaadiga
Mis stiilis see mäng on, kas nagu outlast?
pohmakas,
käed värisevad
pohmakas,
sõnum 30.05.2014 18:52:15 vasta tsitaadiga
Dave20 kirjutas:
Videoid küllaga välja lastud ju. Horror-survival stiilis, ehk siis õudus/ellujäämine.
Chardin
sõnum 30.05.2014 19:11:30 vasta tsitaadiga
Kas keegi aitaks mul seda mängu osta, millegi pärast ei lase steam mul enam paypal balnce'iga maksta kui ei ole krediit kaardiga seotud.
Edit: Sain nüüd eks hiljem annan oma arvamuse.
viimati muutis Chardin 30.05.2014 19:42:20, muudetud 1 kord
Dave20
sõnum 30.05.2014 19:12:46 vasta tsitaadiga
pohmakas, kirjutas:
Dave20 kirjutas:
Vabandust ma polnud veel väga süvenenud selle mängu teemasse icon_redface.gif
Flasky
Flasky
sõnum 30.05.2014 20:06:36 vasta tsitaadiga
siven kirjutas:
Syncmahv kirjutas:
Co-op elimineeriks ju horror elemendi, või mis?
Kes proovinud on, kuidas mäng jookseb?
pohmakas,
käed värisevad
pohmakas,
sõnum 30.05.2014 20:17:25 vasta tsitaadiga
Flasky kirjutas:
siven kirjutas:
Syncmahv kirjutas:
Chardin
sõnum 30.05.2014 21:48:44 vasta tsitaadiga
Mäng näeb minu arust ilus välja, R280X on max seaded 1080p fps 60 kandis mul. Võiks see option kohe olla kust saab horrori välja lülitada aga muidu päris hea. Täheldasin bug'ina et kui itemeid vahetada siis tekib maha ka sama objekt. Lisaks ei õnnestu mul save'ida aga see võib minu viga olla.
siven
siven
sõnum 30.05.2014 22:26:50 vasta tsitaadiga
Chardin kirjutas:
sandbox mode tuleb ka. see lubatud feature.
pohmakas,
käed värisevad
pohmakas,
sõnum 31.05.2014 01:20:17 vasta tsitaadiga
Link
Matisxx
Matisxx
sõnum 31.05.2014 15:07:56 vasta tsitaadiga
Päris hea mäng on, aga päris hirmus on kui rahulikult ehitad ja 10 venda keset ööd sulle seljataha tulevad icon_smile.gif
Velociraptor
Velociraptor
sõnum 31.05.2014 15:18:11 vasta tsitaadiga
Pole viga, varajase alpha kohta. potentsiaali on küll
🕊 Kuruppo ぽ 🕊
https://www.last.fm/user/Ingvaarr
Kommentaarid: 32 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 30
mtv0308
sõnum 31.05.2014 16:20:50 vasta tsitaadiga
xxlmaster kirjutas:
Mina olen proovinud ja praegu soovita küll kellelegi osta.
*Graafika on võrreldes treileriga paar kraadi (kui mitte rohkem) halvem. Väidetavalt keerati esimese release jaoks maha.
*Ehitamine on üpris vaevarikas ning mitte ressursside pärast vaid on probleeme juba käes olevaid asju kasutada. Lihtsalt ei teki seda E tähte, et palki paika panna. Ehitasin maja, mis nõuab 82 palki, mul õnnestus viis paika panna ja siis rohkem ei tekkinud E tähte kuhugi, et järgmist paigutada.
*Sööki ei saa lõkkest kätte ja marjade peal elamine on suht nutune ning nagu arvata võib ei täida väga midagi.
*Puudub salvestamise võimalus ehk iga kord kui mängu tööle lükkad alustad nullist.
*Kui oma esimesed 3-4 põrgulist maha lõin siis rohkem pole neid ka mängus näinud.
486
sõnum 31.05.2014 18:41:56 vasta tsitaadiga
Kuigi fps 50-60 vahel on väga imelik see hiirega vaatamine. Väga häiriv. Vana unity probleem. Praktiliselt iga suurem mäng sellel mootoril on selline ja ei ütleks, et arvuti on n6rk.
zero
uus teema   vasta Tarkvara »  Arvutimängude foorum »  The Forest mine lehele 1, 2, 3  järgmine
