Timberg
ööKARU
03.04.2014 22:01:40
mõned copyppasted faqst
Will there be a peaceful mode?
Yes. You will be able to play the game as a more traditional survival/exploration simulator, with the horror elements effectively disabled.
Where can I buy the game?
The game will be available on Steam, as well as from our store on the games website: http://survivetheforest.com/ . We are also looking into other different options for selling the game and will update this question when things are confirmed.
How much will the game cost?
The initial Alpha release will cost $14.99.
Will you be able to climb trees or mountains?
Currently you cannot climb trees, although enemies in the game will make use of them. Access to mountain areas will be blocked off in the first alpha release.
Can you build defensive structure or bases in the caves and underground?
Not at this time.
Will there be different areas like different cave (sedimentary, igneous or/and metamorphic caves) and will there be different surface environment with like different animals to hunt or kill (is there hunting?) and different plant areas like marsh, jungle, plains?
There will be different small animals you can hunt. There will also be different environments based on North American forest. The environment will include caves, swamps, lakes and mountains.
Can you play as a female character?
Not for the initial alpha release.
272 |
486
03.04.2014 22:35:46
Need vaenlased niigi liiga inimeste moodi.
_________________ zero |
| Kommentaarid: 46 loe/lisa |
39 |
pohmakas,
käed värisevad
| Kommentaarid: 166 loe/lisa |
137 |
siven
26.05.2014 16:11:28
| kahjuks pole MP loodan ,et tuleb üsna varsti...
149 |
Syncmahv
26.05.2014 16:58:09
| Ei tea kui väga sellisele mängule sobiks üldse MP. Loodetavasti enamvähem hind.
102 |
siven
26.05.2014 16:59:55
| Syncmahv kirjutas: |
| Ei tea kui väga sellisele mängule sobiks üldse MP. Loodetavasti enamvähem hind. |
ilma COOP võimaluseta on see mäng küll suht fail.
ja hind oli 14 dollarit.
149 |
pohmakas,
käed värisevad
26.05.2014 17:03:27
| co-op pidavat tulema küll, kuid mitte alphas
137 |
xxlmaster
26.05.2014 21:29:32
on siin keegi siis proovinud ka asja juba?
E: krt asi tuleb välja alles 30 mai
| Kommentaarid: 83 loe/lisa |
77 |
dohc-48v12
Aeg maha 1p
29.05.2014 22:06:39
märk maha,
Tuleb ainult steamile ?
_________________ Ime tala, Nagu ime kepike.
Miks ADMIN Anti112 ambusib mind? andis 1p cooldowni aga ma ei saa peale selle enam mitteühtegi postitust teha! üks päev ei kuid! |
6 :: |
85 |
Syncmahv
29.05.2014 22:29:29
Kuhu veel?
Aga homme siis oodata
102 |
dohc-48v12
Aeg maha 1p
29.05.2014 22:58:07
igale poole, aga mitte steamile ! sooviks !
Kahjuks vist pole alternatiivi steamile :S
6 :: |
85 |
Syncmahv
29.05.2014 23:58:06
Eesti aja järgi launch 30.05 19:00.
102 |
Dave20
30.05.2014 18:48:05
| Mis stiilis see mäng on, kas nagu outlast?
| Kommentaarid: 26 loe/lisa |
25 |
pohmakas,
käed värisevad
30.05.2014 18:52:15
| Dave20 kirjutas: |
| Mis stiilis see mäng on, kas nagu outlast? |
Videoid küllaga välja lastud ju. Horror-survival stiilis, ehk siis õudus/ellujäämine.
137 |
Chardin
30.05.2014 19:11:30
Kas keegi aitaks mul seda mängu osta, millegi pärast ei lase steam mul enam paypal balnce'iga maksta kui ei ole krediit kaardiga seotud.
Edit: Sain nüüd eks hiljem annan oma arvamuse.
viimati muutis Chardin 30.05.2014 19:42:20, muudetud 1 kord |
| Kommentaarid: 9 loe/lisa |
9 |
Dave20
30.05.2014 19:12:46
| pohmakas, kirjutas: |
| Dave20 kirjutas: |
Videoid küllaga välja lastud ju. Horror-survival stiilis, ehk siis õudus/ellujäämine. |
Vabandust ma polnud veel väga süvenenud selle mängu teemasse
25 |
Flasky
30.05.2014 20:06:36
| siven kirjutas: |
ja hind oli 14 dollarit. |
Co-op elimineeriks ju horror elemendi, või mis?
Kes proovinud on, kuidas mäng jookseb?
| Kommentaarid: 4 loe/lisa |
pohmakas,
käed värisevad
30.05.2014 20:17:25
| Flasky kirjutas: |
| siven kirjutas: |
Kes proovinud on, kuidas mäng jookseb? |
Co-op tuleb ju, miljon korda öeldud
137 |
Chardin
30.05.2014 21:48:44
| Mäng näeb minu arust ilus välja, R280X on max seaded 1080p fps 60 kandis mul. Võiks see option kohe olla kust saab horrori välja lülitada aga muidu päris hea. Täheldasin bug'ina et kui itemeid vahetada siis tekib maha ka sama objekt. Lisaks ei õnnestu mul save'ida aga see võib minu viga olla.
9 |
siven
30.05.2014 22:26:50
| Chardin kirjutas: |
| Mäng näeb minu arust ilus välja, R280X on max seaded 1080p fps 60 kandis mul. Võiks see option kohe olla kust saab horrori välja lülitada aga muidu päris hea. Täheldasin bug'ina et kui itemeid vahetada siis tekib maha ka sama objekt. Lisaks ei õnnestu mul save'ida aga see võib minu viga olla. |
sandbox mode tuleb ka. see lubatud feature.
149 |
pohmakas,
käed värisevad
137 |
Matisxx
31.05.2014 15:07:56
Päris hea mäng on, aga päris hirmus on kui rahulikult ehitad ja 10 venda keset ööd sulle seljataha tulevad
Velociraptor
| Kommentaarid: 32 loe/lisa |
30 |
mtv0308
31.05.2014 16:20:50
| xxlmaster kirjutas: |
E: krt asi tuleb välja alles 30 mai  |
Mina olen proovinud ja praegu soovita küll kellelegi osta.
*Graafika on võrreldes treileriga paar kraadi (kui mitte rohkem) halvem. Väidetavalt keerati esimese release jaoks maha.
*Ehitamine on üpris vaevarikas ning mitte ressursside pärast vaid on probleeme juba käes olevaid asju kasutada. Lihtsalt ei teki seda E tähte, et palki paika panna. Ehitasin maja, mis nõuab 82 palki, mul õnnestus viis paika panna ja siis rohkem ei tekkinud E tähte kuhugi, et järgmist paigutada.
*Sööki ei saa lõkkest kätte ja marjade peal elamine on suht nutune ning nagu arvata võib ei täida väga midagi.
*Puudub salvestamise võimalus ehk iga kord kui mängu tööle lükkad alustad nullist.
*Kui oma esimesed 3-4 põrgulist maha lõin siis rohkem pole neid ka mängus näinud.
_________________ http://www.youtube.com/z4nn1n |
486
31.05.2014 18:41:56
Kuigi fps 50-60 vahel on väga imelik see hiirega vaatamine. Väga häiriv. Vana unity probleem. Praktiliselt iga suurem mäng sellel mootoril on selline ja ei ütleks, et arvuti on n6rk.
Kahju et mootor, nii sitt muidu head mängud
39 |
