uus teema   vasta Tarkvara »  Arvutimängude foorum »  Battlefield 4 märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 359, 360, 361 ... 506, 507, 508  järgmine
Avot
sõnum 31.03.2014 15:55:42 vasta tsitaadiga
Sai siis ka yle pika aja proovitud. Battlefield on Battlefield, ei rohkem, ega vähem. Siin vähe infot :
March 31 PC Game Update Notes
GENERAL FIXES
-General stability improvements
-Fix for a crash that could occur when players were customizing vehicles.
-Fix for an issue in the Rush game mode where end-of-round screen would always indicate that there were 60 minutes left of the game.
-Fix for an issue where the splash damage for IFV shells, Helicopter rockets, and Mortar rounds was unable to destroy deployed equipment.
-Fix for an issue that could cause the quad bike to explode when it hit indestructible objects.
-Fix for an issue that would cause sniper rifles to display too much bloom when aiming in snowy conditions, especially the outside areas of Operation Locker.
-Fix for an issue where the ECM would sometimes fail to jam incoming missiles.
-Shortened the take-off distances for jets to match the length of the runways in Second Assault maps.
-Fix for going above ceiling exploits in Operation Metro.
-Fix for a new MAV riding exploit.
-Fix for kill camera jittering/strobing sometimes if colliding with other world objects or terrain.
-Fix for soldiers getting catapulted when walking on steep surfaces
“NETCODE”
-Fix for an issue where the kill camera would display the incorrect killer.
-Fix for an issue where the kill card won’t show up when playing on servers which have the kill camera turned off.
-Fixed an issue where other soldiers would appear to fire in the wrong direction when turning quickly.
-Fix for weapons firing twice, or not at all in some instances.
-Fix for an issue where explosions didn’t do any damage to infantry and vehicles that were outside of the combat area.
-Fix for an issue where late-joining players wouldn’t correctly experience Levolution events on Paracel Storm and Flood Zone.
-Fix for an issue that could cause packet loss.
WEAPONS / GADGET TWEAKS
-Increased the damage of the normal buckshot against targets with Body Armor.
-Reduced the vertical recoil of the M4 and M16A4 to give these burst fire weapons a tighter burst accuracy in their mid- to long range role.
-Reduced the side-to-side and first shot recoil of the G36C. This weapon now has the lowest side-to-side recoil of the carbines, giving it a clear controllable low rate of fire role, especially when compared to the AK5C, Type-95B-1 and the AKU-12.
-Tweaked the detonation time of the 40mm LVG so it bounces less before going off. The maximum damage has however been reduced to 80 like the RGO.
-Reduced the number of how many 40mm HE and LVG rounds players can carry, from 4 to 3.
-Increased the time it takes to get new 40mm round from ammo boxes. The time is longer for HE and LVG grenades and shorter for utility grenades like SMK and FLASH.
GRENADE TWEAKS
-Increased the time it takes to get new RGO IMPACT, V40 MINI, M84 FLASHBANG and M18 SMOKE grenades from ammo boxes. Since the player now carries more of these grenades, the resupply delay needed to be longer to prevent grenade spamming.
VEHICLE TWEAKS
-Significantly improved the suppression from mounted vehicle weapons, including miniguns, HMGs, LMGs, and all shells types for all armored vehicles.
AIRCRAFT TWEAKS
-Further reduced the repair rate for the Scout Helicopters and the Transport Helicopters.
-Significantly increased the damage of Transport Helicopter miniguns.
-Changed the flight ceilings on Gulf of Oman, Caspian Border and Operation Firestorm to better match the height of the structures in those levels.
-Adjusted the damage of the 25mm and 30mm cannons for both Stealth Jets and Mobile AA to be equal in Damage Per Second to the 20mm default weapons. These weapons were clearly poorer choices in all circumstances, and their different rates of fire are intended to be the player's choice factor for these weapon systems.
-Increased the splash damage and the range at which the JDAM bombs can achieve max splash damage. The JDAM's power was not properly balanced with its difficulty to use. The JDAM remains a primarily anti-vehicle weapon, though this change will increase the effectiveness against all targets.
-Increased the accuracy and direct hit damage of the AC130 40mm cannons. 40mm cannons can now be used to fire pinpoint shots in 2-3 round bursts, enabling them to provide accurate fire on infantry and vehicle targets. Their velocity has also been marginally increased to aid their accuracy.
-Increased the splash damage and range of the AC130 25mm cannons. These cannons now do approximately 50% more damage, in a slightly increased area of impact. The increased damage as well as increased suppression effects will allow the 25mm cannon to fill its role as an area of effect weapon against infantry.
MANTLE
-Mantle now requires Catalyst 14.2 or later drivers.
-Fixed multiple crashes.
-Fixed memory leak when switching between windowed and full screen.
-Optimized memory management which can reduce amount of performance stalls when video memory is overcommitted.
-Improved performance when vsync is used.
-Fixed bug with offset mouse cursor when using full screen and horizontal windows taskbar.
-Multi-GPU: Added initial support for frame pacing for smoother frame rate in full screen mode, enabled by default. Can be disabled in console / User.cfg with “RenderDevice.FramePacingMethod 0”.
-Multi-GPU: Fixed black screen when starting on machine with multiple GPUs where the weakest GPU has the display attached to it.
-Multi-GPU: Fixed intermittent crash when switching between windowed and full screen mode when having multiple GPUs
DIRECTX
-Fixed bug with borderless window not covering entire screen when starting up
Kommentaarid: 3 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 1
äss
äss
sõnum 31.03.2014 17:18:40 vasta tsitaadiga
Kommentaarid: 29 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 23
Karl P.
Karl P.
sõnum 31.03.2014 17:47:19 vasta tsitaadiga
Mul viskas uuenduse lõpus, et "updater is not responding" või midagi taolist. Juba viimased 3-4 uuendust nii olnud icon_lol.gif
Kommentaarid: 33 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 29
BullDoze
BullDoze
sõnum 31.03.2014 18:55:44 vasta tsitaadiga
vastukaaluks eelkõnelejatele installis mul uue update ilusti peale ja kõik tiptop thumbs_up.gif
villu70
villu70
sõnum 31.03.2014 18:58:45 vasta tsitaadiga
BullDoze kirjutas:
sekundeerin
Kommentaarid: 142 loe/lisa Kasutajad arvavad:  :: 3 :: 0 :: 122
looder123
looder123
sõnum 31.03.2014 19:05:09 vasta tsitaadiga
Kas ma olen ainuke, kes ei saa enam expansion mappe mängida? Mängu uuendama pannes ei tee ka midagi, ütleb et pole midagi uuendada. Game details alt vaadates on näha, et mul nagu polekski neid peal. Paremklikk näitab, et peaksin ostma.
lopes39
lopes39
sõnum 31.03.2014 19:15:22 vasta tsitaadiga
Team DM serverid neile uutele kaartidele on ikka täiesti tühjad. Ma neid suuri kaarte väga mängida ei viitsi ja pinda käivad need lennukid ja kopterid.
Võiks tulla mingi kaardi pakk kus neid koptereid ja lennukeid ei ole üldse või siis nende maha võtmine reaalsemaks teha. Näiteks kui ühe paugu pihta lasta rakettiga siis sellest võiks piisada.
Kopterite puhul võiks ka kopter maanduda ennem kui seda parandada saaks. liiga võimsad on need kõik lennumasinad.
Sõitsin mingi attack boat-ga ringi ja ei näe lennukit kuskil aga mind tema näeb ja võtab suht kiirelt maha. Ja näeb nii kaugelt ja saab ka nii kaugelt oma spray-ga mulle pihta, et ma ei saa tärget lock ta peale.
parm
sõnum 31.03.2014 19:21:13 vasta tsitaadiga
Ma ei saagi aru, kas see uus semiauto snaiper SR338 on hea või halb.
Carrier assault oli küll väga halb, 5 minutit saad lippe cappida ja siis läheb carrieri peal ilgeks mäsuks ja paari minutiga ongi mäng läbi - WTF DICE?
| SPARCO toolid https://www.carshop.ee/et/2374-sparco | Tuuningosad mootorsõidukitele - www.carshop.ee |
Kommentaarid: 56 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 55
softis
softis
sõnum 31.03.2014 20:13:08 vasta tsitaadiga
Sitaks vett, taevas AC130 mida tiimikaaslased alla tuua ei püüa ja lühikesed roundid.
looder123
looder123
sõnum 31.03.2014 20:14:23 vasta tsitaadiga
A kuidas te selle naval strike'i saite, mulle küll ei paku.
Siim159
Siim159
sõnum 31.03.2014 20:18:00 vasta tsitaadiga
Premium oled üldse?
looder123
looder123
sõnum 31.03.2014 20:19:45 vasta tsitaadiga
Olen.
Siim159
Siim159
sõnum 31.03.2014 20:23:52 vasta tsitaadiga
Kui sa Originis lähed BF4 peal parem klõps - game details, siis kas seal all, kus DLC-d välja toodud, seal näitab Naval Strike'i/on lahti?
BullDoze
BullDoze
sõnum 31.03.2014 20:41:53 vasta tsitaadiga
parm kirjutas:
mulle hetkel meeldib
looder123
looder123
sõnum 31.03.2014 21:11:21 vasta tsitaadiga
Siim159 kirjutas:
Selline pilt avaneb
Tegelikkuses on mul premium olemas. Ma ei tea miks ta nii teeb.
Siim159
Siim159
sõnum 31.03.2014 21:13:23 vasta tsitaadiga
No ilmselt siis ikka ei ole Premiumit, kui selline pilt seal icon_biggrin.gif
Ma ei tea, kas China Risinguga ta näitaks sama pilti, kuid ehk sul Limited Edition, millega tuli esimene DLC ehk China Rising kaasa? Limited Edition ei ole Premium. Või oled eelnevalt ka kõik teised DLC-d saanud endale?
looder123
looder123
sõnum 31.03.2014 21:18:40 vasta tsitaadiga
Mul on Premium, ostsin koos mänguga selle. Kuu aega tagasi oli veel kõik ok. Täna hommikul origini tööle pannes tegi update mängule ja peale seda oligi perses.
Creat_1
Creat_1
sõnum 31.03.2014 21:18:59 vasta tsitaadiga
kas keegi veel tähele pannud, et viimasel ajal serverid läggivad? icon_rolleyes.gif mingi 30min on ok ja siis häkkab jõhker lagfest pihta (ka teised serverites kurdavad) icon_rolleyes.gif
Kommentaarid: 103 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 94
Muhekas
Muhekas
sõnum 01.04.2014 03:28:05 vasta tsitaadiga
ot:
Täiesti uskumatu milline lihtsalt võib üks eestlane olla... küsid viisakalt küsimuse mingit elemantaarset vastus pole lootagi räägi nagu seinaga. Kolmandal korral küsitakse mis ahhh ähhhh ja kogu moos.
Olenemata olukorrast, jää iseendaks ja samas lugupidavaks.
madness
madness
sõnum 01.04.2014 07:33:32 vasta tsitaadiga
looder123 kirjutas:
Mul on Premium, ostsin koos mänguga selle. Kuu aega tagasi oli veel kõik ok. Täna hommikul origini tööle pannes tegi update mängule ja peale seda oligi <b>piixus</b>.
renekas
renekas
sõnum 01.04.2014 09:33:04 vasta tsitaadiga
Kas oled üldse redeeminud oma premiumio ?
@duxdery, mulle ei pea rääkima, ma alati enne clearin area ja alles siis reviven kui aega jääb.
Mis uude patchi puutub siis mul hakkas mäng crashima jälle, nii mantle kui ka directx-ga. migni 3x roundi jooksul crashib.
Ja naval strike mapid on liiga väikesed.
trip
trip
sõnum 01.04.2014 13:35:34 vasta tsitaadiga
tal prem võtmega probleem.
küll huvitav ea suhtumine (Premium was disabled because the retailer who sold the code was unauthorized, and was potentially selling a stolen or hacked code).
võti ise ca 2 kuud kasutusel ja nüüd selline teade.
Killerwave
Killerwave
sõnum 01.04.2014 13:45:40 vasta tsitaadiga
Seega meie kallite idanaabrite käest ostetud versioonid ei tööta enam?
trip
trip
sõnum 01.04.2014 13:48:04 vasta tsitaadiga
kõik toimib nagu peab.
villu70
villu70
sõnum 01.04.2014 18:56:54 vasta tsitaadiga
Mingi imelik lagg on tekkinud. Jooksed ja mingi iga 20-30 meetri pealt jääb mees nagu millegi taha sekundiks/kaheks toppama.
Vahet pole kus serveris ja mis mappi mängid. Kunagi varemalt on ka see jama selles mängus olnud.... vist.
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Battlefield 4 mine lehele eelmine  1, 2, 3 ... 359, 360, 361 ... 506, 507, 508  järgmine
