Laizk
31.03.2014 13:27:26
salatoimik kirjutas: |
optika otsas
tsitaat: |
Pinging neti.ee [195.50.209.246] with 32 bytes of data:
Reply from 195.50.209.246: bytes=32 time=297ms TTL=58
Reply from 195.50.209.246: bytes=32 time=356ms TTL=58
Reply from 195.50.209.246: bytes=32 time=385ms TTL=58
Reply from 195.50.209.246: bytes=32 time=189ms TTL=58
Reply from 195.50.209.246: bytes=32 time=330ms TTL=58
Reply from 195.50.209.246: bytes=32 time=410ms TTL=58
Reply from 195.50.209.246: bytes=32 time=373ms TTL=58
Reply from 195.50.209.246: bytes=32 time=409ms TTL=58
Reply from 195.50.209.246: bytes=32 time=386ms TTL=58
Reply from 195.50.209.246: bytes=32 time=387ms TTL=58
Ping statistics for 195.50.209.246:
Packets: Sent = 11, Received = 11, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 189ms, Maximum = 410ms, Average = 357ms
kurda tehnilisse tukke:
Reply from 195.50.209.246: bytes=32 time=6ms TTL=57
Reply from 195.50.209.246: bytes=32 time=5ms TTL=57
Packets: Sent = 18, Received = 18, Lost = 0 (0% loss),
Minimum = 5ms, Maximum = 6ms, Average = 5ms
Kommentaarid: 10 loe/lisa |
9 |
31.03.2014 13:39:22
salatoimik, kuidas võrgu koormus on, äkki keegi läbustab kohapeal võrku?
Kommentaarid: 181 loe/lisa |
145 |
31.03.2014 13:45:32
Mark0 kirjutas: |
salatoimik, kuidas võrgu koormus on, äkki keegi läbustab kohapeal võrku? |
Olematu koormus.
Nüüdseks normaalseks tagasi läinud.
Kommentaarid: 39 loe/lisa |
31.03.2014 13:47:20
Noh jah. Ega traceroute't ei teinud samal ajal? Oleks vähe rohkem infot, hetkel kahjuks ei teagi, milles kühvel oli.
145 |
ufo56
31.03.2014 15:27:38
Laizk kirjutas: |
optika otsas
tsitaat: |
Minimum = 5ms, Maximum = 6ms, Average = 5ms |
https://www.dropbox.com/s/t7cxsrh3luoldhh/shot_140331_152710.png
Endal suht stabiilselt selline. Vahel oli küll suht kõrge.
Lae pildid -> pilt.io |
Kommentaarid: 78 loe/lisa |
67 |
mustuss
02.04.2014 10:37:09
Üritan TG789 ruuterile uut softi peale ajada, aga saan upgradeST44210.exe programmiga järgneva veateate: This application has failed to start because MSVCIRT.dll was not found. Re-installing the application may fix this problem. Kas keegi teab sellele probleemile mingit lahendust? Guugeldades sain teada, et see dll on seotud Microsoft (R) C++ Runtime Libraryga.
02.04.2014 10:41:23
mustuss, ja google "Microsoft C++ Runtime Library download" on edasi ülejõu käiv? Tiri ometigi alla ja paigalda kui sulle öeldakse selges inglise keeles et teek on puudu.
Kommentaarid: 168 loe/lisa |
157 |
mustuss
02.04.2014 10:58:18
bladerunner kirjutas: |
mustuss, ja google "Microsoft C++ Runtime Library download" on edasi ülejõu käiv? Tiri ometigi alla ja paigalda kui sulle öeldakse selges inglise keeles et teek on puudu.  |
Võtsin eile need maha ja lasin uuesti peale. Ei toiminud. Nüüd tegin uue ringi ja ikka ei saa toimima. Fail iseenesest istub /system32/ kaustas.
02.04.2014 11:01:24
mustuss, VC++ versioone on mitmeid, proovi erinevate aastakäikude oma.
Võid ka katsetada http://www.dependencywalker.com/ et kas ikka kõik teegid leitakse.
157 |
A.S.
02.04.2014 11:23:46
mustuss kirjutas: |
Fail iseenesest istub /system32/ kaustas. |
Ja kui kopeerid selle upgradeST44210.exe kausta?
Kommentaarid: 33 loe/lisa |
33 |
Kommentaarid: 92 loe/lisa |
mustuss
02.04.2014 11:38:18
Seda samasse kausta panemist proovisin, aga tulemust see ei andnud. Igatahes sai tõmmatud mingilt aadressilt see .dll ja asendatud olemasolevaga. Programm hakkas tööle.
02.04.2014 12:06:51
/OT/ Tomorrow, need mis teeke oma (kodu)kaustast otsivad peavad seda spetsiaalselt tegema. Standardne LoadLibrary() käib ikka ennekõike just süsteemsetest kohtadest teeke laadimas.
mustuss, ju sul siis ikka vale versioon oli. VC++ 2005 / 2010 on erinevad mida proovida.
157 |
DarkSky
05.04.2014 19:25:25
Kellelgi veel täna netiga probleeme on olnud? Ise veidi aja eest tükk aega maadlesin ruuteriga (Inteno), ei tahtnud tulla ei internet ega ka TV. Peale korduvaid "Reset" nupu vajutamisi hakkas asi (nett + TV) lõpuks toimima. Küll aga mitte lauatelefon. Selle torust kostab piiksumist. Kas teistel ka sarnast jama või ainult mul siin? Ühendus on VDSL2 30/10.
Pailaps
05.04.2014 19:28:51
DarkSky kirjutas: |
Kellelgi veel täna netiga probleeme on olnud? Ise veidi aja eest tükk aega maadlesin ruuteriga (Inteno), ei tahtnud tulla ei internet ega ka TV. Peale korduvaid "Reset" nupu vajutamisi hakkas asi (nett + TV) lõpuks toimima. Küll aga mitte lauatelefon. Selle torust kostab piiksumist. Kas teistel ka sarnast jama või ainult mul siin? Ühendus on VDSL2 30/10. |
Arvatavasti lokaalne probleem ruuteri firmwarega. Üldist probleemi oleksin ma märganud monitooringus.
Pärast resetti tasub veidi oodata, kui automaat tagasi konfib.
Kommentaarid: 56 loe/lisa |
52 |
DarkSky
05.04.2014 19:38:27
Ruuter juba tiba üle poole tunni näitab et on olnud töös aga telefoni torust kostab endiselt piiksumist. Samas interneti ega ka TV töös häireid pole enam esinenud.
05.04.2014 20:30:58
DarkSky kirjutas: |
Ruuter juba tiba üle poole tunni näitab et on olnud töös aga telefoni torust kostab endiselt piiksumist. Samas interneti ega ka TV töös häireid pole enam esinenud. |
Peale reseti võtab kuni 15 min tavaliselt aega, et voip number taastada. Hetkel paistab sul kõik ruuteris kena olema, liiniga ka probleeme pole.
Kommentaarid: 260 loe/lisa |
226 |
DarkSky
05.04.2014 20:45:09
Teen uue reseti kui teised pereliikmed on tv vaatamise lõpetanud. Hetkel lauatelefon endiselt piiksub.
05.04.2014 20:50:33
DarkSky kirjutas: |
Teen uue reseti kui teised pereliikmed on tv vaatamise lõpetanud. Hetkel lauatelefon endiselt piiksub. |
Kasvata munad ja tee kohe reset
79 |
DarkSky
05.04.2014 21:15:17
Polnud resetti vaja. Telefon hakkas taas normaalselt tööle.
KillFrenzy
08.04.2014 23:23:11
Kuna digitv teemas muud nuttu ja hala nii palju, siis küsiks siit, äkki mõnel targemal ideid.
TG784 -> DD-WRT WDS AP <-> DD-WRT WDS Station -> Samsungi telekas. Selline wireless link sai püsti pandud. Samsungi teleka tööle paned, enam üle wifi interneti ei saa, samas mõlemas telekas pilt jookseb ja samsuniga saab internetti minna. Paned samsungi kinni, saab üle wifi uuesti interneti minna. Ideid?
Kommentaarid: 151 loe/lisa |
133 |
09.04.2014 23:27:05
Huvitav millal Elion hakkab tegema koostööd Huaweiga ja käivitab Eestis samamoodi siis ADSL2 uuenduse Vectoring on VDSL2 technology
Igatahes Iirimaal pandi selline värk siis tööle ja lubatakse selle kaasabil suuremaid ADSL2 kiiruseid.
Vectoring on VDSL2 technology is a cutting edge development that uses noise cancelling technology to boost broadband speeds to homes and businesses. This process strengthens the broadband signal and gives home and business broadband customers faster speeds.
http://pr.huawei.com/en/news/hw-331816-ict.htm#.U0WqSXCitFk
Kommentaarid: 284 loe/lisa |
211 |
10.04.2014 08:07:45
tahanteada kirjutas: |
http://pr.huawei.com/en/news/hw-331816-ict.htm#.U0WqSXCitFk |
1. Elion/EMT teevad koostööd huaweiga pakkudes nende toodetud erinevaid seadmeid.
2. Elion kasutab enamasti ühe teise tootja DSL sõlmesid aga ka Huawei kappe on kasutusel ning kõikides uuemates jaamades on juba VDSL2 olemas mis kasutab ka Vectoringi.
http://en.wikipedia.org/wiki/Very-high-bit-rate_digital_subscriber_line_2
17a profiili kasutavad kliendiseadmed on võimelised pakkuma kiirusi kuni 100 alla ja 50 üles kuid seda vaid tehniliselt lubatud kauguses, kuni 300m. Pikematel vahemaadel muutub kiirus järsult ADSL2+ sarnaseks seega kaugemale pole seda mõtet pakkuda kui kuni 800m mille jaoks on Elion valmis häälestanud profiili kiirustega 45Mbit/s alla ja 12Mbit/s üles. See lubab pakkuda interneti kiirust kuni 30/10 ja jääb vaba ressurssi üle veel IPTV ja VOIP teenuste pakkumiseks.
Loomulikud oleks võimalikud kõik liitpaaridega lahendused ehk siduda kaks vasepaari ja jaamaporti ühe teenuse jaoks mis võimaldaks vahemaad pikendada poole võrra või siis pakkuda lühema maa peale veel topeltkiiruseid. Selliseid kliendiseadmeid erilahenduste pakkumiseks Elionis ei ole. Teades kui probleemne oli kahe vasepaari peal SDSL teenuste tarbimine jääb ka mitme paari VDSL ära.
226 |
eltso
10.04.2014 08:55:19
Aga kui piisavalt kaua vaielda ja peale käia, kas siis oleks lootus, et need kes on natukene 800m piirist väljas, saaksid vähemalt testida vdsl-i ja näha et nad on liiga kaugel ja kvaliteet on olematu?
Kommentaarid: 14 loe/lisa |
14 |
10.04.2014 10:36:13
eltso kirjutas: |
Aga kui piisavalt kaua vaielda ja peale käia, kas siis oleks lootus, et need kes on natukene 800m piirist väljas, saaksid vähemalt testida vdsl-i ja näha et nad on liiga kaugel ja kvaliteet on olematu? |
Küsimus on see, et kuskohast alates on lihtsalt puud ja kuskohast algab mets. Oletame, et elad 850m DSLAMist ja piir tõstetakse näiteks 850m peale. Noh, tulemus ei pruugigi väga hull olla või isegi on täitsa hea Sinu puhul kuna korralik jäme kaabel tuleb koduni.
Aga siis tuleb 875m kaugusel elav inimene ja küsib: "Aga miks tema saab ja mina ei saa? Ma olen ju vaid 25m eemal kui tema." Ning mõned uued 840m kaugusel olevad kliendid on saanud üsna kehva VDSLi kuigi 12/1 oleks märksa paremini läbi käinud. Ja nii see läheb...
Mõne liini peal pole ka üle kilomeetri midagi VDSLi jaoks (praktikas nähtud). Aga hetkeseis näitab, et 800m on üsna mõistlik kesktee. Muidugi seda piiri vaadatakse üle ja võib juhtuda, et millalgi tõstetakse piiri. Sest ega varem oli see joon märksa madalamal kui 800m.
145 |
