jaank
10.02.2014 23:18:37
| Mul ka ainult padjad ära väsinud mingi 6 aasta jooksul. Raske on kurta.
| Kommentaarid: 63 loe/lisa |
57 |
10.02.2014 23:26:06
lopes39, steelseries siberia v2
182 |
lopes39
11.02.2014 02:18:21
| rmc, Ei mitte mingil juhul. Vaatasin neid ja ei meeldi. Hind on ka kirves. Kuskil isegi vist oli võrdlus creative tactic3d sigma versus steelseries siberia ja ei pidand palju parem olema. Samas kui ma kokku maksis 50 euri oma klappide eest ja need pidid ühed kergemad klapid olema, siis kindlasti need ja veel üle kahe korra odavamalt.
| Kommentaarid: 10 loe/lisa |
CoiL
17.02.2014 01:02:59
Jäin vist "natuke" hiljaks vastamisega Aga parem hilja kui mitte kunagi. Rockgrotto foorumist ja mujalt kokku kogutud inf, äkki tuleb kellelegi veel kasuks:
___________________________________________________________________________
---<([|||/// HD-681 Filter mod \\\|||])>---
Filter components:
Resistors:
use wirewound, Metal film, carbon whatever you like or feel will be better.
Not of any importance really in this application as long as the wattage is
ABOVE 0.25W (which most resistors are)
capacitor 1uF:
Multicomp MCRR50105Z5UM00050 = Farnell order code 121-6447
or:
Multicomp MCRR50105X7RK00050 = Farnell order code 121-6443 (used by me)
or:
AVX SR305C105KTR = Farnell order code 110-0398
or:
AVX SA305E10MARTB = Farnell order code 110-0420
Inductor (choke coil):
EPCOS B82144A2474J = Farnell order code 517-070 (used by me)
or:
EPCOS B82145A1474J000 = Farnell order code 164-4331
or any other small coil, inductor, choke with 470uH and a resistance of
equal or lower than 2.5 Ohms.
Only the resistor values are to be altered.
You can vary the resistor value
of R3 and R4 (now 39 Ohms) between 27 (to little damping of high freq) to
120 Ohms (a bit too much damping of high freq.). You can put a 100 Ohms
potentiometer in it's place and fiddle with the settings for instance.
If the resistor value of R3/R4 is between 25 and 50 Ohms use 56 Ohm resistors for R1/R2
If the resistor value of R3/R4 is between 50 and 75 Ohms use 47 Ohm resistors for R1/R2
If the resistor value of R3/R4 is between 75 and 150 Ohms use 39 Ohm resistors for R1/R2
The capacitor and inductor need not to be changed as these are the frequency
determining parts of the filter.
Resistor R3/R4 determines the Q factor of the
filter AND amount (dB) of filtering at the filter frequency.
The center frequency is around 7.2kHz.
L1,C1,R1,L2,C2,R2 are for compensating
the impedance peak which is caused by the filter network L3,L4,R3,R4,C3,C4.
You can leave L1,C1,R1,L2,C2,R2 out IF you want if you are ONLY going
to use these cans on a low Z output amp (around 10 Ohms).
In all other circumstances (output impedance between say .. 20 Ohms and 600
Ohms or unknown) this part (L1,C1,R1,L2,C2,R2) of the filter network is ESSENTIAL
in obtaining the right amount of damping.
maximum highs, sibilance gone HD681 character remains (first filter):
R1=R2=56 Ohm
R3=R4=39 Ohm
slightly less treble but still close to original HD681 character:
R1=R2=56 Ohm
R3=R4=47 Ohm
less treble but still brighter then Sennheiser signature in general (second filter):
R1=R2=39 Ohm
R3=R4=56 Ohm
About equal to Sennheiser signature in general bass more prominent:
R1=R2=39 Ohm
R3=R4=82 Ohm
Capacitors:
Some say polyprop sounds better (in this picture).
Some will say mica or
silver-mica is better, yet not available in these values.
Multitlayer ceramics
(X7R is preferred over Z5U) are small and can be used inside the headphone without
taking up too much space. There are also smaller sized polypropyline avaiable.
The voltage (which determines the size) is not of importance.
For external filters
the sky is the limit (money wise) and can be constructed to your audio religion.
Q: For the orginal HD681 filter from the very first page, say I want to attenuate
the ~7.25 kHz frequency 3db rather than 6db? I replace the resistor in parallel
part of the filter with one of lower value correct? What value would I use?
A: Parallel filter (the one in series with the driver) between 27 and 33 Ohm
series
filter (on the input of the filter) R = 68 Ohm
HD-662 mod (-3dB bandwidth 3.4 kHz - 11 kHz,
-7.5dB @ 6.3kHz):
r1 = r3 = 47 Ohm
c1 = C3 = 1.33nF (1uF // 330nF)
L1 = L3 = 470uH
____________________________________________________________________________
HD-662F filter (CoiL):
r1 = r2 = 47 Ohm
r3 = r4 = 51 (56 Ohm if cymbals and guitars feel too bright)
C1 = C2 = C3 = C4 = 1.33nF (1uF // 330nF)
L1 = L2 = L3 = L4 = 470uH |
Vahelduseks jälle Aune T1 juttu. Jah tean, et mõnel tulevad siin ihukarvad püsti kui seda kuuleb Sattusin hiljuti lampide jahtimisega kogemata sellise kuulasoone otsa (suure tõenäosusega on need samad aga teise markeeringuga): http://www.tubemuseum.org/ProductDetails.asp?ProductCode=SH-E88CC+PVT.STOCK
Sain neid 5tk, kasutamata, 32€ eest, siitsamast kodumailt. Kes asjaga kursis, siis teab palju ainuüksi 1 selline lamp maksab tegelikult
Ja mis seal ikka heli kohta kosta kui et tõesti - püha graal(id)! Nagu head-fi pedekate maalilmas öeldaks - nö. "holograafilise/3D" heliga!
Mul vahepeal igasugu eri tüüpi lampe miski ~70 kandis kogunenud ja need on parimad. Mõned üksikud on, mis saavad üsna lähedale helipildis ja kõlavad samuti "holograafiliselt" aga siiski mõnede väikeste puudustega.
Lambid lampideks, mis veel vahepeal tehtud - hunnik kondekaid välja vahetatud ELNA SilmicII vastu. Kui muidu olin seda usku, et "haha, ei muuda need kondekad muhvigi", siis nüüd söön sõnu - hämmastavalt positiivne muutus helis, kesksagedused on ülimalt "elavad" ja üleüldse terve heli muutus peale seda väga nö. "tõetruuks". Need kondekad + Siemens E88CC lamp = korralik kõrva-orgasm. Näiteks Mari Pokineni "Maa saab taevani" (FLAC) kõlab nii nagu istuks kontserti saalis, iga väikseimgi detail - klaveri haamrite "mütsud", pedaalide liikumine, kitarri/käe liikumine ja klõbinad, iga laulja hingetõmme ja neelatus jne. - kõik on selgesti kuulda. Vahepeal hakkab lausa "häirima" Eriti muljetavaldav on vokaali ehedus - hääle intonatsioon ja "soojus". Pillide paiknemine ruumis on selgesti eristatav jne. ESI Juli@ helikaardilt ei kuulnud ma kunagi sellist helipilti ja "tõetruudust". Peab vist vaikselt kallimate klappide poole ka vaatama hakkama, sest tundub, et moditud HD-681 klapid ei jõua sellele süsteemile järgi, helipildi sügavuses tekib nö. "sein ette".
| ihvike kirjutas: |
Selleks, et tavaliste klappidega n-ö ruumilist heli kuulata, peab olema binaural salvestus. Neid otsi aga tikutulega taga, kui pole juttu neist äraleierdatud demoklippidest. Heal juhul Fritziga (Neumann KU-100) või halvemal juhul jumal teab millega lindistatud binaural ei jäta ausaltöeldes vähemalt muusika puhul küll mingit erilist muljet. Tavaline stereo on väga sarnane.
Ütleks omast kogemusest, et näiteks selle salvestuse puhul: http://www.hdtracks.com/explorations-in-space-and-time-176-24-binaural
tuleb küll vahe tavalise stereoga esile, ei ole küll suur vahe aga minu jaoks küll selgesti eristatav ja tõetruum. Kas sellised salvestused tasuvad ära oma hinda
ja ruumikulu on muidugi kaheldava väärtusega, eriti siis kui juba olemas selline süsteem, mis väheke tõetruuma helipildiga.
Lisaks mainiks ära, et kõik see eelnev on minu subjektiivne arvamus ja reaalne vahetu kogemus ning ei viitsi siin vaidlema kukkuda. Need kes kuulavad "teooriaga" mitte kõrvadega, võiks lihtsalt seda postitust ignoreerida
Et rohkem teemasse oleks, siis ootaks soovitusi klappide suhtes millel nö. sügav helipilt ilma, et kaotaks laiuses. Hind võiks sinna max 200€ piirimaile jääda.
PS, kellel huvi Aune T1-te oma klappidega kuulama tulla, siis võtku ühendust ja lepib miskit kokku
viimati muutis CoiL 17.02.2014 01:30:29, muudetud 1 kord |
| Kommentaarid: 95 loe/lisa |
83 |
jaank
17.02.2014 01:09:29
| Mul tulevad ihukarvad püsti kui mul tuleb jälle tahtmine Aune T1te osta lol.
57 |
bjaka
17.02.2014 21:58:09
Sai süda rindu võetud ja Grado GR10-d hangitud. Võrreldes Vsonic GR07 on heli õhulisem. Sobib eriti klassikalise muusika ning jazzu kuulamiseks. Samas meeldib Vsonic rohkem popi ja rocki puhul. Samas JVC HA-FXT90 on ületamatu David Bowie Ziggy Stardusti remasteri puhul (ei oleks uskunud, et seal midagi uut veel avastan aga võta näpust)
| Kommentaarid: 86 loe/lisa |
81 |
RaPTiLE
19.02.2014 16:33:24
Millised ülepea klapid võtta 40€ eest.
Läheksid PS3 järgi ja läpakast filmide vaatamiseks.
| Kommentaarid: 60 loe/lisa |
55 |
pots4t4j4
19.02.2014 20:45:04
| misasjad on ülepea klapid?
401 |
cubedude
19.02.2014 20:51:49
| pots4t4j4 kirjutas: |
| misasjad on ülepea klapid? |
Ma usun et juttu on 4. ehk over-ear
| Kommentaarid: 90 loe/lisa |
87 |
19.02.2014 20:53:44
| cubedude kirjutas: |
Ma usun et juttu on 4. ehk over-ear |
igaks juhuks mainin, äkki tekib tõlke viga, õige vastus on nr4
edit:
krt, ei näinud, et sul see kirjas
cubedude
19.02.2014 20:59:18
| RaPTiLE kirjutas: |
Läheksid PS3 järgi ja läpakast filmide vaatamiseks. |
endal sama mõte et ps3, telefoni ja läpaka järgi tahaks aga ehk teab keegi blutooth versiooni mille poole oleks mõttekas vaadata ja ka mikrofoniga?
87 |
beastbeats
19.02.2014 22:41:51
| RaPTiLE kirjutas: |
https://foorum.hinnavaatlus.ee/viewtopic.php?t=601158
M: Schwalbe G-One Allround rehvid - 2tk/30€
M: Shimano XT kiirkinnitused - 2tk/15€ |
284 |
Ertai
22.02.2014 23:19:38
Oskate soovitada midagi spordi tegemiseks ? (suusatamine, jooksmine jms)
Hinnaklass 2-20€
| Kommentaarid: 52 loe/lisa |
47 |
22.02.2014 23:48:53
| Ertai kirjutas: |
Hinnaklass 2-20€  |
suvalised?!
Driftmoon
25.02.2014 12:26:10
| Ertai kirjutas: |
Hinnaklass 2-20€  |
ise nendega jooksmas käinud:
http://www.soundshop.ee/?id=1575 Sennheiser CX 150
püsivad kõrvas hästi, ära ei kuku, kvaliteet kah ok
| Kommentaarid: 40 loe/lisa |
39 |
libe
kvaliteetne mees
25.02.2014 21:10:38
| Konks kirjutas: |
| Ertai kirjutas: |
Hinnaklass 2-20€  |
püsivad kõrvas hästi, ära ei kuku, kvaliteet kah ok  |
sai kunagi 525.- eeku eest cx300 ostetud ja nood olid tollal küll võrdlemisi head klapid, aga ikkagi pasad
20€ eest ei saa head klappi
tuleb osta kõige ilusam ja mugavam ning parima garantiiga
garantii osas on koss hea
_________________ ☠ |
| Kommentaarid: 82 loe/lisa |
CoiL
28.02.2014 01:58:09
Keegi teab kus Tartus saaks Sennheiser HD-598 klappe proovida? Või on keegi nii lahke ja ulatab abikäe?
Samuti huvitaks ka Sennheiser HD-650, AKG Q701 või K702 proovimine.
83 |
SunBear
28.02.2014 21:30:00
| tuleb osta kõige ilusam ja mugavam ning parima garantiiga |
Tuleb veel ära märkida, et suurem osa poodidest ei anna sulle blisterpakendis klappe proovida. Ostad põrsa kotis kui kodutöö on tegemata.
Sennide laituseks tuleks märkida, et higi toimel läheb klapi traat jäigaks nagu spagett. Mingi aeg lendavad kergema köhatuse peale kõrvadest välja.
Kiita võin kallimaid Denoneid ja HTC föönidega kaasa tulevaid Beats in-ear klappe.
| Kommentaarid: 12 loe/lisa |
10 |
priitr
05.03.2014 23:39:45
Kui isu paremate-kallimate klappide järele, aga põrsast kotis ei taha osta, siis minu soovitus on vähemalt Tallinna inimestele kasutajaga Vares ühendust võtta ja tema poes kuulamas käia - tal seal ValiHelis igast' patsahkam häid ja paremaid klappe kohapeal proovimiseks olemas. Hinnaklassis vist nii 80-2000€.
Et see lausreklaamina ei kõlaks , siis just ostsin lapsele sealt Denoni AH-D340. Meeldisid värskele omanikule rohkem, kui proovitud Grado SR-80 või Audio-Technica ATH-M50.
_________________ Tšudes ne bõvajet. |
| Kommentaarid: 27 loe/lisa |
CoiL
06.03.2014 22:49:57
| Lastele (veel rikkumata kuulmine) ongi ilmselt Grado / M50 / HD-681 liiast... justnimelt kõrgsageduste poolest.
83 |
Froggy
12.03.2014 17:47:08
| Froggy kirjutas: |
Mu EVO-d puhta pooleks. Ükshetk pähe pannes läks katki lihtsalt :/ Oktoobris ostetud alles.
Täna sain tasuta uued Ei teagi, kas garantii korras või on summa tehasele nii olematu, et jagatakse niisama
| Kommentaarid: 29 loe/lisa |
flake
19.03.2014 07:37:36
Ostsin Bose Quiet Comfort 15ned. Esmamulje on WOW
_________________ ..||.. |
60 |
Markos
22.03.2014 01:30:25
| Kui võtta nt Denon AH-D600 siis mis sorti võimu sellega paaris soetada? |
Need klapid ei vaja võimu, head allikat küll. Takistus on neil 24 oomi ja nad on tõsiselt kergesti draivitavad. Endal on Fiio E17 Alpen + E09k combo toiteks ja peab ütlema, et viimane on liiast, piisaks ainult Alpenist ka, ning seegi on veerandi peal ainult. Piirasin setupis isegi max nivoo ära, igaks juhuks, et õnnetust ei juhtuks. Muidu klapp ise on superluks ja väärt iga eurot.
Samuti huvitaks ka Sennheiser HD-650, AKG Q701 või K702 proovimine. |
Kas sa neid esimesi tahad heli või välimuse poolest ? Kui esimene, siis parem jäta nad rahule ja võta 650 (kui just avatud klappi tahad). Ma kiibitsesin ka pikka aega neid ja kui näpud taha sain, pidin kahjuks pettuma. Mugavad on seda küll.
| Kommentaarid: 14 loe/lisa |
12 |
CoiL
83 |
bjaka
23.03.2014 13:23:45
| Ja kuidas tunduvad heliliselt?
81 |
CoiL
23.03.2014 20:26:37
Järgmise nädala lõpus saan ilmselt alles kätte, eks siis muljetan. Otsus tuli küll kerge kahtlusega kuna tegemist ei ole päris audiofiili klappidega (st. neutraalse helipildiga) aga ei suutnud lihtsalt nende välimusele, pakutud hinnale ja kiidetud helipildi ruumilisusele vastu panna. Arvamusi on seinast seina aga kiidetakse just seda, et need on ühed vähesed klapid, mis meeldivad nii neutraalse heli pooldajatele kui ka neile kellele meeldib natuke koloreeritud heli. Kahes asjas ollakse suhteliselt ühel meelel - vaatamata 30Ohm`le vajavad need klapid võimendust ja originaal kaabel vajab asendamist. Eks näis kuidas Aune T1-ga sobituma hakkavad. Võib juhtuda, et nö. täielik seksuaalne sobimatus ja siis panen ilmselt klapid müüki kuna Aune T1-st loobuda ei kavatse.
Samas lugedes headfonia ülevaadet ( http://www.headfonia.com/the-fidelio-x1-by-philips/ )...
| The 1840 is still more refined, and the mids and highs are smoother, but I find that a good tube amp can help the X1 in those departments. |
| The key, is to find an amp with a smooth top end and a full midrange. This headphone has a good speed and attack by default, so I won’t be needing a solid state. What it needs, however is a little smoother treble and a little boost in the mids body. The ALO Pan Am is the best pairing I’ve heard with the X1 especially with the smooth Siemens tube upgrade. |
...siis tundub, et Aune T1 + Siemens E88CC võib nagu rusikas silmaauku olla
83 |
flake
24.03.2014 13:57:32
Sain siis ka oma Xiaomid kätte. Esmamulje on
60 |
Naljatilk
24.03.2014 15:46:05
Täna käisid mu uudistevoost läbi sellised klapid:
http://www.lstnheadphones.com/collections/troubadours/products/ebony-wood-troubadours
* Käsitöö
* Iga klapipaar on unikaalse välimusega, sest tehakse taastatud puidust.
* Iga paari ostmine läheb ka heategevusse: ühele vaegkuuljale kingitakse kuulmiseks vajalik aparatuur
* Lisaks välimusele ja filantrooplusele pisavat isegi heli olema suurepärane.
_________________ Vaata pilti |
| Kommentaarid: 11 loe/lisa |
flameas
24.03.2014 19:03:31
Sai tellitud Marshall Monitorid, 130 euroga, mis tundus väga hea pakkumine olevat. Varsti saab muljetada ka
| Kommentaarid: 91 loe/lisa |
81 |
CoiL
25.03.2014 13:50:15
| Naljatilk kirjutas: |
* Käsitöö
* Lisaks välimusele ja filantrooplusele pisavat isegi heli olema suurepärane. |
Kas just päris käsitöö ja on-ear`id isiklikult üldse ei istu ning ka disain ei avalda muljet... AGA... see et, iga klapipaar on unikaalse välimusega, sest tehakse taastatud puidust ja iga paari ostmine läheb ka heategevusse: ühele vaegkuuljale kingitakse kuulmiseks vajalik aparatuur - SUPER!
Juba selle tõttu peaks kunagi ühe paari muretsema nt. kingituseks
| flameas kirjutas: |
Sai tellitud Marshall Monitorid, 130 euroga, mis tundus väga hea pakkumine olevat. Varsti saab muljetada ka  |
Näevad väga kenad välja ja koostekvaliteet tundub ka väga hea Heli suhtes oleks pigem uurinud kasutatud DT-770 Pro 32Ohm pakkumisi või siis Thomannist B-stock võtnud: http://www.thomann.de/gb/beyerdynamic_dt_770_pro_32_ohm_b_stock.htm
83 |
Naljatilk
flameas
30.03.2014 04:26:07
Marshalli monitorid on head - ehituskvaliteet on fantastiline, stiil on aegumatu ja heli on väga hea. Tegemist on tippklassi tootega, eriti arvestades hinda - 130 eurot 01.ee-st - vähemalt tol hetkel kui tellisin. Kui dr.Dre klappidega näed välja nagu suvaline nolk, kes kuulab mingit ilget ila ja räppi-cräppi, siis Marshallidega näed välja nagu vana-kooli vend, kelle välimusest karjub lausta "AC/DC". Need klapid on lahedad, tõsiselt.
81 |
iFlop
30.03.2014 17:46:50
| Paar päeva olen nüüd proovinud Superlux HD-681 EVO klappe. Üldiselt olen rahul, aga minu arvates on bassi ikka natuke liiga palju..
| Kommentaarid: 67 loe/lisa |
66 |
martin366
30.03.2014 20:05:48
| iFlop kirjutas: |
| Paar päeva olen nüüd proovinud Superlux HD-681 EVO klappe. Üldiselt olen rahul, aga minu arvates on bassi ikka natuke liiga palju.. |
Aga keera maha
172 |
iFlop
66 |
CoiL
31.03.2014 08:06:31
| CoiL kirjutas: |
Filter components:
Resistors:
capacitor 1uF:
or:
or:
or:
or:
R1=R2=56 Ohm
R3=R4=39 Ohm
R1=R2=56 Ohm
R3=R4=47 Ohm
R1=R2=39 Ohm
R3=R4=56 Ohm
R1=R2=39 Ohm
R3=R4=82 Ohm
Capacitors:
series
-7.5dB @ 6.3kHz):
r1 = r3 = 47 Ohm
L1 = L3 = 470uH
r1 = r2 = 47 Ohm
Mk3 filter pidavat bassi vähendama võrreldes mk2 filtriga. Peale mk2 filtrit on minu arvates bassi just parajalt, siis kui vaja ülimadalaid kuulda on olemas mitte ei tõmba "hinge kinni". Mk3 filter on suunitletud rohkem neutraalse "audiofiili" heli suunas. Kes soovib siiski mõnusat madalat bassi alles jätta, sellele soovitaks siiski mk2 filtrit.
viimati muutis CoiL 31.03.2014 14:35:00, muudetud 2 korda |
83 |
olavsu1
külaline
31.03.2014 10:03:17
CoiL'i jutu täienduseks niipalju, et selle filtri peaks igaüks ise arvutama oma isikliku audiogrammi järgi.
Paar Stirlitz'i pilti tuntud raamatust, jutt on siis "b" skeemist. ahel C3, R3 jäta välja.
Ta ei ole midagi muud, kui amplituudikorrektor. Tema kisub allapoole selle sagedusevahemiku, mille jaoks ta on arvutatud.
soovitud sagedusvahemik vaata oma audogrammi pealt.
CoiL
31.03.2014 12:44:03
olavsu1, mida sa mõtled isikliku audiogrammi all? HD-681 suhtes on Fran`il mõõtmised tehtud ja need filtri komponentide väärtused paika määratud.
Loomulikult saab selle filtriga "mängida" ja vastavalt oma kõrva järgi tuunida aga minu kõrva jaoks on Fran`i filtrid täiesti sobilikud (nagu ka paljude teiste jaoks). HD-662F`i jaoks pidin ise erinevaid väärtusi proovima aga leidsin enda jaoks nö. sweet-spot`i. Mingeid arvutusi ei teinud, lihtsalt nihutasin kõrgsageduste peak-point`i ja proovisin erinevaid takisteid.
83 |
olavsu1
külaline
31.03.2014 13:25:50
| CoiL, mõtlen seda audiomeetrilist uuringut, mis näitab, mida su kõrvad tegelikult kuulevad.
flake
31.03.2014 14:47:38
olen nüüd veidi üle nädala oma Bose QuietComfort15 kasutanud. Superluks asjad. Paned pähe, lülitad sisse ja oled kenasti oma maailmas isegi kui muusikat ei kuula vmt. Lisaks kõrva peal väga mugavad. 90% ajast mis mul kulus USA läänerannikult Tallinna lendamiseks olid peas ning kõrv ei väsinud ära
60 |
CoiL
31.03.2014 16:06:56
Mina isiklikult kuulen ja kuulan seda, mida ma kuulen ja kui minu aju ning kuulmismeel rahuldub sellega ning millestki puudust ei tunne, siis enamat ei olegi vaja. Mk2 filter on HD-681 klappide puhul minu jaoks nö. "õige". Kui hakata personaalseid audiomeetrilisi uuringuid tegema, siis võib vist igasugu high-end klapid ära unustada, sest ka neid tuleks vastavalt personaalsele kuulmisele ja uuringutele tuginedes korrigeerima hakata, olgu siis riistvaralise filtri või EQ kaudu. EQ-ga on muidugi lihtsam ja erinevalt riistvaralisest filtrist on ka lihtsam asju juurde keerata. Samas on muidugi klappide helipilt, instrumentide eraldatus, ruumilisus jne. erinev ja seda EQ ega riistvaralise filtriga ei korrigeeri vastavalt maitsele. See on ka põhjuseks miks HD-681 mk2 pealt edasi Fidelio X1-le liigun. Muidugi on jällegi olemas igasugu tarkvaralised efektid aga minu jaoks on need senini võltsi mulje jätnud.
Mnjah... pikk jutt, s*tt jutt. Minu subjektiivne arvamus on selline, et kui see, mida kuuled on sinu jaoks hea ja ilma puudusteta, siis muud ei olegi vaja. Ja kui on mingisugune puudus, siis saab seda ka lihtsalt kuulmismeele järgi korrigeerida, olgu siis riistvaralise filtri või EQ-ga. Ei ole vaja igasugu uuringuid ja graafikuid hakata taga ajama.
Lõpetuseks küsimus sulle olavsu1 - kas oled teinud enda kõrvadele audiomeetrilise uuringu ja vastavalt sellele riistvaralise filtri või EQ-ga kõrvaklappe/kõlareid korrigeerinud?
83 |
jaank
31.03.2014 16:43:34
Ma enne ka vist öelnud seda, et kui iga kuulaja peaks enda kõrvadele tegema audiomeetrilise uuringu siis võiks teha seda ka muusika autorid ja muud vahemehed ning vastavalt korrigeerida.
Ja seda nad ei ole teinud päris kindlasti. Järgmine samm oleks vastava muusiku analüüsi mappimine enda helitehnikale, et siis eriti tõetruud esitust saada...
57 |
olavsu1
külaline
31.03.2014 17:47:00
CoiL, ma teen audiomeetria uuringut iga 3 aasta järelt. See mul kohustuslik kompenseeriv kuuldeaparaat peaks ka olema, aga just need maksavad jõhkralt, 447€ ja rohkem.
helitehnika paikasättimine ei taha õnnestuda. Need ekvalaiserid mis mul kasutada, ei ole kuigi tasemel või on meditsiini tehnikal ja laiatarbe audiotehnikal dB näitajatesse erinev suhtumine. Dimensionid on nii erinevad.
Näiteks enda audiogrammi järgi peksin tõstma 2kHz sagedust ca 50 dB jagu, ekvalaiseril on +12 dB maksimum . Jagasin audiomeetri tulemusi kümnega, mahtusid ekvalaiseri peale ära. Tundub, et natuke läks paremaks aga päris rahule ikka ei jää.
mp3 mängija peal ei sa midagi sättida. on nagu on ja peab leppima sellega, mis stuudios paika väänati.
Tolka15
31.03.2014 21:18:42
| Oskab keegi soovitada in-ear kõrvaklappe, mis oleksid eelkõige vastupidavad? Kõrget helikvaliteeti taga ei ajaks, eesmärk oleks leida kõrvaklapid, mis ei läheks rikki nt pistiku juurest painutamise tõttu. Tänud!
| Kommentaarid: 21 loe/lisa |
21 |
martin366
31.03.2014 22:11:16
| Tolka15 kirjutas: |
| Oskab keegi soovitada in-ear kõrvaklappe, mis oleksid eelkõige vastupidavad? Kõrget helikvaliteeti taga ei ajaks, eesmärk oleks leida kõrvaklapid, mis ei läheks rikki nt pistiku juurest painutamise tõttu. Tänud! |
Jays klapid on suht vastupidavad.. mul on vist Jays Three, teen tööd ja trenni nendega, pole midagi juhtunud
172 |
1dumbpcuser
97 |
olavsu1
külaline
cubedude
02.04.2014 12:01:16
| Oskab keegi üelda mis on Xiaomi Piston v2 ja Xiaomi Plunger Music Partner vahe peale selle et piston on 24$ ja plunger 30$? Kumb mõistlikum?
87 |
1dumbpcuser
97 |
olavsu1
külaline
