jaank
10.02.2014 22:18:37
| Mul ka ainult padjad ära väsinud mingi 6 aasta jooksul. Raske on kurta.
| Kommentaarid: 63 loe/lisa |
57 |
10.02.2014 22:26:06
lopes39, steelseries siberia v2
182 |
lopes39
11.02.2014 01:18:21
| rmc, Ei mitte mingil juhul. Vaatasin neid ja ei meeldi. Hind on ka kirves. Kuskil isegi vist oli võrdlus creative tactic3d sigma versus steelseries siberia ja ei pidand palju parem olema. Samas kui ma kokku maksis 50 euri oma klappide eest ja need pidid ühed kergemad klapid olema, siis kindlasti need ja veel üle kahe korra odavamalt.
| Kommentaarid: 10 loe/lisa |
CoiL
17.02.2014 00:02:59
Jäin vist "natuke" hiljaks vastamisega Aga parem hilja kui mitte kunagi. Rockgrotto foorumist ja mujalt kokku kogutud inf, äkki tuleb kellelegi veel kasuks:
___________________________________________________________________________
---<([|||/// HD-681 Filter mod \\\|||])>---
Filter components:
Resistors:
use wirewound, Metal film, carbon whatever you like or feel will be better.
Not of any importance really in this application as long as the wattage is
ABOVE 0.25W (which most resistors are)
capacitor 1uF:
Multicomp MCRR50105Z5UM00050 = Farnell order code 121-6447
or:
Multicomp MCRR50105X7RK00050 = Farnell order code 121-6443 (used by me)
or:
AVX SR305C105KTR = Farnell order code 110-0398
or:
AVX SA305E10MARTB = Farnell order code 110-0420
Inductor (choke coil):
EPCOS B82144A2474J = Farnell order code 517-070 (used by me)
or:
EPCOS B82145A1474J000 = Farnell order code 164-4331
or any other small coil, inductor, choke with 470uH and a resistance of
equal or lower than 2.5 Ohms.
Only the resistor values are to be altered.
You can vary the resistor value
of R3 and R4 (now 39 Ohms) between 27 (to little damping of high freq) to
120 Ohms (a bit too much damping of high freq.). You can put a 100 Ohms
potentiometer in it's place and fiddle with the settings for instance.
If the resistor value of R3/R4 is between 25 and 50 Ohms use 56 Ohm resistors for R1/R2
If the resistor value of R3/R4 is between 50 and 75 Ohms use 47 Ohm resistors for R1/R2
If the resistor value of R3/R4 is between 75 and 150 Ohms use 39 Ohm resistors for R1/R2
The capacitor and inductor need not to be changed as these are the frequency
determining parts of the filter.
Resistor R3/R4 determines the Q factor of the
filter AND amount (dB) of filtering at the filter frequency.
The center frequency is around 7.2kHz.
L1,C1,R1,L2,C2,R2 are for compensating
the impedance peak which is caused by the filter network L3,L4,R3,R4,C3,C4.
You can leave L1,C1,R1,L2,C2,R2 out IF you want if you are ONLY going
to use these cans on a low Z output amp (around 10 Ohms).
In all other circumstances (output impedance between say .. 20 Ohms and 600
Ohms or unknown) this part (L1,C1,R1,L2,C2,R2) of the filter network is ESSENTIAL
in obtaining the right amount of damping.
maximum highs, sibilance gone HD681 character remains (first filter):
R1=R2=56 Ohm
R3=R4=39 Ohm
slightly less treble but still close to original HD681 character:
R1=R2=56 Ohm
R3=R4=47 Ohm
less treble but still brighter then Sennheiser signature in general (second filter):
R1=R2=39 Ohm
R3=R4=56 Ohm
About equal to Sennheiser signature in general bass more prominent:
R1=R2=39 Ohm
R3=R4=82 Ohm
Capacitors:
Some say polyprop sounds better (in this picture).
Some will say mica or
silver-mica is better, yet not available in these values.
Multitlayer ceramics
(X7R is preferred over Z5U) are small and can be used inside the headphone without
taking up too much space. There are also smaller sized polypropyline avaiable.
The voltage (which determines the size) is not of importance.
For external filters
the sky is the limit (money wise) and can be constructed to your audio religion.
Q: For the orginal HD681 filter from the very first page, say I want to attenuate
the ~7.25 kHz frequency 3db rather than 6db? I replace the resistor in parallel
part of the filter with one of lower value correct? What value would I use?
A: Parallel filter (the one in series with the driver) between 27 and 33 Ohm
series
filter (on the input of the filter) R = 68 Ohm
HD-662 mod (-3dB bandwidth 3.4 kHz - 11 kHz,
-7.5dB @ 6.3kHz):
r1 = r3 = 47 Ohm
c1 = C3 = 1.33nF (1uF // 330nF)
L1 = L3 = 470uH
____________________________________________________________________________
HD-662F filter (CoiL):
r1 = r2 = 47 Ohm
r3 = r4 = 51 (56 Ohm if cymbals and guitars feel too bright)
C1 = C2 = C3 = C4 = 1.33nF (1uF // 330nF)
L1 = L2 = L3 = L4 = 470uH |
Vahelduseks jälle Aune T1 juttu. Jah tean, et mõnel tulevad siin ihukarvad püsti kui seda kuuleb Sattusin hiljuti lampide jahtimisega kogemata sellise kuulasoone otsa (suure tõenäosusega on need samad aga teise markeeringuga): http://www.tubemuseum.org/ProductDetails.asp?ProductCode=SH-E88CC+PVT.STOCK
Sain neid 5tk, kasutamata, 32€ eest, siitsamast kodumailt. Kes asjaga kursis, siis teab palju ainuüksi 1 selline lamp maksab tegelikult
Ja mis seal ikka heli kohta kosta kui et tõesti - püha graal(id)! Nagu head-fi pedekate maalilmas öeldaks - nö. "holograafilise/3D" heliga!
Mul vahepeal igasugu eri tüüpi lampe miski ~70 kandis kogunenud ja need on parimad. Mõned üksikud on, mis saavad üsna lähedale helipildis ja kõlavad samuti "holograafiliselt" aga siiski mõnede väikeste puudustega.
Lambid lampideks, mis veel vahepeal tehtud - hunnik kondekaid välja vahetatud ELNA SilmicII vastu. Kui muidu olin seda usku, et "haha, ei muuda need kondekad muhvigi", siis nüüd söön sõnu - hämmastavalt positiivne muutus helis, kesksagedused on ülimalt "elavad" ja üleüldse terve heli muutus peale seda väga nö. "tõetruuks". Need kondekad + Siemens E88CC lamp = korralik kõrva-orgasm. Näiteks Mari Pokineni "Maa saab taevani" (FLAC) kõlab nii nagu istuks kontserti saalis, iga väikseimgi detail - klaveri haamrite "mütsud", pedaalide liikumine, kitarri/käe liikumine ja klõbinad, iga laulja hingetõmme ja neelatus jne. - kõik on selgesti kuulda. Vahepeal hakkab lausa "häirima" Eriti muljetavaldav on vokaali ehedus - hääle intonatsioon ja "soojus". Pillide paiknemine ruumis on selgesti eristatav jne. ESI Juli@ helikaardilt ei kuulnud ma kunagi sellist helipilti ja "tõetruudust". Peab vist vaikselt kallimate klappide poole ka vaatama hakkama, sest tundub, et moditud HD-681 klapid ei jõua sellele süsteemile järgi, helipildi sügavuses tekib nö. "sein ette".
| ihvike kirjutas: |
Selleks, et tavaliste klappidega n-ö ruumilist heli kuulata, peab olema binaural salvestus. Neid otsi aga tikutulega taga, kui pole juttu neist äraleierdatud demoklippidest. Heal juhul Fritziga (Neumann KU-100) või halvemal juhul jumal teab millega lindistatud binaural ei jäta ausaltöeldes vähemalt muusika puhul küll mingit erilist muljet. Tavaline stereo on väga sarnane.
Ütleks omast kogemusest, et näiteks selle salvestuse puhul: http://www.hdtracks.com/explorations-in-space-and-time-176-24-binaural
tuleb küll vahe tavalise stereoga esile, ei ole küll suur vahe aga minu jaoks küll selgesti eristatav ja tõetruum. Kas sellised salvestused tasuvad ära oma hinda
ja ruumikulu on muidugi kaheldava väärtusega, eriti siis kui juba olemas selline süsteem, mis väheke tõetruuma helipildiga.
Lisaks mainiks ära, et kõik see eelnev on minu subjektiivne arvamus ja reaalne vahetu kogemus ning ei viitsi siin vaidlema kukkuda. Need kes kuulavad "teooriaga" mitte kõrvadega, võiks lihtsalt seda postitust ignoreerida
Et rohkem teemasse oleks, siis ootaks soovitusi klappide suhtes millel nö. sügav helipilt ilma, et kaotaks laiuses. Hind võiks sinna max 200€ piirimaile jääda.
PS, kellel huvi Aune T1-te oma klappidega kuulama tulla, siis võtku ühendust ja lepib miskit kokku
viimati muutis CoiL 17.02.2014 00:30:29, muudetud 1 kord |
| Kommentaarid: 95 loe/lisa |
83 |
jaank
17.02.2014 00:09:29
| Mul tulevad ihukarvad püsti kui mul tuleb jälle tahtmine Aune T1te osta lol.
57 |
bjaka
17.02.2014 20:58:09
Sai süda rindu võetud ja Grado GR10-d hangitud. Võrreldes Vsonic GR07 on heli õhulisem. Sobib eriti klassikalise muusika ning jazzu kuulamiseks. Samas meeldib Vsonic rohkem popi ja rocki puhul. Samas JVC HA-FXT90 on ületamatu David Bowie Ziggy Stardusti remasteri puhul (ei oleks uskunud, et seal midagi uut veel avastan aga võta näpust)
| Kommentaarid: 86 loe/lisa |
81 |
RaPTiLE
19.02.2014 15:33:24
Millised ülepea klapid võtta 40€ eest.
Läheksid PS3 järgi ja läpakast filmide vaatamiseks.
| Kommentaarid: 60 loe/lisa |
55 |
pots4t4j4
19.02.2014 19:45:04
| misasjad on ülepea klapid?
401 |
cubedude
19.02.2014 19:51:49
| pots4t4j4 kirjutas: |
| misasjad on ülepea klapid? |
Ma usun et juttu on 4. ehk over-ear
| Kommentaarid: 90 loe/lisa |
87 |
19.02.2014 19:53:44
| cubedude kirjutas: |
Ma usun et juttu on 4. ehk over-ear |
igaks juhuks mainin, äkki tekib tõlke viga, õige vastus on nr4
edit:
krt, ei näinud, et sul see kirjas
cubedude
19.02.2014 19:59:18
| RaPTiLE kirjutas: |
Läheksid PS3 järgi ja läpakast filmide vaatamiseks. |
endal sama mõte et ps3, telefoni ja läpaka järgi tahaks aga ehk teab keegi blutooth versiooni mille poole oleks mõttekas vaadata ja ka mikrofoniga?
87 |
beastbeats
19.02.2014 21:41:51
| RaPTiLE kirjutas: |
https://foorum.hinnavaatlus.ee/viewtopic.php?t=601158
M: Uus/pakendis Fjern Fjork Titanium Forked Spoon - 10€ |
| Kommentaarid: 366 loe/lisa |
282 |
Ertai
22.02.2014 22:19:38
Oskate soovitada midagi spordi tegemiseks ? (suusatamine, jooksmine jms)
Hinnaklass 2-20€
| Kommentaarid: 51 loe/lisa |
47 |
22.02.2014 22:48:53
| Ertai kirjutas: |
Hinnaklass 2-20€  |
suvalised?!
Driftmoon
25.02.2014 11:26:10
| Ertai kirjutas: |
Hinnaklass 2-20€  |
ise nendega jooksmas käinud:
http://www.soundshop.ee/?id=1575 Sennheiser CX 150
püsivad kõrvas hästi, ära ei kuku, kvaliteet kah ok
| Kommentaarid: 36 loe/lisa |
libe
kvaliteetne mees
25.02.2014 20:10:38
| Konks kirjutas: |
| Ertai kirjutas: |
Hinnaklass 2-20€  |
püsivad kõrvas hästi, ära ei kuku, kvaliteet kah ok  |
sai kunagi 525.- eeku eest cx300 ostetud ja nood olid tollal küll võrdlemisi head klapid, aga ikkagi pasad
20€ eest ei saa head klappi
tuleb osta kõige ilusam ja mugavam ning parima garantiiga
garantii osas on koss hea
_________________ ☠ |
| Kommentaarid: 82 loe/lisa |
CoiL
28.02.2014 00:58:09
Keegi teab kus Tartus saaks Sennheiser HD-598 klappe proovida? Või on keegi nii lahke ja ulatab abikäe?
Samuti huvitaks ka Sennheiser HD-650, AKG Q701 või K702 proovimine.
83 |
SunBear
28.02.2014 20:30:00
| tuleb osta kõige ilusam ja mugavam ning parima garantiiga |
Tuleb veel ära märkida, et suurem osa poodidest ei anna sulle blisterpakendis klappe proovida. Ostad põrsa kotis kui kodutöö on tegemata.
Sennide laituseks tuleks märkida, et higi toimel läheb klapi traat jäigaks nagu spagett. Mingi aeg lendavad kergema köhatuse peale kõrvadest välja.
Kiita võin kallimaid Denoneid ja HTC föönidega kaasa tulevaid Beats in-ear klappe.
| Kommentaarid: 12 loe/lisa |
10 |
priitr
05.03.2014 22:39:45
Kui isu paremate-kallimate klappide järele, aga põrsast kotis ei taha osta, siis minu soovitus on vähemalt Tallinna inimestele kasutajaga Vares ühendust võtta ja tema poes kuulamas käia - tal seal ValiHelis igast' patsahkam häid ja paremaid klappe kohapeal proovimiseks olemas. Hinnaklassis vist nii 80-2000€.
Et see lausreklaamina ei kõlaks , siis just ostsin lapsele sealt Denoni AH-D340. Meeldisid värskele omanikule rohkem, kui proovitud Grado SR-80 või Audio-Technica ATH-M50.
_________________ Tšudes ne bõvajet. |
| Kommentaarid: 27 loe/lisa |
CoiL
06.03.2014 21:49:57
| Lastele (veel rikkumata kuulmine) ongi ilmselt Grado / M50 / HD-681 liiast... justnimelt kõrgsageduste poolest.
83 |
Froggy
12.03.2014 16:47:08
| Froggy kirjutas: |
Mu EVO-d puhta pooleks. Ükshetk pähe pannes läks katki lihtsalt :/ Oktoobris ostetud alles.
Täna sain tasuta uued Ei teagi, kas garantii korras või on summa tehasele nii olematu, et jagatakse niisama
| Kommentaarid: 29 loe/lisa |
flake
19.03.2014 06:37:36
Ostsin Bose Quiet Comfort 15ned. Esmamulje on WOW
_________________ ..||.. |
60 |
Markos
22.03.2014 00:30:25
| Kui võtta nt Denon AH-D600 siis mis sorti võimu sellega paaris soetada? |
Need klapid ei vaja võimu, head allikat küll. Takistus on neil 24 oomi ja nad on tõsiselt kergesti draivitavad. Endal on Fiio E17 Alpen + E09k combo toiteks ja peab ütlema, et viimane on liiast, piisaks ainult Alpenist ka, ning seegi on veerandi peal ainult. Piirasin setupis isegi max nivoo ära, igaks juhuks, et õnnetust ei juhtuks. Muidu klapp ise on superluks ja väärt iga eurot.
Samuti huvitaks ka Sennheiser HD-650, AKG Q701 või K702 proovimine. |
Kas sa neid esimesi tahad heli või välimuse poolest ? Kui esimene, siis parem jäta nad rahule ja võta 650 (kui just avatud klappi tahad). Ma kiibitsesin ka pikka aega neid ja kui näpud taha sain, pidin kahjuks pettuma. Mugavad on seda küll.
| Kommentaarid: 14 loe/lisa |
12 |
CoiL
83 |
bjaka
23.03.2014 12:23:45
| Ja kuidas tunduvad heliliselt?
81 |
