poroloon
17.08.2013 13:45:02
| Sults kirjutas: |
| Diagonal fisheye tähendabki, et 180 kraadi on diagonaalil. |
Seda ma nüüdseks arvasin tegelikult ise ka, sest nurgast nurka tundub, et tuleb 180 kraadi ära, aga vasakult paremale mitte.
soodent
17.08.2013 18:02:44
| D3000 protsessib pilte terve igaviku, täiesti mõttetu ost praegu.
| Kommentaarid: 822 loe/lisa |
19 :: |
6 :: |
564 |
pacho
17.08.2013 23:04:41
| Kui Active D-Lighting ära keelata siis pole häda midagi.
| Kommentaarid: 25 loe/lisa |
25 |
rex
17.08.2013 23:09:55
| D3000/D5000 ja D3100/D5100 vahelt jookseb väga arvestatav põlvkondadevaheline piir. D40(x)/D60/D3000 omavaheline erinevus näiteks ei ole nii suur.
228 |
pacho
17.08.2013 23:17:42
D5000 on juba uuema põlvkonna kaamera. Põhimõtteliselt paljaks kistud D90.
D3000 on CCD sensoriga, D200 ja D80-ga samast põlvkonnast.
25 |
soodent
20.08.2013 01:33:56
Ken Rockwelli hinnang D3000 kaamerale lisaks D-lighting jamale
High ISOs
High ISOs are poor, compared to other DSLRs. (High ISOs are great compared to pocket cameras.)
The D40 is twice as good, meaning that the D40 looks as good at ISO 1,600 as the D3000 looks at ISO 800.
The fastest speed at which the D3000 gives decent results is ISO 800. At ISO 1,600, normal people are going to notice the noise and wonder why the photo is so grainy.
AUTO ISO climbs up to ISO 1,600. I use Auto ISO, and I'd suggest considering lowering the maximum value to ISO 800 (MENU > CAMERA > ISO sensitivity settings > Max. sensitivity > 800.)
No Correction of Lateral Color Fringes
With other Nikons, colored fringes around lines in corners of photos are never more seen. Canon still has this problem, but not Nikon. With every other Nikon, everything always looks perfect. There are no color fringes.
The D3000 still has this problem, if you care. There is no automatic correction in the D3000, so some lenses will show this slight artifact.
19 :: |
6 :: |
564 |
M8T0
01.09.2013 00:29:13
Tere
Plaan endale D3200 võtta kuid ei suuda valida kolme erineva setupi vahel. Varsti lolliks ennast juba guugeldanud.
1) lihtsalt 18-55 objektiiviga mis mul praegu vanalgi aparaadil on. miinus on see, et suhteliselt tihti tahaks rohkem zoomida aga ei saa
2) 18-105 millega saaks siis natukene zoomimis "viga" parandada aga vähemalt guuglist hüppab välja igaltpoolt , et 18-35 vahel on pildi kvaliteet ja teravus kõvasti kehvemad kui 18-55 oma ( ?? )
3) 18-55 + 55-200 zoomi saab juurde aga tüütu oleks kahte kaasas kanda ja vahetada koguaeg
Küsimus siin siiski ongi selles, et kas selle 18-105 negatiivne jutt tõesti vastab tõele? Tihti tahaks näiteks öösiti taevast (virmalisi?) jms pildistada kuid niigi raskes olustikus kehvem ja eba-terav pildi-jutt hirmutab.
| Kommentaarid: 87 loe/lisa |
Sults
01.09.2013 00:49:18
Sulle sobiks vast mõni supersuumiga seebikas, nagu nt see. Sellel ei ole torude vahetamist ja saad väiksema raha eest rohkem suumi.
Peegelkaamera üks olulisemaid põhimõtteid ongi selles, et saab objektiive vahetada.
| Kommentaarid: 38 loe/lisa |
enigma
rex
01.09.2013 10:33:48
Virmaliste jaoks keerad mingi odava MF fiks lainurga ette. Ega nad naljalt fookusest välja lippa. Statiivi pead ka niikuinii eelarvesse mahutama, kui jutt mingitest öistest lisavalguseta piltidest käima hakkab. Pimeda superzoomiga puusalt ei tee neis oludes naljalt miskit.
Milline su vana aparaat on?
228 |
M8T0
01.09.2013 12:26:29
| D3000 ja 18-55 ning statiiv olemas.
sixkiller
01.09.2013 13:05:17
| Endal seisab kah ees valik, kas D5100 või D3200. Anttilas D3200 399.- ja D5100 429.- hinnaga
| Kommentaarid: 59 loe/lisa |
54 |
Sults
01.09.2013 13:49:48
| Minu soovitatud supersuum on laias otsas avaga 2.8. See sobib virmaliste pildistamiseks küll. Aga Marto. põhimure oli siiski soov saada rohkem suumi ilma torusid vahetamata. Soovitada lainurka inimesele, kes soovib rohkem suumi, ei ole vast kuigi asjakohane.
rex
01.09.2013 13:57:45
| Sults, ma pidasin pimeda superzoomi all tegelikult rohkem silmas kaamera ette keeratavat toru, mitte sinu soovitatud kaamerat.
228 |
M8T0
01.09.2013 14:55:46
Ah võtsin 18-105 + d3200 ära. Zoomi on piisavalt ja samades tingimustes/settingutega on pildi vahe ikka päris öö ja päev d3000ga võrreldes:)
Mina olen rahul.
Keda huvitab siis 150€'ga on müügis d3000 + 18-55 koos kõigega mis kaasa tuli (karp, docid jnejnejne).
Go Kane!
02.09.2013 23:33:46
| Marto. kirjutas: |
Keda huvitab siis 150€'ga on müügis d3000 + 18-55 koos kõigega mis kaasa tuli (karp, docid jnejnejne). |
Ja läinud ta ongi Kahjuks mitte mulle, olin unine, kuigi hind oli
Millega kõige lihtsam Nikoni kaamera läbisõitu kontrollida?
_________________ Vajad midagi Würthist , küsi julgelt 😉 https://eshop.wuerth.ee/et/EE/EUR/
taavi.jahu@wuerth.ee +37258309618 |
| Kommentaarid: 1842 loe/lisa |
1345 |
Sults
03.09.2013 00:20:47
| Nikoni puhul loed iga pildi exifist, mitu säritust tehtud on.
Kuivati
| Kommentaarid: 4 loe/lisa |
Go Kane!
1345 |
1dumbpcuser
04.09.2013 10:46:20
| sixkiller kirjutas: |
| Endal seisab kah ees valik, kas D5100 või D3200. Anttilas D3200 399.- ja D5100 429.- hinnaga |
Anttilas on d3200 objektiiviks II, mitte tiba uuem VR.
Kuna ise kah plaanin d3200 (või midagi analoogset) muretseda, uuriksingi, kuidas on II vs VR objede vahe? Kas tasub viis kümpi VR obje eest juurde maksta?
Oleks siis mulle esimene (tõenäoliselt pikaks ajaks ka viimane) dslr, tulevikus muretseks vast mõne telesuumi (55-200 või 55-300 vms) juurde ja ehk ka mõne kiire 50mm
_________________ M: MSI B660M MORTAR
M: Dell RTX 2060
O: AM5 ITX emaplaat |
97 |
rex
04.09.2013 11:01:44
Mis mõttes kuidas on vahe? Üks stabiliseerib, teine mitte.
Kropikale oleks valge fixina 35mm mõistlikum. 50mm on selle ees juba suht portreeobje.
228 |
1dumbpcuser
04.09.2013 12:03:51
| rex kirjutas: |
| Mis mõttes kuidas on vahe? Üks stabiliseerib, teine mitte. |
Seda tean isegi, aga erinevus inimesele, kes pole dslr-ga ega muu sellisega eriti kokku puutunud?
Et kolmjalata pildistades tulevad pildid nagu Alzheimeri tõve all kannataval inimesel? Või on see suht tühine vahe?
Neostore's VR kit (punase kerega) saadaval 425€ eest, ise asi kas asi ka reaalselt saadaval on või on jälle mingi apsakas. Siia juurde veel küsimus- kui vastupidavad värvitud kered on (kriimustused jms)?
M: Dell RTX 2060
97 |
rex
04.09.2013 12:14:55
| Oleneb valgusest. Kui suudad säri enamvähem fookuskaugusega pöördvõrdelisena hoida, pole probleemi, sellest allpool võiks juba stabikast kasu olla. Või statiivist. Liikuvat objekti stabikas niikuinii seisma ei ehmata. Alternatiiv on hoopis valgusjõulisem obje valida. Mina isiklikult stabikast erilist puudust ei tunne. Eriti väikese fookuskauguse korral. Vajadusel läheb kas lisatugi või kõrgem ISO.
228 |
BanTIIT
21.09.2013 03:14:49
Tere!
Kõik D5200 omanikud võiksid nüüd väikest abi pakkuda.
Oleks soov see kaamera soetada aga oleks enne vaja teada kas video filmimise ajal on võimalik kaamera LCD peal olev pilt saata üle hdmi välisele ekraanile?
Ühesõnaga SAMAL AJAL kui filmin, et näeksin filmitavat otse teise ekraani pealt.
Ette tänades
| Kommentaarid: 8 loe/lisa |
Sults
21.09.2013 04:12:25
| Saab küll. HDMI kaudu peaks saama kätte ka pakkimata video, juhul, kui kaamera enda pakkimise kvaliteet ei rahulda.
MMatsu
17.10.2013 00:23:03
Tervitus! Olen nüüdseks oma 4-5 aastat kasutanud ühte kere, milleks on olnud D40. Nüüd aga tahaks liikuda millegi uuema poole. Miks? Peamine põhjus on see, et on tekkinud vajadus ka videoklippide tegemisele. Samuti jääb kohati jalgu D40 aeglus. Seega milliseid keresi soovitate Teie? Hinnaklass võiks olla mitte väga kallis ning pigem vaataks kasutatud tehnika poole.
Samas palju kasutatud ning suts üle 14k läbisõiduga D40 kere eest üldse müügis küsida? Ega see vist suurt midagi maksa. Aga kere ise on korralik, töötab nii nagu peab.
erko
17.10.2013 00:51:21
| MMatsu kirjutas: |
Samas palju kasutatud ning suts üle 14k läbisõiduga D40 kere eest üldse müügis küsida? Ega see vist suurt midagi maksa. Aga kere ise on korralik, töötab nii nagu peab. |
Panasonic GX7 ja sulle sobiv valik objektiive. Soovitavalt stabikaga objektiivid, keresisene stabikas videorezhiimis GX7-l ei rakendu.
| Kommentaarid: 26 loe/lisa |
26 |
jaank
17.10.2013 01:41:26
| Nikoni teemas pakkuda Nikoni peegli asemele Panasonicu peeglita asja tundub suht radikaalne samm.
| Kommentaarid: 63 loe/lisa |
57 |
korsten
17.10.2013 01:48:03
Milleks punnitada... Kui Nikonil midagi asjalikku mõistliku hinnaga selles valdkonnas pakkuda pole siis alternatiivid (vähemalt arutelu nende üle) ei tohiks keelatud olla? Nikoni teemasse postitas uus kasutaja ilmselt teadmatusest , et HV-s on ka ostuabi teema.
_________________ Ma ei kuuluta jumalikku tõde vaid avaldan oma isiklikku subjektiivset arvamust.
God Hates Us All |
| Kommentaarid: 62 loe/lisa |
58 |
Sults
17.10.2013 01:55:22
| Mis seal D40 puhul aeglaseks jääb? Kaamera käivitumise kiirus? AF kiirus? Sarivõtte kiirus?
erko
17.10.2013 08:30:32
| jaank kirjutas: |
| Nikoni teemas pakkuda Nikoni peegli asemele Panasonicu peeglita asja tundub suht radikaalne samm. |
Kui inimene räägib vajadusest video teha siis pole Nikoni leerist midagi normaalset pakkuda. Kõik teised on suhteliselt paremad.
26 |
Sults
Kruvi
17.10.2013 10:26:22
| MMatsu kirjutas: |
Ole hea anna ka palun teada millised objektiivid sul soetatud on.
Samuti täpsusta kas soovid videoklippe teha nö. hobi korras (youtube, pere, sõbrad, pealtvaataja võistlusel) või rohkem professionaalsemalt (töö, tõsine hobi, film jne)
Selle järgi vast tekib veits parem ette kujutus kas sulle piisab Nikoni filmiomadustest või tasuks hakata teiste poole vaatama.
Nikonite peamine probleem on see, et kõik vähegi mõistliku hinnaga kaamerad ei lase apertuuri filmimise käigus muuta. (pikk seletus)
Samuti on liveview siiani suht aeglane.
Video kvaliteedi osas samas probleemi ei näe ning kui vahepeal pilte ka soovid ikka teha siis pole sel Nikoni videol häda midagi.
Too Panasonic GX7 paistab muidu oäris hea riist ainult, et HV otsingust ei leidnud teda üles. Tea kuida neil objede valikuga on? (kipub olema sedasi et kui CaNikoni leeri ei kuulu on valikuid kohe hulga vähem)
| Kommentaarid: 16 loe/lisa |
16 |
Sults
17.10.2013 10:57:41
Ei vasta tõele, et Nikoni odavama otsa kaameratel ei saa video võtte ajal ava muuta. See sõltub ikka objektiivist.
Panasonic GX7 on rohkem kui 2x kallim kui Nikon D3200. Soovitada GX7 inimesele, kes rõhutab oma hinnatundlikkust, on üsna veider. Eriti, kui Nikoni videole pole sisulisi etteheiteid, mis rohkem kui kahekordset hinnavahet kuidagi õigustaksid.
1dumbpcuser
97 |
korsten
17.10.2013 11:56:06
Hübriidide (ja ka kompaktide) ülemise otsa hinnad on haiged. Ma ei saa aru mille eest seal sellist raha küsitakse...
God Hates Us All |
58 |
MMatsu
17.10.2013 13:00:13
| Kruvi kirjutas: |
| MMatsu kirjutas: |
Too Panasonic GX7 paistab muidu oäris hea riist ainult, et HV otsingust ei leidnud teda üles. Tea kuida neil objede valikuga on? (kipub olema sedasi et kui CaNikoni leeri ei kuulu on valikuid kohe hulga vähem) |
Tere taas, jätsin ennist mainimata, et siiski tahaks edasi jätkata Nikoni tehnikaga, kuna lisaks KIT objele oman veel üht objet (50mm 1.8). Vahepeal sai omatud ka Sigma toru 70-300, kuid see polnud suurem asi. Aga videote tegemise kohapealt niipalju, et eks alguses tahaks lihtsalt kätt harjutada selles vallas ja miks mitte ka tulevikus tsipa tõsisemalt tegelema hakata.
Küsiti ka veel, et mis ma D40 aegluse all mõtlen. Kuna teen üpris palju öövõtteid, mis toovad endaga kaasa pika säriaja, siis eriti praeguste külmade ilmadega on see pildi ekraanile kuvamise aeg ebameeldiv. 30-sekundilise säriajaga näiteks tuleb pilt erkaanile alles miski 32 sekundi jooksul. Või oleneb see kõik hoopis mälukaardist?
Laurman
17.10.2013 13:50:24
| Sul on müraeemaldus sees. Kui teed 30sek pilti siis teeb ta teise 30sek pildi veel kinnise katikuga, et elimineerida sensori kuumenemisest jms tekkinud müra.
102 |
Kruvi
17.10.2013 13:51:45
| Sults kirjutas: |
| Ei vasta tõele, et Nikoni odavama otsa kaameratel ei saa video võtte ajal ava muuta. See sõltub ikka objektiivist. |
Õigus, kuid see on pigem "workaround" kuna tänapäeva objedel siiski ava rõngast väga ei esine.
Probleem tuleneb sellest, et Nikon, Pentax ja Minolta/Sony kasutavad mehaanilist süsteemi ava muutmiseks. Canon ja Olympus (ning mirrorlessid) elektroonilist.
Nikoniga saab tänu sellele igasugu vana toru ette keerata, Canon'i vanatoru tugi lõppes antud muudatusega ära.
Väiksemate Nikoni kerede puhul lihtsalt ei saa seda mehaanilist süsteemi sedasi teha, et pidevalt muuta saaks. Nagu aru olen saanud läheks selleks eraldi mootorit vaja mis alles D3, D800 suguste kerede sisse mahub.
Näiteks LiveView's võid küll ava muuta kuid muutust ekraanil näed alles kui pilt on tehtud (või käid vahepeal liveview'st sisse-välja)
Tegin veits lisa tõlgelt sellest teemast: http://www.dpreview.com/forums/thread/2994813#forum-post-38319497
Seega ta jah otseselt möödapääsmatu probleem pole, kuid limiteerib valikut. Näiteks MMatsu mainitud objedel ei ole ühelgi minu meelest eraldi ava rõngast.
MMatsu:
Ülalolev jutt on siis võibolla veidike infoks - üldiselt mulle kui mitte video kogemust omavale isikule too väga suur probleem ei tundu.
Paned oma ava paika ja filmid. F2.8 pealt ja F11 peale video keskel keerata ei saa, kuid kõik muud võimalused olemas (kui ava rõngaga objet pole), kuid eks video inimesed teavad täpsemalt rääkida kui palju selle võimaluse puudumine häirib.
Sigma 70-300 on jah minu meelest 70-300 seeriatest kõige kehvem obje. Tamron 70-300 ja Nikon 70-300 on palju paremad. 50mm 1.8 on hea valik.
Kitikas on sul 18-105? (väga hea kit obje)
D40 aeglus tuleneb osaliselt nii pildi protsessorist endast kui ka mälukaardi kiirusest. Praegu on viimane versioon Expeed 3 (väidetavalt uuel Nikon D5300 juba Expeed 4)
Eks ta praeguseks ole üldiselt veits iganenud oma võimekuse poolest. Samas läbisõit on ikka päris väike (mul Mai 2013 ostetud D7100'l on pea 7K juba täis)
16 |
MMatsu
17.10.2013 14:04:58
| KIT objeks on 18-55.
korsten
17.10.2013 14:11:47
| MMatsu kirjutas: |
| KIT objeks on 18-55. |
Neid oli vist vr-ga (enamus) ja ilma (vanemad ja/või säästukad). Kindlalt ei raiu aga justkui meenub, et on liikunud D40 eid kit objedega mis on ilma VR-ita (mu D40-l on vr-ga vers).
Mis loom see 50 mm on?
God Hates Us All |
58 |
Kruvi
16 |
MMatsu
17.10.2013 14:37:06
| korsten kirjutas: |
| MMatsu kirjutas: |
Mis loom see 50 mm on? |
Minul näiteks ei ole VR variant. Ja see "viiekümnene loom" on täpselt see, mis kasutaja Kruvi lingil.
vallo
17.10.2013 17:45:33
| Mul tekkis ka küsimus, et miks peaks keset videoklipi võtet ava kruttima? Kui natuke ette planeerida, siis seda vaja pole.
| Kommentaarid: 68 loe/lisa |
66 |
korsten
17.10.2013 18:06:43
Ma sellepärast küsisin. 18-55 ilma vr-ta obje pole küll midagi sellist mille pärast Nikoni brändi taga nutta. 50mm saab ju järelturul maha müüa. Niiet vaata rahulikult laiemalt ringi.
Pole viga jah aga liikuvate asjade filmile saamiseks jääb amatöörioskustest väheseks. Klippe saab teha aga kui sellest edasi minna siis fotokaamera pole selle jaoks mõeldud. Klippide tegemise võimalus võib olla meeldiv lisa (jah, mida parem seda parem ) aga ainuüksi selle järgi Nikoni fotokaamerat valima hakata on pehmelt öeldes silly.
D3000 seeriat ei valiks mina isiklikult sest sellel pole keresisest fookusmootorit (objede valik on kesisem ja kallim).
God Hates Us All |
58 |
Sults
17.10.2013 21:05:58
| Kui juba nii kõvaks video tegemiseks läheb, et on vaja keset võtet ava käsitsi reguleerida, siis tuleks soetada spetsiaalsed videovõtte objektiivid. Nt suht soodsate hindadega Samyangi Cine seeria torud: http://www.samyang-lens.co.uk/samyang-lenses.html (all). Siis saab juurde soetada ka servod jms.
namstoop
17.10.2013 21:22:26
Ja mis pagana põhjusel see küll halb võiks olla, kui sama asja ka iga teise objektiiviga teha saab. Et kui Nikon on rongist maha jäänud ja ei võimalda, siis on kohe põhimõtteliselt paha asi või? Mingi bashimine käib kergelt
viimati muutis namstoop 17.10.2013 22:21:10, muudetud 1 kord |
| Kommentaarid: 72 loe/lisa |
63 |
rex
17.10.2013 22:14:17
| MMatsu kirjutas: |
| Tervitus! Olen nüüdseks oma 4-5 aastat kasutanud ühte kere, milleks on olnud D40. Nüüd aga tahaks liikuda millegi uuema poole. Miks? Peamine põhjus on see, et on tekkinud vajadus ka videoklippide tegemisele. Samuti jääb kohati jalgu D40 aeglus. Seega milliseid keresi soovitate Teie? Hinnaklass võiks olla mitte väga kallis ning pigem vaataks kasutatud tehnika poole. |
D3200/D5200, kasutatuna ka D5100.
Mitte üle 100.
228 |
korsten
17.10.2013 22:24:03
| namstoop kirjutas: |
Ja mis pagana põhjusel ei see küll halb võiks olla, kui sama asja ka iga teise objektiiviga teha saab. Et kui Nikon on rongist maha jäänud ja ei võimalda, siis on kohe põhimõtteliselt paha asi või? Mingi bashimine käib kergelt  |
Sa väidad, et kurgumandlite operatsiooni läbi perseaugu peab tegema ainult sellepärast nii, et taguotsal brändinimi peal on? Nikon on väga hea niikaua kuni asi piirdub pildistamisega ja lihtklippide tegemisega. Filmimise jaoks on teised pillid aga kahjuks on uue kasutaja eelarve piiratud.
God Hates Us All |
58 |
namstoop
17.10.2013 22:30:54
| korsten kirjutas: |
Sa väidad, et kurgumandlite operatsiooni läbi perseaugu peab tegema ainult sellepärast nii, et taguotsal brändinimi peal on? Nikon on väga hea niikaua kuni asi piirdub pildistamisega ja lihtklippide tegemisega. Filmimise jaoks on teised pillid aga kahjuks on uue kasutaja eelarve piiratud. |
meh? Mida täpselt sa nüüd öelda tahtsid?
63 |
