Kristoferr
08.10.2013 15:44:23
| lauri23 kirjutas: |
| Küll millalgi normaalsed driverid tehakse ja ikka mingi vahe 7970 kaardiga tuleb. Kuid saab see olla siiski minimaalne |
280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970
Hakkab vaikselt koitma või mitte?
219 |
lauri23
| Kommentaarid: 29 loe/lisa |
29 |
Genert
08.10.2013 16:15:52
Ma arvan, et siin on midagi sassi läinud.
r9-280x on HD7970 rebrand, r9-270x on HD7870 rebrand jne.
Samas on uued kaardid:r9-290 ja r9-290x, mis ei ole rebrandid.
Kui nüüd hakata mõtlema, et kui r9-290x on hd7970 ja r9-290 on hd7950, siis tegib väike segaduses nõrgemate kaartitega ehk kaks nõrgemat kaarti ei lähe uute kaartitega kokku.
Niisiis oleks lihtsam mõelda, et r9-290 ja x versioon on uued ja pole vastavuses vana seeriaga ning r9-280x ja nõrgemad kaardid on.
Kuid see on minu perspektiivist, nii et pakkuge omi!
_________________ Wannapreneur - Front-End Wizard
http://genert.github.io/ |
SurfData
08.10.2013 16:21:26
| lauri23 kirjutas: |
| Veel mitte. Kui hindu eestis näen, siis koidab paremini. |
no HETKEL on R9-280 ca 275€ ja ülespoole, olenevalt tootjast, kõik laod pole veel pakkuma hakanud
| Kommentaarid: 84 loe/lisa |
74 |
Kristoferr
219 |
caramis
08.10.2013 20:00:48
| klassi mõttes on 280 samas augus 78xx kaartidega. 290 läheb 79xx gruppi. seda mina mõtlesin enne, aga tross oli hommikust saati umbe jooksnud juba.
| Kommentaarid: 174 loe/lisa |
151 |
Killhoven
OC`er
08.10.2013 20:46:37
280 on ~10% kiirem kui siin foorumites ja poodides liikuvad "mitte GHz" editionid ja sama kiire kui 770 (aga rohkem vrammi), mis maksab hoopiski palju rohkem. Pole paha ju.
Aga tegelikult meeldib mulle 280 pikkus, see on nüüd keskklassi kaartide pikkuskategoorias. 7970 power mahub nüüd kenasti 10.5" sisse ja seega päris paljudesse korpustesse nüüdsest. Varasemalt oli 7870 LE lagi.
_________________ Foorumis on ühe lolli kohta kümme tarka, nii et jõud on enam-vähem võrdsed.™ |
| Kommentaarid: 409 loe/lisa |
351 |
Kristoferr
219 |
Killhoven
OC`er
08.10.2013 21:13:53
| Kristoferr kirjutas: |
Ja 280x kaardid on täpselt sama pikad. Paljudel on isegi layout täpselt sama. |
http://www.techpowerup.com/reviews/MSI/R9_280X_Gaming/3.html 26,5cm ~10,43"
Igal 7970 on 27,5cm või rohkem.
351 |
Kristoferr
08.10.2013 21:55:53
| Killhoven kirjutas: |
| Igal 7970 on 27,5cm või rohkem. |
Right...
Club 3D Radeon HD 7970 Dimensions: 268x122x36mm
PowerColor Radeon HD 7970 OC 265x111.2x38mm
MSI R7970 Twin Frozr Dimensions: 269x115x39mm
Need kõigest 3 esimest kaarti, mis tsekkasin. Rohkem ei viitsinud.
219 |
G80
08.10.2013 22:01:39
Millal 290X ülevaated ilmuvad?
210 |
pots4t4j4
08.10.2013 22:05:19
| ega enne 14/15 oktoobrit pole loota ma arvan, need mõttetud uue sildiga jurad pidid nädal varem tulema ja nii oligi.
401 |
Killhoven
OC`er
08.10.2013 22:11:01
Oi vana, ma ei teadnudki. Kõik 7970-d mida mulle on pakutud või mille ülevaadet olen uurinud, on olnud 27,5cm või rohkem ja ma olin igasuguse lootuse minetanud. Seega kaob see pikkuse eelis ära.
351 |
Kristoferr
219 |
pots4t4j4
08.10.2013 22:47:43
| kuidagi haledavõitu, no ?
401 |
bitCON
08.10.2013 22:49:21
| pots4t4j4 kirjutas: |
| kuidagi haledavõitu, no ? |
yes u are
siiiiiickk
ja mida veel Mantle juurde annab, ulme!
pots4t4j4
08.10.2013 22:52:17
| ootaks siiski et GTX 780 kiirem oleks
401 |
bitCON
08.10.2013 22:56:45
| ootaks siiski et GTX 780 kiirem oleks |
overpriced crap
pots4t4j4
08.10.2013 22:57:28
| Nitrub kirjutas: |
overpriced crap |
haha sa loodad alla 450€ seda uut kaarti saada ? palju edu siis
401 |
08.10.2013 23:17:47
tegelikult kogu jama on hinnas, kui vanasti sai tippkaardi kätte 400€ nüüd tuleb laduda 600- tonn
amd ja rohelised on mugavaks läinud, samas ega patsiendid ka lollid pole
bitCON
08.10.2013 23:23:09
| Nitrub kirjutas: |
overpriced crap |
haha sa loodad alla 450€ seda uut kaarti saada ? palju edu siis  |
kust otsast see 780 sul 450 euri makstab?
pots4t4j4
08.10.2013 23:23:37
| Nitrub kirjutas: |
| Nitrub kirjutas: |
overpriced crap |
kust otsast see 780 sul 450 euri makstab? |
foorumis täitsa uued kaardid
401 |
bitCON
08.10.2013 23:30:10
| foorum foorumiks, poehindadega võrreldakse
08.10.2013 23:30:38
Nitrub, mantle ei anna sulle mitte sittagi kuniks mängud selle tuge ei saa.
see pildistet skoor on 200mhz overclockiga. ma ei oska skoore otsida kellade järgi aga klokitud titanid peaks samasse auku või rohkem tegema ju?
_________________ - londiste
217 |
bitCON
08.10.2013 23:34:17
| londiste kirjutas: |
see pildistet skoor on 200mhz overclockiga. ma ei oska skoore otsida kellade järgi aga klokitud titanid peaks samasse auku või rohkem tegema ju? |
jah aga mängud millel on vaja perfi need saavad mantle toe.
see kaart on odavam kui titan
pots4t4j4
08.10.2013 23:35:18
| Nitrub kirjutas: |
see kaart on odavam kui titan |
vägev
401 |
caramis
08.10.2013 23:40:14
| Nitrub kirjutas: |
vägev |
on, eks?
151 |
| Kommentaarid: 92 loe/lisa |
Kristoferr
09.10.2013 10:08:23
Umkaudu selline valem siis.
Firestrike GPU skoor: 1100/1250 R9 290X = 1275/1850 GTX 780.
http://videocardz.com/46558/amd-radeon-r9-290x-r9-290-european-pricing-unveiled
MSI Radeon R9 290X R9-290X-4GD5 649 EUR
MSI Radeon R9 290 R9-290-4GD5 519 EUR
Arvestades, et tabelis on märgitud 280x Gaming hinnaks 279EUR ja ja odavaim EUs on hetkel väga selle hinna lähedale, siis võib neid numbreid tõsiselt võtta.
Minu arvates liiga kallis.
219 |
caramis
09.10.2013 11:05:24
Minu arvates liiga kallis.  |
GTX770 maksab ~350+..
151 |
09.10.2013 11:26:57
hindade võrdluses ärge unustage, et amd rebadge/hinnamuutused tulid alles eile.
amd ei ole ainukene, kes hindasid vastavalt konkurentsile korrigeerib.
217 |
Kristoferr
09.10.2013 13:02:33
GTX 770 oma 320eur hinnaga ongi kehvem valik kui 280x.
Aga ma ei ütleks, et GTX 780 oleks 530eur hinnaga viletsam valik, kui 290x saab olema oma 650eur hinnaga.
290 520eur hinnasilt tundub olema suht OK, sest eeldatavalt tuleb ta täpselt GTX 780 jõudlusklassi.
Ühesõnaga, ei midagi rõõmustavat, mis ostma paneks, aga ei midagi katastroofilist samuti.
HD7990 @ 500eur tundub nende hindade kõrval lausa pool tasuta diil olema.
64 rops Mitte, et see üllatusena tuleks. Pigem kinnitus.
219 |
Kremka
09.10.2013 13:05:53
Sellise hinnaga jääb mulgi ostmata 290X.
Jõudu väheks jääb panen teise 7870 Tahiti kõrvale järelturult.
| Kommentaarid: 80 loe/lisa |
72 |
Kristoferr
219 |
09.10.2013 13:27:57
1.4x stream processors (7970/r2-280 vs r2-290) on huvitavam väide. see suhe on umbes sama, mis nvidia pool 680/770 ja 780 vahel ja tunduvalt väiksem kui 680/770 ja titani vahel.
ropid teevad suurtel resodel küll vahe sisse aga 4k resole suunatuna ainult 4gb mälu?
either way, ajad lähevad jälle lõbusamaks ja meile kui tarbijatele on see kõik kuratlikult tore
217 |
lauri23
29 |
liiv
10.10.2013 03:43:08
| lauri23 kirjutas: |
| Vahet pole, tundub ikkagi mõistlik see 280x variant mulle praegu kaardi otsingul |
mhm, ja ma võin sulle eesti parima hinna teha
| Kommentaarid: 627 loe/lisa |
9 :: |
6 :: |
517 |
Kremka
10.10.2013 05:20:25
| liiv kirjutas: |
| lauri23 kirjutas: |
mhm, ja ma võin sulle eesti parima hinna teha |
Räägi täpsemalt , äkki tekib endalgi huvi siis 280X vastu =)
72 |
lauri23
29 |
Santzu
| Kommentaarid: 9 loe/lisa |
9 |
trip
10.10.2013 20:54:21
nalja teed
Ladu K
Tarne minimaalselt kaks nädalat. |
K=Kosmos
303 |
One
10.10.2013 21:16:40
Päris head hinnad ja eks nad ole mujal kindlasti veel omajagu odavamad.
Toxic võib tegelikult päris korralik loom olla.
728 |
Braien
10.10.2013 21:17:45
No need kellel 7970 kastis, saavad 280 cf'i panna
90 |
VeixES
| Kommentaarid: 36 loe/lisa |
Braien
10.10.2013 21:26:49
[veix], Vaatasin juba.
90 |
trip
303 |
10.10.2013 23:26:12
toxic on siis see?
http://www.anandtech.com/show/7406/the-sapphire-r9-280x-toxic-review
tegelikult näitab väga hästi kus tahiti sweetspot on. klokkimise headroomi pole, isegi võimsa jahutusega on võrdlemisi vali ja voolutarve hakkab 480 karjamaale põrutama (ja ei põruta ilmselt sellepärast, et peale 480 ikaldust on asisem throttle nii amd kui nvidia kividel).
217 |
alexcrx
| Kommentaarid: 30 loe/lisa |
29 |
W!ngs
11.10.2013 18:53:16
| Kahju, et Asus Matrixit nende hulgas pole.
| Kommentaarid: 23 loe/lisa |
23 |
SilQ
11.10.2013 19:11:48
| Millal huvitav see liigitus HV.ee lehele tuleb?
215 |
