uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  AMD Volcanic Islands aka R-200 seeria videokaardid märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 12, 13, 14 ... 61, 62, 63  järgmine
Kristoferr
Kristoferr
sõnum 08.10.2013 15:44:23 vasta tsitaadiga
lauri23 kirjutas:
Küll millalgi normaalsed driverid tehakse ja ikka mingi vahe 7970 kaardiga tuleb. Kuid saab see olla siiski minimaalne
280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970 280x = 7970
Kommentaarid: 269 loe/lisa Kasutajad arvavad:  :: 4 :: 0 :: 220
lauri23
lauri23
sõnum 08.10.2013 16:14:00 vasta tsitaadiga
Veel mitte. Kui hindu eestis näen, siis koidab paremini.
Tasuta 50$pokkeri kontole. Registreeri, õpi strateegiat ja vasta küsimustele. Saad valitud pokkerituppa 50$+veel boonust, kui mängida oskad. Isiklikult saanud 285$ sealt.
Genert
sõnum 08.10.2013 16:15:52 vasta tsitaadiga
Ma arvan, et siin on midagi sassi läinud.
r9-280x on HD7970 rebrand, r9-270x on HD7870 rebrand jne.
Samas on uued kaardid:r9-290 ja r9-290x, mis ei ole rebrandid.
Kui nüüd hakata mõtlema, et kui r9-290x on hd7970 ja r9-290 on hd7950, siis tegib väike segaduses nõrgemate kaartitega ehk kaks nõrgemat kaarti ei lähe uute kaartitega kokku.
Niisiis oleks lihtsam mõelda, et r9-290 ja x versioon on uued ja pole vastavuses vana seeriaga ning r9-280x ja nõrgemad kaardid on.
Wannapreneur - Front-End Wizard
http://genert.github.io/
SurfData
SurfData
sõnum 08.10.2013 16:21:26 vasta tsitaadiga
lauri23 kirjutas:
no HETKEL on R9-280 ca 275€ ja ülespoole, olenevalt tootjast, kõik laod pole veel pakkuma hakanud
Kristoferr
Kristoferr
sõnum 08.10.2013 16:40:16 vasta tsitaadiga
280X kaardid müügis.
http://www.overclockers.co.uk/productlist.php?catid=56&groupid=701&sortby=priceAsc&subid=1842
Odavaim hetkel 234£.
Odavaim 7970 samas kohas on 227£
Erilist vahet pole.
caramis
caramis
sõnum 08.10.2013 20:00:48 vasta tsitaadiga
klassi mõttes on 280 samas augus 78xx kaartidega. 290 läheb 79xx gruppi. seda mina mõtlesin enne, aga tross oli hommikust saati umbe jooksnud juba.
3D-skännin, 3D-prindin, 3D-modelleerin (reverse-engineering või nullist midagi uut) ja remondin-hooldan-ehitan 3D-printereid - https://plastsepp.eu/
Kommentaarid: 177 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 151
Killhoven
OC`er
Killhoven
sõnum 08.10.2013 20:46:37 vasta tsitaadiga
Kristoferr kirjutas:
Erilist vahet pole.
280 on ~10% kiirem kui siin foorumites ja poodides liikuvad "mitte GHz" editionid ja sama kiire kui 770 (aga rohkem vrammi), mis maksab hoopiski palju rohkem. Pole paha ju.
Aga tegelikult meeldib mulle 280 pikkus, see on nüüd keskklassi kaartide pikkuskategoorias. 7970 power mahub nüüd kenasti 10.5" sisse ja seega päris paljudesse korpustesse nüüdsest. Varasemalt oli 7870 LE lagi.
Kommentaarid: 410 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 352
Kristoferr
Kristoferr
sõnum 08.10.2013 20:53:04 vasta tsitaadiga
Eriline optimist ikka icon_lol.gif .
Kes oma 7970 veel vana biosega või def taktil jooksutab, sel pole rohkem vaja või on lihtsalt rumal.
Ja 280x kaardid on täpselt sama pikad. Paljudel on isegi layout täpselt sama.
Liitu Z.ai coding plaaniga ja saa 10% soodust!
Liitu Wise'ga!
Killhoven
OC`er
Killhoven
sõnum 08.10.2013 21:13:53 vasta tsitaadiga
http://www.techpowerup.com/reviews/MSI/R9_280X_Gaming/3.html 26,5cm ~10,43"
Igal 7970 on 27,5cm või rohkem.
Kristoferr
Kristoferr
sõnum 08.10.2013 21:55:53 vasta tsitaadiga
Killhoven kirjutas:
Right...
Club 3D Radeon HD 7970 Dimensions: 268x122x36mm
PowerColor Radeon HD 7970 OC 265x111.2x38mm
MSI R7970 Twin Frozr Dimensions: 269x115x39mm
Need kõigest 3 esimest kaarti, mis tsekkasin. Rohkem ei viitsinud.
G80
G80
sõnum 08.10.2013 22:01:39 vasta tsitaadiga
Ära siia kliki
Kommentaarid: 256 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 210
pots4t4j4
sõnum 08.10.2013 22:05:19 vasta tsitaadiga
ega enne 14/15 oktoobrit pole loota ma arvan, need mõttetud uue sildiga jurad pidid nädal varem tulema ja nii oligi.
Killhoven
OC`er
Killhoven
sõnum 08.10.2013 22:11:01 vasta tsitaadiga
Oi vana, ma ei teadnudki. Kõik 7970-d mida mulle on pakutud või mille ülevaadet olen uurinud, on olnud 27,5cm või rohkem ja ma olin igasuguse lootuse minetanud. Seega kaob see pikkuse eelis ära.
Kristoferr
Kristoferr
sõnum 08.10.2013 22:32:46 vasta tsitaadiga
R9 290x @ 1100/1275mhz.
http://www.3dmark.com/3dm/1334768
pots4t4j4
sõnum 08.10.2013 22:47:43 vasta tsitaadiga
kuidagi haledavõitu, no ?
bitCON
sõnum 08.10.2013 22:49:21 vasta tsitaadiga
pots4t4j4 kirjutas:
yes u are
siiiiiickk
ja mida veel Mantle juurde annab, ulme!
pots4t4j4
sõnum 08.10.2013 22:52:17 vasta tsitaadiga
ootaks siiski et GTX 780 kiirem oleks
bitCON
sõnum 08.10.2013 22:56:45 vasta tsitaadiga
pots4t4j4 kirjutas:
overpriced crap
pots4t4j4
sõnum 08.10.2013 22:57:28 vasta tsitaadiga
Nitrub kirjutas:
pots4t4j4 kirjutas:
overpriced crap
haha sa loodad alla 450€ seda uut kaarti saada ? palju edu siis thumbs_up.gif
sõnum 08.10.2013 23:17:47 vasta tsitaadiga
tegelikult kogu jama on hinnas, kui vanasti sai tippkaardi kätte 400€ nüüd tuleb laduda 600- tonn icon_idea.gif
amd ja rohelised on mugavaks läinud, samas ega patsiendid ka lollid pole thumbs_up.gif
bitCON
sõnum 08.10.2013 23:23:09 vasta tsitaadiga
pots4t4j4 kirjutas:
Nitrub kirjutas:
pots4t4j4 kirjutas:
overpriced crap
kust otsast see 780 sul 450 euri makstab?
pots4t4j4
sõnum 08.10.2013 23:23:37 vasta tsitaadiga
Nitrub kirjutas:
pots4t4j4 kirjutas:
Nitrub kirjutas:
pots4t4j4 kirjutas:
overpriced crap
foorumis thumbs_up.gif täitsa uued kaardid
bitCON
sõnum 08.10.2013 23:30:10 vasta tsitaadiga
foorum foorumiks, poehindadega võrreldakse
sõnum 08.10.2013 23:30:38 vasta tsitaadiga
Nitrub, mantle ei anna sulle mitte sittagi kuniks mängud selle tuge ei saa.
see pildistet skoor on 200mhz overclockiga. ma ei oska skoore otsida kellade järgi aga klokitud titanid peaks samasse auku või rohkem tegema ju?
- londiste
bitCON
sõnum 08.10.2013 23:34:17 vasta tsitaadiga
londiste kirjutas:
jah aga mängud millel on vaja perfi need saavad mantle toe.
see kaart on odavam kui titan
pots4t4j4
sõnum 08.10.2013 23:35:18 vasta tsitaadiga
Nitrub kirjutas:
londiste kirjutas:
vägev
caramis
caramis
sõnum 08.10.2013 23:40:14 vasta tsitaadiga
pots4t4j4 kirjutas:
Nitrub kirjutas:
londiste kirjutas:
vägev
on, eks?
sõnum 09.10.2013 02:08:31 vasta tsitaadiga
No tegu pole iseenesest halva skooriga. 2x 7950 (kellatud) teeb sutsu rohkem, kui 1x R9 290X
Ja antud testis 780 isegi võib ületada Titanit, kui viimane liiga aeglase prosega paaritada. Vaadake meie skooriteemast ise järgi: https://foorum.hinnavaatlus.ee/viewtopic.php?p=7845295#7845295
EDIT: Uute kaartide toega 13.11 Beta kah saadaval: https://foorum.hinnavaatlus.ee/viewtopic.php?p=7842116#7842116
Kristoferr
Kristoferr
sõnum 09.10.2013 10:08:23 vasta tsitaadiga
Umkaudu selline valem siis.
Firestrike GPU skoor: 1100/1250 R9 290X = 1275/1850 GTX 780.
Tomorrow kirjutas:
http://videocardz.com/46558/amd-radeon-r9-290x-r9-290-european-pricing-unveiled
MSI Radeon R9 290X R9-290X-4GD5 649 EUR
MSI Radeon R9 290 R9-290-4GD5 519 EUR
Arvestades, et tabelis on märgitud 280x Gaming hinnaks 279EUR ja ja odavaim EUs on hetkel väga selle hinna lähedale, siis võib neid numbreid tõsiselt võtta.
caramis
caramis
sõnum 09.10.2013 11:05:24 vasta tsitaadiga
Tomorrow kirjutas:
GTX770 maksab ~350+..
sõnum 09.10.2013 11:26:57 vasta tsitaadiga
hindade võrdluses ärge unustage, et amd rebadge/hinnamuutused tulid alles eile.
amd ei ole ainukene, kes hindasid vastavalt konkurentsile korrigeerib.
- londiste
Kristoferr
Kristoferr
sõnum 09.10.2013 13:02:33 vasta tsitaadiga
GTX 770 oma 320eur hinnaga ongi kehvem valik kui 280x.
Aga ma ei ütleks, et GTX 780 oleks 530eur hinnaga viletsam valik, kui 290x saab olema oma 650eur hinnaga.
290 520eur hinnasilt tundub olema suht OK, sest eeldatavalt tuleb ta täpselt GTX 780 jõudlusklassi.
Ühesõnaga, ei midagi rõõmustavat, mis ostma paneks, aga ei midagi katastroofilist samuti.
HD7990 @ 500eur tundub nende hindade kõrval lausa pool tasuta diil olema.
64 rops thumbs_up.gif Mitte, et see üllatusena tuleks. Pigem kinnitus.
Kremka
Kremka
sõnum 09.10.2013 13:05:53 vasta tsitaadiga
Sellise hinnaga jääb mulgi ostmata 290X.
Jõudu väheks jääb panen teise 7870 Tahiti kõrvale järelturult.
Kommentaarid: 80 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 72
Kristoferr
Kristoferr
sõnum 09.10.2013 13:14:48 vasta tsitaadiga
AMD enda lühiülevaade asjast: icon_biggrin.gif
http://wccftech.com/amd-radeon-r9-290x-radeon-r9-290-series-official-presentation-leaked-4k-gaming-performance-unveiled/
sõnum 09.10.2013 13:27:57 vasta tsitaadiga
1.4x stream processors (7970/r2-280 vs r2-290) on huvitavam väide. see suhe on umbes sama, mis nvidia pool 680/770 ja 780 vahel ja tunduvalt väiksem kui 680/770 ja titani vahel.
ropid teevad suurtel resodel küll vahe sisse aga 4k resole suunatuna ainult 4gb mälu?
either way, ajad lähevad jälle lõbusamaks ja meile kui tarbijatele on see kõik kuratlikult tore icon_biggrin.gif
- londiste
lauri23
lauri23
sõnum 09.10.2013 13:38:12 vasta tsitaadiga
Vahet pole, tundub ikkagi mõistlik see 280x variant mulle praegu kaardi otsingul, kui just väga hea hinna ja garantiiga kasutatud 7970 ei saa.
liiv
liiv
sõnum 10.10.2013 03:43:08 vasta tsitaadiga
lauri23 kirjutas:
mhm, ja ma võin sulle eesti parima hinna teha
Kommentaarid: 627 loe/lisa Kasutajad arvavad:  :: 9 :: 6 :: 517
Kremka
Kremka
sõnum 10.10.2013 05:20:25 vasta tsitaadiga
liiv kirjutas:
lauri23 kirjutas:
Räägi täpsemalt , äkki tekib endalgi huvi siis 280X vastu =)
lauri23
lauri23
sõnum 10.10.2013 08:46:22 vasta tsitaadiga
Pakkumist võib mulle ikka teha. Kuna on kahes hulgilaos tutvus sees, siis on vb raske parimat pakkumist teha a eks ole näha thumbs_up.gif
Santzu
Santzu
sõnum 10.10.2013 20:39:22 vasta tsitaadiga
R9 280x poehinnad
https://www.hinnavaatlus.ee/products/pricelist/?Product=r9+280x
trip
trip
sõnum 10.10.2013 20:54:21 vasta tsitaadiga
Ladu K
Tarne minimaalselt kaks nädalat.
One
sõnum 10.10.2013 21:16:40 vasta tsitaadiga
Päris head hinnad ja eks nad ole mujal kindlasti veel omajagu odavamad.
Toxic võib tegelikult päris korralik loom olla.
Braien
Braien
sõnum 10.10.2013 21:17:45 vasta tsitaadiga
VeixES
sõnum 10.10.2013 21:24:53 vasta tsitaadiga
braien334 kirjutas:
Nagu siin tehtud ongi http://www.youtube.com/watch?v=OWnbEHMLRog
Tule ja arutle mobiilsidest, võrkude kaardistamisest, tehnoloogiast, telefonidest ja operaatoritest http://t.me/cellmappereesti
Kommentaarid: 36 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 35
Braien
Braien
sõnum 10.10.2013 21:26:49 vasta tsitaadiga
[veix], Vaatasin juba.
trip
trip
sõnum 10.10.2013 22:52:44 vasta tsitaadiga
http://videocardz.com/46571/amd-radeon-r9-290x-confirmed-feature-64-rops#
sõnum 10.10.2013 23:26:12 vasta tsitaadiga
toxic on siis see?
http://www.anandtech.com/show/7406/the-sapphire-r9-280x-toxic-review
tegelikult näitab väga hästi kus tahiti sweetspot on. klokkimise headroomi pole, isegi võimsa jahutusega on võrdlemisi vali ja voolutarve hakkab 480 karjamaale põrutama (ja ei põruta ilmselt sellepärast, et peale 480 ikaldust on asisem throttle nii amd kui nvidia kividel).
- londiste
alexcrx
alexcrx
sõnum 11.10.2013 17:44:13 vasta tsitaadiga
http://www.arvutitark.ee/est/TOOTEKATALOOG/ARVUTIKOMPONENDID-Graafikakaardid-VGA-AMD-Radeon-Radeon-Rx-200-Series
esimesed saabuvad teisipäeval.
Kommentaarid: 30 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 29
W!ngs
W!ngs
sõnum 11.10.2013 18:53:16 vasta tsitaadiga
Kahju, et Asus Matrixit nende hulgas pole.
SilQ
SilQ
sõnum 11.10.2013 19:11:48 vasta tsitaadiga
Millal huvitav see liigitus HV.ee lehele tuleb?
Kommentaarid: 251 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 215
uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  AMD Volcanic Islands aka R-200 seeria videokaardid mine lehele eelmine  1, 2, 3 ... 12, 13, 14 ... 61, 62, 63  järgmine
