With a new Frostbite engine and a single-player mode inspired by multiplayer dynamics, the latest military shooter from EA DICE promises much – but at this point, gives away little...
Kustkohast see info pärineb, et 64 mängijat uue generatsiooni peal ?
Kui see on tõsi siis see paneks ehk uue konsooli peale mõtlema, muidu suht savi next-gen'st hetkel.
Krt, mõtlen siin, et peaks ikka ära tellima, aga ei saagi siis aru, et kas premium tähendab lihtsalt 1 DLC-d või saab ikka reaalse premiumi kaasa? Kuradi turundus ikka Keegi on ära tellinud ka juba, kust kõige mõttekam on?
Edit:
Olks, uurisin veits veel, leidsin mingist foorumist vestluse kasutaja ja EA support vahel:
Luke: Thank you for contacting EA support, my name is Luke, how can I help you today?
you: hi
you: i've got a question about bf4 preorder
Luke: Ok what is your question?
you: i saw on battlelog that info: "Pre-order Battlefield 4 now and get a Premium expansion pack at no additional charge."
you: what does it mean?
you: if I preorder bf4, I will recieve any DLC when it's out?
you: like premium in bf3?
Luke: That means you will receive the first DLC with the game at no extra charge, so like if you pre-ordered Battlefield 3 you received Back to Karkand, you will receive the first DLC for Battlefield 4
you: only the first dlc?
Luke: Yes just the first DLC.
you: ok, that's everything
you: thank you
Luke: No problem, thanks for contacting EA support.
Inside marked copies of Battlefield 4 for PlayStation®3 there will be a voucher with a unique code printed on it. This code will allow you the one-time opportunity until March 28, 2014 to purchase a digital version of Battlefield 4 via the PlayStation®Store for only $9.99/£9.99/9.99€. Check back here soon for more details. _________________ sometimes i hug myself for no reason.
Jama on see, et PS3 oma ei saa maha müüa, plaat tuleb PS4 panna, et seda soodus versiooni mängida. Kokkuvõttes tuleb ikka sama kallis mis PS4 oma osta, ainuke eelis, et saab kuu aega varem kätte _________________ sometimes i hug myself for no reason.
PS3 peal Beta ikka väga imelik, BF3 pole midagi alles... Nagu BC2 ja selline väga imelik asi...
Vähemalt töötab ilusti, PC teemat vaadates ei saa seal keegi seda tööle...
viimati muutis iir 02.10.2013 10:24:55, muudetud 1 kord
Täielik jama.
tanki juhtimine on üle viidud pulkade peale. Võimatu on kiiresti tagurdada ja keerata näiteks, nüüd sihi selle pulgaga, et otse sõita... Kui ära muuta nupud siis on miskipärast L1 R1 sõitmiseks ja tulistamine muutub L2R2 alla?
Gunneriga kellelegi pihta saada on võimatu, nii tundlik on, võimatu.
Kopteriga lendamine samamoodi pulkade all, kõrgust muudad pulgaga üles alla, kui L ja R alla panna siis liiguvad jälle tulistamis nupud L2R2 alla? Lisaks ei ole enam võimalik manööverdada. Tükk aega läks aega et üldse asi lendama saada, pidev crash...
BF3 võisin une pealt lennata ja trikke teha, madalalt - majade vahelt - polnud probleemi kellelegi pihta saada või sõidukeid hävitada, praegu on võimatu sihtida sellise juhtimisega. viis venda oli maja katusel ja mina neile pihta ei saanud, ennem said nemad mulle pihta oma hernepüssidega... teise kopteri pihta ei saanud ammugi, võimatu mingi pulgaga kõrgust reguleerida...
Praegu küll ostma ei kipu...
Jah lift on kihvt uuendus ja maja vajub kokku, käsklusi saab ka nüüd R2 alt jagada või kellelegi öelda, et kao välja sõidukist... Vees saab sukelduda.
Sellised asjad oleks pidanud BF3 sees olema...
medal of honori uus plat täitsa olemas,karbil kirjas ka battfield 4 beta,aga plaadi sisse pannes,battlefield betat küll pole,pole mingit koodi seal ka kaasas sellele _________________
Sai ka siis ära proovitud Ps3 peal see.Tankiga küll harjumatu jah.Aga 1 kopter juba alla tulistatud sellega.Hetkel õnneks või kahjuks lemmik ikka joosta ringi support klassiga .
Kas konsooli peal on ka beta sama kehvas seisus nagu PC teemast lugeda võib?
BF3 oli väljagi tulles üsna vigane, praegu näib küll, et nutikas on BF4 alles esimeste patchide ilmudes osta
Hetkel käimas beta,mis pole kaugeltki lõpp versioon,selle järgi küll otsustada ei tasuks.
Kas sul BF3 Premium on?
Hetkel ei tööta vist üldse, sest muudavad servereid avaliku beta jaoks... _________________ sometimes i hug myself for no reason.
Olen nüüd paar päeva BF4 betat mänginud XBoxi peal ja peab ütlema, et mäng iseenesest on päris lahe. Siege of Shanghai map on selline mõnus CQB sõda, eriti Dominationis, ja need maast leitavad relvad (USAS12, granaadiheitja ja M82) on selline mõnus vaheldus, eriti USAS12.
Muidu võib aga oodata, et päris release's on relvad käitumine hoopis teine. Näiteks hetkel AK12 on liigagi hea. Sa võid praktiliselt igast kaugusest full autot lasta, spread ja bullet drop on praktiliselt olematut. Samuti ei ole hetkel hit boxe niipalju, kui näiteks BF3's. On ainult keha 1x ja pea 2x.
Kas peale minu on kellelgi veel see jama, et kui lähed Dominationis C kohal olevale katusele siis lifti poolsest poolest teisele poole vaadates vastaseid ei näe (samas vastupidi pole tähele pannud). Pead täiesti klaasi ääre juures olema, et neid näeks. Sama on ka kui vaadata alla, sinna poole, kus teisi punkte pole (ehk siis maja taha?).
Alguses olin hämmingus, miks mul kuulid nii kiiresti otsa saavad. Siis alles märkasin, et relva laadides kaotad salve jäänud kuulid
beta lõppes täna ära või?
Pole nädal aega konsooli taha saanud korralikult ja jäigi see pommi mode proovimata...
Kuskil midagi heli juhtimisest juttu ka on olnud, või jääbki nii nagu demos?
Väga rõve minujaoks, sama ka sõidukitega.
Oleks hea kui saaks ikka sama skeemi võtta mis BF3 oli... _________________ sometimes i hug myself for no reason.
E: http://blogs.battlefield.com/2013/10/thanks-for-bf4-beta-feedback/
Controller layouts (X360/PS3)
We’ve increased the available controller options in Battlefield 4, including the new controller layout and multiple alternatives that we hope will make you feel right at home. If you’re more comfortable with the controls from Battlefield 3, we’ve got you covered. Just by bringing up the options menu, you can choose the “Veteran” layout, which is similar to that in Battlefield 3.
E: PS4 lingi panin... PS3 1 november. Enne oli nagu varem? USA konto näitab 29 oktoober...
johhaidii... _________________ sometimes i hug myself for no reason.
Battlefield 4 Xbox One & PlayStation 4 Videos:
http://www.youtube.com/user/jackfrags/videos _________________ Päevad lõpevad siis, kui lased neil minna...
M: Cannondale Tract MIPSkiiver (uus; Polar White; Large) - 40€
PS3 peal juba downloadib, kuskil näeb mil tööle ka hakkab? _________________ sometimes i hug myself for no reason.
Parem kui oodata oskas. Tundub rohkem BC 2.5 olevat, palju asju sealt üle toodud, tuleb jälle collectablesi otsida ja relvi unlockida. BF3 oli ikka midagi muud.
MP on eriti tugevalt BC2 moodi. _________________ sometimes i hug myself for no reason.
Ei teagi mida arvata
Graafika tundub olevat isegi kehvem kui BF3's, loodan, et next-gen peal on kõvasti parem.
Dominaton mode hakkab ruulima, conquest tundub jube tühi olema 12 vs 12. Teise mode pole veel jõudnud proovida.
Pinda käib, et nad seda battlelogi peale suruvad. Esiteks, et nüüd scoreboard nupu asemel on battlelogi teema ja teiseks, et kui tahad klasse modida siis pead seda sõjas/mängus sees tegema või battlelogi ronima. Või kui ma pime olen ja seda menu's ei näinud siis öelge aga.
Kogu see menu tundub mulle poolik, leaderboarde ka ei ole enam, jälle mine battlelogi.
Aga FUN on ikka
