With a new Frostbite engine and a single-player mode inspired by multiplayer dynamics, the latest military shooter from EA DICE promises much – but at this point, gives away little...
Kustkohast see info pärineb, et 64 mängijat uue generatsiooni peal ?
Kui see on tõsi siis see paneks ehk uue konsooli peale mõtlema, muidu suht savi next-gen'st hetkel.
Krt, mõtlen siin, et peaks ikka ära tellima, aga ei saagi siis aru, et kas premium tähendab lihtsalt 1 DLC-d või saab ikka reaalse premiumi kaasa? Kuradi turundus ikka Keegi on ära tellinud ka juba, kust kõige mõttekam on?
Edit:
Olks, uurisin veits veel, leidsin mingist foorumist vestluse kasutaja ja EA support vahel:
Luke: Thank you for contacting EA support, my name is Luke, how can I help you today?
you: hi
you: i've got a question about bf4 preorder
Luke: Ok what is your question?
you: i saw on battlelog that info: "Pre-order Battlefield 4 now and get a Premium expansion pack at no additional charge."
you: what does it mean?
you: if I preorder bf4, I will recieve any DLC when it's out?
you: like premium in bf3?
Luke: That means you will receive the first DLC with the game at no extra charge, so like if you pre-ordered Battlefield 3 you received Back to Karkand, you will receive the first DLC for Battlefield 4
you: only the first dlc?
Luke: Yes just the first DLC.
you: ok, that's everything
you: thank you
Luke: No problem, thanks for contacting EA support.
Inside marked copies of Battlefield 4 for PlayStation®3 there will be a voucher with a unique code printed on it. This code will allow you the one-time opportunity until March 28, 2014 to purchase a digital version of Battlefield 4 via the PlayStation®Store for only $9.99/£9.99/9.99€. Check back here soon for more details. _________________ sometimes i hug myself for no reason.
Jama on see, et PS3 oma ei saa maha müüa, plaat tuleb PS4 panna, et seda soodus versiooni mängida. Kokkuvõttes tuleb ikka sama kallis mis PS4 oma osta, ainuke eelis, et saab kuu aega varem kätte _________________ sometimes i hug myself for no reason.
PS3 peal Beta ikka väga imelik, BF3 pole midagi alles... Nagu BC2 ja selline väga imelik asi...
Vähemalt töötab ilusti, PC teemat vaadates ei saa seal keegi seda tööle...
viimati muutis iir 02.10.2013 09:24:55, muudetud 1 kord
Täielik jama.
tanki juhtimine on üle viidud pulkade peale. Võimatu on kiiresti tagurdada ja keerata näiteks, nüüd sihi selle pulgaga, et otse sõita... Kui ära muuta nupud siis on miskipärast L1 R1 sõitmiseks ja tulistamine muutub L2R2 alla?
Gunneriga kellelegi pihta saada on võimatu, nii tundlik on, võimatu.
Kopteriga lendamine samamoodi pulkade all, kõrgust muudad pulgaga üles alla, kui L ja R alla panna siis liiguvad jälle tulistamis nupud L2R2 alla? Lisaks ei ole enam võimalik manööverdada. Tükk aega läks aega et üldse asi lendama saada, pidev crash...
BF3 võisin une pealt lennata ja trikke teha, madalalt - majade vahelt - polnud probleemi kellelegi pihta saada või sõidukeid hävitada, praegu on võimatu sihtida sellise juhtimisega. viis venda oli maja katusel ja mina neile pihta ei saanud, ennem said nemad mulle pihta oma hernepüssidega... teise kopteri pihta ei saanud ammugi, võimatu mingi pulgaga kõrgust reguleerida...
Praegu küll ostma ei kipu...
Jah lift on kihvt uuendus ja maja vajub kokku, käsklusi saab ka nüüd R2 alt jagada või kellelegi öelda, et kao välja sõidukist... Vees saab sukelduda.
Sellised asjad oleks pidanud BF3 sees olema...
medal of honori uus plat täitsa olemas,karbil kirjas ka battfield 4 beta,aga plaadi sisse pannes,battlefield betat küll pole,pole mingit koodi seal ka kaasas sellele _________________
Sai ka siis ära proovitud Ps3 peal see.Tankiga küll harjumatu jah.Aga 1 kopter juba alla tulistatud sellega.Hetkel õnneks või kahjuks lemmik ikka joosta ringi support klassiga .
Kas konsooli peal on ka beta sama kehvas seisus nagu PC teemast lugeda võib?
BF3 oli väljagi tulles üsna vigane, praegu näib küll, et nutikas on BF4 alles esimeste patchide ilmudes osta
