uus teema   vasta Tarkvara »  Arvutimängude foorum »  Rise Of The Triad märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3  järgmine
KurjaJuur
KurjaJuur
sõnum 04.08.2013 21:49:03 vasta tsitaadiga
Incorrect query, contact game support.
Sihuke teade siis kui üritan accounti teha.
Steam|Last.fm|
Kutsu
Kutsu
sõnum 04.08.2013 23:30:07 vasta tsitaadiga
KurjaJuur kirjutas:
Nimes ei tohi olla täppidega tähti. Endal oli sama probleem.
KurjaJuur
KurjaJuur
sõnum 05.08.2013 00:04:17 vasta tsitaadiga
Tänud. Nii oligi.
Steam|Last.fm|
Mafia
Mafia
sõnum 06.08.2013 11:41:58 vasta tsitaadiga
IGN icon_lol.gif http://www.ign.com/articles/2013/08/06/rise-of-the-triad-review doh.gif
Bawse
Kommentaarid: 19 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 17
Kutsu
Kutsu
sõnum 06.08.2013 11:48:24 vasta tsitaadiga
Mafia kirjutas:
kopp.gif If its not COD then its bad
hendrik32
sõnum 06.08.2013 12:24:50 vasta tsitaadiga
Kutsu kirjutas:
Mafia kirjutas:
Nali naljaks, päris ootamatu tulemus.
Plin500
HV piljardihai
Plin500
sõnum 06.08.2013 21:14:18 vasta tsitaadiga
The downside is that the more devastating the splash damage of the weapons, the more likely you are to blow yourself up accidentally, and RotT has no pity for those who would disregard their own safety.
thats the point
As was the custom of shooters of that time, the story doesn’t matter, but opening and closing amateurish comic book-style sequences convey the flimsy excuse for action.
Max Payne, üks parimaid oma aja mänge. Ei olegi vaja illustreeritud lühifilmi.
But if you never played 1994’s RotT, and are thus incapable of wistfully experiencing this slavishly authentic regurgitation through nostalgia-colored glasses, it will probably – and hopefully, for your sake – be one of the worst shooters you’ve ever played
If you have the patience, you’ll dodge spinning-blade traps and uncover bronze, silver, and gold keys to unlock doors and bring you that much closer to the end of each of RotT’s 20 insanely difficult levels.
Autor on ise ka veel noor vast, 90'ndate mängud nõudsidki tiba mõtlemist ja osavust, kust-kuhu minna. Ei olnud punast noolt näitamas suunda ega ühesuunalist koridori.
But that doesn’t make it a good shooter, at least not by modern standards
bingo, modern standards ongi üks ühtne standard, mille tõttu isklikult pole shootereid mänginud suurt peale duke 3d ajast (crysis v.a)
Lame ülevaade, mõned head mõtted on, kuid pea üdini negatiivne. Vist ei makstud raha õigesse auku tõesti icon_lol.gif
Kommentaarid: 78 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 76
sõnum 06.08.2013 21:26:43 vasta tsitaadiga
tegelikult on täiesti õige see savesüsteemi lõik.
kes juba bouncy townist läbi käinud on, oskab ilmselt kaasa rääkida...
Oddly enough, the one old-school feature that didn’t make the cut and would’ve helped enormously with RotT’s often cheap-feeling and outrageously high difficulty level is the ability to save anywhere. Rise of the Triad in 2013 uses a checkpoint-only system (strange for a PC-only shooter) which aggravates further when you factor in how obnoxiously far apart these checkpoints are spaced. Most levels only seem to have three or four, and they're not short levels. Accidentally fall off a ledge because trying to hop up slippery columns at breakneck speed with loosey-goosey jump mechanics is a wee bit treacherous? Maybe getting sent back to the beginning of the level will help with that.
- londiste
DeTHiCa.
DeTHiCa.
sõnum 06.08.2013 21:31:49 vasta tsitaadiga
IGN kirjutaja ragequittis.
save süsteemi kohta võib öelda seda, et kuna mängus on võimalik skoori arendada, oleks quicksave kuritarvitatav, mäng ammenduks kiirelt kuna muutuks liiga lihtsaks jne jne.
Kommentaarid: 144 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 136
sõnum 06.08.2013 21:51:12 vasta tsitaadiga
DeTHiCa., seda on võimalik nii teha, et see skooritamist kohe üldse ei takista. liiga lihtsaks muutumist ei ole nii või naa väga karta õnneks.
- londiste
Mafia
Mafia
sõnum 06.08.2013 21:54:19 vasta tsitaadiga
DeTHiCa. kirjutas:
Selle ja muu tuleviku kohta tegid devid ühe suure postituse: http://www.interceptor-entertainment.com/forum/viewtopic.php?f=151&t=3134
Checkpoint System and Quicksaves
We are big fans of quick saves. Quick saves and a real save system were one of our highest requests internally when we started development, and something I personally pushed hard for.
In early April 2012 we had our first "crunch meetup" where we were going through our vertical slice. During this crunch, one issue struck us - Savegames in modern games are a nightmare - especially in a game like Rise of the Triad.
The short version:
Savegames, require the entire "State" of the game to be saved. That means, scripted events, physics, enemies killed, weapons and ammo held, etc.
Back in the day, all of these elements were extremely simple to account for (Doom, Quake, Halflife etc) and were relatively straight forward to save.
However, in modern and very heavy games, it's very hard to save the state of everything accurately, and then rebuild it all as accurately, once you load a save state.
In fact, The Escapist recently wrote a great article called "Why we have Checkpoints", which explains in detail why almost every modern game is using a checkpoint system instead of a save system these days.
When working on Rise of the Triad, we realized that creating a save system was almost impossible. We had long talks with our engineers and our publisher Apogee. We soon realized we had to come up with a solution and a way to work around the issue. Our solution would turn out to be a mix between traditional FPS checkpoints, and doing a Super Mario like "Overworld" where you can pick and choose your checkpoints to load with any character on any difficulty at any time that you find in ROTT currently.
We know that this is far from an ideal solution for many of you - But with our budget, timeframe and manpower, it was the solution we chose.
What can we do about it?
Early next week, I am having a meeting with our coders about save games.
We are going to sit down, and get a conversation going with our contacts at Epic, to find a viable solution to this. Rise of the Triad is very unique, and it will require a lot of work, but we are fully committed to the future of our game, and are going to put a lot of effort into R&D on save games, for possible future patches.
Bawse
DeTHiCa.
DeTHiCa.
sõnum 06.08.2013 22:18:36 vasta tsitaadiga
londiste kirjutas:
kui saab iga 3 sekundi tagant salvestada, siis kuidas see ei tee mängu lihtsamaks? lisaks, igasugune skoori pidamine muutuks kohe mõttetuks.
sõnum 06.08.2013 22:33:36 vasta tsitaadiga
DeTHiCa., iga save nullib skoori?
või ka mõni veidi leebem variant maybe.
see siis tuleb kohe pähe, neid ideid leiab hulgim.
escapisti artikkel siis see:
http://www.escapistmagazine.com/articles/view/columns/experienced-points/10301-Why-We-Have-Checkpoint-Saves
- londiste
olka
olka
sõnum 06.08.2013 23:34:56 vasta tsitaadiga
IGN-i troll võib tagasi kappi minna icon_biggrin.gif ma ootan seda mängu enivei icon_biggrin.gif
You, all gonna make me loose my mind, loose my mind
sõnum 07.08.2013 01:23:16 vasta tsitaadiga
olka, ootad? see reliisiti mõned päevad tagasi ja hind ei ole midagi hirmsat (eriti gmg -20% soodukaga näiteks)
- londiste
Goon
Goon
sõnum 07.08.2013 12:50:28 vasta tsitaadiga
GT käest sai ka 6.2 punkti 10st. Ma kartsin ka et sinna auku see mäng lähebki icon_lol.gif
DeTHiCa.
DeTHiCa.
sõnum 07.08.2013 13:10:37 vasta tsitaadiga
mängisin esimese surma saamiseni. pole sel mängul häda midagi - täpselt selline nagu reklaamiti. kellele vana ROTT meeldis, peaks uus kah meeldima, sest see on gameplay poolest väga sarnane. graafika on veidi aegunud, aga nii väikeselt stuudiolt pole väga palju mõtet tahtagi. kindlasti mängin läbi ja jään nende duke nukemi varianti ootama. icon_biggrin.gif
-Kaivo-
sõnum 07.08.2013 15:26:21 vasta tsitaadiga
IGN on juma ammu endale vee peale tõmmanud.
Goon
Goon
sõnum 07.08.2013 16:05:50 vasta tsitaadiga
Need tüübid kes selle tegid on ikka valusad tüübid küll. icon_lol.gif Suured Pildid
KurjaJuur
KurjaJuur
sõnum 07.08.2013 16:43:02 vasta tsitaadiga
derp
Goon
Goon
sõnum 07.08.2013 19:25:45 vasta tsitaadiga
-Kaivo-
sõnum 09.08.2013 18:20:55 vasta tsitaadiga
HDTanel
Overclocker
HDTanel
sõnum 11.08.2013 03:50:24 vasta tsitaadiga
Sain ka lõpuks ära proovida, hommikupoole video ka üleval kus katsetan vana mängu enne ja siis seda uut versiooni.
Lühidalt, noo alguses tundub igati lahe ja hea remake aga siis kui mängid natukene algusest edasi.. koheselt torkab silma mõttetu AI ning terve mäng on ikka kole odav icon_sad.gif samas ega hind midagi erilist mängul polegi kuid ikkagi veidi selline letdown. Eks pelan nata rohkem veel aga kui alguses mõtlesin, et IGN ja Gametrailersi vennad on segased siis hakkan vaikselt mõistma ise ka, et tegu pole millegi erilisega siiski.
Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel
siLc
sõnum 11.08.2013 09:34:46 vasta tsitaadiga
Peale 7h mänguaega Medium raskusel olen 4. episoodi jõudnud. Mäng ikka bugine ning tundub, et enamus bugisid keerleb AI ümber - näiteks lased maha mõne võrke pilduva vennikese, vend justkui sureb aga kui lähened talle, tärkab ellu silmapilkselt. Uuesti maha lastes püsib maas...
Kommentaarid: 196 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 185
HDTanel
Overclocker
HDTanel
sõnum 11.08.2013 10:20:50 vasta tsitaadiga
Link
Krüpto
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Rise Of The Triad mine lehele eelmine  1, 2, 3  järgmine
