uus teema   vasta Hinnavaatlus »  Microsoft »  Windows 8 ja 8.1 (arutelu ja probleemid) märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 72, 73, 74 ... 160, 161, 162  järgmine
Clover
Clover
sõnum 19.11.2012 23:50:54 vasta tsitaadiga
d3t kirjutas:
Ma olen tihti küsinud, mis siis on Windows 8'l häda, et ei meeldi. Sain nüüd ühe kodaniku käest asjaliku vastuse, jagan ka teistega, ehk kommenteerite: http://www.useit.com/alertbox/windows-8.html
Peale seda kui ma lugesin tema artiklis:
"One of the worst aspects of Windows 8 for power users is that the product's very name has become a misnomer. "Windows" no longer supports multiple windows on the screen.", sain ma aru, et tegemist järjekordse tohmaniga.
Tema kõige paremad põhjused miks Win8 sucks:
"... .As a further problem, the very command label had misleading information scent for some users; they thought of the Surface as a tablet, not a PC." ..ja Win8 süüdi.
"Despite running on a huge 10.6-inch tablet, Bing Finance shows only a single story (plus 3 stock market quotes) on the initial screen. The Los Angeles Times is not much better: this newspaper app's initial screen is limited to 3 headlines and an advertisement. In fact, they don't even show the lead story's full headline and the summary has room for only 7 words." .. Pasasti tehtud appid on kohe tähendab et Windows8 on süüdi ja halb "As a result of the Surface's incredibly low information density, users are relegated to incessant scrolling to get even a modest overview of the available information."
"When we asked participants to use the other apps, they couldn't find them. This on a new tablet with only a few applications installed." .. Sest kõik ülejäänud tabletid tulevad kohe täieliku app kataloogiga installitud. Ja kuigi suudetakse üles leida mujal AppStore, siis suur Store ikoon on midagi arusaamatut.
"The situation is much worse on regular PCs, particularly for knowledge workers doing productivity tasks in the office. This used to be Microsoft's core audience, and it has now thrown the old customer base under the bus by designing an operating system that removes a powerful PC's benefits in order to work better on smaller devices." .. Jep, sest Windows8 koosneb ainult Metrost "The underlying problem is the idea of recycling a single software UI for two very different classes of hardware devices."
Pmst tüüp kirjutas pika artikli sellest, et "Windows8 sucks for Power users", kuna mingid suvalised tüübid kellele anti esimest korda kätte Surface koos Windows RT'ga ei suutnud Metros isegi appe installida.
Mõned sõnad siin lauses ei taha kokku sobida kuidagi.
heikis
sõnum 20.11.2012 00:14:28 vasta tsitaadiga
ilmateade veidi puusse
-e-
regioon oli vale. siiski huvitav, et Tallinna sidus selliste temperatuuridega.
UrmoZ
UrmoZ
sõnum 20.11.2012 00:15:13 vasta tsitaadiga
Fahrenheit?
Amazon - will not buy!
12VHPWR or 12V2x6 GPU power connector - will not touch.
Müügiteemale PS pakkumisi ei aktsepteeri!
heikis
sõnum 20.11.2012 00:19:12 vasta tsitaadiga
UrmoZ kirjutas:
Fahrenheit?
icon_biggrin.gif õigus.
Draco
Draco
sõnum 20.11.2012 09:24:02 vasta tsitaadiga
MSI AfterBurner 2.3.0 tõi tagasi "GPU MEM Usage" monitoring võimaluse mis kadus algselt Windows 8`ga ära. thumbs_up.gif
Kui kedagi peaks huvitama...
Purgatory Judgement
kasutaja01
kasutaja01
sõnum 21.11.2012 17:35:47 vasta tsitaadiga
Draco kirjutas:
Kui mõtlesid sellega seda OSD gpu mem usage, siis kas see toimib ka või? Olemas nüüd on jah ja isegi mõned sekundid alguses toimivad, aga siis tulevad numbrite asemele "akna" (nagu kandiline 8 ) kujud ja rohkem ei näita midagi.
Chidori
Chidori
sõnum 21.11.2012 18:59:54 vasta tsitaadiga
Panin regiooniks UK ja windows store tuli programme täis ja praktikas kõike saab tõmmata icon_sad.gif suht masendav.
sõnum 21.11.2012 19:08:38 vasta tsitaadiga
heikis kirjutas:
UrmoZ kirjutas:
Fahrenheit?
Mul töötab küll ilusti, Eestist ostetud OEM.
Muidu see pilvede liikumise näitamine ka päris äge. Ennustuse õigust ei tea veel...
Inim
Inim
sõnum 21.11.2012 19:11:04 vasta tsitaadiga
Chidori kirjutas:
Aga kui sa proge alla tõmbad\install ja pärast regiooni tagasi muuda eesti peale kas proge tööle ikka läheb?
kasutaja01
kasutaja01
sõnum 21.11.2012 20:17:11 vasta tsitaadiga
Chidori kirjutas:
See on siit küll juba läbi käinud, aga poes olles võta setingute alt preferences ja lülita välja make it easier to find apps in my preferred language. Pole vaja regiooni muuta. Saad ligi enamus äppidele, aga pole katsetanud, kas mingid spets regiooni appid töötavad ka peale installi.
pwn13
pwn13
sõnum 21.11.2012 20:38:08 vasta tsitaadiga
Tekkis üks probleem, nimelt lasin w7 -le w8 külje alla ja w7 ei ole nõus enam töötama. Nii kui selle valin viskab mingi automatic repair kirja ja pika laadimis kriipsu ette ja küsib millist kasutajat tahad kasutada, lähed sisse ja seal siis see repair menu, automatic ühtegi viga ei leia, manuaalselt pannud bootrex /fixmbr, fixboot, rebuildbcd.
Ehk keegi oskab aidata.
pWn
Osiris
Osiris
sõnum 21.11.2012 20:54:02 vasta tsitaadiga
iFlop kirjutas:
Hetkel ei viitsi üldse teemasse süveneda, aga kas "retail" versiooni Win 8st ei olegi?
Näiteks kui on ise kokku pandud masin, kus windows pole varem jooksnud, siis OEM ega upgrade ju ei sobi?
Huvitas sama küsimus - küsisin Microsoft eestist järgi.
Vastati nii:
Upgrade litsentsid (ka 30? pakkumine läbi http://www.microsoftstore.ie/) järgivad karbitoote (Retail) tingimusi. Sellest tulenevalt on võimalik antud upgrade litsentsi üle tõsta ühest arvutist teise. Ümber tõsta ei saa vaid Windows 8 litsentsi mis on tootja poolt eelnevalt paigaldatud ehk OEM litsentsi.
El-Fuego kirjutas:
Sain siis ka backup dvd-d kätte w8 omad. Üks on 32-bit versioonile ja teine 64-bit versioonile.
Kui ruttu kätte said? Ma kuskil paar nädalat + mõni päev ootan asja.
sõnum 21.11.2012 21:31:35 vasta tsitaadiga
PCman kirjutas:
iFlop kirjutas:
Vastati nii:
El-Fuego kirjutas:
Tegelikult võiks Microsoft Eesti hoopis sellele vastata, et miks kuulub Eesti riikide hulka, kus seda Karbi-Retaili ei müüda. icon_razz1.gif Igatahes Hiina kohta ütles MS otse, et Hiinas ei müüda Karbi-Retaile tänu väga suurele piraatluse-protsendile.
Link on kusagil eespool juba olemas.
Chidori
Chidori
sõnum 21.11.2012 21:34:34 vasta tsitaadiga
Inim, Ok proovisin läbi need mis mul alles olid ja kõik toimisid ka Eesti regiooni all. Eesti regiooni all ja selle kuvamise sättega tõesti näeb enamusi programme, aga kõik pole päris samad. Probleem oli mul nimelt selles, et internetist tõmmates ei saanud ma Eesti regiooni all pooli programme installida - Win Store lihtsalt viskas välja. Ma usun, et ta teeb seda ka praegu osade programmidega.
Muidugi mul võib probleemiks olla ka see, et mul Arvuti regioon Eesti, aga konto mul UK (Xboxi pärast)
tahanteada, Eesti on nüüd limited support country - varem ei ole mingit supporti eestile Pmst. Karbiwindowsi kohta ma kuskilt lugesin, et MS pole veel seda kuskil välja lasknud (ei tea kui uus uudis see oli muidugi)
Endale sain Dreamsparkist 64bit full image.
viimati muutis Chidori 21.11.2012 21:37:13, muudetud 1 kord
Muhekas
Muhekas
sõnum 21.11.2012 21:35:10 vasta tsitaadiga
onni
sõnum 22.11.2012 09:03:06 vasta tsitaadiga
olen juba 3 nädalt kastanud win 8 64pro versiooni ja hakka veidi kohanema.seis 50 -50 win 7 ja win 80 vahel,aga ooteme mida aeg edasi toob icon_biggrin.gif olen veidi positiivne win 8 vastu
LiivaneLord
Sõpradele "Olavi"
sõnum 22.11.2012 09:28:52 vasta tsitaadiga
onni kirjutas:
Draco
Draco
sõnum 22.11.2012 09:40:32 vasta tsitaadiga
kasutaja01 kirjutas:
Draco kirjutas:
Mul näitas gpu mälu kasutamist kogu mängimise ajal...ja hiljem ka.
Sama on FPS`i taha tekkinud mingi ms ühikud, ei ole viitsinud uurida mida see tähendab/annab.
Skyrim`il nagu ikka on gpu mem usage 1900 kandis, 2GB kaart oli ikka hea otsus.
4 päeva veel siis on see 3 kuuline prooviversioon otsas, loodame, et uued arvuti jubinad jõuavad sama aegselt kohale kuhu siis juba originaal w8 peale läheb thumbs_up.gif
draggo
draggo
sõnum 25.11.2012 13:05:19 Windows 8 ei installi uusi programme vasta tsitaadiga
Kui üritan installida uut programmi Windows 8'le siis Windows küll küsib, et kas tahad installida ja ka avab istalli akna aga installima ei hakka.
Keegi teab milles asi?
Nüüd proovisin insatllida Daemon Tools Lighti. See jääb installi juures toppama kohas "Updating Virtual Devices".
kellelgi mõõteid on?
Sleepwalkers - parim ansambel peo pidamiseks
KOMPAKT kontorimööbel
.:MDK:.
.:MDK:.
sõnum 25.11.2012 13:25:59 vasta tsitaadiga
ISO-sid saab Windows 8-s juba defaultis mountida. Parem-klõps ja mount. icon_wink.gif
Experience is gained immediately after it is needed.
UrmoZ
UrmoZ
sõnum 25.11.2012 16:42:15 vasta tsitaadiga
draggo, kui Win8-ga ei saa, siis proovi http://www.slysoft.com/en/virtual-clonedrive.html
Draco
Draco
sõnum 25.11.2012 18:33:32 vasta tsitaadiga
Põhimõtteliselt sai 3 kuuline prooviversioon just läbi, seega saab seda windows 8 veel ühe korra kinni panna ja siis kööga, uus w8 koos uue masinaga jõuab see nädal thumbs_up.gif
Purgatory Judgement
draggo
draggo
sõnum 25.11.2012 20:07:04 vasta tsitaadiga
UrmoZ kirjutas:
Ka see install jääb enne lõppu toppama ja edasi ei lähe.
Sama ka Samsungi updater, mis peaks draiverid ise otsima. See jääb juba alguses toppama.
Peab vist Win7 peale tagasi minema... Kuidas seda teha? Kas uus install nullist?
onni
sõnum 25.11.2012 20:21:43 vasta tsitaadiga
ma olen proovinud win 8 alla laadida ja ütleb,et enam pole saada icon_biggrin.gif .poes maksab 1273 sekki
peacemaki
sõnum 26.11.2012 11:56:46 vasta tsitaadiga
Draco
Draco
sõnum 26.11.2012 12:08:29 vasta tsitaadiga
peacemaki kirjutas:
Milleks sellist asjad vaja oleks?
napoleon
Unknown virus
napoleon
sõnum 26.11.2012 12:31:43 vasta tsitaadiga
Mõnikord võib olla, ei mäleta enam mis asi, aga alles hiljuti nägin ise kui mingi vidin win 7 peal käima lastes teatas, et töötab ainult XP ja uuema peal icon_biggrin.gif
peacemaki
sõnum 26.11.2012 12:38:14 vasta tsitaadiga
Mõned Spets programmid ja ime vidinad, millega tööd tehakse töötavad aint XP all.
painkillah
painkillah
sõnum 26.11.2012 12:43:21 vasta tsitaadiga
Siis on selleks kas eraldi masinad (ala vanakooli masin com pordi ja XPga), virtual machine, või programmiuuendus.
Killerwave
Killerwave
sõnum 26.11.2012 12:47:07 vasta tsitaadiga
painkillah kirjutas:
Ideaalis küll, kahjuks on tegelikkuses asjad pisut teistmoodi erinevate olude, laiskuse, oskamatuse või lihtlabase pohhhuismi tõttu.
Mnator
sõnum 26.11.2012 13:10:51 vasta tsitaadiga
Killerwave kirjutas:
pohhuistide pärst pole sul tarvis südant valutada, võta neist endist eeskuju icon_wink.gif
laisad ja oskamatud saada kooli
erinevad olud --- lähemal analüüsil liigituvad tegelikult 99,99% juhtudel eelnevate alla
painkillah
painkillah
sõnum 26.11.2012 14:05:47 vasta tsitaadiga
Tööalaselt puutun kokku palju eritarkvara ja riistvaraga ning nende kooslustega.
Ja sel puhul ongi sisuliselt kolm lahendust mis ma välja pakkusin. Keegi ei hakka soetama ega mõtlemagi Windows 8/7 t asjale, millele on niivõrd erilised nõudmised.
Mnator
sõnum 26.11.2012 14:20:03 vasta tsitaadiga
Siin banaanivabariigis on tüüpnähtus, et seni on kasutatud piraattarkvara ja nüüd tasapisi kartma hakatud avalikukstulekut ja probleeme. Oma osa veel w8 odavail pakkumistel......
Kusjuures, pole võimatu, et tegelikult isegi oleks võimalik seda "eritarkvara" ka w7/w8 peal käima saada aga selleks peab asja põhjalikult tundma.
napoleon
Unknown virus
napoleon
sõnum 26.11.2012 14:46:32 vasta tsitaadiga
Mnator kirjutas:
Oleneb mis mätta otsast asja vaadata. Kui nemad tahavad kangesti minu käest midagi saada, siis nii on. Kui mina tahaks neile midagi müüa ja neil raha on, siis oleks asjaolud teistsugused ja pakutav tuleks neile võimalikult atraktiivseks muuta.
zahhar2
sõnum 26.11.2012 20:21:43 vasta tsitaadiga
Huvitav, miks ei saa enam ametlikule Vistale Win 8-t peale osta. Eile ja täna õhtul olen proovinud. Ei midagi.
Tuleb kiri: We couldn`t not process your order. Mida teha?
Tulevik algab tunni aja pärast
CoiL
CoiL
sõnum 26.11.2012 20:58:39 vasta tsitaadiga
Link
Peale selle video vaatamist ja ennast puruks naermist ei taha küll windows 8-t näha! W7 on legend nagu XP oli ja punkt!.
onni
sõnum 26.11.2012 22:41:01 vasta tsitaadiga
samad sönad icon_biggrin.gif .pakub ju insatlli faili ja siis ei saa alla laadida 249 sekki oleks maksnud win 8 pro 64bit rootsi oma,aga nüüd jokk icon_biggrin.gif .
Chidori
Chidori
sõnum 26.11.2012 22:55:11 vasta tsitaadiga
CoiL, need näitavad videot kuidas nad esimest korda panid asja tööle - peale üht päeva kasutamist ei tee sa niipalju jura kui need seal suust välja ajavad.
Granted - tal on probleeme ja ta ei tööta samamoodi nagu win7 ja metro dashi põhivärgina ei tahaks icon_smile.gif Õnneks dualscreenis on Desktop koguaeg active
pois11
sõnum 26.11.2012 23:07:04 vasta tsitaadiga
Ma just ostsin 30€ eest ühe win8 pro litsentsi. Tegi kõik nii nagu vaja ja sai osta küll.
sõnum 26.11.2012 23:07:44 vasta tsitaadiga
Mõttetu virin, ise kasutan seda tööl ja hetkel mulje, et viin 2013 ka teised arvutid sellele üle. Harjumatu jah, aga areng toimub õiges suunas.
CoiL
CoiL
sõnum 27.11.2012 00:25:36 vasta tsitaadiga
No ei tea kas ikka mõttetu virin. Kasutajamugavus hiirega kasutamisel on küll täielik porr ja seda ka paljude teiste W8't tutvustavate videote põhjal. Saan aru, et tutskriiniga vb. tõesti asjalik aga muidu see metro ikka täielikult mõttetu jura imho ja no krt, jätnud siis vähemalt tavalise start menüü alles deskile. W7-e kasutajana ei näe hetkel ühtegi asja mis paneks mind W8-t ostma icon_neutral.gif 100X ennem panen Ubuntu 12.04 LTS'i tasuta peale kui maksan selle käki eest.
WäntWõll
make.believe
WäntWõll
sõnum 27.11.2012 00:36:21 vasta tsitaadiga
KIndlasti mitte, jube hapu saast.
Pigem mingi Mint diostro aga 8 laseb neile pikalt peale, ning 7 põletab asjad üldse happega üle icon_idea.gif
Selle unixi jural ei ole mingit võrdlus momenti tõelise OS-iga seega jätame selle *unix vs Win teemasse.
Asja juures pole see mitte vähe oluline, et töölkäiva inimese jaoks 15€ või 30€ sõltuvalt skeemist on lumma lasta, vähemalt 10a tasuta klienditoe eest.
oliver.
sõnum 27.11.2012 00:54:38 vasta tsitaadiga
Olles nädalajagu win8 kasutaja olnud, siis mis seal ikka pikalt kosta. Metro-kuvale mul asja pole, desktop-režiimis on vast isegi asjalikum kui win7 seni oli.
Start-menüü sain endale Pokki-nimelise tootja poolt: https://www.pokki.com/windows-8-start-menu
Intel 330-seeria 120gb SSD sai upgreidi jaoks sisse muretsetud, väga muretu ja kiire kasutus hetkel.
Kuna mul oli arvutikastil XP-kleebis, siis läks käiku upgrade-versioon. Küll aga tuli välja, et clean install on seejuures võimatu - ei lase ära registreerida.
Tuli seega proovida XP install enne läbi teha, mis aga paari eri plaadiga errorit viskas. Nii et tuli installida pira-win7, millelt omakorda upgrade ametliku
win8 peale. Veidi frustreeriv, aga vähemalt toimis.
zahhar2
sõnum 27.11.2012 01:07:51 vasta tsitaadiga
Proovisin uuesti, et äkki saab nüüd osta, aga ei, samamoodi kõik.
Chidori
Chidori
sõnum 27.11.2012 01:31:59 vasta tsitaadiga
Eriti mulle meeldib see, et touch ja cursor selles erinevad asjad - see tähendab, et kui mul cursor ühel ekraanil ja teisel ekraanil taon näpuga, siis cursor jääb sinna kus ta varem oli kui hiirt liigutan - kahjuks küll korraga nad ei tööta icon_sad.gif
*Metro dashil - desktopil kasutades näppu tõmbab cursori kah sinna.
CoiL
CoiL
sõnum 27.11.2012 12:22:36 vasta tsitaadiga
WäntWõll kirjutas:
Vabandust veel natukese OT eest aga ei viitsi teise teemasse kaklema minna. Mitte et ma mingi ubuntsi kummardaja oleks, aga olen 4-5 kuud LTS`i kasutanud ja ei näe küll mitte kuskilt otsast, et hapu oleks icon_rolleyes.gif Mint muidugi veel parem aga kui mul oleks valid uus arvuti kas W8 või Ubuntsiga, siis võtaks iga kell viimase, sest kasutajamugavus on kordades üle ja alternatiivsed tarkvarad nagu nt. Libreoffice, GIMP ja Draftsight olemas .Ning LTS`i ametlik tugi 5a millest on küllaga. Ei tahtnudki tegelikult hinna üle vaielda vaid tõesti, kasutajamugavus W8-l on küll nagu näpuga p*rset pühkida. Ei räägi harjumisest vaid konkreetselt kasutajamugavusest. mõttetud liigsed klikid jne. Out of the box on W7 ja Ubuntu 12.04 LTS raudselt kasutajale mugavamad, loogilisemad ja efektiivsemad töö tegemiseks. Punkt!
sakinaga
sõnum 27.11.2012 12:30:53 vasta tsitaadiga
Linux vs Windows teema on võitlustandris, arutaks siin ikka Windows 8 teemadel.
Rõõmustav näha et päris palju uusi ja häid aplikatsioone on Store'i lisandunud (skyscanner meeldib eriti).
WäntWõll
make.believe
WäntWõll
sõnum 27.11.2012 15:10:28 vasta tsitaadiga
kellelgi emakeel ka peal on ? Mul lendas just virtuaal laiali keele paki paigaldamisel, siis palun öelge mis moodi on tõlgitud "devices and printers"
Kui viitsib siis võiks panna ka selle info mis sinna tuleb hiirega peal hoverdades.
d3t
d3t
sõnum 27.11.2012 15:30:22 vasta tsitaadiga
WäntWõll, "Seadmed ja printerid"
IsAiUseful.com - tee oma esimesed sammud kohaliku AI suunas
WäntWõll
make.believe
WäntWõll
sõnum 27.11.2012 15:33:21 vasta tsitaadiga
seda ma aravsin, lihtsalt tekkis kahtlus aga äkki on mingi vemp sees icon_lol.gif
uus teema   vasta Hinnavaatlus »  Microsoft »  Windows 8 ja 8.1 (arutelu ja probleemid) mine lehele eelmine  1, 2, 3 ... 72, 73, 74 ... 160, 161, 162  järgmine
