Clover
19.11.2012 23:50:54
Peale seda kui ma lugesin tema artiklis:
"One of the worst aspects of Windows 8 for power users is that the product's very name has become a misnomer. "Windows" no longer supports multiple windows on the screen.", sain ma aru, et tegemist järjekordse tohmaniga.
Tema kõige paremad põhjused miks Win8 sucks:
"... .As a further problem, the very command label had misleading information scent for some users; they thought of the Surface as a tablet, not a PC." ..ja Win8 süüdi.
"Despite running on a huge 10.6-inch tablet, Bing Finance shows only a single story (plus 3 stock market quotes) on the initial screen. The Los Angeles Times is not much better: this newspaper app's initial screen is limited to 3 headlines and an advertisement. In fact, they don't even show the lead story's full headline and the summary has room for only 7 words." .. Pasasti tehtud appid on kohe tähendab et Windows8 on süüdi ja halb "As a result of the Surface's incredibly low information density, users are relegated to incessant scrolling to get even a modest overview of the available information."
"When we asked participants to use the other apps, they couldn't find them. This on a new tablet with only a few applications installed." .. Sest kõik ülejäänud tabletid tulevad kohe täieliku app kataloogiga installitud. Ja kuigi suudetakse üles leida mujal AppStore, siis suur Store ikoon on midagi arusaamatut.
"The situation is much worse on regular PCs, particularly for knowledge workers doing productivity tasks in the office. This used to be Microsoft's core audience, and it has now thrown the old customer base under the bus by designing an operating system that removes a powerful PC's benefits in order to work better on smaller devices." .. Jep, sest Windows8 koosneb ainult Metrost "The underlying problem is the idea of recycling a single software UI for two very different classes of hardware devices."
Pmst tüüp kirjutas pika artikli sellest, et "Windows8 sucks for Power users", kuna mingid suvalised tüübid kellele anti esimest korda kätte Surface koos Windows RT'ga ei suutnud Metros isegi appe installida.
Mõned sõnad siin lauses ei taha kokku sobida kuidagi.
heikis
20.11.2012 00:14:28
ilmateade veidi puusse
-e-
regioon oli vale. siiski huvitav, et Tallinna sidus selliste temperatuuridega.
UrmoZ
20.11.2012 00:15:13
Fahrenheit?
_________________ Amazon - will not buy! |
heikis
20.11.2012 00:19:12
UrmoZ kirjutas: |
Fahrenheit? |
õigus.
Draco
20.11.2012 09:24:02
MSI AfterBurner 2.3.0 tõi tagasi "GPU MEM Usage" monitoring võimaluse mis kadus algselt Windows 8`ga ära.
Kui kedagi peaks huvitama...
_________________ Purgatory Judgement |
kasutaja01
21.11.2012 17:35:47
Draco kirjutas: |
Kui kedagi peaks huvitama... |
Kui mõtlesid sellega seda OSD gpu mem usage, siis kas see toimib ka või? Olemas nüüd on jah ja isegi mõned sekundid alguses toimivad, aga siis tulevad numbrite asemele "akna" (nagu kandiline 8 ) kujud ja rohkem ei näita midagi.
Chidori
21.11.2012 18:59:54
Panin regiooniks UK ja windows store tuli programme täis ja praktikas kõike saab tõmmata suht masendav.
21.11.2012 19:08:38
heikis kirjutas: |
UrmoZ kirjutas: |
Fahrenheit? |
õigus. |
Mul töötab küll ilusti, Eestist ostetud OEM.
Muidu see pilvede liikumise näitamine ka päris äge. Ennustuse õigust ei tea veel...
Inim
21.11.2012 19:11:04
Chidori kirjutas: |
Panin regiooniks UK ja windows store tuli programme täis ja praktikas kõike saab tõmmata suht masendav. |
Aga kui sa proge alla tõmbad\install ja pärast regiooni tagasi muuda eesti peale kas proge tööle ikka läheb?
kasutaja01
21.11.2012 20:17:11
Chidori kirjutas: |
See on siit küll juba läbi käinud, aga poes olles võta setingute alt preferences ja lülita välja make it easier to find apps in my preferred language. Pole vaja regiooni muuta. Saad ligi enamus äppidele, aga pole katsetanud, kas mingid spets regiooni appid töötavad ka peale installi.
pwn13
21.11.2012 20:38:08
Tekkis üks probleem, nimelt lasin w7 -le w8 külje alla ja w7 ei ole nõus enam töötama. Nii kui selle valin viskab mingi automatic repair kirja ja pika laadimis kriipsu ette ja küsib millist kasutajat tahad kasutada, lähed sisse ja seal siis see repair menu, automatic ühtegi viga ei leia, manuaalselt pannud bootrex /fixmbr, fixboot, rebuildbcd.
Ehk keegi oskab aidata.
_________________ pWn |
Osiris
21.11.2012 20:54:02
iFlop kirjutas: |
Hetkel ei viitsi üldse teemasse süveneda, aga kas "retail" versiooni Win 8st ei olegi?
Näiteks kui on ise kokku pandud masin, kus windows pole varem jooksnud, siis OEM ega upgrade ju ei sobi? |
Huvitas sama küsimus - küsisin Microsoft eestist järgi.
Vastati nii:
tsitaat: |
Upgrade litsentsid (ka 30? pakkumine läbi http://www.microsoftstore.ie/) järgivad karbitoote (Retail) tingimusi. Sellest tulenevalt on võimalik antud upgrade litsentsi üle tõsta ühest arvutist teise. Ümber tõsta ei saa vaid Windows 8 litsentsi mis on tootja poolt eelnevalt paigaldatud ehk OEM litsentsi.
El-Fuego kirjutas: |
Sain siis ka backup dvd-d kätte w8 omad. Üks on 32-bit versioonile ja teine 64-bit versioonile. |
Kui ruttu kätte said? Ma kuskil paar nädalat + mõni päev ootan asja.
21.11.2012 21:31:35
PCman kirjutas: |
iFlop kirjutas: |
Vastati nii:
tsitaat: |
Kui ruttu kätte said? Ma kuskil paar nädalat + mõni päev ootan asja. |
Tegelikult võiks Microsoft Eesti hoopis sellele vastata, et miks kuulub Eesti riikide hulka, kus seda Karbi-Retaili ei müüda. Igatahes Hiina kohta ütles MS otse, et Hiinas ei müüda Karbi-Retaile tänu väga suurele piraatluse-protsendile.
Link on kusagil eespool juba olemas.
Chidori
21.11.2012 21:34:34
Inim, Ok proovisin läbi need mis mul alles olid ja kõik toimisid ka Eesti regiooni all. Eesti regiooni all ja selle kuvamise sättega tõesti näeb enamusi programme, aga kõik pole päris samad. Probleem oli mul nimelt selles, et internetist tõmmates ei saanud ma Eesti regiooni all pooli programme installida - Win Store lihtsalt viskas välja. Ma usun, et ta teeb seda ka praegu osade programmidega.
Muidugi mul võib probleemiks olla ka see, et mul Arvuti regioon Eesti, aga konto mul UK (Xboxi pärast)
tahanteada, Eesti on nüüd limited support country - varem ei ole mingit supporti eestile Pmst. Karbiwindowsi kohta ma kuskilt lugesin, et MS pole veel seda kuskil välja lasknud (ei tea kui uus uudis see oli muidugi)
Endale sain Dreamsparkist 64bit full image.
viimati muutis Chidori 21.11.2012 21:37:13, muudetud 1 kord |
Muhekas
21.11.2012 21:35:10
PCman kirjutas: |
iFlop kirjutas: |
Vastati nii:
tsitaat: |
Nädalat 2 vist tuli kui ma ei eksi
_________________ #Olen küberkiusamise vastu! |
onni
22.11.2012 09:03:06
olen juba 3 nädalt kastanud win 8 64pro versiooni ja hakka veidi kohanema.seis 50 -50 win 7 ja win 80 vahel,aga ooteme mida aeg edasi toob olen veidi positiivne win 8 vastu
LiivaneLord
Sõpradele "Olavi"
22.11.2012 09:28:52
onni kirjutas: |
olen juba 3 nädalt kastanud win 8 64pro versiooni ja hakka veidi kohanema.seis 50 -50 win 7 ja win 80 vahel,aga ooteme mida aeg edasi toob olen veidi positiivne win 8 vastu |
Kogu su tekst on kohutavalt vastuoluline.
Draco
22.11.2012 09:40:32
kasutaja01 kirjutas: |
Draco kirjutas: |
Kui mõtlesid sellega seda OSD gpu mem usage, siis kas see toimib ka või? Olemas nüüd on jah ja isegi mõned sekundid alguses toimivad, aga siis tulevad numbrite asemele "akna" (nagu kandiline 8 ) kujud ja rohkem ei näita midagi. |
Mul näitas gpu mälu kasutamist kogu mängimise ajal...ja hiljem ka.
Sama on FPS`i taha tekkinud mingi ms ühikud, ei ole viitsinud uurida mida see tähendab/annab.
Skyrim`il nagu ikka on gpu mem usage 1900 kandis, 2GB kaart oli ikka hea otsus.
4 päeva veel siis on see 3 kuuline prooviversioon otsas, loodame, et uued arvuti jubinad jõuavad sama aegselt kohale kuhu siis juba originaal w8 peale läheb
draggo
25.11.2012 13:05:19
Windows 8 ei installi uusi programme |
Kui üritan installida uut programmi Windows 8'le siis Windows küll küsib, et kas tahad installida ja ka avab istalli akna aga installima ei hakka.
Keegi teab milles asi?
Nüüd proovisin insatllida Daemon Tools Lighti. See jääb installi juures toppama kohas "Updating Virtual Devices".
kellelgi mõõteid on?
_________________ Sleepwalkers - parim ansambel peo pidamiseks
KOMPAKT kontorimööbel |
.:MDK:.
25.11.2012 13:25:59
ISO-sid saab Windows 8-s juba defaultis mountida. Parem-klõps ja mount.
_________________ Experience is gained immediately after it is needed. |
UrmoZ
Draco
25.11.2012 18:33:32
Põhimõtteliselt sai 3 kuuline prooviversioon just läbi, seega saab seda windows 8 veel ühe korra kinni panna ja siis kööga, uus w8 koos uue masinaga jõuab see nädal
draggo
25.11.2012 20:07:04
Ka see install jääb enne lõppu toppama ja edasi ei lähe.
Sama ka Samsungi updater, mis peaks draiverid ise otsima. See jääb juba alguses toppama.
Peab vist Win7 peale tagasi minema... Kuidas seda teha? Kas uus install nullist?
onni
25.11.2012 20:21:43
ma olen proovinud win 8 alla laadida ja ütleb,et enam pole saada .poes maksab 1273 sekki
peacemaki
26.11.2012 11:56:46
Windows 8 Pro OEMil ei saagi Windows XP peale downgradida.
