21.11.2012 08:48:51
Eizolt 4K x 2K monitor |
Jaapani monitoride tootja Eizo toob turule oma esimese 4096 x 2160 (4K x 2K) resolutsiooni toetava monitori DuraVision FDH3601.
Tehnilised andmed:
36.4" (92 cm) LCD Monitor
8.8 megapixels 4096 x 2160 native resolution
Display Colors 1.07 billion from a palette of 278 trillion (maximum)
Viewing Angles (H / V, typical) 176°, 176°
Brightness (typical) 700 cd/m2
Contrast Ratio (typical) 1000:1
Response Time (typical) 8 ms (Gray-to-gray)
DVI-D 24 pin x 2, DisplayPort x 2
Koduleht: http://www.eizo.com/global/products/duravision/fdh3601/index.html
Orienteeruv hind: ca 35 000 dollarit
_________________ HV-s ID-kaardiga autentimine
HV valuutakursid |
7 :: |
360 |
DVDRW
21.11.2012 08:59:45
DP ja DVI ei toeta nii kõrget resot.
Spets draiver + tarkvara ja Windows näeb 4-ja monitori?
| Kommentaarid: 28 loe/lisa |
21.11.2012 09:02:35
| As of January 2012, the latest HD 7000 series graphics cards - along with a dual-link DVI connector and a HDMI connector - feature the ability to have two Mini DisplayPorts 1.2, allowing daisy-chaining up to six monitors, up to 4096x2160 (4K resolution) or 2560x1600p60 Stereoscopic 3D per display and high bit-rate audio from the same connector, optionally behaving like a single large display. A DisplayPort hub containing three dual-link DVI connectors is also available. |
Allikas: http://en.wikipedia.org/wiki/DisplayPort#ATI.2FAMD
HV valuutakursid |
7 :: |
360 |
.:MDK:.
21.11.2012 09:06:58
Nad võiksid selle punktitiheduse 24" monitorile juba ära mahutada.
_________________ Experience is gained immediately after it is needed. |
96 |
DVDRW
21.11.2012 09:19:16
| Jep, tehnoloogiliselt on pregu võimalik 24" sisse mahutada ~6656x4096 reso kui nende Retina ekraanide järgi arvutada.
21.11.2012 09:23:32
| DVDRW kirjutas: |
| Jep, tehnoloogiliselt on pregu võimalik 24" sisse mahutada ~6656x4096 reso kui nende Retina ekraanide järgi arvutada. |
Arvutamine arvutamiseks, aga mis te arvate, palju selliste ekraanide tootmine maksab (kui see teoreetiliselt võimalik)?
Isegi OLED ekraane tootis Sony vaid 15 või 16" maksimaalselt, suuremaid polnud lihtsalt võimalik mõistliku ressursikuluga toota.
HV valuutakursid |
7 :: |
360 |
peacemaki
21.11.2012 09:24:14
| Hind on küll soodne.
| Kommentaarid: 11 loe/lisa |
Hazar
21.11.2012 10:35:29
| need müügil olnud juba tubli pool aastat
| Kommentaarid: 29 loe/lisa |
28 |
SurfData
| Kommentaarid: 84 loe/lisa |
74 |
ihvike
21.11.2012 12:20:04
Tõenäoliselt ei oleks mingi mure toota taolist monitori ka 10 korda odavama müügihinnaga. EIZO on selline firma, kelle high end tooted on eriti täpselt turunišši suunatud - sellisesse, kus 35 kilotaala on lihtsalt mingi number, mis ei puutu eriti teemasse, peaasi, et töö saab hästi tehtud. Raha küsitakse nii palju kui koosolekul kõige vihasem mees küsida julges.
Seda juttu, et 2560x1600 vs 4096x2160 on nüüd mingi eriti hirmus hinna- ja tootmishüpe, ma ei osta. Pole isegi kahekordne pikslite arv horisontaal- ja vertikaalsuunas.
Meeldetuletuseks veel see http://en.wikipedia.org/wiki/IBM_T220/T221_LCD_monitors
Maksis uuena vähem kui see Eizo.
| Kommentaarid: 12 loe/lisa |
12 |
noxton
21.11.2012 12:38:15
pekki, selliseid peaks 3 tk tellima ja siis bf3 mängima
169 |
Killerwave
21.11.2012 13:21:39
| noxton kirjutas: |
pekki, selliseid peaks 3 tk tellima ja siis bf3 mängima  |
Mis videokaardimassiiviga
TÄnapäevaste monitoride reso on naeruväärne võrreldes nutifonide omaga, veider et arengut pole väga selles vallas toimunud, oskab keegi ehk valgust heita sellele tumedale probleemile. Samas kohe tekib küsimus et misGPU seda välja veab kui mängida ka veel tahad. Et native resoga mängida pead tippkaardi tri-slisse lükkama...
31 |
noxton
169 |
NATAS999
21.11.2012 13:32:32
miks mitte siis juba 4x gtx690?
mis see pixel pitch võiks olla sellisel monitoril ma ise arvutada ei oska? tundub suht masendav, midagi 26"1920x1200 kanti umbes.
| Kommentaarid: 41 loe/lisa |
39 |
Hazar
28 |
DVDRW
21.11.2012 14:29:50
Huvitav kuda siis FULLHD nutitelefonil mängud sujuvalt jooksevad, sees gtx590 sarnane videokaart?
Killerwave
21.11.2012 14:36:36
| DVDRW kirjutas: |
Huvitav kuda siis FULLHD nutitelefonil mängud sujuvalt jooksevad, sees gtx590 sarnane videokaart?  |
See graafika seal on aastast 65 ka
31 |
SurfData
21.11.2012 14:47:59
| Killerwave kirjutas: |
| DVDRW kirjutas: |
See graafika seal on aastast 65 ka  |
vaata mõnda kaasaegset mängu ja graafika on ikka selline prillikivi et vähe pole
74 |
Killerwave
21.11.2012 14:51:31
| SurfData kirjutas: |
| DVDRW kirjutas: |
vaata mõnda kaasaegset mängu ja graafika on ikka selline prillikivi et vähe pole  |
Selle pisikese ekraani pealt tundub ainult, või tahate öelda et see on tasemel tänapäevaste PC omadega....
Või hoopis salajane vandenõu videokaartide võimsuse tagasihoidmise kohta, müüme kallilt "aeglasi kaarte" ja koorime klotsi kokku pingutamata tootearendusega, ala 20ks + aastaks on juba ette toodetud trehnoloogiad ja pole mõtet liialt kiirelt turule tuua suurema tihedusega ekraane ja võimsaid gpusid aga nutifonidesse paneme, igaks juhuks.
31 |
smurfer
21.11.2012 15:01:46
| DVDRW kirjutas: |
Lükka HDMI'ga FHD teleka taha ja telekal pildiparandused maha, siis tuleb õige prillikivi välja.
| Kommentaarid: 351 loe/lisa |
299 |
21.11.2012 15:02:48
Eks video areneb siva järgi. Vastasel juhul, mida on teha plaanitavate 8K telerite ja monitoridega.
Mis aga Eizo-sse puutub, siis tema sihtgrupp on peamiselt disainerid.
Postitatud Sony Ericsson mobiililt
211 |
sant
21.11.2012 20:01:30
Killerwave, Mõnes mõttes on sul õigus, aga videokaardid pole probleemiks, hoopis monitorid on probleemiks. Ma mängisin juba Q2 ja half 1 ajal 1600*1200 resoga Delli monitoril. Koduarvuti videokaardid on vägevalt edasi arenenud sellest ajast, monitorid mitte. Samas see Delli monitor sony trinitron kineskoobiga maksis üle 10 kilo sel ajal
Vaevalt et praegugi ostetaks uuele arvutile arvuti hinna eest veel monitor juurde.
_________________ So, at the end of the day, after I have butchered all the nvidiots all around me, standing alone in a pool of blood surrounded by the corpses of my victims, a horrible truth reveals itself to me: I am an amd\ati fänboy...and I must do my dark masters bidding, for I am damned for all eternity... |
| Kommentaarid: 67 loe/lisa |
60 |
Killerwave
22.11.2012 08:45:57
| sant kirjutas: |
Vaevalt et praegugi ostetaks uuele arvutile arvuti hinna eest veel monitor juurde. |
Samas mis imelooma BF3 või mõni analoogne tänapäeva mäng tahab enda jooksutamiseks 3k+ resol Suht proportsionaalselt jääb asi hetkel toppama. Ulme hinnaga übermonitoridele( mida vai käputäis) leiab ka võimalusel pilti tootma tänased tipud võileivana ja siis on ka uusimad mängud ehk mängitavad max pildiiluga Selline mulje jäänud vähemasti.
31 |
Jaan
22.11.2012 11:28:09
| DVDRW kirjutas: |
Spets draiver + tarkvara ja Windows näeb 4-ja monitori? |
Ei ole vaja mingit spets asju.
DP 1.2 toetab 4K x 2K 60FPS videot
HDMI 1.4 toetab 4K x 2K 24FPS videot
2x Dual-Link DVI suudab samuti 4K video edastamisega hakkama saada.
Nvidia/AMD/Intel uuemad videokaardid/draiverid toetavad kõik 4K videot.
8K on veel probleem, see vajab tõesti erilahendusi, a-la 8xHDMI kokkuliitmist vms.
123 |
DVDRW
22.11.2012 12:10:20
| Selge, Wikipeedias vale inf siis.
