uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  AMD Volcanic Islands aka R-200 seeria videokaardid märgi kõik teemad loetuks
mine lehele 1, 2, 3 ... 124, 125, 126  järgmine
Optimist
Optimist
sõnum 09.07.2012 19:53:07 AMD Volcanic Islands aka R-200 seeria videokaardid vasta tsitaadiga
Esimesed kõlakad on siis väljas: http://news.softpedia.com/news/AMD-s-Radeon-8000-Sea-Islands-40-Faster-than-Tahiti-2-278751.shtml
Fabless GPU and CPU designer, American company AMD is getting ready to launch its newest and most powerful GPU architecture this winter. The new GPU series will bear the codename “Sea Islands,” while the products will be branded Radeon 8000 Series.
Not much is known about the new architecture, but rumors say that the new GPU will have 5.1 billion transistors and will be built in TSMC’s well-known and popular 28nm manufacturing technology.
Considering the fact that the current GCN top-performing GPU has 4.3 billion transistors, a relatively small 18% increase in transistor count would be rather impressive if it yields a 40% performance improvement.
The number of transistors can’t increase too much, especially since the GPU is still made using 28nm bulk wafers and at roughly 410 millimeter die size, the Venus GPU is already big enough.
The internal configuration of the architecture is supposed to be comprised of 2560 stream processors, 160 texture units (TMUs), 32 or 48 ROP units (ROPs) and the same 384-bit memory bus.
AMD’s new flagship is likely to maintain the GHz-like frequencies that are usually achieved by the current GCN processors.
Not moving to a smaller manufacturing process does not mean that AMD will end up with a hot chip. In fact, six months from now, TSMC’s 28nm manufacturing process will basically be more than 1 year old and will yield even better results.
On the other hand, AMD will do its best to achieve a lower current leakage and, overall, a more efficient architecture.
viimati muutis Optimist 25.09.2013 19:32:49, muudetud 2 korda
Kommentaarid: 10 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 8
1dumbpcuser
sõnum 09.07.2012 20:12:15 vasta tsitaadiga
3D Center prognoosid:
http://www.3dcenter.org/news/eine-erste-prognose-zu-sea-islands-aka-amds-radeon-hd-8000-serie
______________________________
http://wccftech.com/amd-sea-island-tenerife-gpu-leaked-features-enhanced-gcn-architecture-450-tflops-raw-processing-power/
http://www.cpu-world.com/news_2012/2012061601_A_First_Look_at_AMD_s_Radeon_HD8000_Series.html
AMD's latest beta graphics drivers revealed a few new device IDs, including four Kaveri and five Kabini graphics solutions for the next generation APUs. There are also a number of IDs for what looks like the next generation of Sea Islands GPUs, code-named Mars (9 models), Oland (3 models) and Venus (4 models).
According to predictions at 3DCenter (Google translation), Venus will be used for high-end GPUs, and it is expected to have around 5.1 billion transistors in a 410mm2 die, using 28nm technology. There could be between 2 and 4 raster engines with 2560 cores, approximately 160 TMUs and 32 or 48 ROPs, and there is likely to be a 384-bit memory interface. The most powerful single-GPU card could be the Radeon HD 8970, with a 30-40% performance boost over current generation of cards.
Oland is expected to be the name given to graphics cards filling the performance sector. With an anticipated 3.2 billion transistors on a 230mm2 die, this is another 28nm product. It is likely to have 2 raster engines, 96 TMUs and 32 ROPs. The full die will likely have 1536 cores and a 256-bit memory interface. The most powerful Oland based card will be the Radeon HD 8870, with a performance increase of around 20% compared to it's current generation of counterparts.
Finally, the mainstream cards will use the Mars core, the last 28nm GPU for the 2013 generation of graphics cards, with an expected 1.7 - 2.0 billion transistors in a 135 - 160mm2 die. There will be 1 raster engine, 40-48 TMUs and 16 ROPs. The core count for the full die is around 768 or 896, with a 128-bit or 192-bit memory interface. The best solution provided by this core will be the Radeon HD 8770, with an expected performance boost of 35% over current generation of mainstream GPUs.
It should be noted that most of the information in this article comes from predictions made by 3DCenter.org, and should not be considered as final information at this stage. We will update this as soon as more information is available.
__________________________________
Uued mudelid Beta draiveris:
M:
Kommentaarid: 101 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 96
Kristoferr
Kristoferr
sõnum 09.07.2012 20:31:33 vasta tsitaadiga
See Tenerife slaid ilmus juba enne GTX680 launchi või siis vahetult peale seda. Ma ei võtaks seda isegi "lekkena" vaid kellegi fantaasiana. Muide praegune GHz edition 7970 on juba +20% juures üle reference 7970.
Kuulduste kohaselt siis uuel lipulaeval 25% jagu rohkem shadereid. Võiks loota kuni 25% paremust võrdväärse kella juures. Mälu ribalaius sama, aga ehk kompenseeritakse seda takti tõstmisega.
Kommentaarid: 264 loe/lisa Kasutajad arvavad:  :: 4 :: 0 :: 215
prtv
sõnum 11.07.2012 18:51:54 vasta tsitaadiga
Järjekordne spekulatsiooni teema, minugipoolest.
sõnum 14.07.2012 06:17:16 vasta tsitaadiga
aap14
aap14
sõnum 14.07.2012 10:43:10 vasta tsitaadiga
Slow is smooth and smooth is fast
hendrik32
sõnum 14.07.2012 13:13:16 vasta tsitaadiga
Jälgin!
Asgate
sõnum 14.07.2012 13:45:45 vasta tsitaadiga
Kui praegu on hd7k seeria GPU-d 28nm-ga ning hd8k pasistab sama tootmisprotessi kasutama, siis millal järgmist chipi kahanemist võiks oodata ja mis number see oleks?
Intelil oli siin uudis et 10, 7, 5nm alates 2015-st aastast siis kuidas AMD ja Nvidia GPU-dega on?
Kommentaarid: 16 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 13
sõnum 14.07.2012 14:51:57 vasta tsitaadiga
Asgate, Arvatavasti 20nm +/- 2 ja seda kuskil 2014 siis. Ei usu, et kohe alla 20nm hüpatakse, sest iga samm on järjest raskem mida väiksemaks tootmisprotsess läheb. Kuigi mine sa tea. Kui suudetakse jälle teha 12nm samm, siis näeme 16nm kiipe 2014 aasta lõpus.
90 --> 65 = -25
65 --> 40 = -25
40 --> 28 = -12
28 --> ??
Win11 25H2 upgrade skriptid neile kelle masin ise ei taha 23H2 või 24H2 pealt ennast uuendada:
sõnum 14.07.2012 14:57:44 vasta tsitaadiga
Ma miskipärast arvan, et järgmine samm oleks 22nm, kuna see on juba küps ja prosed juba tootmises.
Vaata kasutaja äripakkumisi
M: NVMe SSD Samsung 970 Evo Plus 500GB 3440
M: 8TB HDD WD Red Plus 2109
Kommentaarid: 234 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 196
sõnum 15.07.2012 06:06:03 vasta tsitaadiga
Prosede ja videokaartide tootmised on siiski erinevad ma kardan. Prosesid teeb Intel oma tehastes (pole uurinud kus see AMD oma vahvleid küpsetab - vist GlobalFoundries-s), aga videokaardid tehakse enamuses TSMC-s.
Alguses olid ka prosed 90nm aga 4xnm peal läks asi erinevaks:
90 --> 65 = -25
65 --> 45 = -20
45 --> 32 = -13
32 --> 22 = -10
22 --> 15 = -7
15 --> 10 = -5
10 --> 7 = -3
7 --> ?
Prosede shrinkid toimuvad tihedamini aga väiksemate sammudena ja on aeglustumas. 15/10/7 on tulevased Inteli tootmisprotsessid siis. Muidugi kõik see kena OT siin teemas icon_biggrin.gif
abimees0
abimees0
sõnum 15.07.2012 07:22:47 vasta tsitaadiga
Jälgin.
s4nder
sõnum 15.07.2012 10:35:14 vasta tsitaadiga
Absoluutväärtustes asi muidugi aeglustub, aga suhtarvudena püsib areng konstantsena, iga uus shrink on eelmisest ~30% väiksem.
90 --> 65 = -28%
65 --> 45 = -31%
45 --> 32 = -29%
32 --> 22 = -31%
22 --> 15 = -32%
15 --> 10 = -33%
10 --> 7 = -30%
7 --> ?
1dumbpcuser
sõnum 15.07.2012 11:23:38 vasta tsitaadiga
Inteli järgmine tehnoloogia on 14nm (mitte 15) ja seejärel 10nm, vähemalt Wiki andmetel http://en.wikipedia.org/wiki/Haswell_(microarchitecture)
M:
Wiltz
sõnum 18.07.2012 08:30:37 vasta tsitaadiga
nagunii mingi äärmiselt küsitava väärtusega info ilmselt, mis siin selle uue "worlds fastest gpu" kohta, aga asi on ikka suht mõttetuks läind küll kui kuskil 30% lisajõudlust saad uue gen'i ostmisega. ma saaks aru kui selline gain on lihtsalt vana seeria uuenenud mudelitega aga uus gen tähendab tavaliselt ikka hirmsuurt väljaminekut kaardi vahetuse näol. whats the point kui reaalselt vaevu tunnetad vahet icon_confused.gif siiamaani väga tihti vist geni vahele pole jätnud, kuid tundub, et nüüd võib rahulikult seda tegema hakata. tõsi ta on muidugi, et mängude graafika enam ei muutu ka...vähemalt mitte paremaks!
libe
kvaliteetne mees
libe
sõnum 14.08.2012 21:23:35 vasta tsitaadiga
millal?
sõnum 14.08.2012 21:28:49 vasta tsitaadiga
libe kirjutas:
millal?
libe
kvaliteetne mees
libe
sõnum 14.08.2012 21:31:02 vasta tsitaadiga
krt raha sügeleb raisk
SilQ
SilQ
sõnum 14.08.2012 22:01:21 vasta tsitaadiga
Jään ka ootama, 7 seeria jääb nähtavasti vahele.
Kommentaarid: 249 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 213
sõnum 14.08.2012 22:12:06 vasta tsitaadiga
SilQ kirjutas:
siinus
siinus
sõnum 15.08.2012 08:22:52 vasta tsitaadiga
Eks jään ka seda 7k seeria successorit jälgima.
Kunagi lubati, et 2 mDP pordi abil saab 6'le kuvarile pildi ette. Siiamaani pole mingit mõistlikku lahendust veel näinud. Äkki tuleb mingi uuendus selle suhtes?
suck less | ANNA MU SAI!
Kommentaarid: 70 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 63
Gizmoz
Gizmoz
sõnum 15.08.2012 10:20:42 vasta tsitaadiga
huvitav kuidas selle seeria säästu püss ka kõlama hakkab 8670 icon_biggrin.gif? Igastahes ootame kohe huviga.
Kristoferr
Kristoferr
sõnum 15.08.2012 10:52:12 vasta tsitaadiga
Midagi ulmelist oodata pole. Sama rada edasi. 20-40% jõudluse kasvu, olenevalt kaardist. Graafika tuumad lähevad keskeltläbi veidi suuremaks ja voolujanulisemaks.. Kaardid ise veidi efektiivsemaks - ehk jõudluse/voolutarbe suhe veidi paremaks.
Liitu Binance'ga
Liitu Wise'ga!
libe
kvaliteetne mees
libe
sõnum 15.08.2012 20:03:57 vasta tsitaadiga
olen tegelikult piidelnud juba nvidiat, kuid kuupäev on olulisem
kui hetkel turulolevatest tugevama uue põlvkonna pilli saab varem, siis saab mööndusi teha
krt praeguse 6nda seeriagi jookseb gta4 kehvemini kui samaväärse nv kaardiga - pisut pettunud rsk icon_mad.gif
SurfData
SurfData
sõnum 22.08.2012 11:04:12 vasta tsitaadiga
uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  AMD Volcanic Islands aka R-200 seeria videokaardid mine lehele 1, 2, 3 ... 124, 125, 126  järgmine
