uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  AMD Volcanic Islands aka R-200 seeria videokaardid märgi kõik teemad loetuks
mine lehele 1, 2, 3 ... 61, 62, 63  järgmine
Optimist
Optimist
sõnum 09.07.2012 20:53:07 AMD Volcanic Islands aka R-200 seeria videokaardid vasta tsitaadiga
Esimesed kõlakad on siis väljas: http://news.softpedia.com/news/AMD-s-Radeon-8000-Sea-Islands-40-Faster-than-Tahiti-2-278751.shtml
Fabless GPU and CPU designer, American company AMD is getting ready to launch its newest and most powerful GPU architecture this winter. The new GPU series will bear the codename “Sea Islands,” while the products will be branded Radeon 8000 Series.
Not much is known about the new architecture, but rumors say that the new GPU will have 5.1 billion transistors and will be built in TSMC’s well-known and popular 28nm manufacturing technology.
Considering the fact that the current GCN top-performing GPU has 4.3 billion transistors, a relatively small 18% increase in transistor count would be rather impressive if it yields a 40% performance improvement.
The number of transistors can’t increase too much, especially since the GPU is still made using 28nm bulk wafers and at roughly 410 millimeter die size, the Venus GPU is already big enough.
The internal configuration of the architecture is supposed to be comprised of 2560 stream processors, 160 texture units (TMUs), 32 or 48 ROP units (ROPs) and the same 384-bit memory bus.
AMD’s new flagship is likely to maintain the GHz-like frequencies that are usually achieved by the current GCN processors.
Not moving to a smaller manufacturing process does not mean that AMD will end up with a hot chip. In fact, six months from now, TSMC’s 28nm manufacturing process will basically be more than 1 year old and will yield even better results.
On the other hand, AMD will do its best to achieve a lower current leakage and, overall, a more efficient architecture.
viimati muutis Optimist 25.09.2013 20:32:49, muudetud 2 korda
Kommentaarid: 10 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 8
1dumbpcuser
sõnum 09.07.2012 21:12:15 vasta tsitaadiga
3D Center prognoosid:
http://www.3dcenter.org/news/eine-erste-prognose-zu-sea-islands-aka-amds-radeon-hd-8000-serie
______________________________
http://wccftech.com/amd-sea-island-tenerife-gpu-leaked-features-enhanced-gcn-architecture-450-tflops-raw-processing-power/
http://www.cpu-world.com/news_2012/2012061601_A_First_Look_at_AMD_s_Radeon_HD8000_Series.html
AMD's latest beta graphics drivers revealed a few new device IDs, including four Kaveri and five Kabini graphics solutions for the next generation APUs. There are also a number of IDs for what looks like the next generation of Sea Islands GPUs, code-named Mars (9 models), Oland (3 models) and Venus (4 models).
According to predictions at 3DCenter (Google translation), Venus will be used for high-end GPUs, and it is expected to have around 5.1 billion transistors in a 410mm2 die, using 28nm technology. There could be between 2 and 4 raster engines with 2560 cores, approximately 160 TMUs and 32 or 48 ROPs, and there is likely to be a 384-bit memory interface. The most powerful single-GPU card could be the Radeon HD 8970, with a 30-40% performance boost over current generation of cards.
Oland is expected to be the name given to graphics cards filling the performance sector. With an anticipated 3.2 billion transistors on a 230mm2 die, this is another 28nm product. It is likely to have 2 raster engines, 96 TMUs and 32 ROPs. The full die will likely have 1536 cores and a 256-bit memory interface. The most powerful Oland based card will be the Radeon HD 8870, with a performance increase of around 20% compared to it's current generation of counterparts.
Finally, the mainstream cards will use the Mars core, the last 28nm GPU for the 2013 generation of graphics cards, with an expected 1.7 - 2.0 billion transistors in a 135 - 160mm2 die. There will be 1 raster engine, 40-48 TMUs and 16 ROPs. The core count for the full die is around 768 or 896, with a 128-bit or 192-bit memory interface. The best solution provided by this core will be the Radeon HD 8770, with an expected performance boost of 35% over current generation of mainstream GPUs.
It should be noted that most of the information in this article comes from predictions made by 3DCenter.org, and should not be considered as final information at this stage. We will update this as soon as more information is available.
__________________________________
Uued mudelid Beta draiveris:
M: MSI B660M MORTAR
M: Dell RTX 2060
O: AM5 ITX emaplaat
Kristoferr
Kristoferr
sõnum 09.07.2012 21:31:33 vasta tsitaadiga
See Tenerife slaid ilmus juba enne GTX680 launchi või siis vahetult peale seda. Ma ei võtaks seda isegi "lekkena" vaid kellegi fantaasiana. Muide praegune GHz edition 7970 on juba +20% juures üle reference 7970.
Kuulduste kohaselt siis uuel lipulaeval 25% jagu rohkem shadereid. Võiks loota kuni 25% paremust võrdväärse kella juures. Mälu ribalaius sama, aga ehk kompenseeritakse seda takti tõstmisega.
Kommentaarid: 268 loe/lisa Kasutajad arvavad:  :: 4 :: 0 :: 219
prtv
sõnum 11.07.2012 19:51:54 vasta tsitaadiga
Järjekordne spekulatsiooni teema, minugipoolest.
sõnum 14.07.2012 07:17:16 vasta tsitaadiga
aap14
aap14
sõnum 14.07.2012 11:43:10 vasta tsitaadiga
Slow is smooth and smooth is fast
hendrik32
sõnum 14.07.2012 14:13:16 vasta tsitaadiga
Jälgin!
Asgate
sõnum 14.07.2012 14:45:45 vasta tsitaadiga
Kui praegu on hd7k seeria GPU-d 28nm-ga ning hd8k pasistab sama tootmisprotessi kasutama, siis millal järgmist chipi kahanemist võiks oodata ja mis number see oleks?
Intelil oli siin uudis et 10, 7, 5nm alates 2015-st aastast siis kuidas AMD ja Nvidia GPU-dega on?
Kommentaarid: 18 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 15
sõnum 14.07.2012 15:51:57 vasta tsitaadiga
Asgate, Arvatavasti 20nm +/- 2 ja seda kuskil 2014 siis. Ei usu, et kohe alla 20nm hüpatakse, sest iga samm on järjest raskem mida väiksemaks tootmisprotsess läheb. Kuigi mine sa tea. Kui suudetakse jälle teha 12nm samm, siis näeme 16nm kiipe 2014 aasta lõpus.
90 --> 65 = -25
65 --> 40 = -25
40 --> 28 = -12
28 --> ??
sõnum 14.07.2012 15:57:44 vasta tsitaadiga
Ma miskipärast arvan, et järgmine samm oleks 22nm, kuna see on juba küps ja prosed juba tootmises.
sõnum 15.07.2012 07:06:03 vasta tsitaadiga
Prosede ja videokaartide tootmised on siiski erinevad ma kardan. Prosesid teeb Intel oma tehastes (pole uurinud kus see AMD oma vahvleid küpsetab - vist GlobalFoundries-s), aga videokaardid tehakse enamuses TSMC-s.
Alguses olid ka prosed 90nm aga 4xnm peal läks asi erinevaks:
90 --> 65 = -25
65 --> 45 = -20
45 --> 32 = -13
32 --> 22 = -10
22 --> 15 = -7
15 --> 10 = -5
10 --> 7 = -3
7 --> ?
Prosede shrinkid toimuvad tihedamini aga väiksemate sammudena ja on aeglustumas. 15/10/7 on tulevased Inteli tootmisprotsessid siis. Muidugi kõik see kena OT siin teemas icon_biggrin.gif
abimees0
abimees0
sõnum 15.07.2012 08:22:47 vasta tsitaadiga
Jälgin.
s4nder
sõnum 15.07.2012 11:35:14 vasta tsitaadiga
Absoluutväärtustes asi muidugi aeglustub, aga suhtarvudena püsib areng konstantsena, iga uus shrink on eelmisest ~30% väiksem.
90 --> 65 = -28%
65 --> 45 = -31%
45 --> 32 = -29%
32 --> 22 = -31%
22 --> 15 = -32%
15 --> 10 = -33%
10 --> 7 = -30%
7 --> ?
1dumbpcuser
sõnum 15.07.2012 12:23:38 vasta tsitaadiga
Inteli järgmine tehnoloogia on 14nm (mitte 15) ja seejärel 10nm, vähemalt Wiki andmetel http://en.wikipedia.org/wiki/Haswell_(microarchitecture)
M: MSI B660M MORTAR
M: Dell RTX 2060
O: AM5 ITX emaplaat
Wiltz
sõnum 18.07.2012 09:30:37 vasta tsitaadiga
nagunii mingi äärmiselt küsitava väärtusega info ilmselt, mis siin selle uue "worlds fastest gpu" kohta, aga asi on ikka suht mõttetuks läind küll kui kuskil 30% lisajõudlust saad uue gen'i ostmisega. ma saaks aru kui selline gain on lihtsalt vana seeria uuenenud mudelitega aga uus gen tähendab tavaliselt ikka hirmsuurt väljaminekut kaardi vahetuse näol. whats the point kui reaalselt vaevu tunnetad vahet icon_confused.gif siiamaani väga tihti vist geni vahele pole jätnud, kuid tundub, et nüüd võib rahulikult seda tegema hakata. tõsi ta on muidugi, et mängude graafika enam ei muutu ka...vähemalt mitte paremaks!
libe
kvaliteetne mees
libe
sõnum 14.08.2012 22:23:35 vasta tsitaadiga
millal?
sõnum 14.08.2012 22:28:49 vasta tsitaadiga
libe kirjutas:
millal?
libe
kvaliteetne mees
libe
sõnum 14.08.2012 22:31:02 vasta tsitaadiga
krt raha sügeleb raisk
SilQ
SilQ
sõnum 14.08.2012 23:01:21 vasta tsitaadiga
Jään ka ootama, 7 seeria jääb nähtavasti vahele.
Kommentaarid: 251 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 215
sõnum 14.08.2012 23:12:06 vasta tsitaadiga
SilQ kirjutas:
siinus
siinus
sõnum 15.08.2012 09:22:52 vasta tsitaadiga
Eks jään ka seda 7k seeria successorit jälgima.
Kunagi lubati, et 2 mDP pordi abil saab 6'le kuvarile pildi ette. Siiamaani pole mingit mõistlikku lahendust veel näinud. Äkki tuleb mingi uuendus selle suhtes?
suck less | no slop grenade
Kommentaarid: 70 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 63
Gizmoz
Gizmoz
sõnum 15.08.2012 11:20:42 vasta tsitaadiga
huvitav kuidas selle seeria säästu püss ka kõlama hakkab 8670 icon_biggrin.gif? Igastahes ootame kohe huviga.
Kristoferr
Kristoferr
sõnum 15.08.2012 11:52:12 vasta tsitaadiga
Midagi ulmelist oodata pole. Sama rada edasi. 20-40% jõudluse kasvu, olenevalt kaardist. Graafika tuumad lähevad keskeltläbi veidi suuremaks ja voolujanulisemaks.. Kaardid ise veidi efektiivsemaks - ehk jõudluse/voolutarbe suhe veidi paremaks.
Liitu Opencode Go soodsa coding plaaniga ja saa 5€ soodust!
Liitu Wise'ga!
libe
kvaliteetne mees
libe
sõnum 15.08.2012 21:03:57 vasta tsitaadiga
olen tegelikult piidelnud juba nvidiat, kuid kuupäev on olulisem
kui hetkel turulolevatest tugevama uue põlvkonna pilli saab varem, siis saab mööndusi teha
krt praeguse 6nda seeriagi jookseb gta4 kehvemini kui samaväärse nv kaardiga - pisut pettunud rsk icon_mad.gif
SurfData
SurfData
sõnum 22.08.2012 12:04:12 vasta tsitaadiga
CoiL
CoiL
sõnum 23.08.2012 00:06:02 vasta tsitaadiga
Tore tore, kui uus seeria välja tuleb, siis ootan 7K hinnalangust ja ostan hoopis miskit sealt vist icon_smile.gif
Kommentaarid: 95 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 83
sõnum 23.08.2012 00:12:48 vasta tsitaadiga
CoiL kirjutas:
nii võibki ootama jääda kui alati võimsam seeria selga tuleb icon_rolleyes.gif
CoiL
CoiL
sõnum 24.08.2012 23:27:13 vasta tsitaadiga
jeesus188, tean et võib aga see periood kus vahetasin ka kaarte natuke tihedamalt on ammu läbi. Ei mängi mänge enam. Pigem mõtlesin, et 8K seeria toob 7K seeria low/mid-low level kaartide hinnad alla. Võtaks suht kommiraha eest midagi natuke asisemat 2D/3D CAD tarkvara jaoks ja full-hd jooksutamiseks kui HD4550. 7K hea jahe ja mitte-vooluõgard kah, võtaks miski passiiv-jahutusega ligi. Hetkel passiiv HD4550 ikka natuke kütab kasti seda soojakest.
caramis
caramis
sõnum 27.08.2012 00:10:34 vasta tsitaadiga
Kommentaarid: 174 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 151
Siim159
Siim159
sõnum 27.08.2012 13:34:47 vasta tsitaadiga
Hakkan ka jälgima. Oleks väga hea, kui sügisel tuleks. Siis läheb uue kasti ostuks ja saab vb mõelda kohe ka 8K ostule (oleneb muidugi ka hindadest).
SilQ
SilQ
sõnum 27.08.2012 13:39:46 vasta tsitaadiga
Siim159 kirjutas:
Ma väga kahtlen et see aasta seda seeriat näha saab.
heff
sõnum 27.08.2012 13:57:03 vasta tsitaadiga
Ilmselt pole jah mõtet, Nvidia nt toob alles oma eelmist seeriat turule, mis annab AMD-le kõvasti ruumi hingata. Üldiselt pole kumbki seda eelist ära kasutanud ja on tiksutud vana arhitektuuri peal selle võrra kauem lihtsalt. HD7k oli selline erand kui nvidia mingil põhjusel lihtsalt venis kui 7970 pikalt juba turul oli. Samas imo eelmise põlvkonnaga mingit vahet sisse ei tekkinud. HD5k vs GT400 oli nv poolt samasugune venimine, et kaart turule tuua, kuigi siis suudeti full range kiiremini turule tuua, seekord nvidia mökutab niisama, küllap siis neil rahaline seis piisavalt hea ja ei taha enam raha teenida. HD5k edukas ja kiire turule saabumine aga ei tähendanud järgmise põlvkonna kiiret tulekut.
Keeruline jutt vist : D
Kommentaarid: 106 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 97
rene p
sõnum 17.09.2012 17:01:47 vasta tsitaadiga
AMD "Oland" Radeon HD 8800 Series SKUs Unveiled
http://www.techpowerup.com/172312/AMD-quot-Oland-quot-Radeon-HD-8800-Series-SKUs-Unveiled.html
Kommentaarid: 71 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 68
Kristoferr
Kristoferr
sõnum 17.09.2012 17:18:24 vasta tsitaadiga
Sisuliselt sama voolutarbe juures +70% compute icon_eek.gif icon_eek.gif icon_eek.gif . Nii hästi poleks küll oodanud.
Liitu Wise'ga!
Ramones
Ramones
sõnum 17.09.2012 18:40:14 vasta tsitaadiga
Julm perf. boost lubatud vähemalt paberi peal.
caramis
caramis
sõnum 17.09.2012 18:43:03 vasta tsitaadiga
Kristoferr kirjutas:
Killhoven
OC`er
Killhoven
sõnum 17.09.2012 19:00:06 vasta tsitaadiga
Kommentaarid: 409 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 351
Kristoferr
Kristoferr
sõnum 17.09.2012 19:02:33 vasta tsitaadiga
Kui selline slaid ilmus, siis ehk üsna varsti.
Kui see hind ja perf enam vähem paika peab, siis ma ei tea, kes veel GF6xx kaarte osta tahaks. Peavad ka oma 7nda seeriaga kiirustama.
Liitu Wise'ga!
hendrik32
sõnum 17.09.2012 19:18:03 vasta tsitaadiga
Kui paberil olevad andmed peavad paika ka praktikas, siis on küll suuretõenäoline, et mu HD 4870 X2 läheb vahetusse.
caramis
caramis
sõnum 17.09.2012 19:20:36 vasta tsitaadiga
Expect the launch of the next flagship around Q1 2013 or early in Q4 2012.
lisaks veel kirjas, et kahetuumset 7k isendit AMD ei teegi, ei suudeta piisavalt head jahutit teha icon_lol.gif
One
sõnum 17.09.2012 21:28:11 vasta tsitaadiga
caramis kirjutas:
Loll jutt, nn X2-e oleks saanud juba ammu valmis teha kui oleks soovi olnud.
Jahutuse taha ei jää küll midagi.
sõnum 17.09.2012 21:53:57 vasta tsitaadiga
äkki vennad vaatasid, et 8 seeria tuleb haledalt kõva laks, et sellega ajab rohkem pappi kokku kui x2-ga jamamine ehk siis ei näinud lihtsalt asjas pointi
Rudolf112
Rudolf112
sõnum 17.09.2012 22:12:36 vasta tsitaadiga
Winterwind kirjutas:
caramis kirjutas:
ot:
7990 "Devil" ju täitsa olemas. Küll mitte AMD enda toodetud.
Kommentaarid: 57 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 55
sõnum 18.09.2012 08:20:22 vasta tsitaadiga
Kui see graafik mingi BS nüüd pole, siis 8850 alla 200€ saad väljalaskel oleks päris hea. Arvestasin 200$ = 200€ nagu siin kombeks on.
SurfData
SurfData
sõnum 18.09.2012 10:54:52 vasta tsitaadiga
rene p kirjutas:
A-Circus.
A-Circus.
sõnum 18.09.2012 11:12:23 vasta tsitaadiga
SurfData kirjutas:
rene p kirjutas:
Artikli kommentaarides olevate arvutuste järgi peaks olema 1792 ja 1536 vastavalt siis 8870 ja 8850 puhul. Lisada veel selle kõrge taktsagedus, siis 8870 peaks olema umbes sama kiire kui 7970?
Iseasi kas need andmed üldse reaalsusele vastavad või on kellegi poolt põlve peal valmis kritseldatud.
caramis
caramis
sõnum 18.09.2012 14:42:34 vasta tsitaadiga
Rudolf112 kirjutas:
caramis kirjutas:
ot:
d_m
sõnum 19.09.2012 14:23:18 vasta tsitaadiga
aga kui see info vastab vähegi tõele siis tundub asjalikum põlvkond olema kui 7xxx seda oli ja kindlasti on ka, vahet pole mis need parameetrid olema saavad.
Kommentaarid: 10 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 7
bitCON
sõnum 19.09.2012 14:37:10 vasta tsitaadiga
tuleb vist lauaka ostu veidi edasi lükata
Asgate
sõnum 19.09.2012 17:36:19 vasta tsitaadiga
Tabelis on näha HD 8800 seeria andmed, kuid mis saab 8900 seeraist mis peaks vastanduma 7900 seeriale, ega mingit numbrite rebrandigut pole jälle tehtud?
uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  AMD Volcanic Islands aka R-200 seeria videokaardid mine lehele 1, 2, 3 ... 61, 62, 63  järgmine
