uus teema   vasta Tarkvara »  Arvutimängude foorum »  Max Payne 3 märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 7, 8, 9 ... 16, 17, 18  järgmine
sõnum 25.05.2012 22:30:51 vasta tsitaadiga
DefXtreme kirjutas:
Rockstar to push Max Payne 3 "to its limits" on high-end PCs
EuroGamer
"We've worked hard to make sure the game will run smoothly on a wide range of PC builds," he explained.
"But it's when you get towards the top end of that range that you can really push a game to its limits, and the game will look and run incredibly on the most advanced current machines around at the moment and well into the near future.
"You'll find that screen resolution is scalable, there's triple and even sextuple monitor support which helps to run higher screen resolutions, there's various anti-aliasing options, scalable water quality, scalable shadow quality, increased detail for characters and vehicles and a scalable texture filter that further increases visual quality.
"We're also supporting DX11 with Max Payne 3, with features including Hull/Tessellation/Domain Shaders (which adds curvature to the character/vehicle models), Gather4 (for optimized shadow sampling / FXAA), Geometry shader / Stream Output and DX11 texture samplers to name a few."
Hoare went on to explain why the game's install size comes in at a hefty 35GB.
"The installed size of Max Payne 3 is due to the no-compromise quality of its assets, which already push console disc space to the limits," he said.
"A good portion of the extra space requirements on PC can be attributed to the increased size of the textures, which are four times the size of those on consoles. In addition, the audio quality is significantly higher than the consoles due to lower compression rates, which improves audio fidelity.
"Again, this comes back to the range of possibilities that the PC platform opens up for us. That, combined with higher video settings when running the game, results in substantially better visual quality."
You'll get see for yourself when the game launches on 1st June.
In the meantime, here's a revised set of system requirements:
Not bad! icon_eek.gif icon_cool.gif Ja tundub et 35GB on ikka reaalne värk, krt mul võtab see Steamist tõmmates päevi, peab vist karbi versiooni peale mõtlema! icon_razz.gif
kui seda jagatakse nii kiiresti
KrisVr
sõnum 25.05.2012 22:41:18 vasta tsitaadiga
Nujah, mis me siin 100 megaste vendadest räägime, krt ma siin 2 megase otsas! icon_cry.gif icon_redface.gif
Kommentaarid: 30 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 27
sõnum 25.05.2012 22:43:48 vasta tsitaadiga
DefXtreme kirjutas:
rastaman
rastaman
sõnum 26.05.2012 00:18:57 vasta tsitaadiga
DefXtreme kirjutas:
2x kiirem kui mul
Selmet
sõnum 26.05.2012 13:16:44 vasta tsitaadiga
jeesus188 kirjutas:
DefXtreme kirjutas:
iNTERNET Turbo 2012
More then a million satisfied costumers
Kui miljonid kostümeerijad kasutavad ja on rahul ju siis peab aus kaup olema.
- Tempus fugit -
mxr
sõnum 26.05.2012 13:19:34 vasta tsitaadiga
Sai läbi mängitud SP on rockstaril hea nagu ikka, kuid mp on küll minu jaoks pettumus
Kes mängivad mängu SP pärast ei pea pettuma , mps ma ei oleks nii kindel...
Kommentaarid: 85 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 81
Gap
Gap
sõnum 26.05.2012 13:23:01 vasta tsitaadiga
Siim159
Siim159
sõnum 26.05.2012 13:35:55 vasta tsitaadiga
Gap, PC peal pole veel väljas ju.
Flasky
Flasky
sõnum 26.05.2012 13:41:11 vasta tsitaadiga
Kõik, kes Steamist eeltellinud, said lisaks Max Payne 1 & Max Payne 2 eile L.A. Noire ka veel lisaks. Super üllatus minu meelest.
rastaman
rastaman
sõnum 26.05.2012 14:03:03 vasta tsitaadiga
dafuq, mõndadel juba läbi mängitud ?? nolife max või lühike sp ?
Siim159
Siim159
sõnum 26.05.2012 14:54:14 vasta tsitaadiga
Flasky, seepärast ongi suht kirves hind Steamis Max Payne 3-l - 50€. Võtame näitena Gamestari - 40€. Ning Gamestariski tegelikult üsna kirved hinnad aga see selleks...
Flasky
Flasky
sõnum 26.05.2012 18:23:20 vasta tsitaadiga
Siim159 kirjutas:
Njah, eks ta kallis ole tõesti.
Isa lasin ühel sõbral Suurbritanniast giftida, nii sain 40€-ga ja oli ikka korralik ROW versioon, mitte siin peale surutud regiooniblokiga versioon.
j2mm
j2mm
sõnum 31.05.2012 02:00:32 vasta tsitaadiga
Üks pikk päev veel oodata...
HV Crew loodud?
Kommentaarid: 88 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 72
Gap
Gap
sõnum 31.05.2012 10:49:23 vasta tsitaadiga
See mäng on steamiga seotud ? ei tea kas rus keyga saaks kuidagi hakkama ? icon_redface.gif icon_biggrin.gif 50€ suht kirves ...
trip
trip
sõnum 31.05.2012 11:18:20 vasta tsitaadiga
homme saab näha, mis värk vene versiooniga.
müügil retail kujul, st 27gb installikat tuleb netist tirida, heli on originaal, interface inglisekeelne peab ka olema.
Siim159
Siim159
sõnum 31.05.2012 16:37:52 vasta tsitaadiga
Enam vist vene võtmesaitide võtmeid Steamis aktiveerida ei saagi... Vähemalt üks päev kuskil lugesin seda, kuid ei tea, kui kindel see värk on.
Jama on ka see, et mäng nii suur ning netist allalaadimisega läheb päris tükk aega (eriti alguses, mil need torrentid alles uued ja palju jagajaid pole). Enda tutvusringkonnas pole ka kedagi, kellel plaan MP3 DVD peal soetada. Nii et suht nutune värk tundub.
Aeg maha 1p
sõnum 31.05.2012 16:39:24 vasta tsitaadiga
Hommikul paned laadima ja õhtul töölt koju minnes on mäng kohal, pole ületamatuid olukordi, on saamatud inimesed icon_smile.gif
rastaman
rastaman
sõnum 31.05.2012 16:44:26 vasta tsitaadiga
hommikul paned laadima ja nädala pärast on heal juhul mäng kohal
Siim159
Siim159
sõnum 31.05.2012 16:46:22 vasta tsitaadiga
Kui ma nüüd mängu väljatuleku aeg sooviksin mängu kätte saada, siis ma usun, et see küll nii kiirelt ei käiks, kuna jagajaid üsna vähe. Mitmeid päevi läheks selleks aega.
Gap
Gap
sõnum 31.05.2012 18:20:42 vasta tsitaadiga
27 Gb pole ju nii hull icon_biggrin.gif Installituna võtab siis 35 GB või ? Päris palju ikka...krdi asjad seal peal siis on icon_smile.gif
Siim159
Siim159
sõnum 31.05.2012 18:27:42 vasta tsitaadiga
Gap, torrentiga mängu väljalaske alguspäevadel võib küll kiirus olla ikka kohutavalt väike. Samuti mul 20Mbit/s nett, mis pole ka ei tea kui kiire...
Ikka mitu päeva tõmbab sellist vast (Steamis muidugi kiirused suuremad).
Flasky
Flasky
sõnum 31.05.2012 19:34:32 vasta tsitaadiga
Steamis pre-load üleval!
Siim159
Siim159
sõnum 31.05.2012 20:34:48 vasta tsitaadiga
Ega sellel US ja EU mängul ei ole ju mingeid erinevusi? Ehk kui ma juba praegu paneksin torrenti laadima (ehk siis US oma, EU-sse tuleb alles homme, mida praegusel hetkel torrentite seal ei saagi olla), siis töötab see ilusi ikka ka multiplayeris mul? (muidugi soetan key mängu aktiveerimiseks)
villu70
villu70
sõnum 31.05.2012 21:12:12 vasta tsitaadiga
Jube "raske" on küll see mäng, millest see küll koosneb..... 10h videoklippe 2-3 tunni mängimise kohta?
Kommentaarid: 142 loe/lisa Kasutajad arvavad:  :: 3 :: 0 :: 122
Siim159
Siim159
sõnum 31.05.2012 21:17:27 vasta tsitaadiga
Ühel siin sai SP läbi nädalaga. Sinna sisse veel jäi aega MP-ga tutvumiseks jms. Tundub, et üsna lühike story.
IvarV
IvarV
sõnum 31.05.2012 21:17:56 vasta tsitaadiga
SinineSiil
SinineSiil
sõnum 31.05.2012 21:30:46 vasta tsitaadiga
võtas-uxu kirjutas:
Ühtegi videot ei tohiks selles mängus olla peale alguse/lõpuvieo. Kõik in-engine.
scarface
scarface
sõnum 31.05.2012 21:52:04 vasta tsitaadiga
SinineSiil kirjutas:
võtas-uxu kirjutas:
Ma arvasin ka aaaga kahjuks on mingi Movies kaustas 8gb jagu .bik faile : D
pc nimeline kaust on 16gb sellegipoolest. 35gb ist aga asi kaugel tõesti : p
Kommentaarid: 44 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 42
KrisVr
sõnum 31.05.2012 23:36:17 vasta tsitaadiga
Link
Vici
sõnum 01.06.2012 00:19:42 vasta tsitaadiga
mängida tasub kohe hardiga,normal on ikka jube lihtne,hardiga 8 pool tundi ja läbi ta oligi icon_biggrin.gif
Volum
sõnum 01.06.2012 09:13:57 vasta tsitaadiga
Krt, tahaks ka pelada, aga 7970 tuleb alles esmaspäeval icon_cry.gif icon_lol.gif
Tellin originaal A-varuosasi saksast. 15-70% soodsamalt kui esindustes!
Teostan diagonstikat tehasetasemel: BMW, VAG (Audi, VW, Seat, Skoda ja kaubikud), Volvo (sõiduautod), Scania - Tartus, Põlvas ja lisatasu eest Võrus.
Delta
Delta
sõnum 01.06.2012 09:19:25 vasta tsitaadiga
Initial activation requires internet connection and a valid Rockstar Social Club account
Kas see aktiveerimine tähendab Steami või nende enda lehte?
airgun.planet.ee - õhkrelvad ja taskulambid
Salva kindlustus = probleemid
M: 4G ruuter
Kommentaarid: 141 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 133
trip
trip
sõnum 01.06.2012 10:40:04 vasta tsitaadiga
Delta, rockstar lehel peab acc olema.
mängukäivitamisel palub sisse logida socialclub kasutajaga (mail+pwd), ja küsib aktiveerimist, mul vene võtiga kõik toimis kenasti.
zpsy
zpsy
sõnum 01.06.2012 10:53:15 vasta tsitaadiga
Rockstar ei vedanud alt.
Kommentaarid: 825 loe/lisa Kasutajad arvavad:  :: 4 :: 1 :: 587
Gap
Gap
sõnum 01.06.2012 11:48:46 vasta tsitaadiga
Mismoodi see siis käib ? Kas peab läbi selle social clubi aktiveerima või kuidas ? ja mäng on pärast ikka inglise keelne ? Ma vene keelt ei oska üldse,inglise keelest saan midagi aru ikka icon_biggrin.gif
Siim159
Siim159
sõnum 01.06.2012 11:56:15 vasta tsitaadiga
trip, ehk siis tuleb ikka torrentite kaudu mäng alla tõmmata?
trip
trip
sõnum 01.06.2012 12:06:48 vasta tsitaadiga
Gap, mäng 100% inglisekeelne hääled/interface, rockstar ei lase enda mängud tõlkida (hääled).
aktiveerimisest kirjutasin juba, mäng küsib esiteks socialclubi logini ja siis tuleb aken, kuhu vaja võti sisse toksida.
Siim159, jah tuleb torrentiga 27gb alla laadida, lingiga saan aidata icon_smile.gif
Siim159
Siim159
sõnum 01.06.2012 12:11:52 vasta tsitaadiga
Kus sa siis nii kiirelt mängu juba said?icon_biggrin.gif Mul tõmbab ikka tükk aega. Eile õhtupoolikul sai mäng tõmbama pandud ning seni tõmbanud vaid 20%. Õhtul oli veidike aega 1MB/s, kuid üldjuhul on kiirus ikka oluliselt väiksem (hetkel nt 50kB/s)
Gap
Gap
sõnum 01.06.2012 12:13:19 vasta tsitaadiga
Oh issand siis torrentiga tirin seda pool aastat icon_neutral.gif Mul on see elioni 50mb kodulahendus... eelmise 12mb asemel.... mingit suurt kiiruse tõusu pole küll märganud....ok sry see pole see teema icon_redface.gif
aga jah kui nii on võimalik siis ma panen tõmbama ja kui ükskord mäng kohal ja võtmeid on siis olen huvitatud küll icon_rolleyes.gif icon_biggrin.gif
trip
trip
sõnum 01.06.2012 12:17:14 vasta tsitaadiga
Siim159, 5mbit nett, õhtul eile panin tirima, täna tööl juba rdp kaudu sai seda installitud/mängitud
RaPTiLE
RaPTiLE
sõnum 01.06.2012 12:17:49 vasta tsitaadiga
Peaks vast ostma minema - mingi 4 dual layer DVD'd?
Kommentaarid: 60 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 55
Siim159
Siim159
sõnum 01.06.2012 12:18:16 vasta tsitaadiga
Mis asja? 5Mbit netiga on sul nii kiire? Mul 20Mbit ja venib nagu ei tea mis. TUndub, et 1 ööpäev läheb veel selle kohale jõudmiseks. :S
trip
trip
sõnum 01.06.2012 12:24:35 vasta tsitaadiga
27gb / 570kbps ~14 tundi kuskil võttis aega icon_rolleyes.gif
sõnum 01.06.2012 13:22:45 vasta tsitaadiga
privat trackeriga 9,5MB/s icon_rolleyes.gif
nüüd võtit vaid vaja
Siim159
Siim159
sõnum 01.06.2012 13:27:27 vasta tsitaadiga
Kus kohas/kuidas te neid privat trackereid hangite? Pole just nende torrentite ja asjadega just kõike rohkemini kursis.
Volum
sõnum 01.06.2012 15:50:22 vasta tsitaadiga
RaPTiLE kirjutas:
Flasky
Flasky
sõnum 01.06.2012 18:03:42 vasta tsitaadiga
Grr... Max Payne 3 juba eile kella 7-st Steamist alla laadinud... Vast selle tunni jooksul saan mängima. Nii kaua ootamise järel teen küll selle ühe korraga kohe läbi...
scarface
scarface
sõnum 01.06.2012 20:22:21 vasta tsitaadiga
No blinn, mäng on hea, Hardi peal vastased 2 lasku sulle pihta saavad oled kutu, okei. Väga frustreeriv on see, et F5 ja F9 ei tööta : S icon_biggrin.gif Tahaks nagu igalpool saveda kus vaja. Hetkel sealt helipadilt juba 10x alustanud uuesti ja uuest no kurat tehku vahele 1 checkpont siis veel kui neile meedis oma checkponti süsteem niiväga. näiteks kohta kus ma sinna äärele ronima lähen. 3x juba üleääre hüpanud ka icon_razz1.gif No ei saa hakkama. icon_lol.gif
sõnum 02.06.2012 10:53:37 vasta tsitaadiga
kas max on terve mäng purjus, peale esimest chapterit viskab see pildi virvendamine videodes juba vaikselt kope ette icon_rolleyes.gif ?
ja kas see, et ma ei kuule teiste vahelist teksti(vahel vaikselt siiski kuulda) peabki nii olema?
max suu avab, siis kõik ok, kui taustal mingid tyybid asja arutavad, siis nagu kurt oleks, loen su tiitreid
eZ
eZ
sõnum 02.06.2012 11:23:50 vasta tsitaadiga
Mul heliga kõik korras, äkki sul seadetes mingi vale kõlarite asetus valitud.
Mul teine probleem, igakord kui mängu lähen on hiire seaded paigast ära :/
Ja FPS näitab pidevalt mingi 100-300 icon_lol.gif max graafikaga 1920x1200, mida ta selgelt päriselt ei ole.
Mäng muidu suht hea, kinni on suht raske panna, kuna loadimis kohti pole ja siis ongi nagu üks pikk level järjest icon_biggrin.gif
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Max Payne 3 mine lehele eelmine  1, 2, 3 ... 7, 8, 9 ... 16, 17, 18  järgmine
