Kas kavatsed osta D3: Reaper of Souls expansioni? |
Jah |
52% |
[ 171 ] |
Ei |
47% |
[ 154 ] |
hääli kokku : 325 |
Velociraptor
Kommentaarid: 32 loe/lisa |
30 |
Vylx
11.05.2012 16:16:28
Mis selles CE karbis niiväga erilist peaks olema? Ostja saab mängus ka mingit eelist või ongi aint hunnik vidinaid/pudi-padi täis?
Kommentaarid: 51 loe/lisa |
49 |
Azatris
11.05.2012 16:32:35
Minu arust CE tõeline väärtus on neis valgetes inglitiibades.
Aga siiski, not worth it, kui just mänge üle maailma ei casti.
DrZ, sweeping wind. Aga kas Guiding Light töötab üldsegi Breath of Heaveniga?
Kommentaarid: 38 loe/lisa |
34 |
aap14
11.05.2012 16:34:56
Need viimased päevad enne release-i venivad ikka korralikult. Keegi targem juba Diablo 3 stiilis flash mängu on valmis teinud, et selle pealt enne release-i klikke teenida?
_________________ Slow is smooth and smooth is fast |
Kommentaarid: 41 loe/lisa |
38 |
ObNixilis
11.05.2012 17:00:03
Need inglitiivad on eriti tobedad asjad minu arust.
Kommentaarid: 48 loe/lisa |
46 |
LKits
Kommentaarid: 13 loe/lisa |
Leinö
11.05.2012 17:09:24
hmm, mida see guest pass endast kujutab?
Kommentaarid: 34 loe/lisa |
33 |
Timberg
ööKARU
11.05.2012 17:20:52
Ok, there is an official confirmation about guest passes from polish CM, Wuluxar:
http://eu.battle.net/d3/pl/forum/topic/3980578157?page=2#24
For those who don't know polish:
Wuluxar said that guest pass allow us to play only to Skeleton King quest (beta content only). We will not be able to go any further. There will be no time limit - we can play as long as we want and can start at midnight on 15.05.2012.
Those people who bought digital edition will not get a guest pass - it's only in box edition (standard and CE).
Progress in game will be saved, so when you attache you cd-key you will be able to play after Skeleton King content. You will not have to start from the beginning.
Kommentaarid: 341 loe/lisa |
272 |
makaak
Kommentaarid: 25 loe/lisa |
24 |
vasques
11.05.2012 17:37:05
op wizard, saaks vaid sellise ...
_________________ Chuck Norris on juba 2 aastat surnud. Vikatimees kogub siiamaani julgust, et seda talle öelda. |
Kommentaarid: 1 loe/lisa |
irneH
11.05.2012 18:28:00
Nendega on võimalik teha ainult algseid builde. Kui Elective mode on enabled(või disabled?) võid panna skill slottidesse näiteks 2 või 3 primary attacki. Nii et võimalusi on tohutult. Minul ei tule küll see skill slottidesse paiknemine niimoodi, et primary attackist 1 skill, secondarist 1 jne.
Velociraptor
11.05.2012 18:48:55
ArchMage kirjutas: |
DrZ, sweeping wind. Aga kas Guiding Light töötab üldsegi Breath of Heaveniga? |
Arvan et ikka, aga eks näeb Võimalusi, mida selle asemele võtta on palju.
vasques kirjutas: |
Mõtlesin kah oma maagile midagi sellist teha. Kui naked wizard runne tegin, siis diamondskin oli täielik lifesaver SK juures
_________________ 🕊 Kuruppo ぽ 🕊
https://www.last.fm/user/Ingvaarr |
30 |
Ak_47
11.05.2012 18:54:50
Okei,
Progames.ee teatas, et on teinud ettetellimustega ülemüügi CE'le ning mina jäin sellest ilma
Kas on veel poode, kus seda võimalik ette tellida või siis kohapealt osta (vaatasin euronicsi näoraamatu pilti koos kõikide karpidega)
Kommentaarid: 10 loe/lisa |
10 |
Kristoferr
11.05.2012 19:05:34
Kas Frost novat saad spämmida? Või mille peale sa oma AP kulutad? Puha kaitse spellid ja üks AOE. Tundub väga low dps.
_________________ Liitu Binance'ga
Liitu Honey'ga |
Kommentaarid: 260 loe/lisa |
211 |
Kristoferr
11.05.2012 19:52:26
tsitaat: |
uest-728: when you want to play with a friend who is much lower level than you, are you stuck playing the furthest ACT or DIFFICULTY they have achieved?
JasonBender: To Guest-728 They can jump in to your game at a higher level (up to the highest difficulty they've achieved), even though they might miss story points. If the lower level player creates the game you will be limited to their story progress. You're not limited by ACT, but you are limited by DIFFICULTY.
Guest-224: Say for example that I am playing a high level character, but I want to play with my friend who only has a low level character. Will me joining his game ruin the experience for him because I could just blast through the content and make it too easy for him?
JayWilson: To Guest-224 You could blast him through the content, but his XP will be greatly diminished to the point that it's not very beneficial for your low level friend...unless he likes spoilers. But that's what Youtube is for.
Guest-503: Is "rushing" a character possible? Or are there some kind of restrictions that keep a player from getting to Nightmare/**bleep**/Inferno in a significantly shorter time period than usual.
JayWilson: To Guest-503 A higher level character can help you jump past content within a difficulty, but you get greatly diminished XP, so you really need to go through legitimately. We have hard level requirements for difficulty levels, though, so no shortcuts there. |
Natuke kasulikku infot.
Liitu Honey'ga |
211 |
vutt
Kommentaarid: 7 loe/lisa |
Eimar
Kommentaarid: 17 loe/lisa |
16 |
Kristoferr
12.05.2012 09:28:33
See mõõk oli küll . Sellisega läheks sõttagi.
Amazon teatas, et D3 on nende kõigi aegade müüduim mäng. Seda siis, ettetellimise näol. Mitte, et see üllatus oleks.
Liitu Honey'ga |
211 |
Snaxez
12.05.2012 09:34:24
Yogscast-i vennad on alati epic olnud
Kommentaarid: 58 loe/lisa |
53 |
Lyth
12.05.2012 09:38:38
Aga siiski, not worth it, kui just mänge üle maailma ei casti. |
No ikka ronin siia ja diablofansi kuigi tahaks igasuguseid spoilereid vältida. Igatahes, see Art book, on ikka nii epic, et... Isiklikult meeldib selliseid müütilisi tegelasi joonistada ja no see tase, kus Blizzardi kunstnikud omadega on... See on küll puhtalt minu isiklik arvamus, aga ostaksin selle art booki ilma tiibade, WoW'i petita, soundtrackita jne jne 100 euri eest. Nad tõesti joonistavad NII hästi!
edit: Kuigi oleksin nii ehk nii Diablot mängima hakanud, siis piisas sellest pildist ja olin müüdud.
http://eu.battle.net/d3/en/media/artwork/?view#/artwork-class-demonhunter02
viimati muutis Lyth 12.05.2012 09:56:36, muudetud 1 kord |
Kommentaarid: 53 loe/lisa |
48 |
vasques
12.05.2012 10:05:43
Kristoferr kirjutas: |
Kas Frost novat saad spämmida? Või mille peale sa oma AP kulutad? Puha kaitse spellid ja üks AOE. Tundub väga low dps. |
... ja kui sina oled DH mu kõrval... Build oleks puhas tanky bait, samas 0AP vajav ray of frost, vajadusel blur asendada cold blooded-iga, teeks juba dammi ka (illustreeriv näide, millegipärast arvan et magel ei ole võimalik saada tankiks ja high dpsiks). Build on mõeldud dpsi kõrvale ja hoida vaenlane kas stunnis, slowis või siis enda peal 24/7, kriitilises situatsioonis on tp, vajadusel oma mehe juurde minna ja kõik stunnida ja slowda või siis low elu korral unstable anomaly lahti päästa.
Puudu oleks veel see skill
EDIT: Kas itemitel on ka CDR, kui jah mis on maximum CDR. Hetkel frost nova CD 10.2 sekundit. Päris spammiks ei saa nimetada.
Lyth
12.05.2012 10:10:12
Muide, üks "naljakas vahejuhtum". Oli 2011 detsember, kui ma endale puhkust valisin ja kuna mul otseselt mingeid erilisi plaane polnud, siis mõtlesin ,et võiks 14. maist alustada. 3 kuud hiljem sain release date'i teada.
Saatus? Ma arvan küll.
48 |
W!ngs
12.05.2012 10:41:20
Ega Diablo III standard edtiotion peale plaadi väga muud ei sisalda? Siis vist oleks juba targem key osta, kui Euronics pakub hetkel mängu 57€.
Kommentaarid: 23 loe/lisa |
23 |
LKits
Redikate
12.05.2012 10:49:05
3 päeva jäänud!
Eelmine post sisaldas suurel kujul spoilereid seoses guide booki piltidega... nüüd on olemas ka kirjalikul kujul see info.
Hoiatan jälle, et tegu on suure spoileriga ning vaadata ainult omal vastutusel.
NB: Siit spoilerist saadud infot arutagem palun ka spoilerites (vähemalt niikaua kuni mäng väljas ei ole!)
_________________ http://nodejs.org/
"I'm also a person. Programming is just one thing I do." |
33 |
