Veikko
14.01.2012 20:49:54
Kristoferr kirjutas: |
See on tehnoloogia, mis laiatarbekaubaks ilmselt ei saagi. Ei saanud täpselt aru, mis sul mureks on? Kui suuri faile sul vaja liigutada on? Kui tahad kiiret ja järjepidevat kopeerimist, siis SSD vastu ei saa. |
Ssd mul ainult opikas, ülejäänud mahud täna ca 800 GB mis iga päev kasvab vaja iga kuu backuppida teistele ketsatele, selles ongi mure. Tahaks ju 10 minutiga 1 TB liigutada.
LiivaneLord
Sõpradele "Olavi"
14.01.2012 20:56:36
Kristoferr, mina ka ei uskunud, kuni tagasisidena tuli tekst, et "tõesti aitas".
Kommentaarid: 20 loe/lisa |
19 |
14.01.2012 21:12:21
Versiooninumbriks siis 0309 ja changelog:
tsitaat: |
Release Date: 01/13/2012
Change Log:
Changes made in version 0002 (m4 can be updated to revision 0309 directly from either revision 0001, 0002, or 0009)
Correct a condition where an incorrect response to a SMART counter will cause the m4 drive to become unresponsive after 5184 hours of Power-on time. The drive will recover after a power cycle, however, this failure will repeat once per hour after reaching this point. The condition will allow the end user to successfully update firmware, and poses no risk to user or system data stored on the drive.
This firmware update is STRONGLY RECOMMENDED for drives in the field. Although the failure mode due to the SMART Power On Hours counter poses no risk to saved user data, the failure mode can become repetitive, and pose a nuisance to the end user. If the end user has not yet observed this failure mode, this update is required to prevent it from happening.
If you are using a SAS Expander please do not download this Firmware. As soon as we have a Firmware Update that will work in these applications we will release it. |
Kommentaarid: 92 loe/lisa |
WAV
14.01.2012 21:27:53
Veikko kirjutas: |
Sama kaart on jah raidib hdd, raidil marvelli driver. Läbi doki saan hdd-lt laadida hdd peale kiirusega ca 45 MB/s mis minu jaoks üllatavalt aeglane. Kogu masin ja hdd-d sata3. |
Väga võimalik, et see kaart ja RAID teevadki aeglaseks. Ilma RAID'i ja kaardita võib olla kirjutamine kiirem, juhul kui on emaplaadi kiibistikku integreeritud Inteli SATA3 kontroller.
Mul suhteliselt sarnased kettad (sama seeria 3TB variant, mis isegi veidi aeglasemate platteritega) ja alati 80...95 MB/s kirjutab kettalt kettale. RAMdrive pealt samale ühele kettale 154...162 MB/s. Need siis pikema aja (2-3 tundi kirjutamise) keskmised kiirused. Väikeste failide suure hulga juures kiirus natuke langeb, kuid üllatavalt mitte väga palju (võimalik, et ka puhver petab ära).
Kommentaarid: 7 loe/lisa |
Veikko
14.01.2012 21:37:52
WAV kirjutas: |
Veikko kirjutas: |
Mul suhteliselt sarnased kettad (sama seeria 3TB variant, mis isegi veidi aeglasemate platteritega) ja alati 80...95 MB/s kirjutab kettalt kettale. RAMdrive pealt samale ühele kettale 154...162 MB/s. Need siis pikema aja (2-3 tundi kirjutamise) keskmised kiirused. Väikeste failide suure hulga juures kiirus natuke langeb, kuid üllatavalt mitte väga palju (võimalik, et ka puhver petab ära). |
Olen suht võhik, anna juhiseid kus ma saan näha-kontrollida neid inteli SATA3 kontrollerit.
Kristoferr
Kommentaarid: 258 loe/lisa |
209 |
Veikko
14.01.2012 21:47:10
Selline jutt seal, mõhkugi ma ei jaga.
On-Board SATA
• SATAII controller integrated in Intel® P67 (B3) chipset
- Up to 3Gb/s transfer speed.
- Supports four SATAII ports (SATA3~6) by P67 (B3) PCH
• SATAIII controller integrated in Intel® P67 (B3) & Marvell SE9128 chipsets
- Up to 6Gb/s transfer speed.
- Supports two SATAIII ports (SATA1~2) by P67 (B3) PCH
- Supports two SATAIII ports (SATA7~8) by Marvell SE9128
- SATA1~6 ports support RAID 0/1/5/10 mode by Intel P67 (B3) PCH
- SATA7~8 ports support RAID 0/1 mode by Marvell SE9128
• eSATAII controller integrated in JMicron® JMB362 chipset
- Supports two eSATA ports (back panel)
http://www.msi.com/product/mb/P67A-GD65--B3-.html#/?div=Detail
WAV
14.01.2012 21:55:03
Veikko kirjutas: |
Pordid 1 ja 2 ongi need õiged Inteli SATA3 pordid sinu jaoks.
Kristoferr
14.01.2012 21:57:52
Nuh. P67 plaadiga saad teha kuni 4x sata2 ketta raid ja kuni 2x sata3 ketta raidi. Lisaks on võimalik ka marvelli sata3 raid, aga kui vähegi võimalik, siis selle marvelli ma jätaks ainult näiteks optilise seadme jaoks vms. Marvelli kiirusnäitajad ja latency on alla igasugu arvestust ning raid ei toimi seal üldse korralikult.
See ketta port pista sata2 pistikusse. Kuna HDDga sa sata3 kiiruseid nagunii ei vaja, siis P67 sata2 on täpselt samakiire, kui P67 sata3.
_________________ Liitu Binance'ga
Liitu Honey'ga |
209 |
Veikko
14.01.2012 22:08:07
Tänud vastamast. Miks siis see Ordi toppis mulle selle Cronose raidi kaardi sisse. Masin ostetud Ordist, nemad ka panid kokku ja pidid parima seadistuse tagama. Nüüd vaja kedagi targermat kes Tartus tuleks ja seadistaks mulle asja ära. Ma ei soovi oma näppe sinna sisse panna, keeran veel mingi sita kokku. Arvutit ei taha ka kellegipoole viia kuna seal andmebaasid sees ja delikaatne info minu jaoks. Kas on siin kedagi Tartu mehi kes mulle asjad korda teeks, võlgu ei jää.
Kristoferr
209 |
Veikko
Kristoferr
14.01.2012 23:06:07
Võimalik, et saad selle raid1, mis hetkel raid kaardi taga lihtsalt p67 sata2 pistikutesse pista ja rohkem midagi teha vaja polegi. Kui samadele ketastele pole op süsteemi installitud, siis win7 tekitab lihtsalt softraidi ja korras.
See väide vajaks eelnevalt muidugi kellegi targema kinnitust. Ma päris kindel pole.
Liitu Honey'ga |
209 |
14.01.2012 23:58:40
selle marvelli ma jätaks ainult näiteks optilise seadme jaoks vms. |
Kui jutt käib 6Gbps portidest siis:
siinus
15.01.2012 00:03:36
siis polegi sinna mõtet miskit pista
_________________ suck less | ANNA MU SAI!
Kommentaarid: 66 loe/lisa |
59 |
libe
kvaliteetne mees
15.01.2012 00:43:04
tomorrow kirjutas: |
tsitaat: |
Change Log:
peab ära tegema, 4500h juba enda omal täis
_________________ ☠ |
Kommentaarid: 82 loe/lisa |
sama123
15.01.2012 00:52:21
Kas 5000h tõrked on kõikidel M4 või mingil osal.Sai ka pandud 256Gb M4.
Kommentaarid: 23 loe/lisa |
22 |
15.01.2012 05:06:14
sama123, Kõikidel minuteada.
lehm
Kommentaarid: 117 loe/lisa |
110 |
SilQ
15.01.2012 14:12:19
Räägiti siin Crusiali ketaste firmware uuendustest. Vaatasin siis lehelt kas minu vanale C300'le ka mingisugust uuendust on, isegi oli üks versioon uuem.
Aga tee mis tahad õpetuse järgi mina küll seda uuendama ei saa. Veaks ütleb: No default or UI confiuration directive found!
Kas mul jääb midagi tegemata või millest selline viga, oskab keegi öelda?
Kommentaarid: 241 loe/lisa |
208 |
heikis
15.01.2012 14:17:09
SilQ kirjutas: |
Kas mul jääb midagi tegemata või millest selline viga, oskab keegi öelda? |
mis versioon sul hetkel on?
firmware uuendusi peab tegema IDE modes. AHCI modes ei pruugi alati õnnestuda
Kommentaarid: 338 loe/lisa |
290 |
SilQ
15.01.2012 14:25:01
heikis kirjutas: |
SilQ kirjutas: |
firmware uuendusi peab tegema IDE modes. AHCI modes ei pruugi alati õnnestuda |
006 uus on 007. IDE modesse ma ei tõsnud jah.
Edit: tehtud. IDE mode oli abiks, tänud.
208 |
rycyve
15.01.2012 15:52:00
Kas ssd-l kaob ka nt.120gb-st 8gb ära ja see on normaalne?
_________________ CH341A EEPROM Flash BIOS teenus. |
Kommentaarid: 98 loe/lisa |
81 |
WAV
15.01.2012 15:53:37
rycyve kirjutas: |
Kas ssd-l kaob ka nt.120gb-st 8gb ära ja see on normaalne? |
Oleneb kas sa mõõdad gigabaitides (GB) või gibibaitides (GiB). Ära ei kao midagi.
rycyve
15.01.2012 15:57:24
WAV kirjutas: |
rycyve kirjutas: |
Oleneb kas sa mõõdad gigabaitides (GB) või gibibaitides (GiB). Ära ei kao midagi. |
Huvitav mul äsja arvutisse pistetud tutikas SSD näitab wini all 111,7Gb Midagi pole installinud ja arvuti jookseb teise ketta OS-i pealt.
81 |
