pots4t4j4
23.10.2011 17:42:50
| maatriks kirjutas: |
universal cooler - Intel: LGA1366 / 1156 / 775 AMD: AM3 / AM2+ / AM2
LGA1155 ? |
on minuteada sama mis 1156, pead ei anna tho
e: LGA 1155 is designed as a replacement for the LGA 1156 (known as Socket H). LGA 1155 has 1155 protruding pins to make contact with the pads on the processor. Processors of LGA 1155 and LGA 1156 sockets are not compatible with each other since they have different socket notches. However, cooling solutions are backwards compatible between both LGA 1155 and LGA 1156 sockets, due to both having the same distance of 75 mm between each screw hole.[2]
401 |
softis
23.10.2011 18:01:42
| pots4t4j4 kirjutas: |
kui korralikku jahutit tahta võiks ikka NH-D14 ära võtta, sellega pole ka mingi probleem 90c + 2500k peal ajada,
lisaks on megaga võrreldes asjal kaasas 2 korralikku fani ja maksab ainult 20€ rohkem. |
Kes PWM'i eelistab, võib Silver Arrow ka võtta
| Kommentaarid: 21 loe/lisa |
21 |
heikis
23.10.2011 18:14:15
| millist pastat praegu mõistlik osta on? arctic mx4?
| Kommentaarid: 338 loe/lisa |
290 |
23.10.2011 20:07:11
LGA1155 ? |
e: LGA 1155 is designed as a replacement for the LGA 1156 (known as Socket H). LGA 1155 has 1155 protruding pins to make contact with the pads on the processor. Processors of LGA 1155 and LGA 1156 sockets are not compatible with each other since they have different socket notches. However, cooling solutions are backwards compatible between both LGA 1155 and LGA 1156 sockets, due to both having the same distance of 75 mm between each screw hole.[2] |
Seda ma mõtlesin jah, et D14 on ju 1156-le mõeldud.Tänud selgituse eest
| Kommentaarid: 92 loe/lisa |
Raunts33
02.11.2011 00:34:39
| heikis kirjutas: |
| millist pastat praegu mõistlik osta on? arctic mx4? |
Mx4 töötab päris hästi, hea määrida ja värki. Sõber kasutab, ise chill factor III peal.
| Kommentaarid: 39 loe/lisa |
von Wu
02.11.2011 01:04:52
Reklaamivad küll, et on hästi hea määrida, aga pole see nii lihtne midagi. Täpi meetodiga olen parema tulemuse saanud.
Arctic Silver 5-t on muidugi kohutavalt raske korralikult määrida.
_________________ Müüa igasugu asju
| Kommentaarid: 904 loe/lisa |
678 |
von Wu
02.11.2011 18:04:56
No minu jaoks on see ikka väga paks. MX-4 pasta on tunduvalt vedelam.
E: soojana on AS5 üsna vedel.
678 |
Chidori
06.11.2011 12:28:13
| Mina panen alati termopasta tuubi kuuma vette 5'ks minutiks ja alles siis kasutan teda.
99 |
Le Inc
06.11.2011 17:45:24
Thermalright Archon - 4,75 GHz 2500k ~max 59 C. Toas kuskil ~19 C. Igati mõnus ja vaikne 1200 rpm 140 mm ventilaator (see siis def. HAF 922 korpuses).
| Kommentaarid: 56 loe/lisa |
54 |
pots4t4j4
06.11.2011 17:46:29
| max 59c millaga sa seda max tempi testid kui saladus pole ?
401 |
Le Inc
06.11.2011 18:51:08
Nii realtemp kui CPUID Hardware monitor näitavad sama. Asus AI Suite üllatab hoopis 48 C. , aga seda ma väga ei usuks. Hetkel on 40 mintsa Prime95 mütanud, üle 59 C pole fikseeritud.
Inteli burn in annab ~4 .. 5 C juurde. Prime95 keskmine on tegelikult max ~55..56C juures.
54 |
libe
kvaliteetne mees
06.11.2011 19:03:59
ja prime mis režiimiga?
_________________ ☠ |
| Kommentaarid: 82 loe/lisa |
Le Inc
06.11.2011 19:14:43
Prime95 - Small FFT (Maximum FPU stress).
Inteli burn In testis sai valitud maximum stress, mida ta tiksutas 5x. Sealt 59 C max. See on kohe tunda, Inteli testiga hangub pea kogu masin kinni, aknad avanevad paarisekundilise hilinemisega. Prime on suht-koht poisike selle kõrval.
54 |
Killer-Bea
| Kommentaarid: 9 loe/lisa |
9 |
Nu
14.11.2011 18:54:26
Kuna midagi paremat siin tartus poest saada polnud siis võtsin akasa venom voodoo. see on siis 6 pipega. tavaline venom on 4'ga.
ruumi temp praegu 21,6 ja idle on30C, prime95 smallFFT'ga max 60C
cpu auto voldiga 4Ghz.
Seda siis ühe vendiga. teist mis peaks tõmbama ei hakanud ühendama.
Kahjuks ma ei näe mis pööretega asi käib, sest ükski proge ei taha näidata rpm'i millegipärast aga idles midagi kuulda ei ole.
_________________ DO you want it.. And if you had it would you flaunt it...
ss |
157 |
K3ndu
19.11.2011 00:16:57
Ventilaatorid teevad ikka meeletu vahe, mul vahepeal oli 4 ventilaatorit rivist väljas millest 3 on endiselt. Ja täiskoormusel temperatuur tõusis ikka päris korralikult, rohkem kui 7 kraadi selle tõttu.
Kokku korpuses siis 6 ventilaatorit.
120 |
Sandor
01.12.2011 21:40:25
Nii tekkis probleem.
Speedfan näitab selliseid temperatuure:
Bios aga ütleb CPU tempiks 30*C
Mis värk on?
Edit: Unustasin lisada, et cooleriks on CM Hyper 212+
| Kommentaarid: 11 loe/lisa |
Drizzle
| Kommentaarid: 93 loe/lisa |
Jhael
Diesel157
09.12.2011 17:32:57
| Kas aida64 tempe võib usaldada? Nimelt sattusin mingi moment peale ja tempiks oli märgitud 17-18C per core ja cpu all oli vist 19C... jahutus on stock ja prose phenom II 840.
| Kommentaarid: 162 loe/lisa |
146 |
WäntWõll
make.believe
09.12.2011 17:52:28
| Kui sul tuba 20c siis täitsa reaalne.
300 |
Diesel157
09.12.2011 19:05:20
Tuba enamasti 15-18 . Hea arvuti jahutuse temp, aga elada on külm .
146 |
WäntWõll
make.believe
09.12.2011 20:15:31
| Diesel157 kirjutas: |
Tuba enamasti 15-18 . Hea arvuti jahutuse temp, aga elada on külm . |
endal suht sama, ei kurda (keskmine on ikka 19c kandis)
Ei ole tervisehädasid ja kunagi kui sai keskküttega elatud siis +24c hakkas juba pea paksuks tõmbama ning mingid nohud ja jutud oli aastaringselt kallal
300 |
Diesel157
09.12.2011 20:51:55
Njh, aga kui ma juba teema üles võtsin, siis oleks vaja prosele tegelikult uut jahutust, kui linna +25C kätte minna. Vaja oleks odavat ja vaikset jahutust mis puhuks paremalt vasakule suunal. Enamus jahutustel saab ainult ülevalt alla või vastupidi panna puhuma AMD plaadil. Probleemiks antud plaadil on mälupesad ja kondekat mis paiknevad väga prose jahutuse raami ligidal... Ideesid
Sellise leidsin, aga rohkem ei hakka silma nagu - http://www.modikomp.ee/jahutused/RR-S200-18FK-R1/
146 |
WäntWõll
make.believe
09.12.2011 21:02:46
See on AMD piix jah, aga vahet pole, võid lasta läbi toite, vahe on olematu
300 |
Diesel157
09.12.2011 21:16:03
Asi selles, et mu arvuti asendab momendil radikat suht efektiivselt. Graafika kütab kah üles suunal... natuke palju saab vb toitele välja puhuda...
Graafika jookseb stockis (Toas on momendil 17C)
GPU1: GPU diood (DispIO) 46 °C (115 °F)
GPU1: GPU diood (MemIO) 48 °C (118 °F)
GPU1: GPU diood (Shader) 49 °C (120 °F)
GPU2: GPU diood (DispIO) 41 °C (106 °F)
GPU2: GPU diood (MemIO) 46 °C (115 °F)
GPU2: GPU diood (Shader) 46 °C (115 °F)
146 |
CoiL
09.12.2011 22:26:34
| Diesel157, alati on võimalus ettejävad kondekad teiselepoole plaati ümber joota või siis niimoodi, et neid annaks eemale painutada. Aga üldiselt suht mõttetu tegevus kui just mingit über OC LN2 toru ei soovi peale lükata. Kärab see jahutus sul niisama kah ja toiteploki üheks funktsiooniks ongi korpusest kuum õhk väljutada.
| Kommentaarid: 95 loe/lisa |
83 |
Chidori
11.12.2011 00:44:01
| CoiL kirjutas: |
| toiteploki üheks funktsiooniks ongi korpusest kuum õhk väljutada. |
Mis asja? See vähendab toiteploki effektiivsust ja eluiga tublisti.
Originaalis oli toiteplokil 80mm ventikas taga ja asetses ta üleval kuna ei pidanud nii pikad kaablid olema, et komponentideni jõuda - õhku ta protsessodi kohalt ei võtnud.
Tänapäeva toited on seda dünaamikat natuke muutnud 120mm ventikaga ja seetõttu on enamustel uutel korpustel toiteplokk all - Õhu korpusest välja ajamine ei ole toite funktsioon.
99 |
CoiL
11.12.2011 12:32:48
Chidori, loe hoolikalt... see on üheks toiteka funktsiooniks tänapäeval. Ei väitnud, et peamine funktsioon. Oli kunagi mis oli. Fakt on see ,et enamus toiteid on tänapäeval suurema ventikaga ja korpused sellised kust toitekas sooja õhku välja imeb. Loomulikult toiteka eluiga väheneb kui mingi üliumbne ja kuum kast kuid üldjuhul on see eluiga kadu selle korpuse õhu välja imemise tõttu küll üsnagi tühine. Ei tasu nagu juuksekarva ka lõhki ajada
83 |
11.12.2011 13:19:47
Diesel157, mis sind takistab mõnd neljakandilist towerit ostmast? võta ninja3 ligi ja topi vendid täpselt nii pidi nagu sulle endale meeldib.
Chidori, efektiivsust vähendada võib aga ei pruugi. toidetel on kohati kalduvused soojemas paremini töötada. eks see kõik sõltub temperatuurist.
pealegi, atx standard mu mäletamist mööda ütlebki jah, et toiteploki ülesandeks on muuhulgas ka soe õhk kastist väljutada.
praktikas... mina enam ei osta omale kasti, kus toide on üleval. kui ikka soe õhk mingilgi määral sinna satub, ja tõustes ta sinna satub, siis läheb toide lärmakaks ja väga kuumaks minnes just nagu Chidori ütles, hakkab ka toite käitumisele ja elueale.
_________________ - londiste
217 |
Chidori
11.12.2011 17:35:16
| londiste kirjutas: |
| atx standard mu mäletamist mööda ütlebki jah, et toiteploki ülesandeks on muuhulgas ka soe õhk kastist väljutada. |
ATX spec: "The power supply should be placed in close proximity to the processor if the power supply is expected to cool the processor properly" ja 2 rida allpool "A system fan should be considered to allow for proper cooling of all system components." Toite spec: "In general, exhausting air from the system chassis enclosure via a power supply fan at the rear panel is the preferred, most common, and most widely applicable system-level airflow solution. However, some system/chassis designers may choose to use other configurations to meet specific system cooling requirements."
Kas seda päris ülesandeks nimetada saab - pigem on igalpool kirjas, et nii saab teha. Lihtsamate integreeritud süsteemide puhul ei ole see probleemiks aga võimsamate arvutite puhul ei tasu seda võimalust mainidagi.
99 |
heff
11.12.2011 17:36:33
| Päris paljudel uutel kastidel ju hoopis toide võtab korpuse alt õhku ja toimetab tagant välja ilma korpusesisese õhuvooluga kokku puutumata.
97 |
Killer-Bea
11.12.2011 19:06:39
Hiljuti soetasin Chieftec 750w 14cm toite ja sellel näiteks on pool ventikast kaetud plast kattega, mis ei lase üldse tagant õhku välja vaid lükkab selle masinasse tagasi, prose muidugi 2-5c kuumem võrreldes vana toitega, sai maha kisutud see sealt vahelt.
9 |
Chidori
11.12.2011 19:56:52
| Killer-Bea, see ei ole päris nii - see plastik on seal õhu suunaja, et õhk liiguks tagaosast läbi mitte kohe eest välja
99 |
babylon
12.12.2011 19:29:30
Tere
Mul kysimus, et ka arctic freezer 13 pro orig. Termopasta(see mis on kohe jahutuse radika peal) kõlbab kasutada? Voi tuleks kohe välja vahetada?
Tänud ette
| Kommentaarid: 55 loe/lisa |
53 |
12.12.2011 19:33:55
hea termopastaga saab paremal juhul paar kraadi temperatuurivõitu, mis tavakasutuses mingit moodi näole ei anna.
ehk siis kasuta seda, mis all on.
217 |
Timo1337
12.12.2011 19:38:55
| articu termopasta peaks üsna normaalne olema.
| Kommentaarid: 49 loe/lisa |
46 |
Chidori
12.12.2011 21:26:35
| babylon, Arctic MX-2, vägagi hea pasta on all.
99 |
tarmo92
23.12.2011 02:17:12
| Selline küsimus, OCZ Vendetta2 on peale pandud i5 2500k-le. Prose jookseb 4,5GHz peal. IntelBurnIn testiga tuli max tempiks 70 kraadi. Termopastaks on AC MX2. Kas peaksin muretsema või mitte? Toatemp on 20-21 kraadi
heff
23.12.2011 02:18:12
| Ei peaks.
97 |
pots4t4j4
23.12.2011 08:26:03
75 kraadi on jumala normaalne, enda 2500k läheb linxi all kuni 95c NH-D14 all
401 |
heff
23.12.2011 09:06:56
| Ok, 95c ma juba muretseks, aga kuidas kellelegi. Ise oma 45nm 920-t ma üle 80 ei taha lasta.
97 |
pots4t4j4
23.12.2011 09:41:23
| 00bandiit0 kirjutas: |
lasta. |
mis seal muretseda, selline temp vaid seal 1,5v+ all.
401 |
heff
23.12.2011 14:55:21
| Pidasin silmas 24/7 seadistust.
97 |
Fisher
23.12.2011 18:30:20
võtsin eile arvutikeskusest termopasta, nexuse oma. no nii hirmsat asja pole minu silmad varem näinud:) võibolla oleks pidanud mitte ütlema müüjale "andke mulle mingi pohui termopasta, mis oleks samas mõistlik". temperatuurid olid 2500k 4,4g peal umbes 10 kraadi kõrgemad, kui MX-2 pastaga, mille linnunokatäie õnneks sahtlisügavusest leidsin.
samas, selle nexuse omaga saab nüüd midagi hõbedaseks mäkerdada! (see on siukse üsna vedel ja väga hõbedane ollus)
65 |
siinus
23.12.2011 18:49:31
a miks sa MX-2 ei ostnud siis hoopis?
_________________ suck less | no slop grenade
| Kommentaarid: 70 loe/lisa |
63 |
Timo1337
23.12.2011 19:50:08
| mul ka nexuse oma ja ei kurdaks küll tempide üle ... 2600k idle 30c-33c ja mängides 55c max.
46 |
Fisher
23.12.2011 22:17:00
| djpvx kirjutas: |
| a miks sa MX-2 ei ostnud siis hoopis? |
noh, eeldasin, et kõik nad on suht sama vitsaga löödud, et kui siis võibolla paari kraadine vahe on temperatuuris.
65 |
Chidori
25.12.2011 18:48:13
Fisher, Oleneb kuidas ta tehtud on - Kui on hõbeda baasil siis oleneb mitu % seal hõbedat on ja mis see ülejäänud % on... tavaliselt on hõbedat % 5-15 ja see ülejäänud on ju seega vägagi oluline?
Samuti ei tööta hõbeda baasil termopastad üldse hästi kui neid vähe paksemalt panna.
Keraamilised (plastilised?) termopastad on aga toimivuselt palju sarnasemad kui hõbeda baasil ja nendel tõesti suurt vahet ei märka... Samuti kannatab neid natuke paksema kihina panna ilma, et suurt probleemi oleks.
99 |
