pots4t4j4
23.10.2011 16:42:50
| maatriks kirjutas: |
universal cooler - Intel: LGA1366 / 1156 / 775 AMD: AM3 / AM2+ / AM2
LGA1155 ? |
on minuteada sama mis 1156, pead ei anna tho
e: LGA 1155 is designed as a replacement for the LGA 1156 (known as Socket H). LGA 1155 has 1155 protruding pins to make contact with the pads on the processor. Processors of LGA 1155 and LGA 1156 sockets are not compatible with each other since they have different socket notches. However, cooling solutions are backwards compatible between both LGA 1155 and LGA 1156 sockets, due to both having the same distance of 75 mm between each screw hole.[2]
401 |
softis
23.10.2011 17:01:42
| pots4t4j4 kirjutas: |
kui korralikku jahutit tahta võiks ikka NH-D14 ära võtta, sellega pole ka mingi probleem 90c + 2500k peal ajada,
lisaks on megaga võrreldes asjal kaasas 2 korralikku fani ja maksab ainult 20€ rohkem. |
Kes PWM'i eelistab, võib Silver Arrow ka võtta
| Kommentaarid: 21 loe/lisa |
21 |
heikis
23.10.2011 17:14:15
| millist pastat praegu mõistlik osta on? arctic mx4?
| Kommentaarid: 338 loe/lisa |
290 |
23.10.2011 19:07:11
LGA1155 ? |
e: LGA 1155 is designed as a replacement for the LGA 1156 (known as Socket H). LGA 1155 has 1155 protruding pins to make contact with the pads on the processor. Processors of LGA 1155 and LGA 1156 sockets are not compatible with each other since they have different socket notches. However, cooling solutions are backwards compatible between both LGA 1155 and LGA 1156 sockets, due to both having the same distance of 75 mm between each screw hole.[2] |
Seda ma mõtlesin jah, et D14 on ju 1156-le mõeldud.Tänud selgituse eest
| Kommentaarid: 92 loe/lisa |
Raunts33
01.11.2011 23:34:39
| heikis kirjutas: |
| millist pastat praegu mõistlik osta on? arctic mx4? |
Mx4 töötab päris hästi, hea määrida ja värki. Sõber kasutab, ise chill factor III peal.
| Kommentaarid: 39 loe/lisa |
von Wu
02.11.2011 00:04:52
Reklaamivad küll, et on hästi hea määrida, aga pole see nii lihtne midagi. Täpi meetodiga olen parema tulemuse saanud.
Arctic Silver 5-t on muidugi kohutavalt raske korralikult määrida.
_________________ Osta auto ära |
| Kommentaarid: 890 loe/lisa |
669 |
02.11.2011 08:44:21
| von Wu kirjutas: |
Arctic Silver 5-t on muidugi kohutavalt raske korralikult määrida.  |
Nali?
AS5 väga hea määrida.Pole liiga vedel ega liiga paks.
von Wu
02.11.2011 17:04:56
No minu jaoks on see ikka väga paks. MX-4 pasta on tunduvalt vedelam.
E: soojana on AS5 üsna vedel.
669 |
Chidori
06.11.2011 11:28:13
| Mina panen alati termopasta tuubi kuuma vette 5'ks minutiks ja alles siis kasutan teda.
99 |
Le Inc
06.11.2011 16:45:24
Thermalright Archon - 4,75 GHz 2500k ~max 59 C. Toas kuskil ~19 C. Igati mõnus ja vaikne 1200 rpm 140 mm ventilaator (see siis def. HAF 922 korpuses).
| Kommentaarid: 56 loe/lisa |
54 |
pots4t4j4
06.11.2011 16:46:29
| max 59c millaga sa seda max tempi testid kui saladus pole ?
401 |
Le Inc
06.11.2011 17:51:08
Nii realtemp kui CPUID Hardware monitor näitavad sama. Asus AI Suite üllatab hoopis 48 C. , aga seda ma väga ei usuks. Hetkel on 40 mintsa Prime95 mütanud, üle 59 C pole fikseeritud.
Inteli burn in annab ~4 .. 5 C juurde. Prime95 keskmine on tegelikult max ~55..56C juures.
54 |
libe
kvaliteetne mees
06.11.2011 18:03:59
ja prime mis režiimiga?
_________________ ☠ |
| Kommentaarid: 82 loe/lisa |
Le Inc
06.11.2011 18:14:43
Prime95 - Small FFT (Maximum FPU stress).
Inteli burn In testis sai valitud maximum stress, mida ta tiksutas 5x. Sealt 59 C max. See on kohe tunda, Inteli testiga hangub pea kogu masin kinni, aknad avanevad paarisekundilise hilinemisega. Prime on suht-koht poisike selle kõrval.
54 |
Killer-Bea
| Kommentaarid: 9 loe/lisa |
9 |
Nu
14.11.2011 17:54:26
Kuna midagi paremat siin tartus poest saada polnud siis võtsin akasa venom voodoo. see on siis 6 pipega. tavaline venom on 4'ga.
ruumi temp praegu 21,6 ja idle on30C, prime95 smallFFT'ga max 60C
cpu auto voldiga 4Ghz.
Seda siis ühe vendiga. teist mis peaks tõmbama ei hakanud ühendama.
Kahjuks ma ei näe mis pööretega asi käib, sest ükski proge ei taha näidata rpm'i millegipärast aga idles midagi kuulda ei ole.
_________________ DO you want it.. And if you had it would you flaunt it...
ss |
157 |
K3ndu
18.11.2011 23:16:57
Ventilaatorid teevad ikka meeletu vahe, mul vahepeal oli 4 ventilaatorit rivist väljas millest 3 on endiselt. Ja täiskoormusel temperatuur tõusis ikka päris korralikult, rohkem kui 7 kraadi selle tõttu.
Kokku korpuses siis 6 ventilaatorit.
| Kommentaarid: 127 loe/lisa |
117 |
Sandor
01.12.2011 20:40:25
Nii tekkis probleem.
Speedfan näitab selliseid temperatuure:
Bios aga ütleb CPU tempiks 30*C
Mis värk on?
Edit: Unustasin lisada, et cooleriks on CM Hyper 212+
9 |
Drizzle
| Kommentaarid: 93 loe/lisa |
Jhael
| Kommentaarid: 11 loe/lisa |
Diesel157
09.12.2011 16:32:57
| Kas aida64 tempe võib usaldada? Nimelt sattusin mingi moment peale ja tempiks oli märgitud 17-18C per core ja cpu all oli vist 19C... jahutus on stock ja prose phenom II 840.
141 |
WäntWõll
make.believe
09.12.2011 16:52:28
| Kui sul tuba 20c siis täitsa reaalne.
300 |
Diesel157
09.12.2011 18:05:20
Tuba enamasti 15-18 . Hea arvuti jahutuse temp, aga elada on külm .
141 |
WäntWõll
make.believe
09.12.2011 19:15:31
| Diesel157 kirjutas: |
Tuba enamasti 15-18 . Hea arvuti jahutuse temp, aga elada on külm . |
endal suht sama, ei kurda (keskmine on ikka 19c kandis)
Ei ole tervisehädasid ja kunagi kui sai keskküttega elatud siis +24c hakkas juba pea paksuks tõmbama ning mingid nohud ja jutud oli aastaringselt kallal
300 |
Diesel157
09.12.2011 19:51:55
Njh, aga kui ma juba teema üles võtsin, siis oleks vaja prosele tegelikult uut jahutust, kui linna +25C kätte minna. Vaja oleks odavat ja vaikset jahutust mis puhuks paremalt vasakule suunal. Enamus jahutustel saab ainult ülevalt alla või vastupidi panna puhuma AMD plaadil. Probleemiks antud plaadil on mälupesad ja kondekat mis paiknevad väga prose jahutuse raami ligidal... Ideesid
Sellise leidsin, aga rohkem ei hakka silma nagu - http://www.modikomp.ee/jahutused/RR-S200-18FK-R1/
141 |
