sõnum |
Andrus Luht
itimees.ee
Kommentaarid: 377 loe/lisa |
318 |
01.12.2011 22:58:55
Ei ei aita ka see. Kummaline on, et USB kaudu ühendamisel ei ilmu tavapärast dialoogi kus Win7 (suutmata tuvastada seadet) küsib drivereid.
Device Manageri ilmub üks HID Compliant Device ja üks USB Input Device aga üritades kummagile neile käsitsi ette sööta drivereid lahtipakitud UPSDriver_227 kaustast, siis öeldakse, et uusimad driverid on juba installitud.
Devices and Printers all on UPS näha aga nimetusega USB to Serial:
Isegi käsureaga driveri installimine süsteemi justkui toimib. Driver justkui käivitub aga seadet ei tuvastata üheselt UPS-na ja LanSafe ei suuda seda installi käigus ikka leida
Käsurea väljavõte:
D:\Downloads\------------DOWNLOADS--------------\UPSDriver_227\PowerwareUPSDriver>wdreg64_Vista.exe
WDREG utility v8.10, Copyright (c) 2003 - 2006 Jungo Ltd. http://www.jungo.com
Command usage:
non-WDM Drivers: (.SYS drivers on WinNT4; .VXD drivers on Win95/98/Me;
KernelPlugin Win2000/XP)
wdreg64_Vista.exe [Options ...] Action [Action ...]
Options:
-startup <level>: Set startup level: boot, system, automatic,
demand, disabled (default: automatic).
-name <name>: Set then name of the driver (default: windrvr6).
-file <filename>: Set the file name of the driver.
-vxd: Load a .vxd driver(Win95/98/Me only)
-silent: Suppress all messages.
-log <filename>: Log all messages to filename.
Actions:
create: create a registry entry for the driver.
delete: delete the registry entry for the driver.
start: start the driver.
stop: stop the driver.
install: stop + start (if an older version exists)
or create + start (otherwise).
uninstall: stop + delete.
WDM Drivers: (Win2000/XP)
wdreg64_Vista.exe -inf <filename> [-silent] [-log <filename>] Action [Action ...
Options:
-inf <filename>: Full path to an INF file to be dynamically loaded.
Actions:
install: install the INF file (if needed, reloads new driver file).
uninstall: uninstall the INF file.
enable: enable the driver.
disable: disable the driver.
wdreg64_Vista.exe -rescan <enumerator> [-silent] [-log <filename>]
Options:
-rescan <enumerator>: Rescan enumerator (ROOT, ACPI, PCI, USB etc.) for
hardware changes. Only one enumerator can be specified.
For more information, please refer to WinDriver manual.
D:\Downloads\------------DOWNLOADS--------------\UPSDriver_227\PowerwareUPSDriver>wdreg64_Vista.exe install
Nothing to stop: service windrvr6 does not exist
Service windrvr6 already deleted
Error: Error starting the service windrvr6: The system cannot find the file specified.
Error: Failed trying to install the driver
D:\Downloads\------------DOWNLOADS--------------\UPSDriver_227\PowerwareUPSDriver>wdreg64_Vista.exe -inf "D:\Downloads\------------DOWNLOADS--------------\UPSDriver_227\PowerwareUPSDriver\PwdUSB.inf"
no action specified: nothing to do!
D:\Downloads\------------DOWNLOADS--------------\UPSDriver_227\PowerwareUPSDriver>wdreg64_Vista.exe -inf "D:\Downloads\------------DOWNLOADS--------------\UPSDriver_227\PowerwareUPSDriver\PwdUSB.inf" install
Warning: the device (hwid:USB\VID_0592&PID_0000) is not plugged-in.
Warning: the device (hwid:USB\VID_0592&PID_0002) is not plugged-in.
Warning: the device (hwid:USB\VID_0592&PID_0003) is not plugged-in.
Warning: the device (hwid:USB\VID_06DA&PID_0002) is not plugged-in.
install: completed successfully
D:\Downloads\------------DOWNLOADS--------------\UPSDriver_227\PowerwareUPSDriver>wdreg64_Vista.exe -inf "D:\Downloads\------------DOWNLOADS--------------\UPSDriver_227\PowerwareUPSDriver\PwSrlPnP.inf" install
Error: Failed retrieving manufacturer PWR.ntamd64 section from INF file D:\Downl
oads\------------DOWNLOADS--------------\UPSDriver_227\PowerwareUPSDriver\PwSrlPnP.inf:
D:\Downloads\------------DOWNLOADS--------------\UPSDriver_227\PowerwareUPSDriver>wdreg64_Vista.exe -inf "D:\Downloads\------------DOWNLOADS--------------\UPSDriver_227\PowerwareUPSDriver\PwdUSB.inf" enable
Error: Failed to enable device (USB\VID_0592&PID_0000)
Error finding the device USB\VID_0592&PID_0000
Error: Failed trying to enable the driver
D:\Downloads\------------DOWNLOADS--------------\UPSDriver_227\PowerwareUPSDriver>wdreg64_Vista.exe -inf "D:\Downloads\------------DOWNLOADS--------------\UPSDriver_227\PowerwareUPSDriver\x64\windrvr6.inf" install
D:\Downloads\------------DOWNLOADS--------------\UPSDriver_227\PowerwareUPSDriver>wdreg64_Vista.exe -inf "D:\Downloads\------------DOWNLOADS--------------\UPSDriver_227\PowerwareUPSDriver\x64\windrvr6.inf" enable
enable: completed successfully |
Tõsiselt arusaamatu mis toimub. Kas UPSDriver_227 sisalduvad driverid siis pole sellele seadmele ja ainus võimalus on kasutada seda winpower tarkvara?
See toimib aga nagu öeldud on selle kasutamine väga ebamugav:
Kommentaarid: 89 loe/lisa |
79 |
03.12.2011 20:05:11
USB to Serial draiver peaks sulle tekitama virtuaalse COM-pordi portide nimekirja. Sealt peaksid saama valida ka selle pordi numbrit vajadusel (COM1, COM2, ... )
Ja tarkvara seadistuses valid siis vastava COM pordi UPS-i pordiks, kui see seda ise leida ei suuda. (Muidugi ma ei välista, et seda tarkvara ei saagi installida, kui ta ise pole võimeline UPSi üles leidma)
Igaks juhuks katsu pordi number sättida COM1 või COM2, kui need juba kasutusel ei ole ja kui on, siis vaheta omavahel ära (see on ka võimalik). Vanemat sorti tarkvarajupid ei oska vahel suuremat arvu COM porte oodata.
See kipub olema UPS-ide tootjapoolse tarkvara needuseks, et need tarkvarajupid on museaalse väärtusega väga tihti. Ja ega kasutusmugavust ka sealt üldjuhul ka ei leia.
Kommentaarid: 33 loe/lisa |
04.12.2011 17:47:55
Ma üritasin LanSafe installides ka COM porti valida aga seal oli nimekiri tühi ja polnud midagi valida. Eks järgmine nädal nokitsen vaikselt edasi asja kallal. Nii lihtsalt alla ei anna
79 |
LiivaneLord
Sõpradele "Olavi"
04.12.2011 20:26:15
tomorrow kirjutas: |
Ma üritasin LanSafe installides ka COM porti valida aga seal oli nimekiri tühi ja polnud midagi valida. Eks järgmine nädal nokitsen vaikselt edasi asja kallal. Nii lihtsalt alla ei anna |
Seda oleks hea näha.
Kommentaarid: 20 loe/lisa |
19 |
07.12.2011 23:05:47
1. Kuidas UPS suhtub pikendusjuhtmetesse?
2. Mis kulutab UPS-i akut?
3. Välguga peab ikka kogu krempli välja lülitama? (majal on piksemaandus ja pistikul on maandus).
Punkt 1 küsin, kuna oleks vaja pikendusjuhet taha kuhu eelkõige ruuter ühendada, et peale voolukatkestust ei peaks ootama ruuteri starti + kõlarid ja printer kah aga need kaks 90% ajast välja lülitatud niikuinii.
Niipalju sai Wikipedia abil selgeks, et tegu peaks siis olema C14 --> Schuko pikenduskaabliga kus C14 otsik ühendatakse UPS taha ja pikenduskaabli Schuko portidesse siis vajalikud seadmed.
Pikendusjuhtme pesad peaks olema ümmargused Schuko mitte need kitsad Euro mõõtu:
Mõned pildid mis ma leidsin sellistest pikenduskaablitest:
Hinnad varieerusid 10-30€ kandis. On eestis kah kuskil selliseid saada või peab ekstra saksamaalt tellima?
Või on mingi muu variant kuidas ruuter,printer ja kõlarid kah UPS-i taha saada?
Punkt 2 küsin kuna huvitab see mis UPS-i akut rohkem kulutab. Kas see kui UPS peab akutoitel seadmeid üleval hoidma või see, kui asi lihtsalt vooluvõrgus on 24/7?
Punkt 3 küsin peamiselt suve silmas pidades. Talvel on välk õnneks äärmiselt harv juhus.
79 |
A.S.
33 |
LiivaneLord
Sõpradele "Olavi"
08.12.2011 00:30:56
Taolist pistikut tuleks jah hankida. Ei tahaks anda soovitusi, kuidas kaablilt ja pikenduselt pistikud otsast maha lõigata ning seejärel need ära vahetada ...
Omal on mul üks taolise isase pistikuga pikendus ning teine sai korralikult ise tehtud (ühelt igivanalt lauaarvuti kaablilt sai isane pistik võetud).
19 |
08.12.2011 00:33:34
A.S. kirjutas: |
Endal käib suvalise pikenduskaabli pistiku vahetamine üle jõu? |
Jah. Ise ei hakka küll midagi käsitsi aretama. Eriti seoses elektriasjandusega millest ma niigi eriti ei jaga midagi. Tulemused võivad olla..mkhmm..särtsakad
Parem tellin selle pikenduse ära kuskilt
79 |
08.12.2011 00:35:20
Enamus UPSe on offlin või siis line interactive tüüpi, see viimane lülitab aku taha ka pingekõikumiste ajal.
Samas aga reaalselt kumbki akut ei kasuta, va. juhul, kui pinge hoopiski kaob.
On ka kolmas tüüp upse, mis toidabki seadmeid ainult akust genereeritava energiaga ja voolivõrgust leatakse pidevalt akut.
See selleks.
Juhtme saad aga tõesti ise teha, elfaelektroonika on sulle vist lähim ostukoht, või balti-jaama turg. Sealt saad viidatud pistiku ja pikendusjuhtme leiad kodust või lähimast toidupoest (enamustes ikka müüakse )
Kommentaarid: 133 loe/lisa |
120 |
A.S.
33 |
08.12.2011 05:23:34
A.S., Tänud. Ei arvanud, et meil siin midagi sellist on. Uurin huviga edasi
79 |
Dijital
09.12.2011 16:43:45
Hm.. Äriplaan ju lausa, osta pikendusi ja pistikuid. 1 rutsi eest otsik, 5 eest mõne-meetrine pikendus, 5 minutit kruvisid keerata ja valmis .
Ma endal tegin ka ise mõned aastad tagasi sellise nupuga mudeli.
_________________ Mobrog tasustatud küsitluste paneeli affiliate link: KUTSE |
Kommentaarid: 40 loe/lisa |
31 |
Longero
14.12.2011 02:18:31
Küsiks kas erinevad tootjad kirjutavad erinevalt mis klassi UPS kuulub, et ühel on Line-Interactive UPS ja teisel Smart UPS, kas need tähendavad tegelikult üht ja sama?
Oskab keegi öelda palju UPS kaotab vananedes võimsust (arvuti toitekas pidavat samuti kaotama), ei anna kirjade järgi lubatud tootlust, pean silmas mitte akude poolt vaid seadme enda sisu nagu kondekad v misiganes seal pidid toimivust kaotama tasapisi. Mitu protsenti 3, 4, 5 aasta kohta võiks olla kadu... kasvõi ubkaudseltki?
Kommentaarid: 49 loe/lisa |
47 |
120 |
15.12.2011 11:10:34
Kuidas sellesse väitesse suhtuda?:
tsitaat: |
NB! Umbes iga kolme kuu tagant tuleks see UPS seade lasta täiesti tühjaks laadida - see pikendab tema akude eluiga. |
79 |
Andrus Luht
itimees.ee
15.12.2011 13:02:55
tomorrow, loll jutt. Tänapäevased UPSid oskavad ise akudele teha pidevalt hooldust selleks, et eluiga pikendada. See tühjaks ja täis on vanade 'mäluga' NiCd ja NiMh akude ajastu relikt. Olgu siinkohal öeldud, et UPSide all pidasin ma silmas kvaliteetseid UPSe asjalikelt tootjatelt nagu APC, Eaton, Poweware, Microdowell jne. Enamus sellest odavast saastast, mida meil inimestele kodudesse ja tihtipeale ka äridesse müüakse sobib tegelikuses vaid betooni täis valada ning paadi-ankruks kasutada.
_________________ Äriklassi serverilahenduste müük, paigaldus ja haldus. SaaS / PaaS / IaaS lahendused
Tier-3 privaatpilvede, virtuaal- ja virtuaal-privaat-serverite lahendused. 24/7 haldus, monitooring |
318 |
15.12.2011 15:35:27
Andrus Luht kirjutas: |
Enamus sellest odavast saastast, mida meil inimestele kodudesse ja tihtipeale ka äridesse müüakse sobib tegelikuses vaid betooni täis valada ning paadi-ankruks kasutada. |
ot: |
Pole vaja betooneerimisele oma aega raisata, need kolakad on piisavalt rasked ilma betoonitagi. |
tomorrow, loll jutt. Tänapäevased UPSid oskavad ise akudele teha pidevalt hooldust selleks, et eluiga pikendada. See tühjaks ja täis on vanade 'mäluga' NiCd ja NiMh akude ajastu relikt. |
Pole ise kohanud nn. akupatareidega (NiCd ja NiMh) upse. Üldjuhul on neil ikka suletud tüüpi Lead-Acid aku sees.
120 |
15.12.2011 16:45:16
Selge siis
Vaatan, et endal on ikka see kõige parem Line Interactive tüüp. Saab ööse rahulikult magada
79 |
16.12.2011 15:58:01
tomorrow, kõige parem on ikka 'on-line' UPS.
Line Interactive on ikka rohkem selline 'veidi üle küla keskmise'...
Kommentaarid: 163 loe/lisa |
152 |
Andrus Luht
itimees.ee
318 |
16.12.2011 16:40:43
Andrus Luht, sedand küll. Rohkem oli see niisama torge tomorrow suunas, kes seniste siinse foorumi erinevate postitustega on mulje jätnud, et ajab igas asjas perfektsust ja viimase biti optimeerimist taga. On-line UPS sai välja toodud, et hajutada veidi tema öist rahilikku und.
152 |
16.12.2011 18:35:34
Tegelikult kulub ka pliiakudele aeg-ajalt tühjakslaadimine ära. Autode-tsiklite peal toimub igapäevaselt väike kõikumine kasvõi käivitusvoolu ja kasutatud energia taastamise näol generaatori pealt, aga kui päris kalli otsa UPS-id välja arvata (just need tootjad, mida Andrus nimetas ja nende puhul ka mitte need odavama otsa mudelid), siis neil ka kipub see hoodustsükli variant puuduma (tarkvaras võib seda isegi näha, aga töötab see vaid kallimatel mudelitel).
Nii et kellel UPS ise aeg-ajalt akudele end ei lülita ja sedasi väikest kõikumist ei teki, siis pidev täislaetud olek kipub ka plaatide sulfateerumist tekitama...
Kord kuus või paari kuu tagant väike tühjakslaadimine (ei pea laadima täitsa alumise piirini - see tegelikult ei olegi kõige parem) kuluks ära küll ja pikendaks akude iga veidike. Tavaliste akude hinda ja tööiga ilma sellise jukerdamiseta arvestades ei pruugi see aga ära tasuda.
(kuulub kategooriasse "toimige minu sõnade, mitte tegude järgi" )
17.12.2011 05:30:08
bladerunner, Bljaad. Uni rikutud nüüd. Oh joure such a joker dear
79 |
LiivaneLord
Sõpradele "Olavi"
17.12.2011 18:33:40
Ah, kes viitsib seda tühjakslaadimist teha. Peab paar kuud vähem vastu, kuid see-eest on saanud täisväärtuslikult kasutada.
19 |
