uus teema   vasta Tarkvara »  Arvutimängude foorum »  Enemy Territory märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 226, 227, 228 ... 236, 237, 238  järgmine
antsus1000
sõnum 02.11.2011 19:44:47 vasta tsitaadiga
xpander
xpander
sõnum 10.11.2011 03:45:52 vasta tsitaadiga
ETXreaL is a graphics mod for Wolfenstein: Enemy Territory using the enhanced XreaL id Tech 3 GPL engine.
*Modern OpenGL 3.2 renderer with all deprecated OpenGL calls removed
*Clever usage of vertex buffer objects (VBO) to speed up rendering of everything
*Avoids geometry processing each frame using the CPU (worst bottleneck with the Q3A engine)
*Renders up to 500 000 - 1 000 000 polygons at 80 - 200 fps on current hardware (DX10 generation)
*Optional GPU occlusion culling (improved Coherent Hierarchy Culling) useful for rendering large city scenes
*Doom 3 .MD5mesh/.MD5anim skeletal model and animation support
*Unreal Actor X .PSK/.PSA skeletal model and animation support
*True 64 bit HDR lighting with adaptive tone mapping
*Advanced projective and omni-directional soft shadow mapping methods like EVSM
*Real-time sun lights with parallel-split shadow maps
*Optional deferred shading
*Relief mapping that can be enabled by materials
*Optional uniform lighting and shadowing model like in Doom 3 including globe mapping
*Supports almost all Quake 3, Enemy Territory and Doom 3 material shader keywords
*TGA, PNG, JPG and DDS format support for textures
*Usage of frame buffer objects (FBO) to perform offscreen rendering effects
*Improved TrueType font support that does not require external tools
*Linux 64-bit support
*Linux sound backend using SDL
*.avi recorder from ioquake3 including sound support
*Optimized collision detection routines
*Support for Omni-bot
http://www.moddb.com/mods/etxreal
Download
http://www.moddb.com/mods/etxreal/downloads/etxreal-20110505
Linux Gaming Videos: Xpander69
Dude .
sõnum 10.11.2011 15:14:40 vasta tsitaadiga
Võib-olla ma ei ole ET'd lihtsalt pikka aega mänginud ja seetõttu ei mäleta, milline mäng tegelikult välja näeb... või siis lihtsalt ei oska asja tehnilist poolt väärtustada, aga minu jaoks näeb küll üpris jube välja. Ka teised pildid näevad üsna sarnased välja. Madala polycountiga objektidele vistakse mingit üliteravad tekstuurid peale ja kohe absoluutselt ei sobi kokku ja riivab silma.
Kuigi kui seda aja jooksul natuke nuditakse, siis võib näha päris korralik välja. Pildid vajavad hädasti AA'd.
TALUSILDID
ampsu
ampsu
sõnum 10.11.2011 18:19:47 vasta tsitaadiga
Keegi siit laseb veel aktiivselt ETprod?Võiks mingi õhtu mängida mõned 6on6d thumbs_up.gif
Kommentaarid: 109 loe/lisa Kasutajad arvavad:  :: 1 :: 4 :: 97
dud66
dud66
sõnum 10.11.2011 18:21:29 vasta tsitaadiga
ampsu, Ei saaks just öelda, et aktiivselt aga eks vahetevahel õhtul ikka
Kommenteerige kasutajaid, siis teavad teised ka mida oodata!
HellWalKeR
HellWalKeR
sõnum 10.11.2011 18:24:55 vasta tsitaadiga
xpander kirjutas:
icon_confused.gif Hullem kui originaal.
Kommentaarid: 5 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 3
sõnum 10.11.2011 18:35:10 vasta tsitaadiga
selgelt kehvem...
ertr2
ertr2
sõnum 10.11.2011 18:39:31 vasta tsitaadiga
ampsu kirjutas:
võib
Kommentaarid: 67 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 65
hemmar
sõnum 10.11.2011 18:48:07 vasta tsitaadiga
HellWalKeR kirjutas:
xpander kirjutas:
Mis seal paremal üleval nurgas nende kaartega toimub? icon_biggrin.gif Ei ole teisi pilte vaadanud, aga puhtalt selle pildi järgi kõnniks ka sellest asjast kaarega mööda.
dud66
dud66
sõnum 10.11.2011 19:31:20 vasta tsitaadiga
See ETXreaL tundub olema selline Beta versioon, eks näis kas sellest ka miskit asja saab
xpander
xpander
sõnum 10.11.2011 20:06:30 vasta tsitaadiga
dud66 kirjutas:
tegelt peaks alpha versioon olema...suht toores on hetkel veel jah..aga potentsiaali on
Kristjan94
sõnum 10.11.2011 21:52:51 vasta tsitaadiga
Pole sel graafikal midagi viga. Väga hea mäng on!
Võibolla hakkan uuesti mängima.
zlenard
sõnum 10.11.2011 22:04:30 vasta tsitaadiga
Omnibotidega on piisavalt hea manual kaasas, et seda teha ise icon_smile.gif
Xenomorph
sõnum 10.11.2011 23:00:16 vasta tsitaadiga
Kui keegi 5o5 6o6 mängida tahab siis võib pm saata.Algaja päris pole :=) on võidetud isegi lanil ja kaasa mängitud mitmel winter/summercupil
Kommentaarid: 30 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 29
HellWalKeR
HellWalKeR
sõnum 10.11.2011 23:39:32 vasta tsitaadiga
Kui juba pakkumiseks läks siis kellel huvi, võib mulle ka PM saata. Kunagi mängisin suht palju aga nüüd pole enam häid servusid. Kuid vahest võiks mängu ikka teha icon_smile.gif
hannes36
hannes36
sõnum 11.11.2011 00:46:37 vasta tsitaadiga
StaticX kirjutas:
minu lugupeetus
Kommentaarid: 121 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 111
The_Boss
The_Boss
sõnum 11.11.2011 00:57:49 vasta tsitaadiga
Pole vanal graafikal häda midagi, ei näe erilist mõtet uut teha. Ega see mängijaid tagasi ei too...
Kommentaarid: 358 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 283
xpander
xpander
sõnum 12.11.2011 00:43:09 vasta tsitaadiga
Flem
Flem
sõnum 12.11.2011 00:57:36 vasta tsitaadiga
Kui kellelgi on aega siin mingeid mänge korraldada , lööks isegi kaasa icon_smile.gif.
Sai pelatud kunagi suht pikalt AV/MOB-is ja UDU Battles aga enam ei ole jah kuskil võimalik normaalselt aega viita/mängida.
ampsu
ampsu
sõnum 12.11.2011 10:40:01 vasta tsitaadiga
http://files.rag-esports.net/spu9/index.php?id=ET-Pack.zip
See peale (kõik official asjad peal ja TZAC ka)
Kõik kes õhtuti 5on5/6on6 lasta soovivad lisage xire: gepardpoiss.
ertr2
ertr2
sõnum 12.11.2011 13:13:19 vasta tsitaadiga
ampsu kirjutas:
kas steami vms ei kasuta? Kui mänguks läheb saatke mulle HVs PS.
EvilMick007
sõnum 12.11.2011 13:14:47 vasta tsitaadiga
Hmm,.. ei tea palju see Xreal seda asja ikka elustab, kui pool kommuuni või enam veel harrastas/harrastab graafika 0 peale tweakimist, et fps 333 oleks ja vastaseid paremini märgata saaks...
Pentestimise ja küberturbe konsultatsiooni soovi korral võib kirjutada..
Kommentaarid: 46 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 41
ampsu
ampsu
sõnum 12.11.2011 13:56:01 vasta tsitaadiga
EvilMick007 kirjutas:
Ma arvan, et ei elusta see Xreal midagi.See lic asjaarmastajate poolt aretatud asi ja arvan, et officialiks see ei jõua kunagi.Vahetevahel äkki tõesti pubi ilus lasta kui visuaalne poolt natukene ilusam, aga selleks ongi eraldi pubid Xrealil.
ertr2 Steami võib ka mind lisada.Add: ampsu1337
antsus1000
sõnum 14.11.2011 11:32:17 vasta tsitaadiga
viimati muutis antsus1000 07.01.2018 13:44:19, muudetud 1 kord
morfea
morfea
sõnum 14.11.2011 15:05:56 vasta tsitaadiga
antsus1000 kirjutas:
Keegi mõni õhtu mängu viitsib teha siis lisage msn-i andresraja@hotmail.com . lepime serveri kokku ja TULD.
et.kernwaffe.de esimeses servus...pelan 23-02 vahemikus tavaliselt pea iga päev.
Eestlased seal:
NightIFF
Narva
Optimus_Prime
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Enemy Territory mine lehele eelmine  1, 2, 3 ... 226, 227, 228 ... 236, 237, 238  järgmine
